[PATCH 2/9] tools: Remove size_rtems
Thu Jun 14 05:39:01 UTC 2018
This script is horribly out of date.  A new version could be placed in
RTEMS tools if necessary.
Close #3451.
 configure.ac                    |   1 -
 tools/cpu/Makefile.am           |   8 --
 tools/cpu/configure.ac          |  24 ----
 tools/cpu/generic/Makefile.am   |   5 -
 tools/cpu/generic/configure.ac  |  23 ----
 tools/cpu/generic/size_rtems.in | 281 ----------------------------------------
 6 files changed, 342 deletions(-)
 delete mode 100644 tools/cpu/Makefile.am
 delete mode 100644 tools/cpu/configure.ac
 delete mode 100644 tools/cpu/generic/Makefile.am
 delete mode 100644 tools/cpu/generic/configure.ac
 delete mode 100644 tools/cpu/generic/size_rtems.in
diff --git a/configure.ac b/configure.ac
index c245c5ab74..d88964fca2 100644
--- a/configure.ac
+++ b/configure.ac
@@ -41,7 +41,6 @@ test -z "$RTEMS_CC" && AC_MSG_ERROR([no acceptable cc found in \$PATH])
 ## * tools/cpu are host-native or host-cross-target-tools
 RTEMS_BUILD_CONFIG_SUBDIRS([tools/build])
-RTEMS_BUILD_CONFIG_SUBDIRS([tools/cpu])
 # Some BSPs carelessly apply these tools as build-tools
 AS_IF([test $host != $build],[
diff --git a/tools/cpu/Makefile.am b/tools/cpu/Makefile.am
deleted file mode 100644
index 460de891c2..0000000000
--- a/tools/cpu/Makefile.am
+++ /dev/null
@@ -1,8 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../aclocal
-SUBDIRS = @subdirs@
-DIST_SUBDIRS = @subdirs@
-include $(top_srcdir)/../../automake/subdirs.am
-include $(top_srcdir)/../../automake/host.am
diff --git a/tools/cpu/configure.ac b/tools/cpu/configure.ac
index 220311bf80..0000000000
--- a/tools/cpu/configure.ac
+++ /dev/null
@@ -1,24 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-tools-cpu],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([generic])
-RTEMS_TOP(../..)
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_PATH_KSH
-RTEMS_TOOLPATHS
-AC_SUBST(program_prefix)
-AC_CONFIG_SUBDIRS(generic)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/tools/cpu/generic/Makefile.am b/tools/cpu/generic/Makefile.am
index af48742ee0..0000000000
--- a/tools/cpu/generic/Makefile.am
+++ /dev/null
@@ -1,5 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../aclocal
-noinst_SCRIPTS = size_rtems
-include $(top_srcdir)/../../../automake/host.am
diff --git a/tools/cpu/generic/configure.ac b/tools/cpu/generic/configure.ac
index f0b606ea41..0000000000
--- a/tools/cpu/generic/configure.ac
+++ /dev/null
@@ -1,23 +0,0 @@
-AC_PREREQ([2.69])
-AC_INIT([rtems-tools-cpu-generic],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([size_rtems.in])
-RTEMS_TOP(../../..)
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-AM_MAINTAINER_MODE
-RTEMS_PATH_KSH
-RTEMS_TOOLPATHS
-size_rtems])
-AC_OUTPUT
diff --git a/tools/cpu/generic/size_rtems.in b/tools/cpu/generic/size_rtems.in
index d4cea35827..0000000000
--- a/tools/cpu/generic/size_rtems.in
+++ /dev/null
@@ -1,281 +0,0 @@
-#!@KSH@ -p
-#  size_rtems
-#  This script gathers information related to the size of RTEMS
-#  using the GNU "size" command.
-#  This script operates by summing up the sizes of the various
-#  object files which constitute a particular configuration of
-#  RTEMS.  This size information is gathered for placement in the
-#  brochure flyers and supplement manuals.
-#  NOTE: The concept of the minimum executive size is buried in this script.
