[PATCH 6/9] tools: Remove unhex
Thu Jun 14 05:39:05 UTC 2018
This program has no license information and is unused in the RTEMS
build.  Users of HEX files should consider to use ELF instead.  Remove
it.
Close #3378.
 tools/build/Makefile.am |   3 +-
 tools/build/compat.c    |  44 ---
 tools/build/unhex.c     | 733 ------------------------------------------------
 3 files changed, 1 insertion(+), 779 deletions(-)
 delete mode 100644 tools/build/compat.c
 delete mode 100644 tools/build/unhex.c
diff --git a/tools/build/Makefile.am b/tools/build/Makefile.am
index 63ccfa43e4..a8e2e76c44 100644
--- a/tools/build/Makefile.am
+++ b/tools/build/Makefile.am
@@ -1,9 +1,8 @@
 ACLOCAL_AMFLAGS = -I ../../aclocal
-bin_PROGRAMS = packhex unhex
+bin_PROGRAMS = packhex
 packhex_SOURCES = packhex.c
-unhex_SOURCES = unhex.c compat.c
 bin_SCRIPTS = install-if-change
diff --git a/tools/build/compat.c b/tools/build/compat.c
deleted file mode 100644
index 9c6eb10af5..0000000000
--- a/tools/build/compat.c
+++ /dev/null
@@ -1,44 +0,0 @@
- * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <info at embedded-brains.de>
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
- * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
- * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-#include "config.h"
-#include <string.h>
-#if !HAVE_STRNLEN
-size_t strnlen(const char *s, size_t maxlen)
-  const char *n = memchr(s, '\0', maxlen);
-  return n != NULL ? n - s : maxlen;
-#endif
diff --git a/tools/build/unhex.c b/tools/build/unhex.c
index e05f05fdc4..0000000000
--- a/tools/build/unhex.c
+++ /dev/null
@@ -1,733 +0,0 @@
- * unhex
- *      convert a hex file to binary equivalent.  If more than one file name
- *      is given, then the output will be logically concatenated together.
- *      stdin and stdout are defaults. Verbose will enable checksum output.
- *  Supported input formats are Intel hex, Motorola S records, and TI 'B'
- *  records.
- * Intel hex input format is
- *      Byte
- *       1          Colon :
- *       2..3       Record length, eg: "20"
- *       4..7       load address nibbles
- *       8..9       record type: "00" (data) or "02" base addr
- *       10..x      data bytes in ascii-hex
- *       x+1..x+2   cksum (2's compl of (len+addr+data))
- *       x+3        \n -- newline
-char *USAGE = "\
-usage:    unhex [-va] [ -o file ] [ file [file ... ] ]\n\
-                -v          -- verbose\n\
-                -a base     -- 1st byte of output corresponds to this address\n\
-                -l          -- linear, just writes data out\n\
-                -o file     -- output file; must not be input file\n\
-                -F k_bits   -- \"holes\" in input will be filled with 0xFF's\n\
-                                  up to \"k_bits\" * 1024 bits\n\
-#include <stdio.h>
-#include <fcntl.h>
-#include <ctype.h>
-#include <unistd.h>
-#include <stdlib.h>
-#include <stdarg.h>
-#include <errno.h>
-#include <assert.h>
-#ifndef VMS
-#ifndef HAVE_STRERROR
-extern int sys_nerr;
-extern char *sys_errlist[];
-#define strerror( _err ) \
-  ((_err) < sys_nerr) ? sys_errlist [(_err)] : "unknown error"
-#else   /* HAVE_STRERROR */
