[PATCH v4 2/2] Adding trace documentation
Wed Jun 13 01:56:14 UTC 2018
Hi,
This documentation looks good and I welcome this being done and added to the
RTEMS project.
I have some comments below I hope are easy to resolve.
Thanks
On 13/06/2018 11:23, Vidushi Vashishth wrote:
>  user/index.rst                 |   2 +
>  user/tracing/captureengine.rst | 184 ++++++++++++++++++++++++++
>  user/tracing/examples.rst      |  12 ++
>  user/tracing/index.rst         |  29 +++++
>  user/tracing/introduction.rst  | 182 ++++++++++++++++++++++++++
>  user/tracing/tracelinker.rst   | 287 +++++++++++++++++++++++++++++++++++++++++
>  user/tracing/usecases.rst      | 117 +++++++++++++++++
>  7 files changed, 813 insertions(+)
>  create mode 100644 user/tracing/captureengine.rst
>  create mode 100644 user/tracing/examples.rst
>  create mode 100644 user/tracing/index.rst
>  create mode 100644 user/tracing/introduction.rst
>  create mode 100644 user/tracing/tracelinker.rst
>  create mode 100644 user/tracing/usecases.rst
> diff --git a/user/index.rst b/user/index.rst
> index 8cbcd1b..a764fe8 100644
> --- a/user/index.rst
> +++ b/user/index.rst
> @@ -52,6 +52,8 @@ to the Community Project hosted at http://www.rtems.org/.
>  	tools/index
> +        tracing/index
>  	support/index
>  	glossary/index
> diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
> new file mode 100644
> index 0000000..64b501a
> --- /dev/null
> +++ b/user/tracing/captureengine.rst
> @@ -0,0 +1,184 @@
> +.. comment SPDX-License-Identifier: CC-BY-SA-4.0
> +.. comment: Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
> +.. comment: All rights reserved.
> +.. _capturengine:
> +Capture Engine
> +Capture Engine is a trace tool built inside the RTEMS operating system. Capture
> +Engine is designed to cause the lowest load on the system when operating. Hence
> +it does not effect RTEMS when operating or when disabled. It binds to RTEMS at
> +runtime and does not require RTEMS or your application to be rebuilt in order
> +to use it.
> +The Capture Engine's sample testcase for the `sparc/erc32` is available in the
> +"$HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples"
Please use relative paths in the case. The
"$HOME/development/rtems/kernel/erc32" is specific to a user and while I have
used this in the User Manual it does not mean it is mandatory.
I suggest:
build direct created when building RTEMS in the path
file:`sparc-rtems5/c/erc32/testsuites/samples` directory.
Also please use file:`path` for paths and files.
> +directory, provided you followed the installation directions of the quickstart
> +section. In order to access the capture testcase perform the following set of
> +operations.
> +.. code-block:: shell
> +  $ cd
> +  $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples
Please make relative.
> +  $ ../samples
What is this command?
> +  $ sparc-rtems5-run ./capture.exe
> +  *** BEGIN OF TEST CAPTURE ENGINE ***
> +  *** TEST VERSION: 5.0.0.de9b7d712bf5da6593386fd4fbca0d5f8b8431d8
> +  *** TEST STATE: USER_INPUT
> +  *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
> +  *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
> +  a3a6c34c150a357e57769a26a460c475e188438f, Newlib 3.0.0)
> +  Press any key to start capture engine (20s remaining)
> +  Press any key to start capture engine (19s remaining)
> +  Press any key to start capture engine (18s remaining)
> +  Monitor ready, press enter to login.
> +  1-rtems $
> +Capture Engine comes with a set of commands to perform various actions.
> +Capture Engine Commands
> +1) ``copen <buffer-size>``: Used to initialize the Capture Engine with the
> +   trace buffer size in bytes. By default the Capture Engine is not initialized
> +   and not running.
