[PATCH] Fix --show-commands.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jun 12 07:18:59 UTC 2018
Am 12.06.2018 um 07:08 schrieb Chris Johns:
> On 09/06/2018 02:45, Christian Mauderer wrote:
>> Did you also note Gedares suggestion to move the rtems_waf.git to the
>> public repos? Maybe that would be a good idea.
> Yes I did and it is a good idea. I have move the repo to the top level and
> updated cgit's config so it is viewable.
> Will need to update the repos that include this. Please consider the changes to
> do that pre-approved.
This change will make it necessary to do a `git submodule sync` for
every user in the affected repositories. So maybe it would be a good
time to think about another point to avoid a second sync:
Do we want to keep the absolute URL or do we want to use relative URLs?
The first one has a longer backward compatibility (relative URLs are
there since 2007: https://github.com/git/git/commit/f31a522a2d which
should be somewhere between git 1.5 and git 1.6).
The second one would allow mirrors that use a mirrored sub-repository too.
By the way: Shouldn't the rtems_waf be mirrored on github too? I think
most core-repositories are.
> I have not pushed this change so please do so as a test. :)
I have pushed the show-commands patch. Seems that there is something
wrong with the trac-config. Otherwise it worked fine. Sorry for the
German messages. I forgot to set my LANG:
Zähle Objekte: 3, Fertig.
Delta compression using up to 8 threads.
Komprimiere Objekte: 100% (3/3), Fertig.
Schreibe Objekte: 100% (3/3), 468 bytes | 468.00 KiB/s, Fertig.
Total 3 (delta 2), reused 0 (delta 0)
remote: 1: mail vc at rtems.org
remote: 3: update trac
remote: TracError: Repository 'rtems_waf' not found
remote: Repository 'rtems_waf' not found
remote: 4: IRC
To ssh://dispatch.rtems.org/data/git/rtems_waf.git
   f490cd3..656b7b0  master -> master
> Thanks
> Chris
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
