[PATCH v3 11/22] tester/covoar: Remove all exit() calls and throw an rld::error exception.
Mon Jun 18 02:29:09 UTC 2018
Add a suitable catch to covoar's main.
 tester/covoar/CoverageFactory.cc      |  13 +-
 tester/covoar/CoverageReaderQEMU.cc   |  55 +++----
 tester/covoar/CoverageReaderRTEMS.cc  |  59 +++-----
 tester/covoar/CoverageReaderSkyeye.cc |  57 +++----
 tester/covoar/CoverageReaderTSIM.cc   |  39 ++---
 tester/covoar/CoverageWriterRTEMS.cc  |  50 +++----
 tester/covoar/CoverageWriterSkyeye.cc |  54 +++----
 tester/covoar/CoverageWriterTSIM.cc   |  51 ++++---
 tester/covoar/DesiredSymbols.cc       |  43 ++----
 tester/covoar/DesiredSymbols.h        |   3 +-
 tester/covoar/ExecutableInfo.cc       |  20 +--
 tester/covoar/Explanations.cc         |  87 +++++------
 tester/covoar/ObjdumpProcessor.cc     |  23 ++-
 tester/covoar/ReportsHtml.cc          | 275 +++++++++++++++++-----------------
 tester/covoar/SymbolTable.cc          |  18 ++-
 tester/covoar/TargetBase.cc           |  29 ++--
 tester/covoar/TargetFactory.cc        |  23 ++-
 tester/covoar/Target_arm.cc           |  22 ++-
 tester/covoar/Target_m68k.cc          |  24 +--
 tester/covoar/Target_powerpc.cc       |  19 ++-
 tester/covoar/TraceConverter.cc       |   6 +-
 tester/covoar/TraceWriterQEMU.cc      |  55 +++----
 tester/covoar/covoar.cc               | 232 ++++++++++++++++------------
 23 files changed, 608 insertions(+), 649 deletions(-)
diff --git a/tester/covoar/CoverageFactory.cc b/tester/covoar/CoverageFactory.cc
index 8b30371..991ba8f 100644
--- a/tester/covoar/CoverageFactory.cc
+++ b/tester/covoar/CoverageFactory.cc
@@ -10,6 +10,8 @@
+#include <rld.h>
 #include "CoverageFactory.h"
 #include "CoverageReaderQEMU.h"
 #include "CoverageReaderRTEMS.h"
@@ -35,13 +37,10 @@ Coverage::CoverageFormats_t Coverage::CoverageFormatToEnum(
   if (!strcmp( format, "TSIM" ))
     return COVERAGE_FORMAT_TSIM;
-  fprintf(
-    stderr,
-    "ERROR: %s is an unknown coverage format "
-    "(supported formats - QEMU, RTEMS, Skyeye and TSIM)\n",
-    format
-  exit( 1 );
+  std::ostringstream what;
+  what << format << " is an unknown coverage format "
+       << "(supported formats - QEMU, RTEMS, Skyeye and TSIM)";
+  throw rld::error( what, "Coverage" );
 Coverage::CoverageReaderBase* Coverage::CreateCoverageReader(
diff --git a/tester/covoar/CoverageReaderQEMU.cc b/tester/covoar/CoverageReaderQEMU.cc
index 37718ec..3d3b50f 100644
--- a/tester/covoar/CoverageReaderQEMU.cc
+++ b/tester/covoar/CoverageReaderQEMU.cc
@@ -9,8 +9,11 @@
+#include <stdio.h>
 #include <sys/stat.h>
+#include <rld.h>
 #include "app_common.h"
 #include "CoverageMap.h"
@@ -48,57 +51,33 @@ namespace Coverage {
     uint8_t             notTaken;
     uint8_t             branchInfo;
-    taken    = TargetInfo->qemuTakenBit();
-    notTaken = TargetInfo->qemuNotTakenBit();
+    taken      = TargetInfo->qemuTakenBit();
+    notTaken   = TargetInfo->qemuNotTakenBit();
     branchInfo = taken | notTaken;
     // Open the coverage file and read the header.
-    traceFile = OPEN( file, "r" );
+    traceFile = ::OPEN( file, "r" );
     if (!traceFile) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderQEMU::processFile - Unable to open %s\n",
-        file
-      exit( -1 );
+      what << "Unable to open " << file;
+      throw rld::error( what, "CoverageReaderQEMU::processFile" );
-    status = fread( &header, sizeof(trace_header), 1, traceFile );
+    status = ::fread( &header, sizeof(trace_header), 1, traceFile );
     if (status != 1) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderQEMU::processFile - "
-        "Unable to read header from %s\n",
-        file
-      exit( -1 );
+      ::fclose( traceFile );
+      what << "Unable to read header from " << file;
-    #if 0
-      fprintf(
-        stderr,
-        "magic = %s\n"
-        "version = %d\n"
-        "kind = %d\n"
-        "sizeof_target_pc = %d\n"
-        "big_endian = %d\n"
-        "machine = %02x:%02x\n",
-        header.magic,
-        header.version,
-        header.kind,
-        header.sizeof_target_pc,
-        header.big_endian,
-        header.machine[0], header.machine[1]
-    #endif
     // Read ENTRIES number of trace entries.
 #define ENTRIES 1024
-    while (1) {
+    while (true) {
       CoverageMapBase     *aCoverageMap = NULL;
       struct trace_entry  entries[ENTRIES];
       struct trace_entry  *entry;
@@ -106,7 +85,7 @@ namespace Coverage {
       // Read and process each line of the coverage file.