-char *strerror ();
-#endif
-#else   /* VMS */
-char *strerror (int,...);
-#endif
-#define OK      0
-#define FAILURE (-1)
-#define Failed(x)       ((x) == FAILURE)
-#define TRUE    1
-#define FALSE   0
-typedef char bool;
-#define STREQ(a,b)      (strcmp(a,b) == 0)
-typedef unsigned char u8;
-typedef unsigned short u16;
-typedef unsigned long u32;
- * Pick out designated bytes
-#define B0(x)       (((u32)x) & 0xff)
-#define B1(x)       B0(((u32)x) >> 8)
-#define B2(x)       B0(((u32)x) >> 16)
-#define B3(x)       B0(((u32)x) >> 24)
-typedef struct buffer_rec {
-    u32 dl_destaddr;
-    u32 dl_jumpaddr;
-    int dl_count;
-    u8  dl_buf[512];
-} buffer_rec;
- * vars controlled by command line options
-bool verbose = FALSE;                   /* be verbose */
-bool linear = FALSE;                    /* just write out linear data */
-char *outfilename = "-";                /* default output is stdout */
-u32 base = 0L;                         /* base address */
-u32 FFfill = 0L;                       /* how far to fill w 0xFF's */
-extern char *optarg;                    /* getopt(3) control vars */
-extern int optind;
-char *progname;                         /* for error() */
-void error(int errn, ...);
-#define ERR_ERRNO  (1<<((sizeof(int) * 8) - 2)) /* hi bit; use 'errno' */
-#define ERR_FATAL  (ERR_ERRNO / 2)              /* error is fatal; no return */
-#define ERR_ABORT  (ERR_ERRNO / 4)              /* error is fatal; abort */
-#define ERR_MASK   (ERR_ERRNO | ERR_FATAL | ERR_ABORT) /* all */
-#ifdef HAVE_STRTOUL
-#define stol(p) strtoul(p, (char **) NULL, 0)
-#else
-#define stol(p) strtol(p, (char **) NULL, 0)
-#endif
-int   unhex(FILE *ifp, char *inm, FILE *ofp, char *onm);
-int   convert_Intel_records(FILE *ifp, char *inm, FILE *ofp, char *onm);
-int   convert_S_records(FILE *ifp, char *inm, FILE *ofp, char *onm);
-int   convert_TI_records(FILE *ifp, char *inm, FILE *ofp, char *onm);
-void  write_record(buffer_rec *tb, FILE *fp);
-int   getnibble(char **p);
-int   getbyte(char **p);
-long  getNbytes(char **p, int n);
-void  badformat(char *s, char *fname, char *msg);
-void  fix_string_from_gets(char *s, size_t max);
-#define get1bytes(p)    (getbyte(p))
-#define get2bytes(p)    getNbytes(p, 2)
-#define get3bytes(p)    getNbytes(p, 3)
-#define get4bytes(p)    getNbytes(p, 4)
-char *BADADDR = "Invalid record address";
-char *BADLEN  = "Invalid record length";
-char *BADBASE = "Bad base or starting address";
-char *BADFMT =  "Unrecognized record type";
-char *BADDATA = "Invalid data byte";
-char *BADCSUM = "Invalid checksum";
-char *MISCSUM = "Checksum mismatch";
-char *BADTYPE = "Unrecognized record type";
-char *MISTYPE = "Incompatible record types";
-int main(
-  int argc,
-  char **argv
-    int c;
-    bool showusage = FALSE;                     /* usage error? */
-    int rc = 0;
-    FILE *outfp, *infp;
-    long base_long = 0;
-     * figure out invocation leaf-name
-    if ((progname = strrchr(argv[0], '/')) == (char *) NULL)
-        progname = argv[0];
-    else
-        progname++;
-    argv[0] = progname;                         /* for getopt err reporting */
-     *  Check options and arguments.