> +2) ``cwceil <priority-value>``: Capture Engine filter used to put an upper
> +   limit on the event priority to be captured.
> +3) ``cwfloor <priority-value>``: Capture Engine filter used to put a lower
> +4) ``cwglob <on/off>``: Enable or disable the global watch.
> +5) ``cenable``: Enables the Capture Engine. Capture Engine is by default
> +   disabled after being opened.
> +6) ``cdisable``: Disables the Capture Engine.
> +7) ``ctlist``: Lists the watch and trigger configurations.
> +8) ``ctrace``: Dumps the recorded traces. By default this command displays 24
> +   trace records. Repeated use of this command will display all the recorded
> +   traces.
> +9) ``cwadd <task-name>``: Add watch on a particular task.
> +10) ``cwtctl <task-name> <on/off>``: Enable or disable watch on a particular
> +    task.
> +11) ``ctset``: Used to set a trigger. The general form of the command is:
> +``ctset [-?] type [to name/id] [from] [from name/id]``
> +'type' in the above command refers to the type of trigger needed. The types of
> +triggers that currently exist
> +are:
> +- switch  : a context switch from one task to another task
> +- create  : the executing task creates a task
> +- start   : the executing task starts a task
> +- restart : the executing task restarts a task
> +- delete  : the executing task deletes a task
> +- begin   : a task is beginning
> +- exitted : a task is exitting
> +Example
> +The following is a sample run of the capture testsuite. The test1 command on the
Change test1 to `test1` and please change others below as needed. For example
'RMON' to `RMON`, ie most '' to ``.
> +Capture Engine Command Line Interface (CLI) makes the 'RMON' task invoke a call
> +to the 'capture_test_1()' command. This function (in the 'test1.c' source code)
> +creates and starts three tasks : 'CT1a', 'CT1b' and 'CT1c'. These tasks are
> +passed the object id of a semaphore as a task argument. This run through traces
> +the context switches between these tasks. ``cwceil`` and ``cwfloor`` are set to
> +a narrow range of task priorities to avoid creating noise from a large number of
> +context switches between tasks we are not interested in.
> +.. code:: shell
> +  Press any key to start capture engine (17s remaining)
> +  1-rtems $ copen 50000
> +  capture engine opened.
> +  1-rtems $ cwceil 100
> +  watch ceiling is 100.
> +  1-rtems $ cwfloor 102
> +  watch floor is 102.
> +  1-rtems $ cwglob on
> +  global watch enabled.
> +  1-rtems $ ctset RMON
> +  trigger set.
> +  1-rtems $ cenable
> +  capture engine enabled.
> +  1-rtems $ test1
> +  1-rtems $ cdisable
> +  capture engine disabled.
> +  1-rtems $ ctrace
> +  0 0:18:17.462314124           0a010003 CT1a 102 102 102   4096  TASK_RECORD
> +  0 0:18:17.462398963         0 0a010003 CT1a 102 102             CREATED
> +  0 0:18:17.462647987    249024 0a010003 CT1a 102 102             STARTED
> +  0 0:18:17.462904334    256347 0a010003 CT1a 102 102             SWITCHED_IN
> +  0 0:18:17.463069129    164795 0a010003 CT1a 102 102             BEGIN
> +  0 0:18:17.463335853    266724 0a010003 CT1a 102 102             SWITCHED_OUT
> +  0 0:18:18.461348547           0a010004 CT1b 101 101 101   4096  TASK_RECORD
> +  0 0:18:18.461433997 998098144 0a010004 CT1b 101 101             CREATED
> +  0 0:18:18.461683631    249634 0a010004 CT1b 101 101             STARTED
