[PATCH 7/9] tools: Remove multigen
Thu Jun 14 05:39:06 UTC 2018
This script is unused and out dated.
Close #3445.
 tools/build/Makefile.am |   2 +-
 tools/build/multigen    | 171 ------------------------------------------------
 2 files changed, 1 insertion(+), 172 deletions(-)
 delete mode 100755 tools/build/multigen
diff --git a/tools/build/Makefile.am b/tools/build/Makefile.am
index a8e2e76c44..b42f58291e 100644
--- a/tools/build/Makefile.am
+++ b/tools/build/Makefile.am
@@ -6,7 +6,7 @@ packhex_SOURCES = packhex.c
 bin_SCRIPTS = install-if-change
-noinst_SCRIPTS = multigen cvsignore-add.sh
+noinst_SCRIPTS = cvsignore-add.sh
 noinst_SCRIPTS += doxy-filter
diff --git a/tools/build/multigen b/tools/build/multigen
deleted file mode 100755
index 2d9f80b5d3..0000000000
--- a/tools/build/multigen
+++ /dev/null
@@ -1,171 +0,0 @@
-#!/bin/sh
-version=0.1
-verbose=0
-target=
-custom=0
-config=0
-usage()
-program=`basename $0`
-cat << EOF
-$program generates RTEMS custom/*.cfgs and config-files for gcc multilib
-variants a target's gcc supports
-Usage: $program [options]
-Options:
-	--target=STRING         target
-        --custom		generate make/custom/*.cfg files
-        --config                generate config scripts
-        --rtems=DIR             use DIR as location of RTEMS source tree
-	-v, --verbose           verbose
-	-h, --help              Print this usage
-	--version               Print version and exit
-Examples:
-$program --config --target=sh-rtems --rtems=/usr/src/rtems-4.5.0
-	Generates config scripts for all possible bare BSPs from all
-	valid multilib variants sh-rtems-gcc supports
-$program --custom --target=sh-rtems --rtems=/usr/src/rtems-4.5.0
-	Generates /usr/src/rtems-4.5.0/make/custom/*.cfg files
-        for all possible bare BSPs from the multilib variants
-        sh-rtems-gcc supports
-Written by Ralf Corsepius <corsepiu at faw.uni-ulm.de>
-EOF
-while test $# -gt 0; do
-  case "$1" in
-  --rtems=*)
-    rtems_srcdir=`echo "$1" | sed -e 's%--rtems=\(.*\)%\1%g'`
-  --target=*)
-    target=`echo "$1" | sed -e 's%--target=\(.*\)%\1%g'`
-  -v|--verbose)
-    verbose=1
-  --custom)
-    custom=1
-  --config)
-    config=1
-  --version)
-    echo `basename $0` version $version
-    exit 0
-  -h|--help)
-    usage
-    exit 1
-    echo "unknown option $1"
-    usage
-    exit 1
-  esac
-  shift
-done
-if test $# -gt 0; then
-  echo "Invalid number of arguments"
-  exit 1
-fi
-if test x$target = x; then
-  echo "Missing required option:"
-  echo "	--target"
-  exit 1
-fi
-if test x$rtems_srcdir = x; then
-  echo "	--rtems"
-  exit 1
-fi
-if test $config -eq 0 && test $custom -eq 0; then
-  echo "	--config"
-  echo "	--custom"
-  echo " (At least one of these is required)"
-  exit 1
-fi
-if test ! -r $rtems_srcdir/VERSION; then
-  echo "Can't find rtems"
-  echo "Check value passed to --rtems=<DIR>"
-  exit 1
-fi
-if test x$target != x ;then
-target_prefix=$target-
-fi
-# Check for CC
-saved_IFS=$IFS; IFS=":"
-for i in $PATH; do
-  if test -f $i/${target_prefix}gcc; then
-    CC=$i/${target_prefix}gcc
-    break
-  fi
-done
-IFS=$saved_IFS
-if test x$CC = x; then
-  echo "No valid gcc found"
-  exit 1
-fi
-test $verbose -gt 0 && echo "Using $CC"
-for i in `${CC} --print-multi-lib 2>/dev/null`; do
-  dir=`echo $i | sed -e 's/;.*$//'`
-  case $dir in
-  .) f=$target
-     flags=""
-  *) f=`echo $target-$dir | sed -e 's%\/%-%g'`
-     flags=`echo $i | sed -e 's/^[^;]*;//' -e 's/@/ -/g'`
-  esac
-  if test $config -gt 0; then
-    cfg="rtems-config.$f"
-    test $verbose -gt 0 && echo "Generating: $cfg"
-cat << EOF > $cfg
-#!/bin/sh
-${rtems_srcdir}/configure --target=$target \\
-'--enable-bare-cpu-cflags=$flags' \\
---enable-rtemsbsp="bare" \\
---enable-bare-cpu-model=NONE \\
---disable-networking \\
---disable-tests \\
---enable-maintainer-mode
-EOF
-    chmod +x $cfg
-  fi
-  if test $custom -gt 0; then
-    cfg=${rtems_srcdir}/make/custom/bare-$f.cfg
-cat << EOF > $cfg
-#  Config file for the bare-$f BSP
-BARE_CPU_CFLAGS=$flags
-BARE_CPU_MODEL=NONE
-include \$(RTEMS_ROOT)/make/custom/bare.cfg
-EOF
-  fi
-done
-exit 0
2.13.7