-      num_entries = fread(
+      num_entries = ::fread(
         entries,
         sizeof(struct trace_entry),
         ENTRIES,
@@ -149,6 +128,6 @@ namespace Coverage {
-    fclose( traceFile );
diff --git a/tester/covoar/CoverageReaderRTEMS.cc b/tester/covoar/CoverageReaderRTEMS.cc
index 8439c41..a9e8ae8 100644
--- a/tester/covoar/CoverageReaderRTEMS.cc
+++ b/tester/covoar/CoverageReaderRTEMS.cc
@@ -9,6 +9,11 @@
+#include <iostream>
+#include <iomanip>
+#include <rld.h>
 #include "ExecutableInfo.h"
@@ -41,54 +46,36 @@ namespace Coverage {
-    coverageFile = fopen( file, "r" );
+    coverageFile = ::fopen( file, "r" );
     if (!coverageFile) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderRTEMS::processFile - Unable to open %s\n",
-        file
-      exit( -1 );
+      throw rld::error( what, "CoverageReaderRTEMS::processFile" );
-    status = fread( &header, sizeof(header), 1, coverageFile );
+    status = ::fread( &header, sizeof(header), 1, coverageFile );
     if (status != 1) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderRTEMS::processFile - "
-        file
-      exit( -1 );
+      ::fclose( coverageFile );
     baseAddress = header.start;
     length      = header.end - header.start;
-    #if 0
-    fprintf(
-      stderr,
-      "%s: 0x%08x 0x%08x 0x%08lx/%ld\n",
-      file,
-      header.start,
-      header.end,
-      (unsigned long) length,
-    #endif
-    for (i=0; i<length; i++) {
-      status = fread( &cover, sizeof(uint8_t), 1, coverageFile );
+    for (i = 0; i < length; i++) {
+      status = ::fread( &cover, sizeof(uint8_t), 1, coverageFile );
       if (status != 1) {
-        fprintf(
-          stderr,
-          "CoverageReaderRTEMS::ProcessFile - breaking after 0x%08x in %s\n",
-          (unsigned int) i,
-          file
+        std::cerr << "breaking after 0x"
+                  << std::hex << std::setfill('0')
+                  << std::setw(8) << i
+                  << std::setfill(' ') << std::dec
+                  << " in " << file
+                  << std::endl;
         break;
@@ -103,6 +90,6 @@ namespace Coverage {
-    fclose( coverageFile );
diff --git a/tester/covoar/CoverageReaderSkyeye.cc b/tester/covoar/CoverageReaderSkyeye.cc
index 293aef3..0fe33d7 100644
--- a/tester/covoar/CoverageReaderSkyeye.cc
+++ b/tester/covoar/CoverageReaderSkyeye.cc
@@ -9,6 +9,9 @@
+#include <iomanip>
 #include "CoverageReaderSkyeye.h"
@@ -41,54 +44,36 @@ namespace Coverage {
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderSkyeye::processFile - Unable to open %s\n",
-        file
-      exit( -1 );
+      throw rld::error( what, "CoverageReaderSkyeye::processFile" );
     if (status != 1) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderSkyeye::processFile - "
-        file
-      exit( -1 );
     baseAddress = header.prof_start;
     length      = header.prof_end - header.prof_start;
-    #if 0
-    fprintf(
-      stderr,
-      file,
-      header.prof_start,
-      header.prof_end,
-    #endif
-    for (i=0; i<length; i+=8) {
+    for (i = 0; i < length; i += 8) {
       if (status != 1) {
-        fprintf(
-	  stderr,
-	  "CoverageReaderSkyeye::ProcessFile - breaking after 0x%08x in %s\n",
-	  (unsigned int) i,
-          file
+        std::cerr << "CoverageReaderSkyeye::ProcessFile - breaking after 0x"
+                  << " in " << file
+                  << std::endl;
         break;
@@ -121,6 +106,6 @@ namespace Coverage {
diff --git a/tester/covoar/CoverageReaderTSIM.cc b/tester/covoar/CoverageReaderTSIM.cc
index b1a2acb..d8b738e 100644
--- a/tester/covoar/CoverageReaderTSIM.cc
+++ b/tester/covoar/CoverageReaderTSIM.cc
@@ -9,6 +9,11 @@
+#include <iomanip>
+#include <rld.h>
 #include "CoverageReaderTSIM.h"
@@ -40,35 +45,33 @@ namespace Coverage {
     // Open the coverage file.
-      fprintf(
-        stderr,
-        "ERROR: CoverageReaderTSIM::processFile - Unable to open %s\n",
-        file
-      exit( -1 );
+      throw rld::error( what, "CoverageReaderTSIM::processFile" );
-    while ( 1 ) {
-      status = fscanf( coverageFile, "%x : ", &baseAddress );
+    while ( true ) {
+      status = ::fscanf( coverageFile, "%x : ", &baseAddress );
       if (status == EOF || status == 0) {
         break;
-      for (i=0; i < 0x80; i+=4) {
+      for (i = 0; i < 0x80; i += 4) {
         unsigned int a;
-        status = fscanf( coverageFile, "%x", &cover );
+        status = ::fscanf( coverageFile, "%x", &cover );
-          fprintf(
-            stderr,
-            "CoverageReaderTSIM: WARNING! Short line in %s at address 0x%08x\n",
-            file,
-            baseAddress
+          std::cerr << "CoverageReaderTSIM: WARNING! Short line in "
+                    << file
+                    << " at address 0x"
+                    << baseAddress
+                    << std::endl;
           break;
@@ -97,6 +100,6 @@ namespace Coverage {
diff --git a/tester/covoar/CoverageWriterRTEMS.cc b/tester/covoar/CoverageWriterRTEMS.cc
index 7a5150f..48e8fd1 100644
--- a/tester/covoar/CoverageWriterRTEMS.cc
+++ b/tester/covoar/CoverageWriterRTEMS.cc
@@ -9,11 +9,16 @@
+#include <iomanip>
+#include <rld.h>
 #include "CoverageWriterRTEMS.h"
 #include "rtemscov_header.h"
   CoverageWriterRTEMS::CoverageWriterRTEMS()
@@ -38,14 +43,11 @@ namespace Coverage {
      *  read the file and update the coverage map passed in
-    coverageFile = fopen( file, "w" );
+    coverageFile = ::fopen( file, "w" );
     if ( !coverageFile ) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageWriterRTEMS::writeFile - unable to open %s\n",
-        file
-      exit(-1);
+      throw rld::error( what, "CoverageWriterRTEMS::writeFile" );
     /* clear out the header and fill it in */
@@ -56,33 +58,29 @@ namespace Coverage {
     header.end           = highAddress;
     strcpy( header.desc, "RTEMS Coverage Data" );
-    status = fwrite(&header, 1, sizeof(header), coverageFile);
+    status = ::fwrite(&header, 1, sizeof(header), coverageFile);
     if (status != sizeof(header)) {
-      fprintf(
-        stderr,
-        "ERROR: CoverageWriterRTEMS::writeFile - unable to write header "
-        "to %s\n",
-        file
-      exit(-1);
+      what << "Unable to write header to " << file;
     for ( a=lowAddress ; a < highAddress ; a++ ) {
       cover  = ((coverage->wasExecuted( a ))     ? 0x01 : 0);
       status = fwrite(&cover, 1, sizeof(cover), coverageFile);
       if (status != sizeof(cover)) {
-        fprintf(
-          stderr,
-          "ERROR: CoverageWriterRTEMS::writeFile - write to %s "
-          "at address 0x%08x failed\n",
-          file,
-          a
-        exit( -1 );
+        std::cerr << "CoverageWriterRTEMS::writeFile - write to "
+                  << file
+                  << " at address 0x%"
+                  << std::setw(8) << a
+                  << " failed"
+                  << std::endl;
-      // fprintf( stderr, "0x%x %d\n", a, cover );
diff --git a/tester/covoar/CoverageWriterSkyeye.cc b/tester/covoar/CoverageWriterSkyeye.cc
