[PATCH] tools: Remove shgen
Mon Jun 11 14:23:07 UTC 2018
On Mon, Jun 11, 2018 at 8:48 AM, Sebastian Huber
> All tools should be removed from the RTEMS source repository at some
> point in time. Tools with a BSD-style license will be moved to the RTEMS
> tools repository. Unfortunately, the shgen tool is GPL licensed.
> Remove all uses of this tool from the code base. Replace generated files
> with stub functions. If users of this BSP still exist, they can
> reimplement the functionality using a BSD-style license.
Is there a README that needs to be updated, or was the procedure for
this shgen stuff just integrated in the build process? Probably, it
should be noted in the (pending) BSP Supplemental :)
> Close #3443.
>  bsps/sh/gensh1/console/sci.c            |   8 +-
>  bsps/sh/gensh1/console/scitab.c         |  38 ++++
>  bsps/sh/gensh1/include/bsp.h            |   4 +-
>  bsps/sh/gensh2/console/sci.c            |   3 +-
>  bsps/sh/gensh2/console/scitab.c         |  38 ++++
>  bsps/sh/gensh2/include/bsp.h            |   5 +-
>  c/src/lib/libbsp/sh/gensh1/Makefile.am  |   9 +-
>  c/src/lib/libbsp/sh/gensh1/configure.ac |   7 +-
>  c/src/lib/libbsp/sh/gensh2/Makefile.am  |   9 +-
>  c/src/lib/libbsp/sh/gensh2/configure.ac |   6 +-
>  tools/cpu/configure.ac                  |   1 -
>  tools/cpu/sh/AUTHORS                    |   3 -
>  tools/cpu/sh/COPYING                    | 340 --------------------------------
>  tools/cpu/sh/Makefile.am                |  14 --
>  tools/cpu/sh/TODO                       |  13 --
>  tools/cpu/sh/configure.ac               |  25 ---
>  tools/cpu/sh/sci.c                      | 177 -----------------
>  tools/cpu/sh/sci.h                      |  11 --
>  tools/cpu/sh/shgen.c                    | 114 -----------
>  19 files changed, 87 insertions(+), 738 deletions(-)
>  create mode 100644 bsps/sh/gensh1/console/scitab.c
>  create mode 100644 bsps/sh/gensh2/console/scitab.c
>  delete mode 100644 tools/cpu/sh/AUTHORS
>  delete mode 100644 tools/cpu/sh/COPYING
>  delete mode 100644 tools/cpu/sh/Makefile.am
>  delete mode 100644 tools/cpu/sh/TODO
>  delete mode 100644 tools/cpu/sh/configure.ac
>  delete mode 100644 tools/cpu/sh/sci.c
>  delete mode 100644 tools/cpu/sh/sci.h
>  delete mode 100644 tools/cpu/sh/shgen.c
> diff --git a/bsps/sh/gensh1/console/sci.c b/bsps/sh/gensh1/console/sci.c
> index 04d9ca5c70..fedfa30b51 100644
> --- a/bsps/sh/gensh1/console/sci.c
> +++ b/bsps/sh/gensh1/console/sci.c
> @@ -18,7 +18,7 @@
>   *  http://www.rtems.org/license/LICENSE.
> -#include <rtems.h>
> +#include <bsp.h>
>  #include <stdlib.h>
> @@ -53,12 +53,6 @@ struct scidev_t {
>    { "/dev/sci1", SH_SCI_BASE_1, 1, 0, CS8, B9600 }
> -/*  imported from scitab.rel */
> -extern int _sci_get_brparms(
> -  speed_t       spd,
> -  unsigned char *smr,
> -  unsigned char *brr );
>  /* Translate termios' tcflag_t into sci settings */
>  static int _sci_set_cflags(
>    struct scidev_t      *sci_dev,
> diff --git a/bsps/sh/gensh1/console/scitab.c b/bsps/sh/gensh1/console/scitab.c
> new file mode 100644
> index 0000000000..3c698f8100
> --- /dev/null
> +++ b/bsps/sh/gensh1/console/scitab.c
> @@ -0,0 +1,38 @@
> + * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <info at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> + * The content of this file was previously generated by the GPL licensed shgen
> + * tool during the BSP build for a configured clock frequency
> + * (CPU_CLOCK_RATE_HZ). All tools were removed from the RTEMS source repository
> + * at some point in time. Tools with a BSD-style license were moved to the
> + * RTEMS tools repository.
