error while building leon3 with gcov flags
Joel Sherrill
joel at rtems.org
Wed Jun 13 06:20:54 UTC 2018
On Sun, Jun 10, 2018, 6:02 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Sun, 10 Jun 2018, 20:52 Joel Sherrill, <joel at rtems.org> wrote:
>> On Sat, Jun 9, 2018, 6:02 PM Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 10 June 2018 at 04:16, Joel Sherrill <joel at rtems.org> wrote:
>>>> I suggest this because it is a work around for you. The long term
>>>> solution could be to add the symbol to newlib's dummy RTEMS crt0.c, add it
>>>> to librtemscpu.a (which is the temporary hack I suggested), add a libgcov.a
>>>> implementation or stub to RTEMS, or modify GCC.
>>>> Up until now, we have avoided gcc options which altered the code under
>>>> test. Test as you fly, fly as you test. This hints at a problem we need to
>>>> think through. Is the call actually needed? I don't know.
>>>> (according to my understanding)
>>> To generate the gcov reports we would need it .
>>> the -ftest-coverage generates a gcno file that contains information
>>> about each branch in the code.
>>> a code compiled with -fprofile-arcs includes libgcov which
>>> gets invoked during the program exit. The coverage information is
>>> collected during runtime and dumped into gcda file by libgcov.
>> We don't need it to gather its own information. Covoar generates it based
>> on the execution trace. If all this option does is instrument the generated
>> code and write results on exit, then we want to turn that off and teach
>> covoar to write the same files.
> Yes that's all the option does.
> Understood. I'll try to figure out how the
> gcov code in covoar works/is supposed
> to work.
Just remember that we want no changes to the code running on the target. So
covoar has to generate any output like profiling, coverage days, etc. from
the qemu traces. I know that helps me keep it clear.
As to the build error, make sure you have a fresh build with no unnecessary
changes to compile flags.
>> On Sat, Jun 9, 2018, 5:38 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>> For now, add a file to libcsupport/src which provides the symbols
>>>>> needed. Make sure things are methods or data as needed. Check GCC source
>>>>> for the prototype.
>>>>> This looks like something that is going to need a lot of reading.
>>>> On Sat, Jun 9, 2018, 3:34 PM Vijay Kumar Banerjee <
>>>>>> On 10 June 2018 at 01:28, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> On Sat, Jun 9, 2018, 2:29 PM Vijay Kumar Banerjee <
>>>>>>>> On 10 June 2018 at 00:55, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>> On Sat, Jun 9, 2018, 2:22 PM Vijay Kumar Banerjee <
>>>>>>>>>> On 9 June 2018 at 19:56, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>>>> On Sat, Jun 9, 2018, 6:01 AM Vijay Kumar Banerjee <
>>>>>>>>>>>> Hello,
>>>>>>>>>>>> I was going through the gcc manual for gcov
>>>>>>>>>>>> https://gcc.gnu.org/onlinedocs/gcc/Gcov-and-Optimization.html#Gcov-and-Optimization
>>>>>>>>>>>> It mentions that the flag -fprofile-arcs is necessary for
>>>>>>>>>>>> generating the .gcda files.
>>>>>>>>>>>> I have tried it with a small hello world program to see the
>>>>>>>>>>>> reports, and it seems
>>>>>>>>>>>> that for .gcda files this flag is necessary.
>>>>>>>>>>>> when I include the flag `-fprofile-arcs` with `-ftest-coverage`
>>>>>>>>>>>> and then make
>>>>>>>>>>>> I'm getting the following error.
>>>>>>>>>>>> checking whether the C compiler works... no
>>>>>>>>>>>> configure: error: in
>>>>>>>>>>>> `/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3':
>>>>>>>>>>>> configure: error: C compiler cannot create executables
>>>>>>>>>>>> See `config.log' for more details
>>>>>>>>>>>> gmake[2]: *** [Makefile:731: leon3] Error 1
>>>>>>>>>>>> gmake[2]: Leaving directory
>>>>>>>>>>>> '/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c'
>>>>>>>>>>>> gmake[1]: *** [Makefile:289: all-recursive] Error 1
>>>>>>>>>>>> gmake[1]: Leaving directory
>>>>>>>>>>>> gmake: *** [Makefile:414: all-recursive] Error 1
>>>>>>>>>>> It may be looking for a symbol provided by libgov.a. We don't
>>>>>>>>>>> have that based on how we do coverage.
>>>>>>>>>>> The normal approach is to add it to the RTEMS dummy crt0.c in
>>>>>>>>>>> newlib.
>>>>>>>>>> er.... looks confusing, are there any instructions ? :)
>>>>>>>>> What's the error first? What was in config.log in the directory
>>>>>>>>> with the failure?
