[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Cillian O'Donnell
cpodonnell8 at gmail.com
Tue Jun 12 07:19:37 UTC 2018
Looks fine to me. Chris will have the final say though.
On Tue, 12 Jun 2018, 08:00 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On Tue, 12 Jun 2018, 12:27 Joel Sherrill, <joel at rtems.org> wrote:
>> Chris needs to speak up since it is Python.
>> I see changes to HTML output which I doubt are related to the core change.
> There are no real changes to HTML,
> I have just added line breaks in the code
> because it was too long.
>> On Tue, Jun 12, 2018, 8:39 AM Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> Please review this patch. :)
>>> On 7 June 2018 at 16:38, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> Close #3440
>>>> tester/rt/coverage.py | 6 ++++--
>>>> tester/rt/test.py | 15 ++++++++++-----
>>>> 2 files changed, 14 insertions(+), 7 deletions(-)
>>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>> index 54933d5..af24124 100644
>>>> --- a/tester/rt/coverage.py
>>>> +++ b/tester/rt/coverage.py
>>>> @@ -163,7 +163,8 @@ class report_gen_html:
>>>> row += " <td>" + summary.branches_uncovered + "</td>"
>>>> row += " <td>" + summary.branches_total + "</td>"
>>>> row += " <td> {:.3%}
>>>> </td>".format(summary.percentage_branches_covered)
>>>> - row += ' <td><progress value="{:.3}"
>>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>> + row += ' <td><progress value="{:.3}"
>>>> max="100"></progress></td>'\
>>>> + .format(100*summary.percentage_branches_covered)
>>>> row += "</tr>\n"
>>>> return row
>>>> @@ -299,7 +300,8 @@ class covoar(object):
>>>> if (not path.exists(covoar_result_dir)):
>>>> path.mkdir(covoar_result_dir)
>>>> if (not path.exists(symbol_file)):
>>>> - raise error.general('symbol set file: coverage %s was not
>>>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>> + raise error.general('symbol set file: %s was not '
>>>> + 'created for covoar, skipping %s'% (symbol_file,
>>>> set_name))
>>>> command = ('covoar -S ' + symbol_file
>>>> + ' -O ' + covoar_result_dir
>>>> + ' -E ' + self.explanations_txt
>>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>> index 0e744cd..cdb5157 100644
>>>> --- a/tester/rt/test.py
>>>> +++ b/tester/rt/test.py
>>>> @@ -232,7 +232,7 @@ def run(command_path = None):
>>>> '--filter': 'Glob that executables must
>>>> match to run (default: ' +
>>>> default_exefilter + ')',
>>>> '--stacktrace': 'Dump a stack trace on a user
>>>> termination (^C)',
>>>> - '--coverage': 'Perform coverage analysis of
>>>> test executables.'}
>>>> + '--coverage-sets': 'Perform coverage for specific
>>>> sets'}
>>>> mailer.append_options(optargs)
>>>> opts = options.load(sys.argv,
>>>> optargs = optargs,
>>>> @@ -279,15 +279,20 @@ def run(command_path = None):
>>>> else:
>>>> rtems_tools = '%{_prefix}'
>>>> bsp = opts.find_arg('--rtems-bsp')
>>>> + if 'cov' in bsp[1].split('-'):
>>>> + coverage_enabled = True
>>>> if bsp is None or len(bsp) != 2:
>>>> raise error.general('RTEMS BSP not provided or an invalid
>>>> option')
>>>> bsp = config.load(bsp[1], opts)
>>>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>> - coverage_enabled = opts.find_arg('--coverage')
>>>> + coverage_sets = opts.find_arg('--coverage-sets')
>>>> if coverage_enabled:
>>>> - if len(coverage_enabled) == 2:
>>>> - coverage_runner = coverage.coverage_run(opts.defaults,
>>>> - coverage_enabled[1],
>>>> + if coverage_sets:
>>>> + if len(coverage_sets) != 2:
>>>> + raise error.general('No sets provided in
>>>> --coverage-sets')
>>>> + else :
>>>> + coverage_runner =
>>>> + coverage_sets[1],
>>>> executables)
>>>> else:
>>>> 0,
>>>> 2.14.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180612/4b3f0b86/attachment.html>