> +#include <bsp.h>
> +int _sci_get_brparms(
> +  unsigned int   spd,
> +  unsigned char *smr,
> +  unsigned char *brr
> +  if (spd != 9600) {
> +    return -1;
> +  *smr = 0x00;
> +  *brr = 0x40;
> +  return 0;
> diff --git a/bsps/sh/gensh1/include/bsp.h b/bsps/sh/gensh1/include/bsp.h
> index f3f7c028cd..b757a010d6 100644
> --- a/bsps/sh/gensh1/include/bsp.h
> +++ b/bsps/sh/gensh1/include/bsp.h
> @@ -60,8 +60,8 @@ extern void *CPU_Interrupt_stack_high;
>  void bsp_hw_init(void);
> -  tcflag_t      cflag,
> +  unsigned int   spd,
>    unsigned char *smr,
>    unsigned char *brr
> diff --git a/bsps/sh/gensh2/console/sci.c b/bsps/sh/gensh2/console/sci.c
> index 143fc1bb94..e02049cbf3 100644
> --- a/bsps/sh/gensh2/console/sci.c
> +++ b/bsps/sh/gensh2/console/sci.c
> @@ -73,8 +73,7 @@
>  #define SH_SCI_BASE_1   SCI_SMR1
>  #define SH_SCI_DEF_COMM_0   CS8, B9600
> -#define SH_SCI_DEF_COMM_1   CS8, B38400
> -/*  #define SH_SCI_DEF_COMM_1   CS8, B9600 */
> +#define SH_SCI_DEF_COMM_1   CS8, B9600
>  struct scidev_t {
>    char *                     name;
> diff --git a/bsps/sh/gensh2/console/scitab.c b/bsps/sh/gensh2/console/scitab.c
> index 0000000000..ca253df573
> --- /dev/null
> +++ b/bsps/sh/gensh2/console/scitab.c
> @@ -0,0 +1,38 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#include <bsp.h>
> +  unsigned int   spd,
> +    return -1;
> +  *smr = 0x00;
> +  *brr = 0x5f;
> +  return 0;
> diff --git a/bsps/sh/gensh2/include/bsp.h b/bsps/sh/gensh2/include/bsp.h
> index 221137ad81..1a08df9a43 100644
> --- a/bsps/sh/gensh2/include/bsp.h
> +++ b/bsps/sh/gensh2/include/bsp.h
> @@ -72,8 +72,9 @@ extern void *CPU_Interrupt_stack_high;
>   * BSP methods that cross file boundaries.
> -  tcflag_t      cflag,
> +  unsigned int   spd,
>    unsigned char *smr,
>    unsigned char *brr
> diff --git a/c/src/lib/libbsp/sh/gensh1/Makefile.am b/c/src/lib/libbsp/sh/gensh1/Makefile.am
> index 3ebc5ad678..ca2c0f9d72 100644
> --- a/c/src/lib/libbsp/sh/gensh1/Makefile.am
> +++ b/c/src/lib/libbsp/sh/gensh1/Makefile.am
> @@ -16,13 +16,6 @@ project_lib_DATA += linkcmds
>  project_lib_LIBRARIES = librtemsbsp.a
>  librtemsbsp_a_SOURCES =
> -SHGEN = $(PROJECT_TOPdir)/tools/cpu/sh/shgen
> -scitab.c: $(SHGEN)
> -       $(SHGEN) -H @CPU_CLOCK_RATE_HZ@ sci > $@
> -BUILT_SOURCES = scitab.c
> -CLEANFILES = scitab.c
>  # startup
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/shared/start/bspstart.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
> @@ -37,7 +30,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh1/start/cpu_asm.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh1/start/ispsh7032.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh1/btimer/btimer.c
>  # scitab
> -librtemsbsp_a_SOURCES += scitab.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh1/console/scitab.c
>  # console
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/shared/console/console.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh1/console/sci.c
> diff --git a/c/src/lib/libbsp/sh/gensh1/configure.ac b/c/src/lib/libbsp/sh/gensh1/configure.ac
> index 44b2e047eb..d336f9e094 100644
> --- a/c/src/lib/libbsp/sh/gensh1/configure.ac
> +++ b/c/src/lib/libbsp/sh/gensh1/configure.ac
> @@ -13,17 +13,12 @@ RTEMS_BSP_CONFIGURE
>  ## bsp-specific options
> -RTEMS_BSPOPTS_SET([CPU_CLOCK_RATE_HZ],[*],[20000000])
> -RTEMS_BSPOPTS_HELP([CPU_CLOCK_RATE_HZ],[cpu clock rate in HZ])
>  RTEMS_BSPOPTS_SET([START_HW_INIT],[*],[])
>  RTEMS_BSPOPTS_HELP([START_HW_INIT],
>  [If defined, selects whether 'early_hw_init()' is called from 'start.S';
>   'bsp_hw_init()' is always called from 'bspstart.c'])
> -## Used in scitab/Makefile.am
> -AC_SUBST(CPU_CLOCK_RATE_HZ)
> +AC_DEFINE(CPU_CLOCK_RATE_HZ, 20000000, [cpu clock rate in HZ])
>  RTEMS_BSP_CLEANUP_OPTIONS
>  # Explicitly list all Makefiles here
> diff --git a/c/src/lib/libbsp/sh/gensh2/Makefile.am b/c/src/lib/libbsp/sh/gensh2/Makefile.am
> index 2d964dc9e7..96c30a985e 100644
> --- a/c/src/lib/libbsp/sh/gensh2/Makefile.am
> +++ b/c/src/lib/libbsp/sh/gensh2/Makefile.am
> @@ -18,13 +18,6 @@ dist_project_lib_DATA += ../../../../../../bsps/sh/gensh2/start/linkcmds.rom
> -scitab.c: $(SHGEN)
>  # startup
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh2/start/hw_init.c
> @@ -39,7 +32,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh2/start/cpu_asm.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh2/start/ispsh7045.c