> +  0 0:18:18.461934485    250854 0a010004 CT1b 101 101             SWITCHED_IN
> +  0 0:18:18.462099891    165406 0a010004 CT1b 101 101             BEGIN
> +  0 0:18:19.460935339 998835448 0a010004 CT1b 101 101             SWITCHED_OUT
> +  0 0:18:19.461431555           0a010005 CT1c 100 100 100   4096  TASK_RECORD
> +  0 0:18:19.461516394    581055 0a010005 CT1c 100 100             CREATED
> +  0 0:18:19.461765418    249024 0a010005 CT1c 100 100             STARTED
> +  0 0:18:19.462019324    253906 0a010005 CT1c 100 100             SWITCHED_IN
> +  0 0:18:19.462184119    164795 0a010005 CT1c 100 100             BEGIN
> +  0 0:18:19.462475257    291138 0a010005 CT1c 100 100             SWITCHED_OUT
> +  0 0:18:19.462551551     76294 0a010004 CT1b 101 101             SWITCHED_IN
> +  0 0:18:19.960935645 498384094 0a010004 CT1b 101 101             SWITCHED_OUT
> +  0 0:18:19.961012549     76904 0a010003 CT1a 102 100             SWITCHED_IN
> +  0 0:18:19.961341528    328979 0a010003 CT1a 102 102             SWITCHED_OUT
> +  1-rtems $ ctrace
> +  0 0:18:19.961418433         0 0a010005 CT1c 100 100             SWITCHED_IN
> +  0 0:18:19.961672339    253906 0a010005 CT1c 100 100             SWITCHED_OUT
> +  0 0:18:19.961749854     77515 0a010004 CT1b 101 101             SWITCHED_IN
> +  0 0:18:20.460967077 499217223 0a010004 CT1b 101 101             SWITCHED_OUT
> +  0 0:18:20.461219763    252686 0a010005 CT1c 100 100             SWITCHED_IN
> +  0 0:18:20.461424231    204468 0a010005 CT1c 100 100             TERMINATED
> +  0 0:18:20.461747107    322876 0a010005 CT1c 100 100             SWITCHED_OUT
> +  0 0:18:20.461824011     76904 0a010004 CT1b 101 101             SWITCHED_IN
> +  0 0:18:20.462015052    191041 0a010004 CT1b 101 101             TERMINATED
> +  0 0:18:20.462336707    321655 0a010004 CT1b 101 101             SWITCHED_OUT
> +  0 0:18:20.462414222     77515 0a010003 CT1a 102 102             SWITCHED_IN
> +  0 0:18:20.462608924    194702 0a010003 CT1a 102 102             TERMINATED
> +  0 0:18:20.462933021    324097 0a010003 CT1a 102 102             SWITCHED_OUT
> +  1-rtems $ ctrace
> +  1-rtems $
> diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
> index 0000000..f51613e
> --- /dev/null
> +++ b/user/tracing/examples.rst
> @@ -0,0 +1,12 @@
> +.. _examples:
> +Tracing Examples
> +[TBD]
> diff --git a/user/tracing/index.rst b/user/tracing/index.rst
> index 0000000..951ead2
> --- /dev/null
> +++ b/user/tracing/index.rst
> @@ -0,0 +1,29 @@
> +.. _tracing-framework:
> +RTEMS Tracing Framework
> +.. index:: Tracing Framework
> +RTEMS Tracing Framework is an on-target software based system which helps track
> +the ongoings inside applications, 3rd party packages, and the kernel in real
ongoings inside => the operation of
> +time.
> +Software based tracing is a complex process which requires components on both
> +the target and the host to work together. However its portability across all
> +architectures and board support packages makes it a useful asset. A key
> +requirement in RTEMS trace process is to take existing code in compiled format
> +(ELF) and instrument it in order to log various events and records in real time.
> +However instrumenting of the code for tracing should happen without rebuilding
> +the code from the source and without annotating the source with trace code.