>>>>>>>>> I added this.
>>>>>>>> CFLAGS_OPTIMIZE_V += -fprofile-arcs -ftest-coverage
>>>>>>>> when I `make` it, I see this error.
>>>>>>> I completely understood that. When you look in config.log in what
>>>>>>> looks to be a leon3 subdirectory, what's in the log file?
>>>>>>> I have attached the config.log file .
>>>>>>> My reading of the gcc manual was that one of those options
>>>>>>> implicitly added an option to link with libgcov.a. please confirm that.
>>>>>> yes , -fprofile-arcs implicitly adds option to link with libgcov
>>>>>>>>>>>> On 8 June 2018 at 01:13, Vijay Kumar Banerjee <
>>>>>>>>>>>>> On Fri, 8 Jun 2018, 01:09 Joel Sherrill, <joel at rtems.org>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Bringing in Krzysztof. Hoping he can get us on the right
>>>>>>>>>>>>>> track here.
>>>>>>>>>>>>>> I don't think you can run GcovData.cc independent of a covoar
>>>>>>>>>>>>>> run.
>>>>>>>>>>>>> Understood.
>>>>>>>>>>>>>> If you can figure out how to write a unit test that would be
>>>>>>>>>>>>>> helpful.
>>>>>>>>>>>>> Will try to do that if possible.
>>>>>>>>>>>>>> On Thu, Jun 7, 2018 at 2:29 PM, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>>> I was looking into the code in GcovData.cc to see how it
>>>>>>>>>>>>>>> works
>>>>>>>>>>>>>>> and what it's doing, too me it looked like very messed up, I
>>>>>>>>>>>>>>> couldn't
>>>>>>>>>>>>>>> understand (yet) what it's trying to do.
>>>>>>>>>>>>>>> Is there some way I can manually run it for one file?
>>>>>>>>>>>>>>> Is there any place where I can read how it was intended to
>>>>>>>>>>>>>>> work?
>>>>>>>>>>>>>>> Or something like a flow diagram?
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 7 June 2018 at 02:56, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> On Thu, 7 Jun 2018, 02:39 Joel Sherrill, <joel at rtems.org>
>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>> On Wed, Jun 6, 2018, 3:56 PM Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>> On 7 June 2018 at 01:48, Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>> On Wed, Jun 6, 2018, 2:07 PM Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>> On 6 June 2018 at 20:49, Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>>>> I can't duplicate this. My configure command was:
>>>>>>>>>>>>>>>>>>>>> ../rtems/configure --target=sparc-rtems5
>>>>>>>>>>>>>>>>>>>>> --enable-rtemsbsp=leon3 --prefix=/home/joel/rtems-work/tools/5 \
>>>>>>>>>>>>>>>>>>>>> --disable-networking --enable-posix --disable-smp
>>>>>>>>>>>>>>>>>>>>> --disable-multiprocessing \
>>>>>>>>>>>>>>>>>>>>> --enable-tests --enable-cxx --enable-maintainer-mode
>>>>>>>>>>>>>>>>>>>>> What was yours?
>>>>>>>>>>>>>>>>>>>>> I didn't have --enable-cxx and
>>>>>>>>>>>>>>>>>>>> --enable-maintainer-more.
>>>>>>>>>>>>>>>>>>>> I made some tries and somehow it's perfectly working
>>>>>>>>>>>>>>>>>>>> now.
>>>>>>>>>>>>>>>>>>>> I am trying to find out now how covoar generates the
>>>>>>>>>>>>>>>>>>>> reports.
>>>>>>>>>>>>>>>>>>>> I made a file with a list of all gcno in score/ and run
>>>>>>>>>>>>>>>>>>>> with -g argument
>>>>>>>>>>>>>>>>>>>> now I'mg seeing the following error while running
>>>>>>>>>>>>>>>>>>>> covoar
>>>>>>>>>>>>>>>>>>>> Generating Gcov reports...
>>>>>>>>>>>>>>>>>>>> Processing file: libscore_a-allocatormutex.gcno
>>>>>>>>>>>>>>>>>>>> Unable to open libscore_a-allocatormutex.gcno
>>>>>>>>>>>>>>>>>>>> Processing file: libscore_a-apimutexisowner.gcno
>>>>>>>>>>>>>>>>>>>> Unable to open libscore_a-apimutexisowner.gcno
>>>>>>>>>>>>>>>>>>>> Processing file: libscore_a-apimutexlock.gcno
>>>>>>>>>>>>>>>>>>>> Unable to open libscore_a-apimutexlock.gcno
>>>>>>>>>>>>>>>>>>>> Processing file: libscore_a-apimutexunlock.gcno
>>>>>>>>>>>>>>>>>>>> Unable to open libscore_a-apimutexunlock.gcno
>>>>>>>>>>>>>>>>>>>> Processing file: libscore_a-chain.gcno
>>>>>>>>>>>>>>>>>>>> Unable to open libscore_a-chain.gcno
>>>>>>>>>>>>>>>>>>>> Processing file: libscore_a-chainnodecount.gcno
>>>>>>>>>>>>>>>>>>> I suspect this is another instance of the path issues
>>>>>>>>>>>>>>>>>>> inside the build tree you and Cillian fixed earlier.
