[PATCH 3/6] shgen: Import from RTEMS
Mon Jun 11 09:35:29 UTC 2018
On 11/6/18 5:49 pm, Sebastian Huber wrote:
> On 11/06/18 08:22, Joel Sherrill wrote:
>>     >     >>> Does this tool need to move over?
>>     >     >> I would like to move all host tools out of the RTEMS
>>     repository
>>     >     to simplify the
>>     >     >> build. If we get rid of the host tools, then we have only to
>>     >     deal with the
>>     >     >> cross-build tools.
>>     >     > This is a good thing to do, thank you.
>>     >     >>>    Is the sh arch active?
>>     >     >> I don't know.
>>     >     > I suggest we remove this code until someone needs it and can
>>     >     resolve this issue.
>>     >     > The code is in the 4.11 releases so is easy to find.
>>     >     The shgen tool is used to build the gensh1 and gensh2 BSPs to
>>     >     generate
>>     >     the scitab.c source file.
>> Sorry..I missed this.
>>     >     One option to get rid of the shgen tool would be to remove the
>>     >     CPU_CLOCK_RATE_HZ BSP option.
>> Ok. Or retroactively deprecate in 4.11
> The tool generates a scitab.c with this header:
>  * DO NOT EDIT - this file is automatically generated by shgen
> 5.07adc7f7e37a_modified
>  * Copyright (c) 1998,1999,2000 Ralf Corsepius (corsepiu at faw.uni-ulm.de)
> /* This file is not copyrighted */
> Files with such a header are not acceptable for an import into the RTEMS sources
> repository  from my point of view.
I agree.
> We have three options now:
> 1. Keep the tools in the RTEMS source repository.
I prefer they are moved out.
> 2. Add GPL software to rtems-tools.
I prefer this not happen. I have worked hard over the life of repo to be careful
not to have GPL in the repo.
> 3. Remove the gensh1 and gensh2 BSPs.
What is in the generated file?
We use weak symbols in the Zynq BSP to allow us to override defaults. Could this
approach be used?
