[PATCH v4 2/2] Adding trace documentation
Vidushi Vashishth
reachvidu at gmail.com
Wed Jun 13 01:23:39 UTC 2018
user/index.rst | 2 +
user/tracing/captureengine.rst | 184 ++++++++++++++++++++++++++
user/tracing/examples.rst | 12 ++
user/tracing/index.rst | 29 +++++
user/tracing/introduction.rst | 182 ++++++++++++++++++++++++++
user/tracing/tracelinker.rst | 287 +++++++++++++++++++++++++++++++++++++++++
user/tracing/usecases.rst | 117 +++++++++++++++++
7 files changed, 813 insertions(+)
create mode 100644 user/tracing/captureengine.rst
create mode 100644 user/tracing/examples.rst
create mode 100644 user/tracing/index.rst
create mode 100644 user/tracing/introduction.rst
create mode 100644 user/tracing/tracelinker.rst
create mode 100644 user/tracing/usecases.rst
diff --git a/user/index.rst b/user/index.rst
index 8cbcd1b..a764fe8 100644
--- a/user/index.rst
+++ b/user/index.rst
@@ -52,6 +52,8 @@ to the Community Project hosted at http://www.rtems.org/.
tools/index
+ tracing/index
support/index
glossary/index
diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
new file mode 100644
index 0000000..64b501a
--- /dev/null
+++ b/user/tracing/captureengine.rst
@@ -0,0 +1,184 @@
+.. comment SPDX-License-Identifier: CC-BY-SA-4.0
+.. comment: Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
+.. comment: All rights reserved.
+.. _capturengine:
+Capture Engine
+Capture Engine is a trace tool built inside the RTEMS operating system. Capture
+Engine is designed to cause the lowest load on the system when operating. Hence
+it does not effect RTEMS when operating or when disabled. It binds to RTEMS at
+runtime and does not require RTEMS or your application to be rebuilt in order
+to use it.
+The Capture Engine's sample testcase for the `sparc/erc32` is available in the
+"$HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples"
+directory, provided you followed the installation directions of the quickstart
+section. In order to access the capture testcase perform the following set of
+operations.
+.. code-block:: shell
+ $ cd
+ $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples
+ $ ../samples
+ $ sparc-rtems5-run ./capture.exe
+ *** BEGIN OF TEST CAPTURE ENGINE ***
+ *** TEST VERSION: 5.0.0.de9b7d712bf5da6593386fd4fbca0d5f8b8431d8
+ *** TEST STATE: USER_INPUT
+ *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
+ *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
+ a3a6c34c150a357e57769a26a460c475e188438f, Newlib 3.0.0)
+ Press any key to start capture engine (20s remaining)
+ Press any key to start capture engine (19s remaining)
+ Press any key to start capture engine (18s remaining)
+ Monitor ready, press enter to login.
+ 1-rtems $
+Capture Engine comes with a set of commands to perform various actions.
+Capture Engine Commands
+1) ``copen <buffer-size>``: Used to initialize the Capture Engine with the
+ trace buffer size in bytes. By default the Capture Engine is not initialized
+ and not running.
+2) ``cwceil <priority-value>``: Capture Engine filter used to put an upper
+ limit on the event priority to be captured.
+3) ``cwfloor <priority-value>``: Capture Engine filter used to put a lower
+4) ``cwglob <on/off>``: Enable or disable the global watch.
+5) ``cenable``: Enables the Capture Engine. Capture Engine is by default
+ disabled after being opened.
+6) ``cdisable``: Disables the Capture Engine.
+7) ``ctlist``: Lists the watch and trigger configurations.
+8) ``ctrace``: Dumps the recorded traces. By default this command displays 24
+ trace records. Repeated use of this command will display all the recorded
+ traces.
+9) ``cwadd <task-name>``: Add watch on a particular task.
+10) ``cwtctl <task-name> <on/off>``: Enable or disable watch on a particular
+ task.
