[PATCH 1/4] Reassign system initilization order numbers
Sebastian Huber
Fri Jun 15 11:13:00 UTC 2018
Assign each system initialization step a number divisible by 256 to
allow more easily future additions. Keep the order as is.
cpukit/include/rtems/sysinit.h | 78 +++++++++++++++++++++---------------------
1 file changed, 39 insertions(+), 39 deletions(-)
diff --git a/cpukit/include/rtems/sysinit.h b/cpukit/include/rtems/sysinit.h
index 535fb98e2c..93e3017358 100644
--- a/cpukit/include/rtems/sysinit.h
+++ b/cpukit/include/rtems/sysinit.h
@@ -28,45 +28,45 @@ extern "C" {
#define RTEMS_SYSINIT_BSP_WORK_AREAS 000100
#define RTEMS_SYSINIT_BSP_START 000200
-#define RTEMS_SYSINIT_INITIAL_EXTENSIONS 000300
-#define RTEMS_SYSINIT_MP_EARLY 000301
-#define RTEMS_SYSINIT_DATA_STRUCTURES 000302
-#define RTEMS_SYSINIT_MP 00030e
-#define RTEMS_SYSINIT_USER_EXTENSIONS 000320
-#define RTEMS_SYSINIT_CLASSIC_TASKS 000340
-#define RTEMS_SYSINIT_CLASSIC_TIMER 000341
-#define RTEMS_SYSINIT_CLASSIC_SIGNAL 000342
-#define RTEMS_SYSINIT_CLASSIC_EVENT 000343
-#define RTEMS_SYSINIT_CLASSIC_MESSAGE_QUEUE 000344
-#define RTEMS_SYSINIT_CLASSIC_SEMAPHORE 000345
-#define RTEMS_SYSINIT_CLASSIC_PARTITION 000346
-#define RTEMS_SYSINIT_CLASSIC_REGION 000347
-#define RTEMS_SYSINIT_CLASSIC_DUAL_PORTED_MEMORY 000348
-#define RTEMS_SYSINIT_CLASSIC_RATE_MONOTONIC 000349
-#define RTEMS_SYSINIT_CLASSIC_BARRIER 00034a
-#define RTEMS_SYSINIT_POSIX_SIGNALS 000360
-#define RTEMS_SYSINIT_POSIX_THREADS 000361
-#define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE 000364
-#define RTEMS_SYSINIT_POSIX_SEMAPHORE 000365
-#define RTEMS_SYSINIT_POSIX_TIMER 000366
-#define RTEMS_SYSINIT_POSIX_SHM 000369
-#define RTEMS_SYSINIT_POSIX_KEYS 00036a
-#define RTEMS_SYSINIT_POSIX_CLEANUP 00036b
-#define RTEMS_SYSINIT_IDLE_THREADS 000380
-#define RTEMS_SYSINIT_LIBIO 000400
-#define RTEMS_SYSINIT_ROOT_FILESYSTEM 000401
-#define RTEMS_SYSINIT_DRVMGR 000500
-#define RTEMS_SYSINIT_MP_SERVER 000501
-#define RTEMS_SYSINIT_BSP_PRE_DRIVERS 000600
-#define RTEMS_SYSINIT_DRVMGR_LEVEL_1 000700
-#define RTEMS_SYSINIT_DEVICE_DRIVERS 000701
-#define RTEMS_SYSINIT_DRVMGR_LEVEL_2 000702
-#define RTEMS_SYSINIT_DRVMGR_LEVEL_3 000703
-#define RTEMS_SYSINIT_DRVMGR_LEVEL_4 000704
-#define RTEMS_SYSINIT_MP_FINALIZE 000705
-#define RTEMS_SYSINIT_CLASSIC_USER_TASKS 000706
-#define RTEMS_SYSINIT_POSIX_USER_THREADS 000707
-#define RTEMS_SYSINIT_STD_FILE_DESCRIPTORS 000800
+#define RTEMS_SYSINIT_INITIAL_EXTENSIONS 000400
+#define RTEMS_SYSINIT_MP_EARLY 000500
+#define RTEMS_SYSINIT_DATA_STRUCTURES 000600
+#define RTEMS_SYSINIT_MP 000700
+#define RTEMS_SYSINIT_USER_EXTENSIONS 000900
+#define RTEMS_SYSINIT_CLASSIC_TASKS 000a00
+#define RTEMS_SYSINIT_CLASSIC_TIMER 000b00
+#define RTEMS_SYSINIT_CLASSIC_SIGNAL 000c00
+#define RTEMS_SYSINIT_CLASSIC_EVENT 000d00
+#define RTEMS_SYSINIT_CLASSIC_MESSAGE_QUEUE 000e00
+#define RTEMS_SYSINIT_CLASSIC_SEMAPHORE 000f00
+#define RTEMS_SYSINIT_CLASSIC_PARTITION 001000
+#define RTEMS_SYSINIT_CLASSIC_REGION 001100
+#define RTEMS_SYSINIT_CLASSIC_DUAL_PORTED_MEMORY 001200
+#define RTEMS_SYSINIT_CLASSIC_RATE_MONOTONIC 001300
+#define RTEMS_SYSINIT_CLASSIC_BARRIER 001400
+#define RTEMS_SYSINIT_POSIX_SIGNALS 001500
+#define RTEMS_SYSINIT_POSIX_THREADS 001600
+#define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE 001700
+#define RTEMS_SYSINIT_POSIX_SEMAPHORE 001800
+#define RTEMS_SYSINIT_POSIX_TIMER 001900
+#define RTEMS_SYSINIT_POSIX_SHM 001a00
+#define RTEMS_SYSINIT_POSIX_KEYS 001b00
+#define RTEMS_SYSINIT_POSIX_CLEANUP 001c00
+#define RTEMS_SYSINIT_IDLE_THREADS 001d00
+#define RTEMS_SYSINIT_LIBIO 001e00
+#define RTEMS_SYSINIT_ROOT_FILESYSTEM 001f00
+#define RTEMS_SYSINIT_DRVMGR 002000
+#define RTEMS_SYSINIT_MP_SERVER 002100
+#define RTEMS_SYSINIT_BSP_PRE_DRIVERS 002200
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_1 002300
+#define RTEMS_SYSINIT_DEVICE_DRIVERS 002400
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_2 002500
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_3 002600
+#define RTEMS_SYSINIT_DRVMGR_LEVEL_4 002700
+#define RTEMS_SYSINIT_MP_FINALIZE 002800
+#define RTEMS_SYSINIT_CLASSIC_USER_TASKS 002900
+#define RTEMS_SYSINIT_POSIX_USER_THREADS 002a00
+#define RTEMS_SYSINIT_STD_FILE_DESCRIPTORS 002b00
#define RTEMS_SYSINIT_LAST ffffff
2.13.7