index e0aa943..7f78644 100644
--- a/tester/covoar/CoverageWriterSkyeye.cc
+++ b/tester/covoar/CoverageWriterSkyeye.cc
@@ -8,13 +8,19 @@
+#include <stdio.h>
+#include <iomanip>
+#include <rld.h>
 #include "CoverageWriterSkyeye.h"
 #include "skyeye_header.h"
   CoverageWriterSkyeye::CoverageWriterSkyeye()
@@ -39,14 +45,11 @@ namespace Coverage {
-      fprintf(
-        stderr,
-        "ERROR: CoverageWriterSkyeye::writeFile - unable to open %s\n",
-        file
-      exit(-1);
+      throw rld::error( what, "CoverageWriterSkyeye::writeFile" );
@@ -57,34 +60,31 @@ namespace Coverage {
     header.prof_end      = highAddress;
     strcpy( header.desc, "Skyeye Coverage Data" );
-      fprintf(
-        stderr,
-        "ERROR: CoverageWriterSkyeye::writeFile - unable to write header "
-        "to %s\n",
-        file
-      exit(-1);
-    for ( a=lowAddress ; a < highAddress ; a+= 8 ) {
+    for ( a = lowAddress; a < highAddress; a += 8 ) {
       cover |= ((coverage->wasExecuted( a + 4 )) ? 0x10 : 0);
-	fprintf(
-          stderr,
-          "ERROR: CoverageWriterSkyeye::writeFile - write to %s "
-          file,
-          a
-	exit( -1 );
+        what << "write to " << file
+             << "failed";
diff --git a/tester/covoar/CoverageWriterTSIM.cc b/tester/covoar/CoverageWriterTSIM.cc
index ec7c5b4..a4731a9 100644
--- a/tester/covoar/CoverageWriterTSIM.cc
+++ b/tester/covoar/CoverageWriterTSIM.cc
@@ -8,10 +8,15 @@
+#include <iomanip>
+#include <rld.h>
 #include "CoverageWriterTSIM.h"
   CoverageWriterTSIM::CoverageWriterTSIM()
@@ -20,7 +25,7 @@ namespace Coverage {
   void CoverageWriterTSIM::writeFile(
     const char* const file,
     CoverageMapBase*  coverage,
@@ -37,42 +42,36 @@ namespace Coverage {
-      fprintf(
-        stderr,
-        "ERROR: CoverageWriterTSIM::writeFile - unable to open %s\n",
-        file
-      exit(-1);
+      throw rld::error( what, "CoverageWriterTSIM::writeFile" );
-    for ( a=lowAddress ; a < highAddress ; a+= 0x80 ) {
+    for ( a = lowAddress; a < highAddress; a += 0x80 ) {
       status = fprintf( coverageFile, "%x : ", a );
       if ( status == EOF || status == 0 ) {
         break;
-      // fprintf( stderr, "%08x : ", baseAddress );
-      for ( i=0 ; i < 0x80 ; i+=4 ) {
+      for ( i = 0; i < 0x80; i += 4 ) {
         cover = ((coverage->wasExecuted( a + i )) ? 1 : 0);
-        status = fprintf( coverageFile, "%d ", cover );
+        status = ::fprintf( coverageFile, "%d ", cover );
-          fprintf(
-            stderr,
-            "ERROR: CoverageWriterTSIM:writeFile - write to %s "
-            file,
-            a
-	  exit( -1 );
+               << "failed";
-        // fprintf( stderr, "%d ", cover );
-      fprintf( coverageFile, "\n" );
-      // fprintf( stderr, "\n" );
+      ::fprintf( coverageFile, "\n" );
diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
index 84296f7..a38860a 100644
--- a/tester/covoar/DesiredSymbols.cc
+++ b/tester/covoar/DesiredSymbols.cc
@@ -37,7 +37,7 @@ namespace Coverage {
-  bool DesiredSymbols::load(
+  void DesiredSymbols::load(
     const std::string& symbolsSet,
     const std::string& buildTarget,
     const std::string& buildBSP,
@@ -45,7 +45,6 @@ namespace Coverage {
     rld::files::cache cache;
-    bool              r = true;
     // Load the INI file looking for a top level:
@@ -103,20 +102,12 @@ namespace Coverage {
         const rld::symbols::symbol& sym = *(kv.second);
         set[sym.name()] = *(new SymbolInformation);
-    } catch (rld::error re) {
-      std::cerr << "error: "
-                << re.where << ": " << re.what
-                << std::endl;
-      r = false;
     } catch (...) {
       cache.close();
       throw;
     cache.close();
-    return r;
   void DesiredSymbols::preprocess( void )
@@ -332,12 +323,11 @@ namespace Coverage {
     symbolSet_t::iterator itr = set.find( symbolName );
     if (itr == set.end()) {
-      std::cerr << "ERROR: DesiredSymbols::createCoverageMap - Unable to create "
-                << "unified coverage map for "
-                << symbolName
-                << " because it is NOT a desired symbol"
-                << std::endl;
-      exit( -1 );
+      what << "Unable to create unified coverage map for "
+           << symbolName
+           << " because it is NOT a desired symbol";
+      throw rld::error( what, "DesiredSymbols::createCoverageMap" );
     // If we have already created a coverage map, ...
@@ -373,17 +363,6 @@ namespace Coverage {
       highAddress = size - 1;
       aCoverageMap = new CoverageMap( exefileName, 0, highAddress );
-      if (!aCoverageMap) {
-        fprintf(
-          stderr,
-          "ERROR: DesiredSymbols::createCoverageMap - Unable to allocate "
-          "coverage map for %s:%s\n",
-          exefileName.c_str(),
-          symbolName.c_str()
-        exit( -1 );
       if ( Verbose )
         fprintf(
@@ -490,11 +469,11 @@ namespace Coverage {
-      std::cerr << "ERROR: DesiredSymbols::mergeCoverageMap - Unable to merge "
-                << "coverage map for %s because it is NOT a desired symbol"
-                << symbolName
-                << std::endl;
-      exit( -1 );
+      what << "Unable to merge coverage map for "
+           << symbolName
+      throw rld::error( what, "DesiredSymbols::mergeCoverageMap" );
     // Ensure that the source and destination coverage maps
diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
index 21c5602..5c45af8 100644
--- a/tester/covoar/DesiredSymbols.h
+++ b/tester/covoar/DesiredSymbols.h
@@ -297,9 +297,8 @@ namespace Coverage {
      *  @param[in] symbolsSet An INI format file of the symbols to be loaded.
      *  @param[in] buildTarget The build target
      *  @param[in] buildBSP The BSP
-     *  @return Returns false if the load fails.
-    bool load(
+    void load(
diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
index 1755e93..b1eba68 100644
--- a/tester/covoar/ExecutableInfo.cc
+++ b/tester/covoar/ExecutableInfo.cc
@@ -25,20 +25,12 @@ namespace Coverage {
     if (theLibraryName)
       libraryName = theLibraryName;
-    try {
-      executable.open();
-      executable.begin();
-      executable.load_symbols(symbols);
-      debug.begin(executable.elf());
-      debug.load_debug();
-                << std::endl;
-      exit(2);
-    } catch (...) {
-      exit(2);
+    executable.open();
+    executable.begin();
+    executable.load_symbols(symbols);
+    debug.begin(executable.elf());
+    debug.load_debug();
   ExecutableInfo::~ExecutableInfo()
diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
index c316a0b..2050b84 100644
--- a/tester/covoar/Explanations.cc
+++ b/tester/covoar/Explanations.cc
@@ -1,7 +1,7 @@
 /*! @file Explanations.cc
  *  @brief Explanations Implementation
- *  This file contains the implementation of the functions
+ *  This file contains the implementation of the functions
  *  which provide a base level of functionality of a Explanations.
