[PATCH v5 1/2] Adding Trace Docuemntation Images
Wed Jun 13 09:36:17 UTC 2018
Hello Vidushi,
the patch set looks good. Would you mind fixing also the white space errors:
git am \[PATCH\ v5\ *
Applying: Adding Trace Docuemntation Images
.git/rebase-apply/patch:44: trailing whitespace.
Capture Engine is a trace tool built inside the RTEMS operating system.
Capture
.git/rebase-apply/patch:48: trailing whitespace.
to use it.
.git/rebase-apply/patch:49: trailing whitespace.
.git/rebase-apply/patch:50: trailing whitespace.
The Capture Engine's sample testcase for the `sparc/erc32` is available in
.git/rebase-apply/patch:57: trailing whitespace.
warning: squelched 147 whitespace errors
warning: 152 lines add whitespace errors.
Do we have PDF versions of the PNG images? PNG images are not really
good for PDF generation.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