-    while ((c = getopt(argc, argv, "F:a:o:vl")) != EOF) {
-        switch (c) {
-            case 'a':                           /* base address */
-                base_long = stol(optarg);
-                if (base_long < 0) {
-                    (void) fprintf(stderr, "%s", USAGE);
-                    (void) fprintf(stderr, "\n*** base is an illegal value\n" );
-                    exit(1);
-                base = (u32) base_long;
-                break;
-            case 'l':                           /* linear output */
-                linear = TRUE;
-                break;
-            case 'v':                           /* toggle verbose */
-                verbose = ! verbose;
-                break;
-            case 'o':                           /* output file */
-                outfilename = optarg;
-                break;
-            case 'F':                           /* 0xFF fill amount (bytes) */
-                FFfill = stol(optarg) * 1024L / 8L;
-                break;
-            case '?':
-                showusage = TRUE;
-    if (showusage) {
-        exit(1);
-    if (linear && (base != 0)) {
-        error(0, "-l and -a may not be specified in combination");
-        exit(1);
-    if (STREQ(outfilename, "-")) {
-        outfp = stdout;
-        outfilename = "stdout";
-    } else if ((outfp = fopen(outfilename, "w")) == (FILE *) NULL) {
-        error(-1, "couldn't open '%s' for output", outfilename);
-        exit(1);
-     * Now process the input files (or stdin, if none specified)
-    if (argc == optind)          /* just stdin */
-        exit(unhex(stdin, "stdin", outfp, outfilename));
-    else
-        for (; optind < argc ; optind++) {
-            optarg = argv[optind];
-            if (STREQ(optarg, "-")) {
-                rc += unhex(stdin, "stdin", outfp, outfilename);
-            } else {
-                if ((infp = fopen(optarg, "r")) == (FILE *) NULL) {
-                    error(-1, "couldn't open '%s' for input", optarg);
-                    exit(1);
-                rc += unhex(infp, optarg, outfp, outfilename);
-                fclose(infp);
-    fclose(outfp);
-    return(rc);
-u16 filesum;
-int
-unhex(FILE *ifp,
-      char *inm,
-      FILE *ofp,
-      char *onm)
-    int c;
-    filesum = 0;
-     * Make sure holes will be filled with 0xFF's if requested.  We
-     *  do this the easy way by just filling the file with FF's before
-     *  getting started.  To do it more optimally would be quite a bit
-     *  more difficult since the user can skip around as much as he/she
-     *  likes in the input hex file addressing.
-     *  We'll clean this up later (after this program has run) with
-     *  'stripffs'
-    if (FFfill) {
-        (void) fseek(ofp, 0, 0);
-        for (c = FFfill; c > 0; c--)
-            (void) fputc(0xFF, ofp);
-     * Read the first char from file and determine record types
-    if ((c = getc(ifp)) != EOF) {
-        ungetc(c, ifp);
-        switch(c) {
-            case 'S':
-                convert_S_records(ifp, inm, ofp, onm);
-                break;
-            case ':':
-                convert_Intel_records(ifp, inm, ofp, onm);
-                break;
-            case '9':
-            case 'B':
-                convert_TI_records(ifp, inm, ofp, onm);
-                break;
-            default:
-                char tmp[2];
-                tmp[0] = (char) (c & 0x7f);
-                tmp[1] = 0;
-                badformat(tmp, inm, BADFMT);
-    if (verbose)
-        fprintf(stderr, "'%s' checksum is 0x%04x\n", inm, filesum);
-    return 0;
-int
-convert_Intel_records(
-    FILE *ifp,
-    char *inm,
-    FILE *ofp,
-    char *onm)
-    char buff[512];
-    char *p;
-    u8 cksum;
-    int incksum;
-    int c;
-    int rectype;                    /* record type */
-    long len;                        /* data length of current line */
-    u32 addr;
-    u32 base_address = 0;
-    bool endrecord = FALSE;
-    buffer_rec tb;
-    long getBytesStatus;
-    while ( !endrecord && (fgets(buff, sizeof(buff), ifp)) ) {
-        p = &buff[0];
-        fix_string_from_gets(p, sizeof(buff));