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh2/btimer/btimer.c
>  # scitab
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh2/console/scitab.c
>  # console
>  librtemsbsp_a_SOURCES += ../../../../../../bsps/sh/gensh2/console/config.c
> diff --git a/c/src/lib/libbsp/sh/gensh2/configure.ac b/c/src/lib/libbsp/sh/gensh2/configure.ac
> index 55232320fe..97203eeceb 100644
> --- a/c/src/lib/libbsp/sh/gensh2/configure.ac
> +++ b/c/src/lib/libbsp/sh/gensh2/configure.ac
> @@ -13,11 +13,7 @@ RTEMS_BSP_CONFIGURE
> -RTEMS_BSPOPTS_SET([CPU_CLOCK_RATE_HZ],[*],[29491200])
> +AC_DEFINE(CPU_CLOCK_RATE_HZ, 29491200, [cpu clock rate in HZ])
> diff --git a/tools/cpu/configure.ac b/tools/cpu/configure.ac
> index 69ac4d89dd..8e96cf9c13 100644
> --- a/tools/cpu/configure.ac
> +++ b/tools/cpu/configure.ac
> @@ -19,7 +19,6 @@ AC_SUBST(program_prefix)
>  AC_CONFIG_SUBDIRS(generic)
>  case "$RTEMS_CPU" in
> -sh ) AC_CONFIG_SUBDIRS(sh);;
>  nios2 ) AC_CONFIG_SUBDIRS(nios2);;
>  esac
> diff --git a/tools/cpu/sh/AUTHORS b/tools/cpu/sh/AUTHORS
> deleted file mode 100644
> index 225c2fa974..0000000000
> --- a/tools/cpu/sh/AUTHORS
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -Ralf Corsepius (corsepiu at faw.uni-ulm.de)
> -       * Initial implementation
> -       * generator for sci bitrate table
> diff --git a/tools/cpu/sh/COPYING b/tools/cpu/sh/COPYING
> index 8cc2ef7f9c..0000000000
> --- a/tools/cpu/sh/COPYING
> +++ /dev/null
> @@ -1,340 +0,0 @@
> -                   GNU GENERAL PUBLIC LICENSE
> -                      Version 2, June 1991
> - Copyright (C) 1989, 1991 Free Software Foundation, Inc.
> - 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
> - Everyone is permitted to copy and distribute verbatim copies
> - of this license document, but changing it is not allowed.
> -                           Preamble
> -  The licenses for most software are designed to take away your
> -freedom to share and change it.  By contrast, the GNU General Public
> -License is intended to guarantee your freedom to share and change free
> -software--to make sure the software is free for all its users.  This
> -General Public License applies to most of the Free Software
> -Foundation's software and to any other program whose authors commit to
> -using it.  (Some other Free Software Foundation software is covered by
> -the GNU Library General Public License instead.)  You can apply it to
> -your programs, too.
> -  When we speak of free software, we are referring to freedom, not
> -price.  Our General Public Licenses are designed to make sure that you
> -have the freedom to distribute copies of free software (and charge for
> -this service if you wish), that you receive source code or can get it
> -if you want it, that you can change the software or use pieces of it
> -in new free programs; and that you know you can do these things.
> -  To protect your rights, we need to make restrictions that forbid
> -anyone to deny you these rights or to ask you to surrender the rights.
> -These restrictions translate to certain responsibilities for you if you
> -distribute copies of the software, or if you modify it.
> -  For example, if you distribute copies of such a program, whether
> -gratis or for a fee, you must give the recipients all the rights that
> -you have.  You must make sure that they, too, receive or can get the
> -source code.  And you must show them these terms so they know their
> -rights.
> -  We protect your rights with two steps: (1) copyright the software, and
> -(2) offer you this license which gives you legal permission to copy,
> -distribute and/or modify the software.
> -  Also, for each author's protection and ours, we want to make certain
> -that everyone understands that there is no warranty for this free
> -software.  If the software is modified by someone else and passed on, we
> -want its recipients to know that what they have is not the original, so
> -that any problems introduced by others will not reflect on the original
> -authors' reputations.
> -  Finally, any free program is threatened constantly by software
> -patents.  We wish to avoid the danger that redistributors of a free
> -program will individually obtain patent licenses, in effect making the
> -program proprietary.  To prevent this, we have made it clear that any
> -patent must be licensed for everyone's free use or not licensed at all.
