error while building from RSB
Joel Sherrill
joel at rtems.org
Sat Jun 16 05:56:25 UTC 2018
On Fri, Jun 15, 2018, 10:37 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On 16 June 2018 at 01:50, Gedare Bloom <gedare at rtems.org> wrote:
>> Hello there,
>> someone on IRC mentions that www.gaisler.com works still. Maybe try
>> changing the URL to that one?
>> https://www.gaisler.com/gdb/gdb-8.0.1-sis-leon2-leon3.diff
> returns 404
>> On Fri, Jun 15, 2018 at 1:09 PM, Vijay Kumar Banerjee
>> <vijaykumar9597 at gmail.com> wrote:
>> > On Fri, 15 Jun 2018, 22:35 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>> wrote:
>> >> On Fri, 15 Jun 2018 at 17:49, Vijay Kumar Banerjee
>> >>> Hello,
>> >>> While trying to freshly build RTEMS from RSB with the following
>> command
>> >>> `../source-builder/sb-set-builder \
>> >>> --prefix=/home/lunatic/development/rtems/5 5/rtems-sparc"
>> >>> I'm getting the following error :
>> >>> error: downloading
>> >>> https://gaisler.org/gdb/gdb-8.0.1-sis-leon2-leon3.diff: all paths
>> have
>> >>> failed, giving up
>> >>> Build FAILED
>> >> Yeah gailser.org does seem to be down. You could grep for that patch
>> in
>> >> rsb and comment it out and just build without it. You're using qemu to
>> run
>> >> it so I don't think the gdb patch is necessary.
These patches should be on RTEMS.org. Those patches are on Jiri's home
server
>> > Will do it. Thanks. :)
>> >>> The url doesn't seem to work when I open from browser.
>> >>> -- vijay
>> >>> _______________________________________________
>> >>> devel mailing list
>> >>> devel at rtems.org
>> >>> http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180616/ed2f5915/attachment-0001.html>