-#  COPYRIGHT (c) 1989-1999.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
-target=@target@
-program_prefix=@program_prefix@
-gnusize=${program_prefix}size
-# check usage
-if [ $# -ne 2 ] ; then
-  echo usage ${0}: bsp object_directory
-  exit 1
-fi
-bsp=$1
-board=$1
-ARCH=$2
-cpu=`echo $target | sed -e 's/-.*//'`
-case $target in
-  sparc-sun-solaris*)
-      rtems_cpu=unix
-      bsp=solaris2
-      echo Not supported on unix port.
-      exit 0
-  i[34567]86-pc-linux-gnu)
-      echo linux
-      rtems_cpu=unix
-      bsp=linux1
-      exit 0
-  i[34567]86-unknown-freebsd2.[12]*)
-      echo freebsd
-      rtems_cpu=unix
-      bsp=freebsd2
-      exit 0
-  *-rtems*)
-    cpu=`echo $target | sed -e 's/-.*//'`
-    rtems_cpu=$cpu
-    echo unknown target $target
-    exit 1
-esac
-case $ARCH in
-  *debug*)   VARIANT=debug ;;
-  *profile*) VARIANT=profile ;;
-  *)         VARIANT=optimized;;
-esac
-echo
-echo Size Information for the Following Configuration:
-echo CPU: ${cpu}
-echo BSP: ${board}
-echo VARIANT: ${VARIANT}
-echo
-#  KLUDGE to figure out at runtime how to echo a line without a
-#  newline.
-count=`echo "\\c" | wc -c`
-if [ ${count} -ne 0 ] ; then
-  EARG="-n"
-  EOL=""
-else
-  EARG=""
-  EOL="\\c"
-fi
-if [ ! -d ../${board} ] ; then
-  echo "${board} does not exist ... is the current directory the build directory?"
-  exit 1
-fi
-#DIRLIST -- so greps for DIRLIST will find this file
-CPUOBJ=exec/score/cpu/${rtems_cpu}/wrap/${ARCH}
-COREOBJ=exec/score/src/${ARCH}
-RTEMSOBJ=exec/rtems/src/${ARCH}
-SAPIOBJ=exec/sapi/src/${ARCH}
-OPTOBJ=exec/rtems/optman/${ARCH}
-# XXX These have been split up
-MANLIST=" \
-${RTEMSOBJ}/clockget.o \
-${RTEMSOBJ}/clockset.o \
-${RTEMSOBJ}/clocktick.o \
-${RTEMSOBJ}/dpmem.o \
-${RTEMSOBJ}/event.o \
-${RTEMSOBJ}/intr.o \
-${RTEMSOBJ}/msg.o \
-${RTEMSOBJ}/part.o \
-${RTEMSOBJ}/ratemon.o \
-${RTEMSOBJ}/region.o \
-${RTEMSOBJ}/sem.o \
-${RTEMSOBJ}/signal.o \
-${RTEMSOBJ}/tasks.o \
-${RTEMSOBJ}/timer.o \
-${SAPIOBJ}/debug.o \
-${SAPIOBJ}/extension.o \
-${SAPIOBJ}/fatal.o \
-${SAPIOBJ}/exinit.o \
-${SAPIOBJ}/io.o \
-${SAPIOBJ}/rtemsapi.o \
-if [ -r ${RTEMSOBJ}/mp.o ] ; then
-  MPLIST="\
-  ${RTEMSOBJ}/mp.o ${RTEMSOBJ}/eventmp.o \
-  ${COREOBJ}/mpci.o ${RTEMSOBJ}/msgmp.o ${COREOBJ}/objectmp.o \
-  ${RTEMSOBJ}/partmp.o ${RTEMSOBJ}/regionmp.o ${RTEMSOBJ}/semmp.o \
-  ${RTEMSOBJ}/signalmp.o ${RTEMSOBJ}/taskmp.o ${COREOBJ}/threadmp.o \
-  MPOBJLIST=${OPTOBJ}/no-mp.rel
-fi
-OPTMANLIST="\
-${OPTOBJ}/no-dpmem.rel \
-${OPTOBJ}/no-event.rel \
-${MPOBJLIST} \
-${OPTOBJ}/no-msg.rel \
-${OPTOBJ}/no-part.rel \
-${OPTOBJ}/no-region.rel \
-${OPTOBJ}/no-rtmon.rel \
-${OPTOBJ}/no-sem.rel \
-${OPTOBJ}/no-signal.rel \
-${OPTOBJ}/no-timer.rel \
-REQMANLIST="\
-# XXX parts of these have been split up
-CORELIST=" \
-${COREOBJ}/apiext.o ${COREOBJ}/chain.o \
-${COREOBJ}/coremsg.o   ${COREOBJ}/coremutex.o ${COREOBJ}/coresem.o \
-${COREOBJ}/heap.o  ${COREOBJ}/interr.o \
-${COREOBJ}/isr.o \
-${COREOBJ}/object.o \
-${COREOBJ}/thread.o ${COREOBJ}/threadq.o ${COREOBJ}/tod.o \
-${COREOBJ}/userext.o \
-${COREOBJ}/watchdog.o ${COREOBJ}/wkspace.o \
-CPULIST="\
-${CPUOBJ}/rtems-cpu.rel \
-# check directories
-for i in ${EXECOBJ} ${CPUOBJ} ${OPTOBJ}
-do
-  if [ ! -d ${i} ] ; then
-    echo "${i} does not exist ... is RTEMS compiled and installed?"