> -  The precise terms and conditions for copying, distribution and
> -modification follow.
> -   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
> -  0. This License applies to any program or other work which contains
> -a notice placed by the copyright holder saying it may be distributed
> -under the terms of this General Public License.  The "Program", below,
> -refers to any such program or work, and a "work based on the Program"
> -means either the Program or any derivative work under copyright law:
> -that is to say, a work containing the Program or a portion of it,
> -either verbatim or with modifications and/or translated into another
> -language.  (Hereinafter, translation is included without limitation in
> -the term "modification".)  Each licensee is addressed as "you".
> -Activities other than copying, distribution and modification are not
> -covered by this License; they are outside its scope.  The act of
> -running the Program is not restricted, and the output from the Program
> -is covered only if its contents constitute a work based on the
> -Program (independent of having been made by running the Program).
> -Whether that is true depends on what the Program does.
> -  1. You may copy and distribute verbatim copies of the Program's
> -source code as you receive it, in any medium, provided that you
> -conspicuously and appropriately publish on each copy an appropriate
> -copyright notice and disclaimer of warranty; keep intact all the
> -notices that refer to this License and to the absence of any warranty;
> -and give any other recipients of the Program a copy of this License
> -along with the Program.
> -You may charge a fee for the physical act of transferring a copy, and
> -you may at your option offer warranty protection in exchange for a fee.
> -  2. You may modify your copy or copies of the Program or any portion
> -of it, thus forming a work based on the Program, and copy and
> -distribute such modifications or work under the terms of Section 1
> -above, provided that you also meet all of these conditions:
> -    a) You must cause the modified files to carry prominent notices
> -    stating that you changed the files and the date of any change.
> -    b) You must cause any work that you distribute or publish, that in
> -    whole or in part contains or is derived from the Program or any
> -    part thereof, to be licensed as a whole at no charge to all third
> -    parties under the terms of this License.
> -    c) If the modified program normally reads commands interactively
> -    when run, you must cause it, when started running for such
> -    interactive use in the most ordinary way, to print or display an
> -    announcement including an appropriate copyright notice and a
> -    notice that there is no warranty (or else, saying that you provide
> -    a warranty) and that users may redistribute the program under
> -    these conditions, and telling the user how to view a copy of this
> -    License.  (Exception: if the Program itself is interactive but
> -    does not normally print such an announcement, your work based on
> -    the Program is not required to print an announcement.)
> -These requirements apply to the modified work as a whole.  If
> -identifiable sections of that work are not derived from the Program,
> -and can be reasonably considered independent and separate works in
> -themselves, then this License, and its terms, do not apply to those
> -sections when you distribute them as separate works.  But when you
> -distribute the same sections as part of a whole which is a work based
> -on the Program, the distribution of the whole must be on the terms of
> -this License, whose permissions for other licensees extend to the
> -entire whole, and thus to each and every part regardless of who wrote it.
> -Thus, it is not the intent of this section to claim rights or contest
> -your rights to work written entirely by you; rather, the intent is to
> -exercise the right to control the distribution of derivative or
> -collective works based on the Program.
> -In addition, mere aggregation of another work not based on the Program
> -with the Program (or with a work based on the Program) on a volume of
> -a storage or distribution medium does not bring the other work under
> -the scope of this License.
> -  3. You may copy and distribute the Program (or a work based on it,
> -under Section 2) in object code or executable form under the terms of
> -Sections 1 and 2 above provided that you also do one of the following:
> -    a) Accompany it with the complete corresponding machine-readable
> -    source code, which must be distributed under the terms of Sections
> -    1 and 2 above on a medium customarily used for software interchange; or,
> -    b) Accompany it with a written offer, valid for at least three
> -    years, to give any third party, for a charge no more than your
> -    cost of physically performing source distribution, a complete
> -    machine-readable copy of the corresponding source code, to be
> -    distributed under the terms of Sections 1 and 2 above on a medium
> -    customarily used for software interchange; or,
> -    c) Accompany it with the information you received as to the offer
> -    to distribute corresponding source code.  (This alternative is
> -    allowed only for noncommercial distribution and only if you
> -    received the program in object code or executable form with such
> -    an offer, in accord with Subsection b above.)
> -The source code for a work means the preferred form of the work for
> -making modifications to it.  For an executable work, complete source
> -code means all the source code for all modules it contains, plus any
> -associated interface definition files, plus the scripts used to
> -control compilation and installation of the executable.  However, as a
> -special exception, the source code distributed need not include
> -anything that is normally distributed (in either source or binary
> -form) with the major components (compiler, kernel, and so on) of the
> -operating system on which the executable runs, unless that component
> -itself accompanies the executable.
> -If distribution of executable or object code is made by offering
> -access to copy from a designated place, then offering equivalent
> -access to copy the source code from the same place counts as
> -distribution of the source code, even though third parties are not
> -compelled to copy the source along with the object code.