@@ -10,6 +10,8 @@
 #include <unistd.h>
+#include <rld.h>
 #include "Explanations.h"
@@ -36,14 +38,11 @@ namespace Coverage {
     if (!explanations)
       return;
-    explain = fopen( explanations, "r" );
+    explain = ::fopen( explanations, "r" );
     if (!explain) {
-      fprintf(
-        stderr,
-        "ERROR: Explanations::load - unable to open explanations file %s\n",
-        explanations
-      exit(-1);
+      what << "Unable to open " << explanations;
+      throw rld::error( what, "Explanations::load" );
     while ( 1 ) {
@@ -62,47 +61,38 @@ namespace Coverage {
       // Have we already seen this one?
       if (set.find( inputBuffer ) != set.end()) {
-        fprintf(
-          stderr,
-          "ERROR: Explanations::load - line %d "
-          "contains a duplicate explanation (%s)\n",
-          line,
-          inputBuffer
-        exit( -1 );
+        what << "line " << line
+             << "contains a duplicate explanation ("
+             << inputBuffer << ")";
       // Add the starting line and file
       e->startingPoint = std::string(inputBuffer);
       e->found = false;
-      // Get the classification
+      // Get the classification
       cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, explain );
       if (cStatus == NULL) {
-        fprintf(
-          stderr,
-          "out of sync at the classification\n",
-          line
-        exit( -1 );
+             << "out of sync at the classification";
       inputBuffer[ strlen(inputBuffer) - 1] = '\0';
       e->classification = inputBuffer;
       line++;
-      // Get the explanation
+      // Get the explanation
       while (1) {
         // fprintf( stderr, "%d - %s\n", line, inputBuffer );
-          fprintf(
-            stderr,
-            "out of sync at the explanation\n",
-            line
-          exit( -1 );
+               << "out of sync at the explanation";
         line++;
@@ -130,10 +120,8 @@ done:
     if (set.find( start ) == set.end()) {
       #if 0
-        fprintf( stderr,
-          "Warning: Unable to find explanation for %s\n",
-          start.c_str()
+        std::cerr << "Warning: Unable to find explanation for "
+                  << start << std::endl;
       #endif
       return NULL;
@@ -150,23 +138,21 @@ done:
     if (!fileName)
       return;
     notFoundFile = fopen( fileName, "w" );
     if (!fileName) {
-      fprintf(
-        stderr,
-        "ERROR: Explanations::writeNotFound - unable to open file %s\n",
-        fileName
-      exit( -1 );
+      what << "Unable to open " << fileName
+      throw rld::error( what, "Explanations::writeNotFound" );
     for (std::map<std::string, Explanation>::iterator itr = set.begin();
          itr != set.end();
          itr++) {
       Explanation e = (*itr).second;
       std::string key = (*itr).first;
       if (!e.found) {
         notFoundOccurred = true;
         fprintf(
@@ -174,18 +160,17 @@ done:
           "%s\n",
           e.startingPoint.c_str()
     fclose( notFoundFile );
     if (!notFoundOccurred) {
       if (!unlink( fileName )) {
-        fprintf( stderr,
-          "Warning: Unable to unlink %s\n\n",
-          fileName
+        std::cerr << "Warning: Unable to unlink " << fileName
+                  << std::endl
+                  << std::endl;
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index d41906c..c98dad7 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -149,26 +149,23 @@ namespace Coverage {
     dlinfoName += ".dlinfo";
     // Read load address.
-    loadAddressFile = fopen( dlinfoName.c_str(), "r" );
+    loadAddressFile = ::fopen( dlinfoName.c_str(), "r" );
     if (!loadAddressFile) {
-      fprintf( stderr, METHOD "unable to open %s\n", dlinfoName.c_str() );
-      exit( -1 );
+      what << "Unable to open " << dlinfoName;
+      throw rld::error( what, METHOD );
     // Process the dlinfo file.
     while ( 1 ) {
       // Get a line.
-      cStatus = fgets( inputBuffer, MAX_LINE_LENGTH, loadAddressFile );
+      cStatus = ::fgets( inputBuffer, MAX_LINE_LENGTH, loadAddressFile );
-        fprintf(
-          stderr,
-          METHOD "library %s not found in %s\n",
-          Library.c_str(),
-          dlinfoName.c_str()
-        fclose( loadAddressFile );
-        exit( -1 );
+        ::fclose( loadAddressFile );
+        what << "library " << Library << " not found in " << dlinfoName;
       sscanf( inputBuffer, "%s %x", inLibName, &offset );
       std::string tmp = inLibName;
@@ -179,7 +176,7 @@ namespace Coverage {
     return address;
     #undef METHOD
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index 247253c..ebc6ee0 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -2,6 +2,8 @@
+#include <rld.h>
 #include "ReportsHtml.h"
 #include "CoverageRanges.h"
@@ -24,7 +26,7 @@
    "</tfoot>\n"
 #else
 #define TABLE_HEADER_CLASS
-#define TABLE_FOOTER
+#define TABLE_FOOTER
 #endif
@@ -56,7 +58,7 @@ namespace Coverage {
         _t, _n );
     FILE*  aFile;
     // Open the file
     aFile = OpenFile( fileName );
@@ -77,7 +79,7 @@ namespace Coverage {
       aFile,
       "Coverage Analysis Reports</div>\n"
       "<div class =\"datetime\">%s</div>\n",
-      asctime( localtime(&timestamp_m) )
+      asctime( localtime(&timestamp_m) )
     fprintf( aFile, "<ul>\n" );
@@ -109,7 +111,7 @@ namespace Coverage {
     FILE*  aFile;
     // Open the file
     aFile = ReportsBase::OpenFile( fileName );
@@ -154,7 +156,7 @@ namespace Coverage {
       "<body>\n"
       "<pre class=\"code\">\n",
     return aFile;
@@ -206,10 +208,10 @@ namespace Coverage {
         "</tr>\n"
         "</thead>\n"
         "<tbody>\n",
     return aFile;
@@ -255,7 +257,7 @@ namespace Coverage {
       "</tr>\n"
       "</thead>\n"
       "<tbody>\n",
@@ -298,7 +300,7 @@ namespace Coverage {
       "</tr>\n"
       "</thead>\n"
       "<tbody>\n",
@@ -346,7 +348,7 @@ namespace Coverage {
       "</tr>\n"
       "</thead>\n"
       "<tbody>\n",
     return aFile;
@@ -398,7 +400,7 @@ namespace Coverage {
       "</tr>\n"
       "</thead>\n"
       "<tbody>\n",
     return aFile;
@@ -408,29 +410,29 @@ namespace Coverage {
     FILE*                aFile
-    fprintf(
+    fprintf(
       aFile,
-      "<hr>\n"
+      "<hr>\n"
   void ReportsHtml::AnnotatedEnd(
     FILE*                aFile
-  void ReportsHtml::PutAnnotatedLine(
-    FILE*                aFile,
-    AnnotatedLineState_t state,
-    std::string          line,
-    uint32_t             id
+  void ReportsHtml::PutAnnotatedLine(
+    FILE*                aFile,
+    AnnotatedLineState_t state,
+    std::string          line,
+    uint32_t             id
     std::string stateText;
     char        number[10];
     sprintf(number,"%d", id);
     // Set the stateText based upon the current state.