+11) ``ctset``: Used to set a trigger. The general form of the command is:
+``ctset [-?] type [to name/id] [from] [from name/id]``
+'type' in the above command refers to the type of trigger needed. The types of
+triggers that currently exist
+are:
+- switch : a context switch from one task to another task
+- create : the executing task creates a task
+- start : the executing task starts a task
+- restart : the executing task restarts a task
+- delete : the executing task deletes a task
+- begin : a task is beginning
+- exitted : a task is exitting
+Example
+The following is a sample run of the capture testsuite. The test1 command on the
+Capture Engine Command Line Interface (CLI) makes the 'RMON' task invoke a call
+to the 'capture_test_1()' command. This function (in the 'test1.c' source code)
+creates and starts three tasks : 'CT1a', 'CT1b' and 'CT1c'. These tasks are
+passed the object id of a semaphore as a task argument. This run through traces
+the context switches between these tasks. ``cwceil`` and ``cwfloor`` are set to
+a narrow range of task priorities to avoid creating noise from a large number of
+context switches between tasks we are not interested in.
+.. code:: shell
+ Press any key to start capture engine (17s remaining)
+ 1-rtems $ copen 50000
+ capture engine opened.
+ 1-rtems $ cwceil 100
+ watch ceiling is 100.
+ 1-rtems $ cwfloor 102
+ watch floor is 102.
+ 1-rtems $ cwglob on
+ global watch enabled.
+ 1-rtems $ ctset RMON
+ trigger set.
+ 1-rtems $ cenable
+ capture engine enabled.
+ 1-rtems $ test1
+ 1-rtems $ cdisable
+ capture engine disabled.
+ 1-rtems $ ctrace
+ 0 0:18:17.462314124 0a010003 CT1a 102 102 102 4096 TASK_RECORD
+ 0 0:18:17.462398963 0 0a010003 CT1a 102 102 CREATED
+ 0 0:18:17.462647987 249024 0a010003 CT1a 102 102 STARTED
+ 0 0:18:17.462904334 256347 0a010003 CT1a 102 102 SWITCHED_IN
+ 0 0:18:17.463069129 164795 0a010003 CT1a 102 102 BEGIN
+ 0 0:18:17.463335853 266724 0a010003 CT1a 102 102 SWITCHED_OUT
+ 0 0:18:18.461348547 0a010004 CT1b 101 101 101 4096 TASK_RECORD
+ 0 0:18:18.461433997 998098144 0a010004 CT1b 101 101 CREATED
+ 0 0:18:18.461683631 249634 0a010004 CT1b 101 101 STARTED
+ 0 0:18:18.461934485 250854 0a010004 CT1b 101 101 SWITCHED_IN
+ 0 0:18:18.462099891 165406 0a010004 CT1b 101 101 BEGIN
+ 0 0:18:19.460935339 998835448 0a010004 CT1b 101 101 SWITCHED_OUT
+ 0 0:18:19.461431555 0a010005 CT1c 100 100 100 4096 TASK_RECORD
+ 0 0:18:19.461516394 581055 0a010005 CT1c 100 100 CREATED
+ 0 0:18:19.461765418 249024 0a010005 CT1c 100 100 STARTED
+ 0 0:18:19.462019324 253906 0a010005 CT1c 100 100 SWITCHED_IN
+ 0 0:18:19.462184119 164795 0a010005 CT1c 100 100 BEGIN
+ 0 0:18:19.462475257 291138 0a010005 CT1c 100 100 SWITCHED_OUT
+ 0 0:18:19.462551551 76294 0a010004 CT1b 101 101 SWITCHED_IN
+ 0 0:18:19.960935645 498384094 0a010004 CT1b 101 101 SWITCHED_OUT
+ 0 0:18:19.961012549 76904 0a010003 CT1a 102 100 SWITCHED_IN
+ 0 0:18:19.961341528 328979 0a010003 CT1a 102 102 SWITCHED_OUT
+ 1-rtems $ ctrace
+ 0 0:18:19.961418433 0 0a010005 CT1c 100 100 SWITCHED_IN
+ 0 0:18:19.961672339 253906 0a010005 CT1c 100 100 SWITCHED_OUT
+ 0 0:18:19.961749854 77515 0a010004 CT1b 101 101 SWITCHED_IN
+ 0 0:18:20.460967077 499217223 0a010004 CT1b 101 101 SWITCHED_OUT
+ 0 0:18:20.461219763 252686 0a010005 CT1c 100 100 SWITCHED_IN
+ 0 0:18:20.461424231 204468 0a010005 CT1c 100 100 TERMINATED
+ 0 0:18:20.461747107 322876 0a010005 CT1c 100 100 SWITCHED_OUT
+ 0 0:18:20.461824011 76904 0a010004 CT1b 101 101 SWITCHED_IN
+ 0 0:18:20.462015052 191041 0a010004 CT1b 101 101 TERMINATED
+ 0 0:18:20.462336707 321655 0a010004 CT1b 101 101 SWITCHED_OUT
+ 0 0:18:20.462414222 77515 0a010003 CT1a 102 102 SWITCHED_IN
