[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Fri Jun 15 03:08:51 UTC 2018
On 14/06/2018 03:12, Gedare Bloom wrote:
> On Wed, Jun 13, 2018 at 12:23 PM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
>> On Wed, 13 Jun 2018, 21:39 Gedare Bloom, <gedare at rtems.org> wrote:
>>> On Wed, Jun 13, 2018 at 11:58 AM, Vijay Kumar Banerjee
>>>> On 13 June 2018 at 10:29, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Thu, Jun 7, 2018 at 7:08 AM, Vijay Kumar Banerjee
>>>>>>          bsp = opts.find_arg('--rtems-bsp')
>>>>>> +        if 'cov' in bsp[1].split('-'):
>>>>> I'm not sure if this use of the 'cov' field in the bsp config filename
>>>>> itself is the proper way to go about accomplishing the activation of
>>>>> coverage. What are other possible ways to get this done? Is the use of
>>>>> a portion of the bsp config filename done elsewhere in tester?
>>>> This patch was made following Chris' comments in another thread
>>>> https://lists.rtems.org/pipermail/devel/2018-June/021931.html
>>> I can't be sure, but I don't think his intent was to infer the
>>> coverage from the ini file name.
Correct.
>>> For example, does the tester parse
>>> the ini file name to check for 'qemu' to decide if that target is
>>> being used? Instead, it should look in to the config file to read the
>>> option somehow.
>> In leon3-qemu.ini the bsp option inside the
>> config file is set to leon3-qemu.
>> There's no such special thing added to bsp for coverage.
>> Only difference we have is that,
>> the option 'bsp_qemu_cov_opts' is added in the coverage supported file. we
>> can
>> read the config file to see if this option is present.
>> Shall I do it this way?
> Yes, I suspect you should.
Can we have 'coverage = true' in the INI file to indicate this BSP supports
coverage?
>>>>>> +            coverage_enabled = True
And that values maps to here.