> -  4. You may not copy, modify, sublicense, or distribute the Program
> -except as expressly provided under this License.  Any attempt
> -otherwise to copy, modify, sublicense or distribute the Program is
> -void, and will automatically terminate your rights under this License.
> -However, parties who have received copies, or rights, from you under
> -this License will not have their licenses terminated so long as such
> -parties remain in full compliance.
> -  5. You are not required to accept this License, since you have not
> -signed it.  However, nothing else grants you permission to modify or
> -distribute the Program or its derivative works.  These actions are
> -prohibited by law if you do not accept this License.  Therefore, by
> -modifying or distributing the Program (or any work based on the
> -Program), you indicate your acceptance of this License to do so, and
> -all its terms and conditions for copying, distributing or modifying
> -the Program or works based on it.
> -  6. Each time you redistribute the Program (or any work based on the
> -Program), the recipient automatically receives a license from the
> -original licensor to copy, distribute or modify the Program subject to
> -these terms and conditions.  You may not impose any further
> -restrictions on the recipients' exercise of the rights granted herein.
> -You are not responsible for enforcing compliance by third parties to
> -this License.
> -  7. If, as a consequence of a court judgment or allegation of patent
> -infringement or for any other reason (not limited to patent issues),
> -conditions are imposed on you (whether by court order, agreement or
> -otherwise) that contradict the conditions of this License, they do not
> -excuse you from the conditions of this License.  If you cannot
> -distribute so as to satisfy simultaneously your obligations under this
> -License and any other pertinent obligations, then as a consequence you
> -may not distribute the Program at all.  For example, if a patent
> -license would not permit royalty-free redistribution of the Program by
> -all those who receive copies directly or indirectly through you, then
> -the only way you could satisfy both it and this License would be to
> -refrain entirely from distribution of the Program.
> -If any portion of this section is held invalid or unenforceable under
> -any particular circumstance, the balance of the section is intended to
> -apply and the section as a whole is intended to apply in other
> -circumstances.
> -It is not the purpose of this section to induce you to infringe any
> -patents or other property right claims or to contest validity of any
> -such claims; this section has the sole purpose of protecting the
> -integrity of the free software distribution system, which is
> -implemented by public license practices.  Many people have made
> -generous contributions to the wide range of software distributed
> -through that system in reliance on consistent application of that
> -system; it is up to the author/donor to decide if he or she is willing
> -to distribute software through any other system and a licensee cannot
> -impose that choice.
> -This section is intended to make thoroughly clear what is believed to
> -be a consequence of the rest of this License.
> -  8. If the distribution and/or use of the Program is restricted in
> -certain countries either by patents or by copyrighted interfaces, the
> -original copyright holder who places the Program under this License
> -may add an explicit geographical distribution limitation excluding
> -those countries, so that distribution is permitted only in or among
> -countries not thus excluded.  In such case, this License incorporates
> -the limitation as if written in the body of this License.
> -  9. The Free Software Foundation may publish revised and/or new versions
> -of the General Public License from time to time.  Such new versions will
> -be similar in spirit to the present version, but may differ in detail to
> -address new problems or concerns.
> -Each version is given a distinguishing version number.  If the Program
> -specifies a version number of this License which applies to it and "any
> -later version", you have the option of following the terms and conditions
> -either of that version or of any later version published by the Free
> -Software Foundation.  If the Program does not specify a version number of
> -this License, you may choose any version ever published by the Free Software
> -Foundation.
> -  10. If you wish to incorporate parts of the Program into other free
> -programs whose distribution conditions are different, write to the author
> -to ask for permission.  For software which is copyrighted by the Free
> -Software Foundation, write to the Free Software Foundation; we sometimes
> -make exceptions for this.  Our decision will be guided by the two goals
> -of preserving the free status of all derivatives of our free software and
> -of promoting the sharing and reuse of software generally.
> -                           NO WARRANTY
> -  11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY
> -FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.  EXCEPT WHEN
> -OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
> -PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED
> -OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> -MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.  THE ENTIRE RISK AS
> -TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU.  SHOULD THE
> -PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING,
> -REPAIR OR CORRECTION.
> -  12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
> -WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR
> -REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES,
> -INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING
> -OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED
> -TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY
> -YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER
> -PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE
> -POSSIBILITY OF SUCH DAMAGES.
> -                    END OF TERMS AND CONDITIONS
> -       Appendix: How to Apply These Terms to Your New Programs
> -  If you develop a new program, and you want it to be of the greatest
> -possible use to the public, the best way to achieve this is to make it
> -free software which everyone can redistribute and change under these terms.
> -  To do so, attach the following notices to the program.  It is safest
> -to attach them to the start of each source file to most effectively
> -convey the exclusion of warranty; and each file should have at least
> -the "copyright" line and a pointer to where the full notice is found.