> +.. toctree::
> +   introduction
> +   usecases
> +   examples
> diff --git a/user/tracing/introduction.rst b/user/tracing/introduction.rst
> index 0000000..640eb0c
> --- /dev/null
> +++ b/user/tracing/introduction.rst
> @@ -0,0 +1,182 @@
> +.. _introduction:
> +Introduction to Tracing
> +Tracing is an important function which has several applications including
> +identification of complex threading, detection of deadlocks, tracing
> +functions along with their argument values, and return values through
> +progression of several function calls and audit the performance of an
> +application according to required specifications.
> +RTEMS tracing framework is under development and welcomes contribution by users.
> +RTEMS has the following trace components:
> +- RTEMS :ref:`tracelinker`
> +- RTEMS :ref:`capturengine`
> +- Common Trace Format Integration
> +RTEMS trace framework can currently function using the following methods. Both
> +of the methods make use of the :ref:`tracelinker` :
> +.. _tracebuffering:
> +RTEMS Trace Using Trace Buffering
> +This scheme of tracing goes through the flow of events described in a
> +subsequent flowchart:
> +Step 1: The user creates an application and user configuration file. The
> +configuration file specifies the use of the trace buffer generator and other
> +standard initializations. The user then configures her BSP and invokes the
her => their
> +trace linker using a command to link the application executable. The trace
> +linker uses the application files in compiled format (ELF) and the libraries
> +used to build the application for performing this link.
> +Step 2: The RTEMS Trace Linker reads the user’s configuration file and that
> +results in it reading the standard Trace Buffering Configuration files
> +installed with the RTEMS Trace Linker. The trace linker uses the target
> +compiler and linker to create the trace enabled application executable. It
> +wraps the functions defined in the user’s configuration with code that captures
> +trace records into the statically allocated buffer. The trace wrapper code is
> +compiled with the target compiler and the resulting ELF object file is added to
> +the standard link command line used to link the application and the application
> +is re-linked using the wrapping option of the GNU linker.
> +Step 3: The trace linker creates an executable which is capable of running on
> +the target hardware or simulator.
> +Step 4: RTEMS shell provides the “rtrace” command to display and save trace
> +buffers.
> +.. comment: taken from https://devel.rtems.org/wiki/Developer/Tracing
> +.. figure:: ../../images/user/rtems-trace-buffering.png
> +  :align: center
> +  :width: 75%
White space.
> +.. _printk:
> +RTEMS Trace Using Printk
> +This scheme of tracing goes through the flow of events described in a subsequent
> +flowchart:
> +Step 1: The user creates an RTEMS application in the normal manner as well as a
> +Trace Linker configuration file. The configuration file specifies using the
> +Printk trace mode and the functions to trace. The user invokes the Trace Linker
> +with the configuration and the normal link command line used to the link the
> +application executable. The application ELF object files and libraries,
> +including the RTEMS libraries are standard and do not need to be built
> +specially.
> +Step 2: The RTEMS Trace Linker reads the user's configuration file and that
> +results in it reading the standard Printk Trace Configuration files installed
> +with the RTEMS Trace Linker. The trace linker uses the target compiler and
> +linker to create the trace enabled application executable. It wraps the
> +functions defined in the user's configuration with code that prints the entry
> +with arguments and exit and return value if any. The trace wrapper code is
> +is relinked using the wrapping option of the GNU linker.
> +Step 3: The trace linker creates and RTEMS ELF executable that can be run on the
> +target hardware or simulator.
> +Step 4: The application is run in the hardware directly or using a debugger. The
> +printk() output appears on the target console and the user can save that to a file.
> +.. figure:: ../../images/user/rtems-trace-printk.png
> +  :align: center
> +  :width: 75%
> +The :ref:`examples` section describes generation of traces using both of the
> +aforementioned techniques using the `fileio` testsuite available with RTEMS
> +installation.
> +RTEMS Trace Using CTF
> +`Common Trace Format <http://diamon.org/ctf/>`_ (CTF) is a binary trace format
> +which is fast to write and has great flexibility. It allows traces to be
> +developed by bare-metal applications or by any other C/C++ system. RTEMS tracing
> +framework can benefit from these features of CTF.