>>>>>>>>>>>>>>>>>>> correcting the path worked.
>>>>>>>>>>>>>>>>> Submit a patch for this. It needs fixing to get 5onyour
>>>>>>>>>>>>>>>>> next issue.
>>>>>>>>>>>>>>>> It just needed the absolute path to be fed.
>>>>>>>>>>>>>>>> here's what I did.
>>>>>>>>>>>>>>>> I manually 'find' all the gcno files under score.
>>>>>>>>>>>>>>>> wrote it all in a file separated by newlines.
>>>>>>>>>>>>>>>> fed that file as an argument to covoar.
>>>>>>>>>>>>>>>> and that brought me here.
>>>>>>>>>>>>>>>> So when we write script, these are the
>>>>>>>>>>>>>>>> things that will be done by the script.
>>>>>>>>>>>>>>>> Once everything strats running manually,
>>>>>>>>>>>>>>>> we can proceed to write scripts.
>>>>>>>>>>>>>>>>>> Now I'm getting this error.
>>>>>>>>>>>>>>>>>> Processing file:
>>>>>>>>>>>>>>>>>> sparc-rtems5/c/leon3/cpukit/score/src/libscore_a-kern_tc.gcno
>>>>>>>>>>>>>>>>>> ERROR: Unable to read string from gcov file
>>>>>>>>>>>>>>>>>> ERROR: Unable to read string length from gcov file
>>>>>>>>>>>>>>>>>> ERROR: Unable to read Function starting line number
>>>>>>>>>>>>>>>>>> Segmentation fault (core dumped)
>>>>>>>>>>>>>>>>> Welcome to GSoC! You are now in new territory. :)
>>>>>>>>>>>>>>>> So here the real work begins!
>>>>>>>>>>>>>>>>> Dig in and see what went wrong. Be aware.that GCC file
>>>>>>>>>>>>>>>>> formats may (or may not) be subject to.changing over time and this could
>>>>>>>>>>>>>>>>> just be bitrot.
>>>>>>>>>>>>>>>> I got started with it.
>>>>>>>>>>>>>>>>> Gcov-dump is installed with the compiler.
>>>>>>>>>>>>>>>>> You should check it we have a .h file describing the file
>>>>>>>>>>>>>>>>> and it is out of date.
>>>>>>>>>>>>>>>> I'll look into it.
>>>>>>>>>>>>>>>>> Also I think we now should bring the gsov maintainer in.
>>>>>>>>>>>>>>>> The covoar's gcov support needs to be reworked.
>>>>>>>>>>>>>>>> We can get the help of the expert here.
>>>>>>>>>>>>>>>>> Good job!
>>>>>>>>>>>>>>>> Thanks. :)
>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 6, 2018 at 9:40 AM, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>>>>>>>>>> I have added the following changes in the
>>>>>>>>>>>>>>>>>>>>>> bsps/sparc/leon3/config/leon3.cfg
>>>>>>>>>>>>>>>>>>>>>> CFLAGS_OPTIMIZE_V = -Os -g
>>>>>>>>>>>>>>>>>>>>>> CFLAGS_OPTIMIZE_V += -ftest-coverage
>>>>>>>>>>>>>>>>>>>>>> While trying to build with these flags, I got a bunch
>>>>>>>>>>>>>>>>>>>>>> of
>>>>>>>>>>>>>>>>>>>>>> the following errors:
>>>>>>>>>>>>>>>>>>>>>> {standard input}: Assembler messages:
>>>>>>>>>>>>>>>>>>>>>> {standard input}:6510: Error: can't resolve
>>>>>>>>>>>>>>>>>>>>>> `.data._SPARC_Counter' {.data._SPARC_Counter section} - `.LLtext0' {.text
>>>>>>>>>>>>>>>>>>>>>> section}
>>>>>>>>>>>>>>>>>>>>>> {standard input}:6511: Error: can't resolve
>>>>>>>>>>>>>>>>>>>>>> section}
>>>>>>>>>>>>>>>>>>>>>> after the `make install` I do get a lot of .gcno
>>>>>>>>>>>>>>>>>>>>>> files, and no
>>>>>>>>>>>>>>>>>>>>>> executables.
>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180613/118095f5/attachment-0001.html>