-    exit 1
-  fi
-done
-for i in ${MANLIST} ${MPLIST} ${OPTMANLIST} ${REQMANLIST} ${CORELIST} ${CPULIST}
-do
-  if [ ! -r ${i} ] ; then
-    echo ${i} does not exist ... is RTEMS compiled and installed?
-    exit 1
-  fi
-done
-# "rips" a line of gsize's output and prints size, data, bss
-parse_size()
-  echo $1 $2 $3
-# prepares a list of code, data, bss sizes for a directory
-sizedir()
-  ${gnusize} $* | sed -e '1,1d' |
-    while read line
-      do
-        parse_size ${line}
-      done
-# adds the numbers passed on the command line
-addit()
-  sumx=0
-  for x in $*
-  do
-    sumx=`expr $sumx + $x`
-  done
-  echo $sumx
-# adds a column from the output of sizedir
-addsizes()
-  # dc version is not portable enough -- It can be left out during
-  #  installing linux and may not be available on non-UNIX hosts.
-  #cut -d' ' -f${2} ${1} | sed -e '2,$s/$/ + /' -e '$,$s/$/ p/' | dc
-  #  This may not be as fast but it is probably more portable.
-  addit `cut -d' ' -f${2} ${1}`
-# calculates total size of a directory and prints report line
-size_files()
-  trap "rm -f /tmp/size.$$ ; exit 1"  2 3
-    for file in $*
-      do
-        parse_size `${gnusize} $file | sed -e '/text/d'`
-      done >/tmp/size.$$
-  code=`cat /tmp/size.$$ | addsizes 1`
-  data=`cat /tmp/size.$$ | addsizes 2`
-  bss=` cat /tmp/size.$$ | addsizes 3`
-  echo "${code}	${data}	${bss}"
-  rm /tmp/size.$$
-echo
-echo "     RTEMS SIZE REPORT"
-echo
-echo   "          CODE	DATA	BSS"
-echo   "          =================="
-echo ${EARG} "MANAGERS: " ${EOL} ; size_files $MANLIST $MPLIST
-echo ${EARG} "CORE    : " ${EOL} ; size_files $CORELIST $CPULIST
-echo ${EARG} "CPU     : " ${EOL} ; size_files $CPULIST
-echo ${EARG} "OVERALL : " ${EOL} ; size_files $CPULIST $CORELIST $MANLIST \
-                                               $MPLIST
-echo ${EARG} "MINIMUM : " ${EOL} ; size_files $CPULIST $CORELIST \
-                                               $OPTMANLIST $REQMANLIST
-echo
-for file in $MANLIST
-do
-  base=`basename ${file}`
-  echo ${EARG}  ""${base}	: " ${EOL} " ; size_files ${file}
-done
-echo ${EARG} "MP	 : " ${EOL} ; size_files $MPLIST
-echo
-for file in $OPTMANLIST
-do
-  echo ${EARG} "${base}	: " ${EOL} ; size_files ${file}
-done
-echo
-exit 0
2.13.7