Is CTF support available for all users? If this is pushed to master it will be
in the main doco.
There is some doco that would be good to have in master now and somewhich needs
to wait. Should this be split do we can do this?
> +A typical CTF *trace* consists of multiple *streams* of binary *events*. The
> +*metadata* stream is a mandatory stream which describes the layout of all the
> +other streams in a trace. This metadata stream is written using *Trace Stream
> +Description Language* (TSDL).
> +.. comment: image taken from view-source:http://diamon.org/ctf/img/ctf-trace.png
> +.. comment: Not generating a copyright in the high chance we decide to not keep
> +.. comment: a descriptive section on CTF
> +.. figure:: ../../images/user/ctf-trace.png
> +  :align: center
> +  :width: 75%
> +A binary *stream* is further a concatenation of several packets each containing
> +the following:
> +- A packet header
> +- An optional packet context
> +- A set of concatenated events each containing:
> + - An event header
> + - A stream-specific context
> + - An event-specific context
> + - A payload
> +.. comment: taken from http://diamon.org/ctf/img/ctf-stream-packet.png
> +.. figure:: ../../images/user/ctf-stream-packet.png
> +  :align: center
> +  :width: 75%
> +All the headers, contexts and payloads are written in TSDL using CTF data types.
> +CTF supports a rich set of configurable datatypes which makes it possible to
> +describe a larger variety of binary structure. Moreover types in CTF are
> +organized as type classes where type specifications can be inherited to allow
> +deriving types. These factors make CTF flexible. CTF enables fast writing of
> +binary data as it usually involves appending memory contents, as it is to a
> +binary CTF stream. CTF streams are capable of being sent or received over the
> +network without any data being written to disk and hence can be useful in
> +transporting traces from the target to the host machine for analysis.
> +Due to these advantages tracing using CTF will prove to be beneficial for the
> +users. This method of tracing is currently under development. Currently the
> +RTEMS tracing framework is able to output trace data in the form of trace
> +buffers, console output and csv files. A conversion tool which transforms
> +these trace output formats to CTF will be viable approach to generating CTF
> +traces. In this regard we utilize babeltrace, which is described in the
> +following section.
> +Babeltrace
> +Babeltrace is an open source trace format converter which can be used to convert
> +RTEMS traces into CTF. It is also a reference parser implementation of CTF. Babeltrace
> +currently supports the following output formats for traces:
> +- Text
> +- CTF
> +- CTF-metadata
> +- Dummy
> +- lttng-live
> +Babeltrace comes in the form of a library, python bindings (python3) and command line
> +tool called ``babeltrace``. To install babeltrace on your host you can install a
> +distribution package or build from source using tarballs or git repositories of
> +babeltrace. Refer to http://diamon.org/babeltrace/ for further details.
> diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
> index 0000000..3340794
> --- /dev/null
> +++ b/user/tracing/tracelinker.rst
> @@ -0,0 +1,287 @@
> +.. _tracelinker:
> +Trace Linker
> +RTEMS trace linker is a post link tool central to the RTEMS trace framework. It
> +is installed as a part of the RTEMS Tool Project.The RTEMS Trace Linker is a
> +post link tool that performs a re-link of your application to produce a trace
> +executable. A trace executable has been instrumented by the RTEMS Trace Linker
> +with additional code that implements software tracing. A key requirement of the
> +trace process in RTEMS is to take existing code in a compiled format (ELF) and
> +instrument it without rebuilding that code from source and without annotating
> +that source with trace code.
