error while building from RSB
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Jun 15 17:05:33 UTC 2018
On Fri, 15 Jun 2018 at 17:49, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello,
> While trying to freshly build RTEMS from RSB with the following command
> `../source-builder/sb-set-builder \
> --prefix=/home/lunatic/development/rtems/5 5/rtems-sparc"
> I'm getting the following error :
> error: downloading https://gaisler.org/gdb/gdb-8.0.1-sis-leon2-leon3.diff:
> all paths have failed, giving up
> Build FAILED
Yeah gailser.org does seem to be down. You could grep for that patch in rsb
and comment it out and just build without it. You're using qemu to run it
so I don't think the gdb patch is necessary.
> The url doesn't seem to work when I open from browser.
> -- vijay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180615/a869fb8f/attachment-0001.html>
