[PATCH v3 06/22] rtemstoolkit/elf: Add data size and endian support to the ELF interface.
Mon Jun 18 02:29:04 UTC 2018
 rtemstoolkit/rld-elf.cpp | 22 ++++++++++++++++++++++
 rtemstoolkit/rld-elf.h   | 10 ++++++++++
 2 files changed, 32 insertions(+)
diff --git a/rtemstoolkit/rld-elf.cpp b/rtemstoolkit/rld-elf.cpp
index 2d3d090..60ba484 100644
--- a/rtemstoolkit/rld-elf.cpp
+++ b/rtemstoolkit/rld-elf.cpp
@@ -1082,6 +1082,28 @@ namespace rld
       return writable;
+    size_t
+    file::machine_size () const
+      size_t bytes;
+      switch (object_class ())
+      case ELFCLASS64:
+        bytes = sizeof (uint64_t);
+        break;
+      default:
+        bytes = sizeof (uint32_t);
+        break;
+      return bytes;
+    bool
+    file::is_little_endian () const
+      return data_type () == ELFDATA2LSB;
     void
     file::check (const char* where) const
diff --git a/rtemstoolkit/rld-elf.h b/rtemstoolkit/rld-elf.h
index 92e92c1..4919135 100644
--- a/rtemstoolkit/rld-elf.h
+++ b/rtemstoolkit/rld-elf.h
@@ -655,6 +655,16 @@ namespace rld
       void reference_release ();
+       * Get the machine size in bytes.
+      size_t machine_size () const;
+       * Returns true if little endian.
+      bool is_little_endian () const;
     private:
2.15.1
