[PATCH] RISC-V: Add custom RTEMS multilibs
Sebastian Huber
Wed Jun 13 09:39:09 UTC 2018
Add multilib variants for -march=rv64imafd, e.g. to support the BOOMv2 core.
Add -mcmodel=medany as a variant of the 64-bit multilibs for RTEMS. The
ratinale for this change is that several existing RISC-V chips map the
RAM at 0x80000000. In RTEMS, we do not use virtual memory, so
applications will run at this location which is outside the +-2GiB range
in a 64-bit configuration.
gcc/
* config.gcc (riscv*-*-elf* | riscv*-*-rtems*): Use custom
multilibs for *-*-rtems*.
* config/riscv/t-rtems: New file.
gcc/config.gcc | 20 +++++++++++---------
gcc/config/riscv/t-rtems | 25 +++++++++++++++++++++++++
2 files changed, 36 insertions(+), 9 deletions(-)
create mode 100644 gcc/config/riscv/t-rtems
diff --git a/gcc/config.gcc b/gcc/config.gcc
index c3aecbfe764..25383423721 100644
--- a/gcc/config.gcc
+++ b/gcc/config.gcc
@@ -2085,10 +2085,17 @@ riscv*-*-linux*)
tm_file="elfos.h newlib-stdint.h ${tm_file} riscv/elf.h"
- case "x${enable_multilib}" in
- xno) ;;
- xyes) tmake_file="${tmake_file} riscv/t-elf-multilib" ;;
- *) echo "Unknown value for enable_multilib"; exit 1
+ case ${target} in
+ *-*-rtems*)
+ tm_file="${tm_file} rtems.h riscv/rtems.h"
+ tmake_file="${tmake_file} riscv/t-rtems"
+ case "x${enable_multilib}" in
+ xno) ;;
+ xyes) tmake_file="${tmake_file} riscv/t-elf-multilib" ;;
+ *) echo "Unknown value for enable_multilib"; exit 1
+ esac
esac
tmake_file="${tmake_file} riscv/t-riscv"
gnu_ld=yes
@@ -2096,11 +2103,6 @@ riscv*-*-elf* | riscv*-*-rtems*)
# Force .init_array support. The configure script cannot always
# automatically detect that GAS supports it, yet we require it.
gcc_cv_initfini_array=yes
- case ${target} in
- riscv*-*-rtems*)
- tm_file="${tm_file} rtems.h riscv/rtems.h"
- esac
riscv*-*-freebsd*)
tm_file="${tm_file} elfos.h ${fbsd_tm_file} riscv/freebsd.h"
diff --git a/gcc/config/riscv/t-rtems b/gcc/config/riscv/t-rtems
new file mode 100644
index 00000000000..41f5927fc87
--- /dev/null
+++ b/gcc/config/riscv/t-rtems
@@ -0,0 +1,25 @@
+MULTILIB_OPTIONS =
+MULTILIB_DIRNAMES =
+MULTILIB_OPTIONS += march=rv32i/march=rv32im/march=rv32imafd/march=rv32iac/march=rv32imac/march=rv32imafc/march=rv64imafd/march=rv64imac/march=rv64imafdc
+MULTILIB_DIRNAMES += rv32i rv32im rv32imafd rv32iac rv32imac rv32imafc rv64imafd rv64imac rv64imafdc
+MULTILIB_OPTIONS += mabi=ilp32/mabi=ilp32f/mabi=ilp32d/mabi=lp64/mabi=lp64d
+MULTILIB_DIRNAMES += ilp32 ilp32f ilp32d lp64 lp64d
+MULTILIB_OPTIONS += mcmodel=medany
+MULTILIB_DIRNAMES += medany
+MULTILIB_REQUIRED =
+MULTILIB_REQUIRED += march=rv32i/mabi=ilp32
+MULTILIB_REQUIRED += march=rv32im/mabi=ilp32
+MULTILIB_REQUIRED += march=rv32imafd/mabi=ilp32d
+MULTILIB_REQUIRED += march=rv32iac/mabi=ilp32
+MULTILIB_REQUIRED += march=rv32imac/mabi=ilp32
+MULTILIB_REQUIRED += march=rv32imafc/mabi=ilp32f
+MULTILIB_REQUIRED += march=rv64imafd/mabi=lp64d
+MULTILIB_REQUIRED += march=rv64imafd/mabi=lp64d/mcmodel=medany
+MULTILIB_REQUIRED += march=rv64imac/mabi=lp64
+MULTILIB_REQUIRED += march=rv64imac/mabi=lp64/mcmodel=medany
+MULTILIB_REQUIRED += march=rv64imafdc/mabi=lp64d
+MULTILIB_REQUIRED += march=rv64imafdc/mabi=lp64d/mcmodel=medany
2.13.7