+ 0 0:18:20.462608924 194702 0a010003 CT1a 102 102 TERMINATED
+ 0 0:18:20.462933021 324097 0a010003 CT1a 102 102 SWITCHED_OUT
+ 1-rtems $ ctrace
+ 1-rtems $
diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
index 0000000..f51613e
--- /dev/null
+++ b/user/tracing/examples.rst
@@ -0,0 +1,12 @@
+.. _examples:
+Tracing Examples
+[TBD]
diff --git a/user/tracing/index.rst b/user/tracing/index.rst
index 0000000..951ead2
--- /dev/null
+++ b/user/tracing/index.rst
@@ -0,0 +1,29 @@
+.. _tracing-framework:
+RTEMS Tracing Framework
+.. index:: Tracing Framework
+RTEMS Tracing Framework is an on-target software based system which helps track
+the ongoings inside applications, 3rd party packages, and the kernel in real
+time.
+Software based tracing is a complex process which requires components on both
+the target and the host to work together. However its portability across all
+architectures and board support packages makes it a useful asset. A key
+requirement in RTEMS trace process is to take existing code in compiled format
+(ELF) and instrument it in order to log various events and records in real time.
+However instrumenting of the code for tracing should happen without rebuilding
+the code from the source and without annotating the source with trace code.
+.. toctree::
+ introduction
+ usecases
+ examples
diff --git a/user/tracing/introduction.rst b/user/tracing/introduction.rst
index 0000000..640eb0c
--- /dev/null
+++ b/user/tracing/introduction.rst
@@ -0,0 +1,182 @@
+.. _introduction:
+Introduction to Tracing
+Tracing is an important function which has several applications including
+identification of complex threading, detection of deadlocks, tracing
+functions along with their argument values, and return values through
+progression of several function calls and audit the performance of an
+application according to required specifications.
+RTEMS tracing framework is under development and welcomes contribution by users.
+RTEMS has the following trace components:
+- RTEMS :ref:`tracelinker`
+- RTEMS :ref:`capturengine`
+- Common Trace Format Integration
+RTEMS trace framework can currently function using the following methods. Both
+of the methods make use of the :ref:`tracelinker` :
+.. _tracebuffering:
+RTEMS Trace Using Trace Buffering
+This scheme of tracing goes through the flow of events described in a
+subsequent flowchart:
+Step 1: The user creates an application and user configuration file. The
+configuration file specifies the use of the trace buffer generator and other
+standard initializations. The user then configures her BSP and invokes the
+trace linker using a command to link the application executable. The trace
+linker uses the application files in compiled format (ELF) and the libraries
+used to build the application for performing this link.
+Step 2: The RTEMS Trace Linker reads the userâs configuration file and that
+results in it reading the standard Trace Buffering Configuration files
+installed with the RTEMS Trace Linker. The trace linker uses the target
+compiler and linker to create the trace enabled application executable. It
+wraps the functions defined in the userâs configuration with code that captures
+trace records into the statically allocated buffer. The trace wrapper code is
+compiled with the target compiler and the resulting ELF object file is added to
+the standard link command line used to link the application and the application
+is re-linked using the wrapping option of the GNU linker.
+Step 3: The trace linker creates an executable which is capable of running on
+the target hardware or simulator.
+Step 4: RTEMS shell provides the ârtraceâ command to display and save trace
+buffers.
