[PATCH 9/9] tools: Remove rtems-testsuite-autostuff
Thu Jun 14 05:39:08 UTC 2018
It is not used.
Close #3447.
 tools/build/rtems-testsuite-autostuff | 49 -----------------------------------
 1 file changed, 49 deletions(-)
 delete mode 100755 tools/build/rtems-testsuite-autostuff
diff --git a/tools/build/rtems-testsuite-autostuff b/tools/build/rtems-testsuite-autostuff
deleted file mode 100755
index 8f298bac3c..0000000000
--- a/tools/build/rtems-testsuite-autostuff
+++ /dev/null
@@ -1,49 +0,0 @@
-#! /usr/bin/env python
-# Copyright 2017 Chris Johns <chrisj at rtems.org>
-# All rights reserved
-# Create the testsuite's configure.am and Makefile.am from the directories
-# found. This does not handle any conditional functionality that may be needed.
-from __future__ import print_function
-import os
-import os.path
-import sys
-def eprint(*args, **kwargs):
-    print(*args, file = sys.stderr, **kwargs)
-def die(*args, **kwargs):
-    sys.exit(1)
-if len(sys.argv) != 2:
-    die('error: just provide the path to the test directory')
-testdir = sys.argv[1]
-if not os.path.exists(testdir):
-    die('error: not found: %s' % (testdir))
-if not os.path.isdir(testdir):
-    die('error: not a directory: %s' % (testdir))
-excludes = ['autom4te.cache']
-tests = sorted([t for t in os.listdir(testdir)
-                if os.path.isdir(os.path.join(testdir, t)) \
-                and t not in excludes \
-                and os.path.exists(os.path.join(testdir, t, 'Makefile.am'))])
-configure = ['AC_CONFIG_FILES([Makefile'] + ['%s/Makefile' % (t) for t in tests] + ['])']
-makefile  = ['_SUBDIRS  ='] + ['_SUBDIRS += %s' % (t) for t in tests]
-print(os.linesep.join(configure))
-print()
-print(os.linesep.join(makefile))
-sys.exit(0)
2.13.7