> +Command Line
> +A typical command to invoke the trace linker consists of two parts separated by
> +``--``.  The first part controls the trace linker and provides the various
> +options it needs and the second part is a standard linker command line you would
> +use to link an RTEMS application. The current command line for trace linker consists
> +of:
> +  $ rtems-tld -h
> +  rtems-trace-ld [options] objects
> +  Options and arguments:
> +   -h          : help (also --help)
> +   -V          : print linker version number and exit (also --version)
> +   -v          : verbose (trace import parts), can supply multiple times
> +                 to increase verbosity (also --verbose)
> +   -w          : generate warnings (also --warn)
> +   -k          : keep temporary files (also --keep)
> +   -c compiler : target compiler is not standard (also --compiler)
> +   -l linker   : target linker is not standard (also --linker)
> +   -E prefix   : the RTEMS tool prefix (also --exec-prefix)
> +   -f cflags   : C compiler flags (also --cflags)
> +   -r path     : RTEMS path (also --rtems)
> +   -B bsp      : RTEMS arch/bsp (also --rtems-bsp)
> +   -W wrapper  : wrapper file name without ext (also --wrapper)
> +   -C ini      : user configuration INI file (also --config)
> +   -P path     : user configuration INI file search path (also --path)
> +The trace linker generates code that needs to be compiled and linked to the
> +application executable so it needs to know the target compiler and `CFLAGS`.
> +There are a couple of ways to do this. The simplest is to provide the path to
> +RTEMS using the `-r` option and the architecture and BSP name in the standard
> +RTEMS format of arch/bsp. The trace linker will extract the compiler and flags
> +used to build RTEMS and will use them. If you require specific options you can
> +use the `-f`, `-c`, `-l` and `-E` options to provide them. If the functions you
> +are tracing use types from your code then add the include path to the `CFLAGS`.
> +The trace linker requires you to provide a user configuration file using the
> +`-C` or ``--config`` option. This is an INI format file detailed in the
> +Configuration section. You can also provide an INI file search path using the
> +`-P` option.
> +If you are working with new configuration files and you want to view the files
> +the trace linker generates add the `-k` option to keep the temporary files, and
> +`-W` to specify an explicit wrapper C file name. If you set the
> +``dump-on-error`` option in the configuration options section you will get a
> +dump of the configuration on an error.
> +Configuration (INI) files
> +The Trace Linker is controlled using configuration files. Configuration files
> +are categorized into 3 types:
> +- User Configuration: These are specific to the user application to be traced.
> +  This file initializes the values of the trace generator, triggers, enables and
> +  traces.
> +- Tracer Configuration: These are like a library of common or base trace
> +  functions that can be referenced by an application. These files tend to hold
> +  the details needed to wrap a specific set of functions. Examples provided with
> +  the RTEMS Linker are the RTEMS API and Libc.
> +- Generator Configuration: This is used to encapsulate a specific method of
> +  tracing. Rtems currently provides generators for trace buffering, printk and
> +  printf.
> +The configuration files are in the *INI file format* which is composed of
> +`sections`. Each section has a section name and set of *keys* which consist of
> +*names* and *values*. A typical key is of the form ``name=value``. Keys can be
> +used to include other INI files using the include key name. This is shown in the
> +following example where the values indicate rtems and rtld-base configuration files:
> +.. code-block::shell
> +  include = rtems.ini, rtld-base.ini
> +The trace linker also uses values in keys to specify other sections. In this
> +example the functions name lists test-trace-funcs and that section contains a headers
> +key that references a further section test-headers:
> +  functions = test-trace-funcs, rtems-api
> +  [test-trace-funcs]
> +  ; Parsed via the 'function-set', not parse as a 'trace'.
> +  headers = test-headers
> +  [test-headers]
> +  header = '#include "test-trace-1.h"'
> +The format of a configuration file is explained next. Snippets of the fileio-trace.ini
> +file have been used for explicit understanding. This file can be downloaded from `here
> +<https://devel.rtems.org/attachment/wiki/Developer/Tracing/Trace_Buffering/filei
> +o-trace.ini>`_.
> +Tracer Section
> +The topmost level section is the ``tracer`` section. It can contains the
> +following keys:
> +- name: The name of trace being linked.
> +- options: A list of option sections.