> -    <one line to give the program's name and a brief idea of what it does.>
> -    Copyright (C) 19yy  <name of author>
> -    This program is free software; you can redistribute it and/or modify
> -    it under the terms of the GNU General Public License as published by
> -    the Free Software Foundation; either version 2 of the License, or
> -    (at your option) any later version.
> -    This program is distributed in the hope that it will be useful,
> -    but WITHOUT ANY WARRANTY; without even the implied warranty of
> -    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
> -    GNU General Public License for more details.
> -    You should have received a copy of the GNU General Public License
> -    along with this program; if not, write to the Free Software
> -    Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
> -Also add information on how to contact you by electronic and paper mail.
> -If the program is interactive, make it output a short notice like this
> -when it starts in an interactive mode:
> -    Gnomovision version 69, Copyright (C) 19yy name of author
> -    Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
> -    This is free software, and you are welcome to redistribute it
> -    under certain conditions; type `show c' for details.
> -The hypothetical commands `show w' and `show c' should show the appropriate
> -parts of the General Public License.  Of course, the commands you use may
> -be called something other than `show w' and `show c'; they could even be
> -mouse-clicks or menu items--whatever suits your program.
> -You should also get your employer (if you work as a programmer) or your
> -school, if any, to sign a "copyright disclaimer" for the program, if
> -necessary.  Here is a sample; alter the names:
> -  Yoyodyne, Inc., hereby disclaims all copyright interest in the program
> -  `Gnomovision' (which makes passes at compilers) written by James Hacker.
> -  <signature of Ty Coon>, 1 April 1989
> -  Ty Coon, President of Vice
> -This General Public License does not permit incorporating your program into
> -proprietary programs.  If your program is a subroutine library, you may
> -consider it more useful to permit linking proprietary applications with the
> -library.  If this is what you want to do, use the GNU Library General
> -Public License instead of this License.
> diff --git a/tools/cpu/sh/Makefile.am b/tools/cpu/sh/Makefile.am
> index e72f37dd77..0000000000
> --- a/tools/cpu/sh/Makefile.am
> +++ /dev/null
> @@ -1,14 +0,0 @@
> -ACLOCAL_AMFLAGS = -I ../../../aclocal
> -noinst_PROGRAMS = shgen
> -shgen_SOURCES = sci.h sci.c shgen.c
> -if HELP2MAN
> -man_MANS = shgen.1
> -shgen.1: shgen$(EXEEXT)
> -       $(HELP2MAN) -N ./shgen >$@
> -endif
> -include $(top_srcdir)/../../../automake/host.am
> diff --git a/tools/cpu/sh/TODO b/tools/cpu/sh/TODO
> index bcdd1bf6df..0000000000
> --- a/tools/cpu/sh/TODO
> +++ /dev/null
> @@ -1,13 +0,0 @@
> -* Add support for more drivers to shgen !!!!
> -* shgen relies on having a gnu-compatible getopt, which should be
> -  available on all hosts using gcc/egcs/binutils.
> -  Using other getopt-variants may produce faulty results or shgen may also
> -  refuse to compile. Probably the easiest solution to this problem would be
> -  to integrate libiberty into rtems.
> -* shgen uses floating point mathematics. Therefore Makefile.in contains a
> -  reference to libm. In case the host doesn't have its floating point
> -  support in libm, shgen will fail to compile. If we should ever meet such
> -  a host, checks for floating point libraries have to be added to rtems'
> -  autoconf support.
> diff --git a/tools/cpu/sh/configure.ac b/tools/cpu/sh/configure.ac
> index fd368e6001..0000000000
> --- a/tools/cpu/sh/configure.ac
> +++ /dev/null
> @@ -1,25 +0,0 @@
> -## Process this file with autoconf to produce a configure script.
> -AC_PREREQ([2.69])
> -AC_INIT([rtems-tools-cpu-sh],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
> -AC_CONFIG_SRCDIR([shgen.c])
> -RTEMS_TOP(../../..)
> -RTEMS_SOURCE_TOP
> -RTEMS_BUILD_TOP
> -RTEMS_CANONICAL_TARGET_CPU
> -AM_INIT_AUTOMAKE([foreign subdir-objects 1.12.2])
> -AM_MAINTAINER_MODE
> -AC_PROG_CC
> -AC_CHECK_LIB(m,fabs)
> -AC_CHECK_FUNCS(getopt_long)
> -AC_CHECK_PROGS(HELP2MAN,help2man)
> -AM_CONDITIONAL(HELP2MAN,test -n "$HELP2MAN" )
> -RTEMS_TOOLPATHS
> -# Explicitly list all Makefiles here
> -AC_CONFIG_FILES([Makefile])
> -AC_OUTPUT
> diff --git a/tools/cpu/sh/sci.c b/tools/cpu/sh/sci.c
> index 2b68612f2c..0000000000
> --- a/tools/cpu/sh/sci.c
> +++ /dev/null
> @@ -1,177 +0,0 @@
> - * Copyright (c) 1998 Ralf Corsepius (corsepiu at faw.uni-ulm.de)
> - * See the file COPYING for copyright notice.