+.. comment: taken from https://devel.rtems.org/wiki/Developer/Tracing
+.. figure:: ../../images/user/rtems-trace-buffering.png
+ :align: center
+ :width: 75%
+.. _printk:
+RTEMS Trace Using Printk
+This scheme of tracing goes through the flow of events described in a subsequent
+flowchart:
+Step 1: The user creates an RTEMS application in the normal manner as well as a
+Trace Linker configuration file. The configuration file specifies using the
+Printk trace mode and the functions to trace. The user invokes the Trace Linker
+with the configuration and the normal link command line used to the link the
+application executable. The application ELF object files and libraries,
+including the RTEMS libraries are standard and do not need to be built
+specially.
+Step 2: The RTEMS Trace Linker reads the user's configuration file and that
+results in it reading the standard Printk Trace Configuration files installed
+with the RTEMS Trace Linker. The trace linker uses the target compiler and
+linker to create the trace enabled application executable. It wraps the
+functions defined in the user's configuration with code that prints the entry
+with arguments and exit and return value if any. The trace wrapper code is
+is relinked using the wrapping option of the GNU linker.
+Step 3: The trace linker creates and RTEMS ELF executable that can be run on the
+target hardware or simulator.
+Step 4: The application is run in the hardware directly or using a debugger. The
+printk() output appears on the target console and the user can save that to a file.
+.. figure:: ../../images/user/rtems-trace-printk.png
+ :align: center
+ :width: 75%
+The :ref:`examples` section describes generation of traces using both of the
+aforementioned techniques using the `fileio` testsuite available with RTEMS
+installation.
+RTEMS Trace Using CTF
+`Common Trace Format <http://diamon.org/ctf/>`_ (CTF) is a binary trace format
+which is fast to write and has great flexibility. It allows traces to be
+developed by bare-metal applications or by any other C/C++ system. RTEMS tracing
+framework can benefit from these features of CTF.
+A typical CTF *trace* consists of multiple *streams* of binary *events*. The
+*metadata* stream is a mandatory stream which describes the layout of all the
+other streams in a trace. This metadata stream is written using *Trace Stream
+Description Language* (TSDL).
+.. comment: image taken from view-source:http://diamon.org/ctf/img/ctf-trace.png
+.. comment: Not generating a copyright in the high chance we decide to not keep
+.. comment: a descriptive section on CTF
+.. figure:: ../../images/user/ctf-trace.png
+ :align: center
+ :width: 75%
+A binary *stream* is further a concatenation of several packets each containing
+the following:
+- A packet header
+- An optional packet context
+- A set of concatenated events each containing:
+ - An event header
+ - A stream-specific context
+ - An event-specific context
+ - A payload
+.. comment: taken from http://diamon.org/ctf/img/ctf-stream-packet.png
+.. figure:: ../../images/user/ctf-stream-packet.png
+ :align: center
+ :width: 75%
+All the headers, contexts and payloads are written in TSDL using CTF data types.
+CTF supports a rich set of configurable datatypes which makes it possible to
+describe a larger variety of binary structure. Moreover types in CTF are
+organized as type classes where type specifications can be inherited to allow
+deriving types. These factors make CTF flexible. CTF enables fast writing of
+binary data as it usually involves appending memory contents, as it is to a
+binary CTF stream. CTF streams are capable of being sent or received over the
+network without any data being written to disk and hence can be useful in
+transporting traces from the target to the host machine for analysis.
+Due to these advantages tracing using CTF will prove to be beneficial for the
+users. This method of tracing is currently under development. Currently the
+RTEMS tracing framework is able to output trace data in the form of trace
+buffers, console output and csv files. A conversion tool which transforms
+these trace output formats to CTF will be viable approach to generating CTF
+traces. In this regard we utilize babeltrace, which is described in the
+following section.
