[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Joel Sherrill
joel at rtems.org
Tue Jun 12 06:57:33 UTC 2018
Chris needs to speak up since it is Python.
I see changes to HTML output which I doubt are related to the core change.
On Tue, Jun 12, 2018, 8:39 AM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Please review this patch. :)
> On 7 June 2018 at 16:38, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Close #3440
>> tester/rt/coverage.py | 6 ++++--
>> tester/rt/test.py | 15 ++++++++++-----
>> 2 files changed, 14 insertions(+), 7 deletions(-)
>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> index 54933d5..af24124 100644
>> --- a/tester/rt/coverage.py
>> +++ b/tester/rt/coverage.py
>> @@ -163,7 +163,8 @@ class report_gen_html:
>> row += " <td>" + summary.branches_uncovered + "</td>"
>> row += " <td>" + summary.branches_total + "</td>"
>> row += " <td> {:.3%}
>> </td>".format(summary.percentage_branches_covered)
>> - row += ' <td><progress value="{:.3}"
>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>> + row += ' <td><progress value="{:.3}"
>> max="100"></progress></td>'\
>> + .format(100*summary.percentage_branches_covered)
>> row += "</tr>\n"
>> return row
>> @@ -299,7 +300,8 @@ class covoar(object):
>> if (not path.exists(covoar_result_dir)):
>> path.mkdir(covoar_result_dir)
>> if (not path.exists(symbol_file)):
>> - raise error.general('symbol set file: coverage %s was not
>> created for covoar, skipping %s'% (symbol_file, set_name))
>> + raise error.general('symbol set file: %s was not '
>> + 'created for covoar, skipping %s'% (symbol_file,
>> set_name))
>> command = ('covoar -S ' + symbol_file
>> + ' -O ' + covoar_result_dir
>> + ' -E ' + self.explanations_txt
>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>> index 0e744cd..cdb5157 100644
>> --- a/tester/rt/test.py
>> +++ b/tester/rt/test.py
>> @@ -232,7 +232,7 @@ def run(command_path = None):
>> '--filter': 'Glob that executables must
>> match to run (default: ' +
>> default_exefilter + ')',
>> '--stacktrace': 'Dump a stack trace on a user
>> termination (^C)',
>> - '--coverage': 'Perform coverage analysis of
>> test executables.'}
>> + '--coverage-sets': 'Perform coverage for specific
>> sets'}
>> mailer.append_options(optargs)
>> opts = options.load(sys.argv,
>> optargs = optargs,
>> @@ -279,15 +279,20 @@ def run(command_path = None):
>> else:
>> rtems_tools = '%{_prefix}'
>> bsp = opts.find_arg('--rtems-bsp')
>> + if 'cov' in bsp[1].split('-'):
>> + coverage_enabled = True
>> if bsp is None or len(bsp) != 2:
>> raise error.general('RTEMS BSP not provided or an invalid
>> option')
>> bsp = config.load(bsp[1], opts)
>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>> - coverage_enabled = opts.find_arg('--coverage')
>> + coverage_sets = opts.find_arg('--coverage-sets')
>> if coverage_enabled:
>> - if len(coverage_enabled) == 2:
>> - coverage_runner = coverage.coverage_run(opts.defaults,
>> - coverage_enabled[1],
>> + if coverage_sets:
>> + if len(coverage_sets) != 2:
>> + raise error.general('No sets provided in
>> --coverage-sets')
>> + else :
>> + coverage_runner =
>> + coverage_sets[1],
>> executables)
>> else:
>> coverage_runner = coverage.coverage_run(opts.defaults, 0,
>> 2.14.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180612/d57cf061/attachment.html>