-        tb.dl_count = 0;
-        if (*p != ':')
-            badformat(p, inm, BADFMT);
-        p++;
-        if ((len = getbyte(&p)) == -1)      /* record len */
-            badformat(buff, inm, BADLEN);
-        if ((getBytesStatus = get2bytes(&p)) == -1L)          /* record addr */
-            badformat(buff, inm, BADADDR);
-        addr = (u32) getBytesStatus;
-        rectype = getbyte(&p);
-        cksum = len + B0(addr) + B1(addr) + rectype;
-        switch (rectype) {
-            case 0x00:                  /* normal data record */
-                tb.dl_destaddr = (u32) base_address + addr;
-                while (len--)
-                    if ((c = getbyte(&p)) == -1)
-                        badformat(buff, inm, BADDATA);
-                    cksum += c;
-                    filesum += c;
-                    tb.dl_buf[tb.dl_count++] = c;
-                break;
-            case 0x01:                  /* execution start address */
-                base_address = addr;
-                endrecord = TRUE;
-                break;
-            case 0x02:                  /* new base */
-                long blong;
-                if ((blong = get2bytes(&p)) == -1L)
-                    badformat(buff, inm, BADBASE);
-                base_address = (u32) blong;
-                cksum += B0(base_address) + B1(base_address);
-                base_address <<= 4;
-                break;
-            case 0x03:                  /* seg/off execution start address */
-                long seg, off;
-                seg = get2bytes(&p);
-                off = get2bytes(&p);
-                if ((seg == -1L) || (off == -1L))
-                cksum += B0(seg) + B1(seg) + B0(off) + B1(off);
-                tb.dl_jumpaddr = (seg << 4) + off;
-                break;
-            default:
-                error(0, "unknown Intel-hex record type: 0x%02x", rectype);
-                badformat(buff, inm, BADTYPE);
-         * Verify checksums are correct in file.
-        cksum = (-cksum) & 0xff;
-        if ((incksum = getbyte(&p)) == -1)
-            badformat(buff, inm, BADCSUM);
-        if (((u8) incksum) != cksum)
-            badformat(buff, inm, MISCSUM);
-        if (tb.dl_count)
-            write_record(&tb, ofp);
-    return 0;
-int
-convert_S_records(
-    FILE *ifp,
-    char *inm,
-    FILE *ofp,
-    char *onm)
-    char buff[512];
-    char *p;
-    u8 cksum;
-    int incksum;
-    int c;
-    long addr;
-    buffer_rec tb;
-        p = &buff[0];
-        tb.dl_count = 0;
-        if (*p != 'S')
-        p++;
-        if ((rectype = getnibble(&p)) == -1)        /* record type */
-        cksum = len;
-            case 0x00:                  /* comment field, ignored */
-                goto write_it;
-            case 0x01:                          /* data record, 16 bit addr */
-                if ((addr = get2bytes(&p)) == -1L)
-                len -= 3;
-                goto doit;
-            case 0x02:                          /* ... 24 bit addr */
-                if ((addr = get3bytes(&p)) == -1L)
-                len -= 4;
-                goto doit;
-            case 0x03:                          /* ... 32 bit addr */
-                if ((addr = get4bytes(&p)) == -1L)
-                len -= 5;
-    doit:
-                cksum += B0(addr) + B1(addr) + B2(addr) + B3(addr);
-                tb.dl_destaddr = (u32) addr;
-                while (len--) {
-                    cksum += c;
-                    filesum += c;
-                break;
-            case 0x07:                  /* 32 bit end record */
-                goto end_rec;
-            case 0x08:                  /* 24 bit end record */
-                goto end_rec;
-            case 0x09:                  /* 16 bit end record */
-end_rec:
-                tb.dl_jumpaddr = addr;
-                break;
-            default:
-                error(0, "unknown Motorola-S record type: 0x%02x", rectype);
-                break;
-        cksum = (~cksum) & 0xff;
-write_it:
-        if (tb.dl_count)
-    return 0;
-int
-convert_TI_records(
-    FILE *ifp,
-    char *inm,
-    FILE *ofp,