@@ -460,8 +462,7 @@ namespace Coverage {
         stateText += "\"></a><pre class=\"codeNeverTaken\">\n";
         break;
       default:
-        fprintf(stderr, "ERROR:  ReportsHtml::PutAnnotatedLine Unknown state\n");
-        exit( -1 );
+        throw rld::error( "Unknown state", "ReportsHtml::PutAnnotatedLine");
         break;
@@ -517,16 +518,16 @@ namespace Coverage {
       fprintf( report, "<tr>\n");
     // symbol
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
+    fprintf(
+      report,
+      "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
       symbolPtr->first.c_str()
     // line
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s</td>\n",
+    fprintf(
+      report,
+      "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s</td>\n",
       rangePtr->id,
       rangePtr->lowSourceLine.c_str()
@@ -534,15 +535,15 @@ namespace Coverage {
     // File
     i = rangePtr->lowSourceLine.find(":");
     temp =  rangePtr->lowSourceLine.substr (0, i);
-    fprintf(
-      report,
+    fprintf(
+      report,
       temp.c_str()
     // Size in bytes
-    fprintf(
-      report,
+    fprintf(
+      report,
       "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
       rangePtr->highAddress - rangePtr->lowAddress + 1
@@ -550,14 +551,14 @@ namespace Coverage {
     // Reason Branch was uncovered
     if (rangePtr->reason ==
       Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN)
-      fprintf(
+      fprintf(
         report,
         "<td class=\"covoar-td\" align=\"center\">Always Taken</td>\n"
     else if (rangePtr->reason ==
       Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN)
-      fprintf(
-        report,
+      fprintf(
+        report,
         "<td class=\"covoar-td\" align=\"center\">Never Taken</td>\n"
@@ -581,16 +582,16 @@ namespace Coverage {
     explanation = AllExplanations->lookupExplanation( rangePtr->lowSourceLine );
     if ( !explanation ) {
       // Write Classificationditr->second.baseAddress
-      fprintf(
-        report,
+      fprintf(
+        report,
         "<td class=\"covoar-td\" align=\"center\">NONE</td>\n"
         "<td class=\"covoar-td\" align=\"center\">No Explanation</td>\n"
     } else {
       char explanationFile[48];
       sprintf( explanationFile, "explanation%d.html", rangePtr->id );
-      fprintf(
-        report,
+      fprintf(
+        report,
         "<td class=\"covoar-td\" align=\"center\">"
         "<a href=\"%s\">Explanation</a></td>\n",
@@ -653,44 +654,44 @@ namespace Coverage {
     // symbol
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol.c_str()
-    fprintf(
-      noRangeFile,
+    fprintf(
+      noRangeFile,
       symbol.c_str()
     // starting line
-    fprintf(
-      report,
+    fprintf(
+      report,
       "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
     // file
-    fprintf(
-      report,
+    fprintf(
+      report,
      // Size in bytes
-    fprintf(
-      report,
+    fprintf(
+      report,
     // Size in instructions
-    fprintf(
-      report,
+    fprintf(
+      report,
     // See if an explanation is available
-    fprintf(
-      report,
+    fprintf(
+      report,
       "<td class=\"covoar-td\" align=\"center\">Unknown</td>\n"
       "<a href=\"NotReferenced.html\">No data</a></td>\n"
@@ -719,17 +720,17 @@ namespace Coverage {
     // symbol
-    fprintf(
-      report,
+    fprintf(
+      report,
     // Range
-    fprintf(
-      report,
+    fprintf(
+      report,
       "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s <br>%s</td>\n",
-      rangePtr->id,
+      rangePtr->id,
       rangePtr->lowSourceLine.c_str(),
       rangePtr->highSourceLine.c_str()
@@ -737,43 +738,43 @@ namespace Coverage {
     // File
-    fprintf(
-      report,
+    fprintf(
+      report,
       temp.c_str()
     // Size in bytes
-    fprintf(
-      report,
+    fprintf(
+      report,
-    fprintf(
-      report,
+    fprintf(
+      report,
       rangePtr->instructionCount
-      fprintf(
-        report,
+      fprintf(
+        report,
-      fprintf(
-        report,
+      fprintf(
+        report,
     } else {
-      fprintf(
-        report,
+      fprintf(
+        report,
@@ -805,23 +806,23 @@ namespace Coverage {
     // size
-    fprintf(
-      report,
+    fprintf(
+      report,
       range->highAddress - range->lowAddress + 1
     // symbol
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol->first.c_str()
     // line
-    fprintf(
-      report,
+    fprintf(
+      report,
       range->id,
       range->lowSourceLine.c_str()
@@ -829,12 +830,12 @@ namespace Coverage {
     // File
     i = range->lowSourceLine.find(":");
     temp =  range->lowSourceLine.substr (0, i);
-    fprintf(
-      report,
+    fprintf(
+      report,
       temp.c_str()
     fprintf( report, "</tr>\n");
     return true;
@@ -846,7 +847,7 @@ namespace Coverage {
     Coverage::DesiredSymbols::symbolSet_t::iterator symbol
     // Mark the background color different for odd and even lines.