+Babeltrace
+Babeltrace is an open source trace format converter which can be used to convert
+RTEMS traces into CTF. It is also a reference parser implementation of CTF. Babeltrace
+currently supports the following output formats for traces:
+- Text
+- CTF
+- CTF-metadata
+- Dummy
+- lttng-live
+Babeltrace comes in the form of a library, python bindings (python3) and command line
+tool called ``babeltrace``. To install babeltrace on your host you can install a
+distribution package or build from source using tarballs or git repositories of
+babeltrace. Refer to http://diamon.org/babeltrace/ for further details.
diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
index 0000000..3340794
--- /dev/null
+++ b/user/tracing/tracelinker.rst
@@ -0,0 +1,287 @@
+.. _tracelinker:
+Trace Linker
+RTEMS trace linker is a post link tool central to the RTEMS trace framework. It
+is installed as a part of the RTEMS Tool Project.The RTEMS Trace Linker is a
+post link tool that performs a re-link of your application to produce a trace
+executable. A trace executable has been instrumented by the RTEMS Trace Linker
+with additional code that implements software tracing. A key requirement of the
+trace process in RTEMS is to take existing code in a compiled format (ELF) and
+instrument it without rebuilding that code from source and without annotating
+that source with trace code.
+Command Line
+A typical command to invoke the trace linker consists of two parts separated by
+``--``. The first part controls the trace linker and provides the various
+options it needs and the second part is a standard linker command line you would
+use to link an RTEMS application. The current command line for trace linker consists
+of:
+ $ rtems-tld -h
+ rtems-trace-ld [options] objects
+ Options and arguments:
+ -h : help (also --help)
+ -V : print linker version number and exit (also --version)
+ -v : verbose (trace import parts), can supply multiple times
+ to increase verbosity (also --verbose)
+ -w : generate warnings (also --warn)
+ -k : keep temporary files (also --keep)
+ -c compiler : target compiler is not standard (also --compiler)
+ -l linker : target linker is not standard (also --linker)
+ -E prefix : the RTEMS tool prefix (also --exec-prefix)
+ -f cflags : C compiler flags (also --cflags)
+ -r path : RTEMS path (also --rtems)
+ -B bsp : RTEMS arch/bsp (also --rtems-bsp)
+ -W wrapper : wrapper file name without ext (also --wrapper)
+ -C ini : user configuration INI file (also --config)
+ -P path : user configuration INI file search path (also --path)
+The trace linker generates code that needs to be compiled and linked to the
+application executable so it needs to know the target compiler and `CFLAGS`.
+There are a couple of ways to do this. The simplest is to provide the path to
+RTEMS using the `-r` option and the architecture and BSP name in the standard
+RTEMS format of arch/bsp. The trace linker will extract the compiler and flags
+used to build RTEMS and will use them. If you require specific options you can
+use the `-f`, `-c`, `-l` and `-E` options to provide them. If the functions you
+are tracing use types from your code then add the include path to the `CFLAGS`.
+The trace linker requires you to provide a user configuration file using the
+`-C` or ``--config`` option. This is an INI format file detailed in the
+Configuration section. You can also provide an INI file search path using the
+`-P` option.
+If you are working with new configuration files and you want to view the files
+the trace linker generates add the `-k` option to keep the temporary files, and
+`-W` to specify an explicit wrapper C file name. If you set the
+``dump-on-error`` option in the configuration options section you will get a
+dump of the configuration on an error.
+Configuration (INI) files
+The Trace Linker is controlled using configuration files. Configuration files
+are categorized into 3 types:
+- User Configuration: These are specific to the user application to be traced.
+ This file initializes the values of the trace generator, triggers, enables and
+ traces.
+- Tracer Configuration: These are like a library of common or base trace
+ functions that can be referenced by an application. These files tend to hold
+ the details needed to wrap a specific set of functions. Examples provided with
+ the RTEMS Linker are the RTEMS API and Libc.
+- Generator Configuration: This is used to encapsulate a specific method of
+ tracing. Rtems currently provides generators for trace buffering, printk and
+ printf.