-    char *onm)
-    char buff[512];
-    char *p;
-    int c;
-    bool eol;
-    buffer_rec tb;
-    while ( ! endrecord && (fgets(buff, sizeof(buff), ifp))) {
-        p = &buff[0];
-        tb.dl_count = 0;
-        eol = FALSE;
-        while ( ! eol && ! endrecord) {
-            switch (*p++) {
-                case '9':
-                    if (tb.dl_count)
-                    tb.dl_destaddr = (u32) get2bytes(&p);
-                    break;
-                case 'B':
-                    c = getbyte(&p);
-                    assert( c != -1 );
-                    filesum += c;
-                    c = getbyte(&p);
-                    filesum += c;
-                    break;
-                case 'F':
-                    eol = TRUE;
-                    break;
-                case ':':
-                    endrecord = TRUE;
-                    break;
-                default:
-        if (tb.dl_count)
-    return 0;
-void
-write_record(buffer_rec *tb,
-             FILE *fp)
-    if ( ! linear) {
-        if (tb->dl_destaddr < base)
-            error(ERR_FATAL, "record at address 0x%x precedes base of 0x%x",
-                     tb->dl_destaddr, base);
-        (void) fseek(fp, tb->dl_destaddr - base, 0);
-    (void) fwrite(tb->dl_buf, tb->dl_count, 1, fp);
-    tb->dl_destaddr += tb->dl_count;
-    tb->dl_count = 0;
-int
-getnibble(char **p)
-    register int val;
-    **p = toupper(**p);
-    switch (**p) {
-        case '0': case '1': case '2': case '3': case '4':
-        case '5': case '6': case '7': case '8': case '9':
-            val = **p - '0';
-            break;
-        case 'A': case 'B': case 'C': case 'D': case 'E': case 'F':
-            val = 10 + (**p - 'A');
-            break;
-        default:
-            return(-1);
-    *p += 1;
-    return(val & 0x0f);
-int
-getbyte(char **p)
-    int n0, n1;
-    if ((n0 = getnibble(p)) == -1)
-        return(-1);
-    if ((n1 = getnibble(p)) == -1)
-        return(-1);
-    return(((n0 << 4) + n1) & 0xff);
-long
-getNbytes(char **p,
-          int n)
-    long t;
-    u32 val = 0;
-    while (n--) {
-        if ((t = getbyte(p)) == -1)
-            return(-1L);
-        val <<= 8;
-        val += (u32) t;
-    return(val);
-void
-badformat(char *s,
-          char *fname,
-          char *msg)
-    if ( *s != '\0' ) {
-      if (s[strlen(s)-1] == '\n')             /* get rid of newline */
-        s[strlen(s)-1] = '\0';
-    error(0, "line '%s'::\n\tfrom file '%s'; %s", s, fname, msg);
-    exit(1);
- * error(errn, arglist)
- *      report an error to stderr using printf(3) conventions.
- *      Any output is preceded by '<progname>: '
- * Uses ERR_EXIT  bit to request exit(errn)
- *      ERR_ABORT to request abort()
- *      ERR_ERRNO to indicate use of errno instead of argument.
- * If resulting 'errn' is non-zero, it is assumed to be an 'errno' and its
- *      associated error message is appended to the output.
-/*VARARGS*/
-void
-error(int error_flag, ...)
-    va_list arglist;
-    register char *format;
-    int local_errno;
-    (void) fflush(stdout);          /* in case stdout/stderr same */
-    local_errno = error_flag & ~ERR_MASK;
-    if (error_flag & ERR_ERRNO)     /* use errno? */
-        local_errno = errno;
-    va_start(arglist, error_flag);
-    format = va_arg(arglist, char *);
-    (void) fprintf(stderr, "%s: ", progname);
-    (void) vfprintf(stderr, format, arglist);
-    va_end(arglist);
-    if (local_errno)
-      (void) fprintf(stderr, " (%s)\n", strerror(local_errno));
-    else
-      (void) fprintf(stderr, "\n");
-    (void) fflush(stderr);
-    if (error_flag & (ERR_FATAL | ERR_ABORT)) {
-        if (error_flag & ERR_FATAL) {
-            error(0, "fatal error, exiting");
-            exit(local_errno ? local_errno : 1);
-        } else {
-            error(0, "fatal error, aborting");
-            abort();
-  size_t len;
-  assert( s );
-  if ( *s == '\0' )
-    return;
-  len = strnlen( s, max );
-  if ( s[len - 1] == '\n')                 /* get rid of newline */
-      s[len - 1] = '\0';
-  if ( s[len - 1] == '\r')                 /* get rid of any CR */
2.13.7