     if ( ( count%2 ) != 0 )
       fprintf( report, "<tr class=\"covoar-tr-odd\">\n");
@@ -854,77 +855,77 @@ namespace Coverage {
     // symbol
-    fprintf(
-      report,
+    fprintf(
+      report,
     // Total Size in Bytes
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol->second.stats.sizeInBytes
-    // Total Size in Instructions
-    fprintf(
-      report,
+    // Total Size in Instructions
+    fprintf(
+      report,
       symbol->second.stats.sizeInInstructions
     // Total Uncovered Ranges
-    fprintf(
-      report,
-      "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
+    fprintf(
+      report,
+      "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
       symbol->second.stats.uncoveredRanges
     // Uncovered Size in Bytes
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol->second.stats.uncoveredBytes
-    // Uncovered Size in Instructions
-    fprintf(
-      report,
+    // Uncovered Size in Instructions
+    fprintf(
+      report,
        symbol->second.stats.uncoveredInstructions
     // Total number of branches
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol->second.stats.branchesNotExecuted +  symbol->second.stats.branchesExecuted
     // Total Always Taken
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol->second.stats.branchesAlwaysTaken
     // Total Never Taken
-    fprintf(
-      report,
+    fprintf(
+      report,
       symbol->second.stats.branchesNeverTaken
     // % Uncovered Instructions
     if ( symbol->second.stats.sizeInInstructions == 0 )
-      fprintf(
-        report,
+      fprintf(
+        report,
         "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
-    else
-      fprintf(
-        report,
+    else
+      fprintf(
+        report,
         "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
         (symbol->second.stats.uncoveredInstructions*100.0)/
@@ -932,13 +933,13 @@ namespace Coverage {
     // % Uncovered Bytes
     if ( symbol->second.stats.sizeInBytes == 0 )
-      fprintf(
-        report,
+      fprintf(
+        report,
-    else
-      fprintf(
-        report,
+    else
+      fprintf(
+        report,
         (symbol->second.stats.uncoveredBytes*100.0)/
@@ -972,12 +973,12 @@ namespace Coverage {
         aFile,
         TABLE_FOOTER
         "</tbody>\n"
-        "</table>\n"
+        "</table>\n"
     fprintf(
       aFile,
-      "</pre>\n"
+      "</pre>\n"
       "</body>\n"
       "</html>"
@@ -993,8 +994,8 @@ namespace Coverage {
       aFile,
       TABLE_FOOTER
       "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
+      "</table>\n"
+      "</pre>\n"
       "</body>\n"
       "</html>"
@@ -1010,8 +1011,8 @@ namespace Coverage {
       aFile,
       TABLE_FOOTER
       "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
+      "</table>\n"
+      "</pre>\n"
       "</body>\n"
       "</html>"
@@ -1028,8 +1029,8 @@ namespace Coverage {
       aFile,
       TABLE_FOOTER
       "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
+      "</table>\n"
+      "</pre>\n"
       "</body>\n"
       "</html>"
@@ -1045,8 +1046,8 @@ namespace Coverage {
       aFile,
       TABLE_FOOTER
        "</tbody>\n"
-      "</table>\n"
-      "</pre>\n"
+      "</table>\n"
+      "</pre>\n"
       "</body>\n"
       "</html>"
diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
index 062e0a3..53bc8af 100644
--- a/tester/covoar/SymbolTable.cc
+++ b/tester/covoar/SymbolTable.cc
@@ -10,6 +10,8 @@
+#include <rld.h>
 #include "SymbolTable.h"
@@ -43,16 +45,16 @@ namespace Coverage {
     // Add an entry to the symbol information map.
     symbolData.startingAddress = start;
     symbolData.length = length;
     if ( info[ symbol ].empty() == false ) {
       if ( info[ symbol ].front().length != length ) {
-        fprintf(stderr,
-          "ERROR==> Different lengths for the symbol %s (%d and %d)\n",
-          symbol.c_str(),
-          info[ symbol ].front().length,
-          length
-        exit( 0 );
+        what << "Different lengths for the symbol "
+             << symbol
+             << " (" << info[ symbol ].front().length
+             << " and " << length
+        throw rld::error( what, "SymbolTable::addSymbol" );
diff --git a/tester/covoar/TargetBase.cc b/tester/covoar/TargetBase.cc
index e5a0ee6..354a580 100644
--- a/tester/covoar/TargetBase.cc
+++ b/tester/covoar/TargetBase.cc
@@ -1,20 +1,22 @@
 /*! @file TargetBase.cc
  *  @brief TargetBase Implementation
- *  This file contains the implementation of the base class for
+ *  This file contains the implementation of the base class for
  *  functions supporting target unique functionallity.
-#include "TargetBase.h"
-#include "qemu-traces.h"
 #include <algorithm>
+#include <rld.h>
+#include "TargetBase.h"
+#include "qemu-traces.h"
 namespace Target {
-  TargetBase::TargetBase(
+  TargetBase::TargetBase(
     std::string targetName
     targetName_m( targetName )
@@ -65,13 +67,12 @@ namespace Target {
     std::list <std::string>::iterator i;
     if (branchInstructions.empty()) {
-      fprintf(
-        stderr,
-        "DETERMINE BRANCH INSTRUCTIONS FOR THIS ARCHITECTURE! -- fix me\n"
-       exit( -1 );
+      throw rld::error(
+        "DETERMINE BRANCH INSTRUCTIONS FOR THIS ARCHITECTURE! -- fix me",
+        "TargetBase::isBranch"
     i = find(branchInstructions.begin(), branchInstructions.end(), instruction);
     if ( i  == branchInstructions.end() )
       return false;
@@ -90,11 +91,11 @@ namespace Target {
     char instruction[120];
     int  result;
     ch = &(line[0]);
     // Increment to the first tab in the line
-    while ((*ch != '\t') && (*ch != '\0')) {
+    while ((*ch != '\t') && (*ch != '\0')) {
       ch++;
     if (*ch != '\t') {
@@ -104,7 +105,7 @@ namespace Target {
     ch++;
     // Increment to the second tab in the line
       ch++;
     if (*ch != '\t') {
       fprintf( stderr, WARNING, 2, line) ;
diff --git a/tester/covoar/TargetFactory.cc b/tester/covoar/TargetFactory.cc
index 27b0bc1..fc9c30b 100644
--- a/tester/covoar/TargetFactory.cc
+++ b/tester/covoar/TargetFactory.cc
@@ -8,6 +8,13 @@
 //! instances of a family of classes derived from TargetBase.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <rld.h>
 #include "TargetFactory.h"
 #include "Target_arm.h"
@@ -16,10 +23,6 @@
 #include "Target_powerpc.h"
 #include "Target_lm32.h"
 #include "Target_sparc.h"
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <unistd.h>
 namespace Target {
@@ -34,7 +37,7 @@ namespace Target {
      //! This is the string found in configuration to match.
      const char    *theTarget;
      //! This is the static wrapper for the constructor.
