error while building from RSB
Fri Jun 15 20:20:41 UTC 2018
Hello there,
someone on IRC mentions that www.gaisler.com works still. Maybe try
changing the URL to that one?
On Fri, Jun 15, 2018 at 1:09 PM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> On Fri, 15 Jun 2018, 22:35 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
>> On Fri, 15 Jun 2018 at 17:49, Vijay Kumar Banerjee
>>> Hello,
>>> While trying to freshly build RTEMS from RSB with the following command
>>> `../source-builder/sb-set-builder \
>>> --prefix=/home/lunatic/development/rtems/5 5/rtems-sparc"
>>> I'm getting the following error :
>>> error: downloading
>>> https://gaisler.org/gdb/gdb-8.0.1-sis-leon2-leon3.diff: all paths have
>>> failed, giving up
>>> Build FAILED
>> Yeah gailser.org does seem to be down. You could grep for that patch in
>> rsb and comment it out and just build without it. You're using qemu to run
>> it so I don't think the gdb patch is necessary.
> Will do it. Thanks. :)
>>> The url doesn't seem to work when I open from browser.
>>> -- vijay
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