> -#include <math.h>
> -#include <stdio.h>
> -#include <stdlib.h>
> -#include "sci.h"
> -   n .. baudrate generator source 0,1,2,3
> -   N .. BRR setting (0..255)
> -   Phi .. processor baud rate
> -   B .. bitrate
> -typedef struct sci_tab {
> -  unsigned int  B ;
> -  unsigned int  n ;
> -  int          N ;
> -  double        err ;
> -  } sci_tab_t ;
> -static unsigned int bitrate [] = {
> -  50,
> -  75,
> -  110,
> -  134,
> -  150,
> -  200,
> -  300,
> -  600,
> -  1200,
> -  1800,
> -  2400,
> -  4800,
> -  9600,
> -  19200,
> -  38400,
> -  7200,
> -  14400,
> -  28800,
> -  57600,
> -  76800,
> -  115200,
> -  230400,
> -  460800,
> -  921600
> -static sci_tab_t test_array[4] ;
> -static void Compute(
> -  unsigned int n,
> -  unsigned int B,
> -  double   Phi,
> -  struct sci_tab *entry )
> -  int    a = ( 32 << ( 2 * n ) ) * B ;
> -  entry->n = n ;
> -  entry->B = B ;
> -  entry->N = rint( ( Phi / a ) - 1.0 ) ;
> -  if ( ( entry->N > 0 ) && ( entry->N < 256 ) )
> -    entry->err =
> -      ( ( Phi / ( (entry->N + 1) * a ) - 1.0 ) * 100.0 );
> -  else
> -    entry->err = 100.0 ;
> -    entry->n = 255 ;
> -    entry->N = 0 ;
> -static sci_tab_t *SelectN(
> -  unsigned int         B,
> -  double       Phi )
> -  unsigned int i ;
> -  struct sci_tab* best = NULL ;
> -  for ( i = 0 ; i < 4 ; i++ )
> -    double err ;
> -    Compute( i, B, Phi, &test_array[i] );
> -    err = fabs( test_array[i].err );
> -    if ( best )
> -      if ( err < fabs( best->err ) )
> -        best = &test_array[i] ;
> -    else
> -  return best ;
> -int shgen_gensci(
> -  FILE         *file,
> -  double       Phi ) /* Processor frequency [Hz] */
> -  unsigned int i ;
> -  fprintf( file,
> -    "/*\n * Bitrate table for the serial devices (sci) of the SH at %.3f MHz\n"
> -    " */\n\n", Phi / 1000000.0 );
> -  fprintf( file,
> -    "/*\n"
> -    " * n     .. SMR bits 0,1 : baud rate generator clock source\n"
> -    " * N     .. BRR bits 0..7: setting for baud rate generator\n"
> -    " * error .. percentual error to nominal bitrate\n"
> -    " *   Hitachi's HW manual recommends bitrates with an error less than 1%%\n"
> -    " *   We experienced values less than 2%% to be stable\n"
> -    " */\n\n" );
> -  fprintf( file, "#include <bsp.h>\n" );
> -  fprintf( file, "#include <termios.h>\n\n" );
> -  fprintf( file,
> -    "static struct sci_bitrate_t {\n"
> -    "  unsigned char n ;\n"
> -    "  unsigned char N ;\n"
> -    "  speed_t       B ;\n"
> -    "} _sci_bitrates[] = {\n"
> -    "/*  n    N      B      error */\n" );
> -  for ( i = 0 ; i < sizeof(bitrate)/sizeof(int) ; i++ )
> -    struct sci_tab* best = SelectN( bitrate[i], Phi );
> -    if ( i > 0 )
> -      fprintf( file, ",\n" );
> -      fprintf( file, "  { %1d, %3d, %d } /* %+7.2f%% ; B%d ",
> -      best->n,
> -      best->N,
> -      best->B,
> -      best->err,
> -      best->B );
> -    if ( best->n > 3 )
> -      fprintf( file, "(unusable) " );
> -    fprintf( file, "*/" );
> -  fprintf( file, "\n};\n\n" );
> -  fprintf( file,
> -    "int _sci_get_brparms( \n"
> -    "  speed_t        spd,\n"
> -    "  unsigned char *smr,\n"
> -    "  unsigned char *brr )\n"
> -    "{\n"
> -    "  int offset = -1;\n"
> -    "  int i;\n\n"
> -    "  for(i = 0; i < sizeof(_sci_bitrates)/sizeof(_sci_bitrates[0]); i++) {\n"
> -    "    if( _sci_bitrates[i].B == spd ) {\n"
> -    "      offset = i;\n"
> -    "      break;\n"
> -    "    }\n"
> -    "  }\n"
> -    "  if ( offset == -1 ) return -1 ;\n"
> -    "  if ( _sci_bitrates[offset].n > 3 )  return -1;\n\n"
> -    "  *smr &= ~0x03;\n"
> -    "  *smr |= _sci_bitrates[offset].n;\n"
> -    "  *brr =  _sci_bitrates[offset].N;\n\n"
> -    "  return 0;\n"
> -    "}\n" );
> -  return 0 ;
> diff --git a/tools/cpu/sh/sci.h b/tools/cpu/sh/sci.h
> index b55bbfb670..0000000000
> --- a/tools/cpu/sh/sci.h
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -#ifndef _shgen_sci_h
> -#define _shgen_sci_h
> -#include <stdio.h>
> -extern int shgen_gensci(
> -  FILE         *file,
> -  double       Phi /* Processor frequency [Hz] */
> -#endif
> diff --git a/tools/cpu/sh/shgen.c b/tools/cpu/sh/shgen.c
> index 57f9120e39..0000000000
> --- a/tools/cpu/sh/shgen.c
> +++ /dev/null
> @@ -1,114 +0,0 @@
> - * Copyright (c) 1998,1999,2000, 2006 Ralf Corsepius, Ulm Germany.
