[PATCH v4 2/2] Adding trace documentation
Wed Jun 13 03:20:17 UTC 2018
On 13/06/2018 13:04, Vidushi Vashishth wrote:
> I have made the changes you suggested.
Thanks.
> I am still working on CTF support.
>>> +  $ ../samples
>>What is this command?
> This is not a command. It is used to show which directory we are in. This method
> was used in the quickstart section. But I have removed this.
Oh that maybe a mistake. Which section?
>>There is some doco that would be good to have in master now and somewhich needs
>>to wait. Should this be split do we can do this?
> I could complete the tracing examples page and the trace linker page and remove
> the CTF portion and submit another patch?
Yes please that would be good then we can have some documentation for what
exists pushed to master.
> The section on use cases and CTF are under development.
I understand and it is great to see the documentation you have already on the
subject.