-     TargetBase *(*theCtor)(
+     TargetBase *(*theCtor)(
        std::string
   } FactoryEntry_t;
@@ -76,13 +79,9 @@ namespace Target {
         return FactoryTable[i].theCtor( targetName );
-    fprintf(
-      stderr,
-      "ERROR!!! %s is not a known architecture!!!\n",
-      cpu.c_str()
-    fprintf( stderr, "-- fix me\n" );
-    exit( 1 );
+    what << cpu << "is not a known architecture!!! - fix me" << std::endl;
+    throw rld::error( what, "TargetFactory" );
     return NULL;
diff --git a/tester/covoar/Target_arm.cc b/tester/covoar/Target_arm.cc
index a2b65c8..a33ec80 100644
--- a/tester/covoar/Target_arm.cc
+++ b/tester/covoar/Target_arm.cc
@@ -1,15 +1,19 @@
 /*! @file Target_arm.cc
  *  @brief Target_arm Implementation
-#include "Target_arm.h"
 #include <unistd.h>
+#include <rld.h>
+#include "Target_arm.h"
 namespace Target {
   Target_arm::Target_arm( std::string targetName ):
@@ -31,7 +35,7 @@ namespace Target {
     branchInstructions.push_back("bpl");
     branchInstructions.push_back("bvc");
     branchInstructions.push_back("bvs");
     branchInstructions.sort();
@@ -46,7 +50,7 @@ namespace Target {
     if (!strcmp( &line[strlen(line)-3], "nop")) {
-      size = 4;
+      size = 4;
       return true;
@@ -66,15 +70,17 @@ namespace Target {
     return false;
   bool Target_arm::isBranch(
       const char* instruction
-    fprintf( stderr, "DETERMINE BRANCH INSTRUCTIONS FOR THIS ARCHITECTURE! -- fix me\n" );
-    exit( -1 );
+    throw rld::error(
+      "Target_arm::isBranch"
   TargetBase *Target_arm_Constructor(
diff --git a/tester/covoar/Target_m68k.cc b/tester/covoar/Target_m68k.cc
index 683458a..5dc7993 100644
--- a/tester/covoar/Target_m68k.cc
+++ b/tester/covoar/Target_m68k.cc
@@ -1,16 +1,19 @@
 /*! @file Target_m68k.cc
  *  @brief Target_m68k Implementation
-#include "Target_m68k.h"
 #include <unistd.h>
+#include <rld.h>
+#include "Target_m68k.h"
 namespace Target {
   Target_m68k::Target_m68k( std::string targetName ):
@@ -64,7 +67,7 @@ namespace Target {
     branchInstructions.push_back("bvss");
     branchInstructions.push_back("bvsl");
@@ -79,7 +82,7 @@ namespace Target {
-      size = 2;
+      size = 2;
       return true;
@@ -87,9 +90,9 @@ namespace Target {
     #if defined(GNU_LD_FILLS_ALIGNMENT_WITH_RTS)
       // Until binutils 2.20, binutils would fill with rts not nop
       if (!strcmp( &line[strlen(line)-3], "rts")) {
-        size = 4;
+        size = 4;
         return true;
     #endif
     return false;
@@ -99,11 +102,10 @@ namespace Target {
       const char* const instruction
-    fprintf(
-      stderr,
+    throw rld::error(
+      "Target_m68k::isBranch"
-    exit( -1 );
   uint8_t Target_m68k::qemuTakenBit(void)
diff --git a/tester/covoar/Target_powerpc.cc b/tester/covoar/Target_powerpc.cc
index f7a5acb..3444b3c 100644
--- a/tester/covoar/Target_powerpc.cc
+++ b/tester/covoar/Target_powerpc.cc
@@ -1,15 +1,18 @@
 /*! @file Target_powerpc.cc
  *  @brief Target_powerpc Implementation
-#include "Target_powerpc.h"
 #include <unistd.h>
+#include <rld.h>
+#include "Target_powerpc.h"
 namespace Target {
   Target_powerpc::Target_powerpc( std::string targetName ):
@@ -46,8 +49,8 @@ namespace Target {
     branchInstructions.push_back("bclr");
     branchInstructions.push_back("bclrl");
-    branchInstructions.sort();
+    branchInstructions.sort();
   Target_powerpc::~Target_powerpc()
@@ -60,7 +63,7 @@ namespace Target {
-      size = 4;
+      size = 4;
       return true;
@@ -71,8 +74,10 @@ namespace Target {
-    exit( -1 );
+    throw rld::error(
+      "Target_powerpc::isBranch"
   TargetBase *Target_powerpc_Constructor(
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index 86bc6c1..57ec6eb 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -13,6 +13,9 @@
 #include <signal.h>
 #include <unistd.h>
+#include <rld.h>
+#include <rld-process.h>
 #include "qemu-log.h"
 #include "TraceReaderLogQEMU.h"
 #include "TraceWriterQEMU.h"
@@ -21,9 +24,6 @@
-#include "rld.h"
-#include "rld-process.h"
 #ifdef _WIN32
   #define kill(p,s) raise(s)
 #endif
diff --git a/tester/covoar/TraceWriterQEMU.cc b/tester/covoar/TraceWriterQEMU.cc
index 9a8affc..cd325b6 100644
--- a/tester/covoar/TraceWriterQEMU.cc
+++ b/tester/covoar/TraceWriterQEMU.cc
@@ -38,14 +38,17 @@
+#include <iomanip>
 #if HAVE_STAT64
 #define STAT stat64
 #else
@@ -94,9 +97,10 @@ namespace Trace {
     // Open the trace file.
-    traceFile = OPEN( file, "w" );
+    traceFile = ::OPEN( file, "w" );
     if (!traceFile) {
-      fprintf( stderr, "Unable to open %s\n", file );
+      std::cerr << "Unable to open " << file << std::endl;
       return false;
@@ -110,28 +114,23 @@ namespace Trace {
     header.big_endian = false;
     header.machine[0] = 0; // XXX ??
     header.machine[1] = 0; // XXX ??
-    status = fwrite( &header, sizeof(trace_header), 1, traceFile );
+    status = ::fwrite( &header, sizeof(trace_header), 1, traceFile );
     if (status != 1) {
-      fprintf( stderr, "Unable to write header to %s\n", file );
+      std::cerr << "Unable to write header to " << file << std::endl;
       return false;
     if (Verbose)
-      fprintf(
-        stderr,
-        "magic = %s\n"
-        "version = %d\n"
-        "kind = %d\n"
-        header.magic,
-        header.version,
-        header.kind,
+      std::cerr << "magic = " << header.magic << std::endl
+                << "version = " << header.version << std::endl
+                << "kind = " << header.kind << std::endl
+                << "sizeof_target_pc = " << header.sizeof_target_pc << std::endl
+                << "big_endian = " << header.big_endian << std::endl
+                << "machine = " << std::setw(2) << header.machine[0]
+                << ':' << header.machine[1]
+                << std::dec << std::setfill(' ')
+                << std::endl;
     // Loop through log and write each entry.
@@ -153,22 +152,24 @@ namespace Trace {
         case TraceList::EXIT_REASON_OTHER:
           break;
         default:
-          fprintf(stderr, "Unknown exit Reason\n");
-          exit(1);
+          throw rld::error( "Unknown exit Reason", "TraceWriterQEMU::writeFile" );
           break;
       if ( Verbose )
-        fprintf(stderr, "%x %x %x\n", entry.pc, entry.size, entry.op);
+        std::cerr << std::hex << std::setfill('0')
+                  << entry.pc << ' ' << entry.size << ' ' << entry.op
+                  << std::endl;
-      status = fwrite( &entry, sizeof(entry), 1, traceFile );
+      status = ::fwrite( &entry, sizeof(entry), 1, traceFile );
       if (status != 1) {
-        fprintf( stderr, "Unable to write entry to %s\n", file );
+        std::cerr << "Unable to write entry to " << file << std::endl;
         return false;
     return true;
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index eadf0ec..26abf34 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -1,3 +1,7 @@
+#include <iomanip>
+#include <cxxabi.h>
 #include <ctype.h>
 #include <fcntl.h>
@@ -12,6 +16,9 @@
 #include <list>
+#include <rld.h>
@@ -23,14 +30,13 @@
 #include "GcovData.h"
 #ifdef _WIN32
 #endif
 typedef std::list<std::string> CoverageNames;
 typedef std::list<Coverage::ExecutableInfo*> Executables;
+typedef std::string option_error;
  * Create a build path from the executable paths. Also extract the build prefix
@@ -105,8 +111,7 @@ static void createBuildPath(Executables& executablesToAnalyze,
     if (!fail.empty()) {
-      std::cerr << "ERROR: " << fail << std::endl;
-      exit(EXIT_FAILURE);
+      throw rld::error( fail, "createBuildPath" );
@@ -138,44 +143,7 @@ void usage(const std::string& progname)
             << std::endl;
-#define PrintableString(_s) \
-((!(_s)) ? "NOT SET" : (_s))
-static void
-fatal_signal( int signum )
-  signal( signum, SIG_DFL );
-  rld::process::temporaries_clean_up();
-   * Get the same signal again, this time not handled, so its normal effect
-   * occurs.
