[PATCH 5/9] tools: Remove eolstrip
Thu Jun 14 05:39:04 UTC 2018
This program has no license information and is unused in the RTEMS
build.  General usability is questionable, for example a
  sed -i 's/[[:space:]]*$//' file
performs a similar task.  Remove it.
Close #3377.
 tools/build/Makefile.am |   3 +-
 tools/build/eolstrip.c  | 370 ------------------------------------------------
 2 files changed, 1 insertion(+), 372 deletions(-)
 delete mode 100644 tools/build/eolstrip.c
diff --git a/tools/build/Makefile.am b/tools/build/Makefile.am
index e2ef95d516..63ccfa43e4 100644
--- a/tools/build/Makefile.am
+++ b/tools/build/Makefile.am
@@ -1,8 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../../aclocal
-bin_PROGRAMS = eolstrip packhex unhex
+bin_PROGRAMS = packhex unhex
-eolstrip_SOURCES = eolstrip.c compat.c
 packhex_SOURCES = packhex.c
 unhex_SOURCES = unhex.c compat.c
diff --git a/tools/build/eolstrip.c b/tools/build/eolstrip.c
deleted file mode 100644
index 091b06e47e..0000000000
--- a/tools/build/eolstrip.c
+++ /dev/null
@@ -1,370 +0,0 @@
- *  eolstrip - strip white space from end of lines
- *  This program strips the white space from the end of every line in the
- *  specified program.
- *  usage:  eolstrip  [ -v ] [ arg ... ] files...
- *           -v          -- verbose
-#define GETOPTARGS "vt"
-char *USAGE = "\
-usage:  cklength  [ -v ] [ arg ... ] files... \n\
-            -v          -- verbose\n\
-            -t          -- test only .. DO NOT OVERWRITE FILE!!!\n\
-\n\
-Strip the white space from the end of every line on the list of files.\n\
-#include <stdio.h>
-#include <stdlib.h>
-#include <fcntl.h>
-#include <ctype.h>
-#include <unistd.h>
-#include <string.h>
-#include <memory.h>
-#include <stdarg.h>
-#include <errno.h>
-#include "config.h"
-#ifndef VMS
-#ifndef HAVE_STRERROR
-extern int sys_nerr;
-extern char *sys_errlist[];
-#define strerror( _err ) \
-  ((_err) < sys_nerr) ? sys_errlist [(_err)] : "unknown error"
-#else   /* HAVE_STRERROR */
-char *strerror ();
-#endif
-#else   /* VMS */
-char *strerror (int,...);
-#endif
-#define BUFFER_SIZE     2048
-#define MAX_PATH        2048
-#define SUCCESS         0
-#define FAILURE         -1
-#define Failed(x)       (((int) (x)) == FAILURE)
-#define TRUE    1
-#define FALSE   0
-#define STREQ(a,b)      (strcmp(a,b) == 0)
-#define NUMELEMS(arr)   (sizeof(arr) / sizeof(arr[0]))
- * Definitions for unsigned "ints"; especially for use in data structures
- *  that will be shared among (potentially) different cpu's (we punt on
- *  byte ordering problems tho)
-typedef unsigned char   u8;
-typedef unsigned short  u16;
-typedef unsigned long   u32;
- * vars controlled by command line options
-int verbose = FALSE;                    /* be verbose */
-int test_only = FALSE;                  /* test only */
-extern char *optarg;                    /* getopt(3) control vars */
-extern int optind, opterr;
-char *progname;                         /* for error() */
-int process(char *arg);
-void error(int errn, ...);
-long getparm(char *s, long min, long max, char *msg);
-#define ERR_ERRNO  (1<<((sizeof(int) * 8) - 2)) /* hi bit; use 'errno' */
-#define ERR_FATAL  (ERR_ERRNO / 2)              /* fatal error ; no return */
-#define ERR_ABORT  (ERR_ERRNO / 4)              /* fatal error ; abort */
-#define ERR_MASK   (ERR_ERRNO | ERR_FATAL | ERR_ABORT) /* all */
-#define stol(p) strtol(p, (char **) NULL, 0)
-int  Open(), Read(), Write();
-int main(
-  int argc,
-  char **argv
-    register int c;
-    int showusage = FALSE;                      /* usage error? */
-    int rc = 0;
-     * figure out invocation leaf-name
-    if ((progname = strrchr(argv[0], '/')) == (char *) NULL)
-        progname = argv[0];
-    else
-        progname++;
-    argv[0] = progname;                         /* for getopt err reporting */
-     *  Check options and arguments.
