[PATCH 3/6] shgen: Import from RTEMS
Mon Jun 11 10:25:38 UTC 2018
On 11/6/18 7:48 pm, Sebastian Huber wrote:
> On 11/06/18 11:35, Chris Johns wrote:
>>> 3. Remove the gensh1 and gensh2 BSPs.
>> What is in the generated file?
>> We use weak symbols in the Zynq BSP to allow us to override defaults. Could this
>> approach be used?
> The generated file provides a function _sci_get_brparms() and an array with
> generated data items used by this function. Its not really much stuff.
Could this function be added, tagged weak and it calls raises a fatal error?
