[PATCH] Fix --show-commands.
Thu Jun 14 07:43:17 UTC 2018
On 14/06/18 09:40, Chris Johns wrote:
> On 14/6/18 5:34 pm, Christian Mauderer wrote:
>> Am 14.06.2018 um 09:31 schrieb Chris Johns:
>>> On 14/6/18 4:27 pm, Sebastian Huber wrote:
>>>> Hello,
>>>> On 13/06/18 13:27, Christian Mauderer wrote:
>>>>> OK. I'll have a look at all repos in the next few days where the
>>>>> submodule is used and change the URL. I'll post a message to the mailing
>>>>> lists as soon as it is done to inform the user that a "git submodule
>>>>> sync" fixes the address.
>>>> since we have to change the URL anyway, would it be possible to rename this
>>>> repository from "rtems_waf" to "rtems-waf" similar to all other RTEMS repositories?
>>> The name would have to be transformed into 'rtems_waf' in each submodule as:
>>>    import rtems-waf
>>> is not valid Python. Can git perform this type of transformation?
>>> Chris
>> Hello Chris,
>> basically it's no problem to use a URL that doesn't have the same name
>> as the directory. You just have to use a
>>    git submodule add some-url target-path-name
>> So it's not really a problem. It only means that the one adding the
>> submodule to some new repo has to use the right target path.
> This makes sense. I am OK with a name change for the repo as I like consistent
> naming so if this can be made to work that would be good.
> The README in the repo would need to be updated.
> If you want the repo's name changed please let me know. I can update cgit's config.
I think it is not user friendly. I missed the point that the
repository/directory name directly corresponds to a Python import directive.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