> +- defines: A list of sections containing defines or define record.
> +- define: A list of define string that are single or double quoted.
> +- enables: The list of sections containing enabled functions to trace.
> +- triggers: The list of sections containing enabled functions to trigger trace
> +  on.
> +- traces: The list of sections containing function lists to trace.
> +- functions: The list of sections containing function details.
> +- include: The list of files to include
> +  [tracer]
> +  name = File IO tracer
> +  ; The configuration
> +  options = fileio-options
> +  traces = fileio
> +  defines = fileio
> +  enables = fileio
> +  triggers = fileio
> +  functions = fileio-funcs, rtems-api, rtems-posix, libc-heap
> +  include = rtems.ini, rtld-base.ini, rtld-trace-buffer.ini, libc-heap.ini
> +Options section
> +The options section in the fileio-trace.ini is called the `fileio-options`. A
> +general options section can contain following sets of keys:
> +- dump-on-error: Dump the parsed configuration data on error. The value can be
> +  true or false.
> +- verbose: Set the verbose level. The value can be true or a number value.
> +- prefix: The prefix for the tools and an install RTEMS if rtems-path is not
> +  set.
> +- cc: The compiler used to compile the generated wrapper code. Overrides the
> +  BSP configuration value if a BSP
> +  is specified.
> +- ld: The linker used to link the application. The default is the cc value as
> +  read from the BSP configuration if specificed. If your application contains
> +  C++ code use this setting to the change the linker to g++.
> +- cflags: Set the CFLAGS used to compiler the wrapper. These flags are
> +  pre-pended to the BSP read flags if a BSP is specified. This option is used
> +  to provide extra include paths to header files in your application that
> +  contain types any functions being traced reference.
> +- rtems-path: The path to an install RTEMS if not installed under the prefix.
> +- rtems-bsp: The BSP we are building the trace executable for. The is an arch
> +  and bsp pair. For example sparc/erc32.
> +  [fileio-options]
> +  dump-on-error = true
> +  ; Tools
> +  prefix = /development/rtems/5
> +  rtems-path = /development/rtems/kernel/5
> +  rtems-bsp = sparc/erc32
> +  ; Generator options.
> +  gen-enables = enable
> +  gen-triggers = enable
> +Trace Section
> +A trace section defines how trace wrapper functions are built. To build a trace
> +function that wraps an existing function in an ELF object file or library
> +archive we need to have the function's signature. A signature is the function's
> +declaration with any types used. The the signature has specific types we need
> +access to those types which means the wrapper code needs to include header files
> +that define those types. There may also be specific defines needed to access
> +those types.
> +- generator: The generator defines the type of tracing being used.
> +- headers: List of sections that contain header files keys.
> +- header: A header key. Typically the include code.
> +- defines: List of sections that contain defines.
> +- define: A define key. Typically the define code.
> +- signatures: List of function signature sections.
> +- trace: Functions that are instrumented with trace code.
> +[TBD]
> +Function Wrapping
> +The trace linker's major role is to wrap functions in the existing executable
> +with trace code. The directions on how to wrap application functions is provided
> +by the generator configuration. The wrapping function uses a GNU linker option
> +called --wrap=symbol. The GNU Ld manual states:
> +"Use a wrapper function for symbol. Any undefined reference to symbol will be
> +resolved to __wrap_symbol. Any undefined reference to __real_symbol will be
> +resolved to symbol."
> +The trace linker generates C code with a wrapper for each function to be instrumented.
> +The trace code generated is driven by the configuration INI files.
> +Function Signatures
> +A function signature is the function's declaration. It is the name of the
> +function, the return value and the arguments. Tracing using function wrappers
> +requires that we have accurate function signatures and ideally we would like to
> +determine the function signature from the data held in ELF files. ELF files can
> +contain DWARF data, the ELF debugging data format. In time the trace project
> +would like to support libdwarf so the DWARF data can be accessed and use to determine
> +a function's signature. This work is planned but not scheduled to be done and so in the
> +meantime we explicitly define the function signatures in the configuration files.