+The configuration files are in the *INI file format* which is composed of
+`sections`. Each section has a section name and set of *keys* which consist of
+*names* and *values*. A typical key is of the form ``name=value``. Keys can be
+used to include other INI files using the include key name. This is shown in the
+following example where the values indicate rtems and rtld-base configuration files:
+.. code-block::shell
+ include = rtems.ini, rtld-base.ini
+The trace linker also uses values in keys to specify other sections. In this
+example the functions name lists test-trace-funcs and that section contains a headers
+key that references a further section test-headers:
+ functions = test-trace-funcs, rtems-api
+ [test-trace-funcs]
+ ; Parsed via the 'function-set', not parse as a 'trace'.
+ headers = test-headers
+ [test-headers]
+ header = '#include "test-trace-1.h"'
+The format of a configuration file is explained next. Snippets of the fileio-trace.ini
+file have been used for explicit understanding. This file can be downloaded from `here
+<https://devel.rtems.org/attachment/wiki/Developer/Tracing/Trace_Buffering/filei
+o-trace.ini>`_.
+Tracer Section
+The topmost level section is the ``tracer`` section. It can contains the
+following keys:
+- name: The name of trace being linked.
+- options: A list of option sections.
+- defines: A list of sections containing defines or define record.
+- define: A list of define string that are single or double quoted.
+- enables: The list of sections containing enabled functions to trace.
+- triggers: The list of sections containing enabled functions to trigger trace
+ on.
+- traces: The list of sections containing function lists to trace.
+- functions: The list of sections containing function details.
+- include: The list of files to include
+ [tracer]
+ name = File IO tracer
+ ; The configuration
+ options = fileio-options
+ traces = fileio
+ defines = fileio
+ enables = fileio
+ triggers = fileio
+ functions = fileio-funcs, rtems-api, rtems-posix, libc-heap
+ include = rtems.ini, rtld-base.ini, rtld-trace-buffer.ini, libc-heap.ini
+Options section
+The options section in the fileio-trace.ini is called the `fileio-options`. A
+general options section can contain following sets of keys:
+- dump-on-error: Dump the parsed configuration data on error. The value can be
+ true or false.
+- verbose: Set the verbose level. The value can be true or a number value.
+- prefix: The prefix for the tools and an install RTEMS if rtems-path is not
+ set.
+- cc: The compiler used to compile the generated wrapper code. Overrides the
+ BSP configuration value if a BSP
+ is specified.
+- ld: The linker used to link the application. The default is the cc value as
+ read from the BSP configuration if specificed. If your application contains
+ C++ code use this setting to the change the linker to g++.
+- cflags: Set the CFLAGS used to compiler the wrapper. These flags are
+ pre-pended to the BSP read flags if a BSP is specified. This option is used
+ to provide extra include paths to header files in your application that
+ contain types any functions being traced reference.
+- rtems-path: The path to an install RTEMS if not installed under the prefix.
+- rtems-bsp: The BSP we are building the trace executable for. The is an arch
+ and bsp pair. For example sparc/erc32.
+ [fileio-options]
+ dump-on-error = true
+ ; Tools
+ prefix = /development/rtems/5
+ rtems-path = /development/rtems/kernel/5
+ rtems-bsp = sparc/erc32
+ ; Generator options.
+ gen-enables = enable
+ gen-triggers = enable
+Trace Section
+A trace section defines how trace wrapper functions are built. To build a trace
+function that wraps an existing function in an ELF object file or library
+archive we need to have the function's signature. A signature is the function's
+declaration with any types used. The the signature has specific types we need
+access to those types which means the wrapper code needs to include header files
+that define those types. There may also be specific defines needed to access
+those types.
+- generator: The generator defines the type of tracing being used.
+- headers: List of sections that contain header files keys.
+- header: A header key. Typically the include code.
+- defines: List of sections that contain defines.
+- define: A define key. Typically the define code.
+- signatures: List of function signature sections.
+- trace: Functions that are instrumented with trace code.
+[TBD]
+Function Wrapping
+The trace linker's major role is to wrap functions in the existing executable
+with trace code. The directions on how to wrap application functions is provided
+by the generator configuration. The wrapping function uses a GNU linker option
+called --wrap=symbol. The GNU Ld manual states:
+"Use a wrapper function for symbol. Any undefined reference to symbol will be
+resolved to __wrap_symbol. Any undefined reference to __real_symbol will be
+resolved to symbol."