-  kill( getpid(), signum );
-static void
-setup_signals( void )
-  if ( signal( SIGINT, SIG_IGN ) != SIG_IGN )
-    signal( SIGINT, fatal_signal );
-#ifdef SIGHUP
-  if ( signal( SIGHUP, SIG_IGN ) != SIG_IGN )
-    signal( SIGHUP, fatal_signal );
-#endif
-  if ( signal( SIGTERM, SIG_IGN ) != SIG_IGN )
-    signal( SIGTERM, fatal_signal );
-#ifdef SIGPIPE
-  if ( signal( SIGPIPE, SIG_IGN ) != SIG_IGN )
-    signal( SIGPIPE, fatal_signal );
-#endif
-#ifdef SIGCHLD
-  signal( SIGCHLD, SIG_DFL );
-#endif
-int main(
+int covoar(
   int    argc,
   char** argv
@@ -204,16 +172,12 @@ int main(
   rld::process::tempfile        syms( ".syms" );
   bool                          debug = false;
   std::string                   symbolSet;
-  std::string                   progname;
   std::string                   option;
   int                           opt;
-  setup_signals();
   // Process command line options.
-  progname = rld::path::basename(argv[0]);
   while ((opt = getopt(argc, argv, "1:L:e:c:g:E:f:s:S:T:O:p:vd")) != -1) {
     switch (opt) {
@@ -232,46 +196,31 @@ int main(
       case 'p': projectName         = optarg; break;
       case 'd': debug               = true;   break;
       default: /* '?' */
-        usage(progname);
+        throw option_error( "unknown option" );
-  try
-     * Validate inputs.
-     * Validate that we have a symbols of interest file.
-    if ( symbolSet.empty() ) {
-      option = "symbol set file -S";
-      throw option;
+   * Validate inputs.
-     * Has path to explanations.txt been specified.
-    if ( !explanations ) {
-      option = "explanations -E";
-      throw option;
+   * Validate that we have a symbols of interest file.
+  if ( symbolSet.empty() )
+    throw option_error( "symbol set file -S" );
-     * Check for project name.
-    if ( !projectName ) {
-      option = "project name -p";
-      throw option;
-  catch( std::string option )
-    std::cerr << "error missing option: " + option << std::endl;
-    usage(progname);
+   * Has path to explanations.txt been specified.
+  if ( !explanations )
+    throw option_error( "explanations -E" );
+   * Check for project name.
+  if ( !projectName )
+    throw option_error( "project name -p" );
   // If a single executable was specified, process the remaining
   // arguments as coverage file names.
@@ -332,18 +281,14 @@ int main(
   // Ensure that there is at least one executable to process.
-  if (executablesToAnalyze.empty()) {
-    std::cerr << "error: No information to analyze" << std::endl;
+  if (executablesToAnalyze.empty())
+    throw rld::error( "No information to analyze", "covoar" );
   // The executablesToAnalyze and coverageFileNames containers need
   // to be the name size of some of the code below breaks. Lets
   // check and make sure.
-  if (executablesToAnalyze.size() != coverageFileNames.size()) {
-    std::cerr << "ERROR: executables and coverage name size mismatch" << std::endl;
+  if (executablesToAnalyze.size() != coverageFileNames.size())
+    throw rld::error( "executables and coverage name size mismatch", "covoar" );
   // Find the top of the BSP's build tree and if we have found the top
@@ -398,9 +343,7 @@ int main(
   // Read symbol configuration file and load needed symbols.
-  if (!SymbolsToAnalyze->load( symbolSet, buildTarget, buildBSP, Verbose )) {
+  SymbolsToAnalyze->load( symbolSet, buildTarget, buildBSP, Verbose );
   if ( Verbose )
     std::cerr << "Analyzing " << SymbolsToAnalyze->set.size()
@@ -413,10 +356,8 @@ int main(
   // Create coverage map reader.
   coverageReader = Coverage::CreateCoverageReader(coverageFormat);
-  if (!coverageReader) {
-    std::cerr << "error: Unable to create coverage file reader" << std::endl;
+  if (!coverageReader)
+    throw rld::error( "Unable to create coverage file reader", "covoar" );
   // Create the objdump processor.
   objdumpProcessor = new Coverage::ObjdumpProcessor();
@@ -555,3 +496,102 @@ int main(
   return 0;
+#define PrintableString(_s) \
+((!(_s)) ? "NOT SET" : (_s))
+static void
+fatal_signal( int signum )
+  signal( signum, SIG_DFL );
+  rld::process::temporaries_clean_up();
+   * Get the same signal again, this time not handled, so its normal effect
+   * occurs.
+  kill( getpid(), signum );
+static void
+setup_signals( void )
+  if ( signal( SIGINT, SIG_IGN ) != SIG_IGN )
+    signal( SIGINT, fatal_signal );
+#ifdef SIGHUP
+  if ( signal( SIGHUP, SIG_IGN ) != SIG_IGN )
+    signal( SIGHUP, fatal_signal );
+#endif
+  if ( signal( SIGTERM, SIG_IGN ) != SIG_IGN )
+    signal( SIGTERM, fatal_signal );
+#ifdef SIGPIPE
+  if ( signal( SIGPIPE, SIG_IGN ) != SIG_IGN )
+    signal( SIGPIPE, fatal_signal );
+#endif
+#ifdef SIGCHLD
+  signal( SIGCHLD, SIG_DFL );
+#endif
+void
+unhandled_exception (void)
+  std::cerr << "error: exception handling error, please report" << std::endl;
+  exit (1);
+int main(
+  int    argc,
+  char** argv
+  std::string progname( argv[0] );
+  int         ec = 0;
+  setup_signals();
+  std::set_terminate(unhandled_exception);
+  try
+    progname = rld::path::basename(argv[0]);
+    covoar( argc, argv );
+  catch ( option_error oe )
+    std::cerr << "error: missing option: " + oe << std::endl;
+    usage(progname);
+    ec = EXIT_FAILURE;
+  catch (rld::error re)
+    std::cerr << "error: "
+              << re.where << ": " << re.what
+              << std::endl;
+    ec = 10;
+  catch (std::exception e)
+    int   status;
+    char* realname;
+    realname = abi::__cxa_demangle (e.what(), 0, 0, &status);
+    std::cerr << "error: exception: " << realname << " [";
+    ::free (realname);
+    const std::type_info &ti = typeid (e);
+    realname = abi::__cxa_demangle (ti.name(), 0, 0, &status);
+    std::cerr << realname << "] " << e.what () << std::endl << std::flush;
+    ec = 11;
+  catch (...)
+     * Helps to know if this happens.
+    std::cerr << "error: unhandled exception" << std::endl;
+    ec = 12;
+  return ec;
2.15.1