> +Development
> +The Trace Linker is part of the RTEMS tools git repository available at :
> +https://git.rtems.org/rtems-tools
> +The RTEMS tools project utilizes the waf build system. Use the following
> +commands in the topmost build directory to build the tools project:
> +First we configure using:
> +  $./waf configure --prefix=$HOME/development/rtems/5
> +Then we build and install using:
> +  $./waf build install
> diff --git a/user/tracing/usecases.rst b/user/tracing/usecases.rst
> index 0000000..5105650
> --- /dev/null
> +++ b/user/tracing/usecases.rst
> @@ -0,0 +1,117 @@
> +.. _usecases:
> +Tracing Use Cases
> +Following are the use cases of the tracing framework that are currently under
> +development:
> +Function Tracing
> +Tracing the entry and exit of a function as well as the values of the arguments
> +and return values can prove to be an important application for the tracing
> +framework.
> +Objective
> +This use case can prove to be helpful in debugging of applications for the
> +users. It can also be used to understand the working of existing application
> +code bases. Capturing of argument and return values maybe useful in tracking
> +unexpected output results from the applications.
> +Requirements
> +The current tracing framework provides this functionality with
> +:ref:`tracebuffering`. The output is provided in the form of printing on
> +console or saving the buffer in the form of a bin file. In order to develop this
> +use case using CTF we need to be able to convert this RTEMS trace output into
> +CTF. This could be done using babeltrace. The converted CTF traces would then be
> +sent over to the host using a transport mechanism.
> +Example
> +As a start to the development of function tracing using CTF we can work on the
> +fileio sample testsuite and trace all the calls to malloc, calloc, free and
> +realloc functions. Along with the calls made to these functions the trace must
> +also capture the values of their arguments at entry and the return values at
> +function exit. As an example of an application having the following progression
> +of function calls:
> +.. code-block:: c
> +  #include <stdlib.h>
> +  int main(int argc, char** argv)
> +    int* a = malloc(sizeof(int));
> +    free(a);
> +    a = calloc(1, sizeof(int));
> +    return 0;
> +The trace of such an application must be output of the following kind:
> +  Timestamp1    entry of malloc > argument value
> +  Timestamp2    exit of malloc < return value
> +  Timestamp3    entry of free > argument value
> +  Timestamp4    exit of free < return value (null)
> +  Timestamp5    entry of calloc > argument1 value, argument2 value
> +  Timestamp6    exit of calloc < return value1
> +There could be additional columns of details including current priority, task
> +state etc.
> +Tracing Thread Operations
> +Tracing thread creation, switching and termination operation in a thread's
> +lifetime within an application.
> +Objective
> +Real time applications inherently utilize parallel programming which entails
> +several tasks executing simultaneously and competing for common resources.
> +On single processor systems the CPU performs context switching between each of
> +these tasks rapidly. By tracing the creation and termination of tasks as well
> +as the context switches between them one can possibly identify probable race
> +conditions or complex threading operations.
> +Requirements
> +[TBD]
> +Example
> +A sample trace tracking two tasks Ta and Tb could have an output of the
> +following kind:
> +  Timestamp1 taskid Ta CREATED
> +  Timestamp1 taskid Ta SWITCHED-IN
> +  Timestamp1 taskid Ta BEGIN
> +  Timestamp1 taskid Tb CREATED
> +  Timestamp1 taskid Ta SWITCHED-OUT
> +  Timestamp1 taskid Tb SWITCHED-IN
> +  Timestamp1 taskid Tb BEGIN
> +  Timestamp1 taskid Tb SWITCHED-OUT
> +  Timestamp1 taskid Tb TERMINATED
> +  Timestamp1 taskid Ta TERMINATED
> devel mailing list
> devel at rtems.org