> -#include <stdio.h>
> -#include <string.h>    /* strcmp, strerror */
> -#include <stdlib.h>    /* exit */
> -#include <errno.h>
> -#include <getopt.h>
> -#include "sci.h"
> -static void usage( FILE* ofile, char *prog )
> -  fprintf( ofile, "Usage: %s [options] driver\n", prog );
> -  fprintf( ofile, "\nOptions:\n" );
> -  fprintf( ofile, "Processor frequency (default 20MHz):\n") ;
> -  fprintf( ofile, "\t-M Phi      .. processor frequency [MHz]\n" );
> -  fprintf( ofile, "\t-K Phi      .. processor frequency [KHz]\n" );
> -  fprintf( ofile, "\t-H Phi      .. processor frequency [Hz]\n" );
> -  fprintf( ofile, "Driver:\n" );
> -  fprintf( ofile, "\tsci         .. bitrate table for sci\n" );
> -  fprintf( ofile, "\nWritten by Ralf Corsepius <corsepiu at faw.uni-ulm.de>\n" );
> -  fprintf( ofile, "\nCopyright (c) 1998,1999,2000\tRalf Corsepius\n" );
> -#if HAVE_GETOPT_LONG
> -#define NOARG   0
> -#define HASARG  1
> -#define OPTARG  2
> -static struct option long_options[] =
> -  { "version",         NOARG,  NULL, 'v' },
> -  { "help",            NOARG,  NULL, 'h' },
> -  { "mega-hertz",       HASARG, NULL, 'M' },
> -  { "kilo-hertz",       HASARG, NULL, 'K' },
> -  { "hertz",           HASARG, NULL, 'H' },
> -  { 0, 0, 0, 0 }
> -#endif
> -static void shgen_header( FILE *file )
> -  fprintf( file,
> -    "/*\n * DO NOT EDIT - this file is automatically generated by shgen %s\n",
> -    VERSION );
> -  fprintf( file,
> -    " * Copyright (c) 1998,1999,2000 Ralf Corsepius (corsepiu at faw.uni-ulm.de)\n */\n" );
> -  fprintf( file,
> -    "\n/* This file is not copyrighted */\n\n" );
> -int main( int argc, char *argv[] )
> -  double       Phi = 20000000.0 ;
> -  int option_index = 0 ;
> -  while( ( optopt = getopt_long( argc, argv, "M:K:H:hv",
> -      long_options, &option_index ) ) > 0 )
> -#else
> -  while ( ( optopt = getopt( argc, argv, "M:K:H:hv" ) ) > 0 )
> -#endif
> -    switch ( optopt )
> -    case 'M' :
> -      sscanf( optarg, "%lf", &Phi );
> -      Phi = Phi * 1000000.0;
> -      break ;
> -    case 'K' :
> -      Phi = Phi * 1000.0;
> -      break ;
> -    case 'H' :
> -      break ;
> -    case 'h' :
> -      usage( stdout, argv[0] );
> -      exit(0);
> -    case 'v' :
> -      fprintf( stdout, "%s version %s\n", argv[0], VERSION );
> -      exit(0);
> -    default  :
> -      usage( stderr, argv[0] );
> -      exit(1);
> -      break ;
> -  if ( argc - optind != 1 )
> -    fprintf( stderr, "%s: Missing argument: driver\n", argv[0] );
> -    exit(1);
> -  shgen_header( stdout );
> -  if ( strcmp( argv[optind], "sci" ) == 0 )
> -    shgen_gensci( stdout, Phi );
> -  else
> -    fprintf( stderr, "%s: Invalid argument: driver\n", argv[0] );
> -    exit(1);
> -  return 0 ;
> 2.13.7
> devel mailing list
> devel at rtems.org