-    opterr = 0;                                 /* we'll report all errors */
-    while ((c = getopt(argc, argv, GETOPTARGS)) != EOF)
-        switch (c)
-            case 't':                           /* toggle test only mode */
-                test_only = ! test_only;
-                break;
-            case 'v':                           /* toggle verbose */
-                verbose = ! verbose;
-                break;
-            case '?':
-                showusage = TRUE;
-    if (showusage)
-        (void) fprintf(stderr, "%s", USAGE);
-        exit(1);
-     *  traverse and process the arguments
-    for ( ; argv[optind]; optind++)
-        if (Failed(process(argv[optind])))
-            rc = FAILURE;
-    return rc;
- * process(arg)
-int
-process(char *arg)
-  FILE   *in;
-  FILE   *out = (FILE *) 0;
-  char    outname[ MAX_PATH ];
-  char   *bptr;
-  char    buffer[ BUFFER_SIZE ];
-  int     length;
-  int     line_number;
-  int     rc = SUCCESS;  /* succeed by default */
-  in = fopen( arg, "r" );
-  if (!in)
-    error( ERR_ERRNO | ERR_FATAL, "Unable to open file (%s)\n", arg );
-  if ( !test_only ) {
-    length = snprintf( outname, BUFFER_SIZE, "%s.eoltmp", arg );
-    if (length >= BUFFER_SIZE)
-      error( ERR_ERRNO | ERR_FATAL, "Tmp file name too long\n" );
-    out = fopen( outname, "w" );
-    if (!out)
-  if ( verbose )
-    fprintf( stderr, "Processing %s\n", arg );
-  for ( line_number=1 ; ; line_number++ ) {
-    bptr = fgets( buffer, BUFFER_SIZE, in );
-    if (!bptr)
-      break;
-     *  Don't count the carriage return.
-    length = 0;
-    if ( *buffer != '\0' )
-      length = strnlen( buffer, BUFFER_SIZE ) - 1;
-    if ( buffer[ length ] != '\n' )
-      error(ERR_ERRNO|ERR_FATAL, "Line %d too long in %s\n", line_number, arg);
-    while ( length && isspace( (unsigned char) buffer[ length ] ) )
-      buffer[ length-- ] = '\0';
-    if ( test_only ) {
-      fprintf( stderr, "%s\n", arg );
-      break;
-    fprintf( out, "%s\n", buffer );
-  fclose( in );
-    if (out) fclose( out );
-    rc = rename( outname, arg );
-    if ( rc != 0 ) {
-      fprintf( stderr, "Unable to rename %s to %s\n", outname, arg );
-  return rc;
- * error(errn, arglist)
- *      report an error to stderr using printf(3) conventions.
- *      Any output is preceded by '<progname>: '
- * Uses ERR_FATAL bit to request exit(errn)
- *      ERR_ABORT to request abort()
- *      ERR_ERRNO to indicate use of errno instead of argument.
- * If resulting 'errn' is non-zero, it is assumed to be an 'errno' and its
- *      associated error message is appended to the output.
-/*VARARGS*/
-void
-error(int error_flag, ...)
-    va_list arglist;
-    register char *format;
-    int local_errno;
-    extern int errno;
-    (void) fflush(stdout);          /* in case stdout/stderr same */
-    local_errno = error_flag & ~ERR_MASK;
-    if (error_flag & ERR_ERRNO)     /* use errno? */
-        local_errno = errno;
-    va_start(arglist, error_flag);
-    format = va_arg(arglist, char *);
-    (void) fprintf(stderr, "%s: ", progname);
-    (void) vfprintf(stderr, format, arglist);
-    va_end(arglist);
-    if (local_errno)
-      (void) fprintf(stderr, " (%s)\n", strerror(local_errno));
-    else
-      (void) fprintf(stderr, "\n");
-    (void) fflush(stderr);
-    if (error_flag & (ERR_FATAL | ERR_ABORT))
-        if (error_flag & ERR_FATAL)
-            error(0, "fatal error, exiting");
-            exit(local_errno ? local_errno : 1);
-        else
-            error(0, "fatal error, aborting");
-            abort();
-long
-getparm(char *s,
-        long min,
-        long max,
-        char *msg)
-    long val;
-    if ( ! strchr("0123456789-", *s))
-        error(ERR_FATAL, "'%s' is not a number", s);
-        return min;
-    val = strtol(s, (char **) NULL, 0);
-    if ((val < min) || (val > max))
-        if (min == max)
-            error(ERR_FATAL, "%s can only be %ld", s, min);
-        else
-            error(ERR_FATAL, "%s must be between %ld and %ld", msg, min, max);
-    return val;
- * Open()
- *      Perform open(2), returning the file descriptor.  Prints
- *      error message if open fails.
-int
-Open(char *file,
-     int oflag,
-     int mode)
-    int O_fd;
-    if (Failed(O_fd = open(file, oflag, mode)))
-        error(
-          ERR_ERRNO | ERR_FATAL,
-          "open('%s', 0x%x, 0%o) failed", file, oflag, mode
-    return O_fd;
- * Read()
- *      Perform read(2); prints error message if fails.
-int
-Read(int file,
-     char *buffer,
-     unsigned int count)
-    int nbytes;
-    if (Failed(nbytes = read(file, buffer, count)))
-        error(
-          "read(%d, 0x%x, %d) failed", file, buffer, count
-    return nbytes;
- * Write()
- *      Perform write(2); prints error message if fails.
-int
-Write(int file,
-      char *buffer,
-    int nbytes;
-    if (Failed(nbytes = write(file, buffer, count)))
-        error(
-          "write(%d, 0x%x, %d) failed", file, buffer, count
-    return nbytes;
2.13.7