+The trace linker generates C code with a wrapper for each function to be instrumented.
+The trace code generated is driven by the configuration INI files.
+Function Signatures
+A function signature is the function's declaration. It is the name of the
+function, the return value and the arguments. Tracing using function wrappers
+requires that we have accurate function signatures and ideally we would like to
+determine the function signature from the data held in ELF files. ELF files can
+contain DWARF data, the ELF debugging data format. In time the trace project
+would like to support libdwarf so the DWARF data can be accessed and use to determine
+a function's signature. This work is planned but not scheduled to be done and so in the
+meantime we explicitly define the function signatures in the configuration files.
+Development
+The Trace Linker is part of the RTEMS tools git repository available at :
+https://git.rtems.org/rtems-tools
+The RTEMS tools project utilizes the waf build system. Use the following
+commands in the topmost build directory to build the tools project:
+First we configure using:
+ $./waf configure --prefix=$HOME/development/rtems/5
+Then we build and install using:
+ $./waf build install
diff --git a/user/tracing/usecases.rst b/user/tracing/usecases.rst
index 0000000..5105650
--- /dev/null
+++ b/user/tracing/usecases.rst
@@ -0,0 +1,117 @@
+.. _usecases:
+Tracing Use Cases
+Following are the use cases of the tracing framework that are currently under
+development:
+Function Tracing
+Tracing the entry and exit of a function as well as the values of the arguments
+and return values can prove to be an important application for the tracing
+framework.
+Objective
+This use case can prove to be helpful in debugging of applications for the
+users. It can also be used to understand the working of existing application
+code bases. Capturing of argument and return values maybe useful in tracking
+unexpected output results from the applications.
+Requirements
+The current tracing framework provides this functionality with
+:ref:`tracebuffering`. The output is provided in the form of printing on
+console or saving the buffer in the form of a bin file. In order to develop this
+use case using CTF we need to be able to convert this RTEMS trace output into
+CTF. This could be done using babeltrace. The converted CTF traces would then be
+sent over to the host using a transport mechanism.
+Example
+As a start to the development of function tracing using CTF we can work on the
+fileio sample testsuite and trace all the calls to malloc, calloc, free and
+realloc functions. Along with the calls made to these functions the trace must
+also capture the values of their arguments at entry and the return values at
+function exit. As an example of an application having the following progression
+of function calls:
+.. code-block:: c
+ #include <stdlib.h>
+ int main(int argc, char** argv)
+ int* a = malloc(sizeof(int));
+ free(a);
+ a = calloc(1, sizeof(int));
+ return 0;
+The trace of such an application must be output of the following kind:
+ Timestamp1 entry of malloc > argument value
+ Timestamp2 exit of malloc < return value
+ Timestamp3 entry of free > argument value
+ Timestamp4 exit of free < return value (null)
+ Timestamp5 entry of calloc > argument1 value, argument2 value
+ Timestamp6 exit of calloc < return value1
+There could be additional columns of details including current priority, task
+state etc.
+Tracing Thread Operations
+Tracing thread creation, switching and termination operation in a thread's
+lifetime within an application.
+Objective
+Real time applications inherently utilize parallel programming which entails
+several tasks executing simultaneously and competing for common resources.
+On single processor systems the CPU performs context switching between each of
+these tasks rapidly. By tracing the creation and termination of tasks as well
+as the context switches between them one can possibly identify probable race
+conditions or complex threading operations.
+Requirements
+[TBD]
+Example
+A sample trace tracking two tasks Ta and Tb could have an output of the
+following kind:
+ Timestamp1 taskid Ta CREATED
+ Timestamp1 taskid Ta SWITCHED-IN
+ Timestamp1 taskid Ta BEGIN
+ Timestamp1 taskid Tb CREATED
+ Timestamp1 taskid Ta SWITCHED-OUT
+ Timestamp1 taskid Tb SWITCHED-IN
+ Timestamp1 taskid Tb BEGIN
+ Timestamp1 taskid Tb SWITCHED-OUT
+ Timestamp1 taskid Tb TERMINATED
+ Timestamp1 taskid Ta TERMINATED
2.7.4
