[PATCH v3 17/22] linkers: Add an address to line tool.
Mon Jun 18 02:29:15 UTC 2018
This tool provides a way to check the DWARF toolkit support for finding
lines from addresses.
 linkers/rtems-addr2line.cpp | 289 ++++++++++++++++++++++++++++++++++++++++++++
 linkers/wscript             |  15 ++-
 2 files changed, 303 insertions(+), 1 deletion(-)
 create mode 100644 linkers/rtems-addr2line.cpp
diff --git a/linkers/rtems-addr2line.cpp b/linkers/rtems-addr2line.cpp
new file mode 100644
index 0000000..2e79c62
--- /dev/null
+++ b/linkers/rtems-addr2line.cpp
@@ -0,0 +1,289 @@
+ * Copyright (c) 2018, Chris Johns <chrisj at rtems.org>
+ * Permission to use, copy, modify, and/or distribute this software for any
+ * purpose with or without fee is hereby granted, provided that the above
+ * copyright notice and this permission notice appear in all copies.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+ * WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+ * ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+ * WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+ * ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+ * OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+ * @file
+ * @ingroup rtems_rld
+ * @brief RTEMS Address to Line is a version of the classic addr2line
+ *        utility to test the DWARF info support in the RTEMS Toolkit.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <iomanip>
+#include <iostream>
+#include <signal.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <getopt.h>
+#include <rld.h>
+#include <rld-dwarf.h>
+#include <rld-files.h>
+#include <rld-rtems.h>
+#ifndef HAVE_KILL
+#define kill(p,s) raise(s)
+#endif
+ * RTEMS Symbols options.
+static struct option rld_opts[] = {
+  { "help",         no_argument,            NULL,           'h' },
+  { "version",      no_argument,            NULL,           'V' },
+  { "verbose",      no_argument,            NULL,           'v' },
+  { "executable",   required_argument,      NULL,           'e' },
+  { "addresses",    no_argument,            NULL,           'a' },
+  { "pretty-print", no_argument,            NULL,           'p' },
+  { "basenames",    no_argument,            NULL,           's' },
+  { NULL,           0,                      NULL,            0 }
+void
+usage (int exit_code)
+  std::cout << "rtems-addr2line [options] addresses" << std::endl
+            << "Options and arguments:" << std::endl
+            << " -h        : help (also --help)" << std::endl
+            << " -V        : print version number and exit (also --version)" << std::endl
+            << " -v        : verbose (trace import parts), can supply multiple times" << std::endl
+            << "             to increase verbosity (also --verbose)" << std::endl
+            << " -e        : executable (also --executablewarn)" << std::endl
+            << " -a        : show addresses (also --addresses)" << std::endl
+            << " -p        : human readable format (also --pretty-print)" << std::endl
+            << " -s        : Strip directory paths (also --basenames)" << std::endl;
+  ::exit (exit_code);
+static void
+fatal_signal (int signum)
+  signal (signum, SIG_DFL);
+   * Get the same signal again, this time not handled, so its normal effect
+   * occurs.
+  kill (getpid (), signum);
+static void
+setup_signals (void)
+  if (signal (SIGINT, SIG_IGN) != SIG_IGN)
+    signal (SIGINT, fatal_signal);
+#ifdef SIGHUP
+  if (signal (SIGHUP, SIG_IGN) != SIG_IGN)
+    signal (SIGHUP, fatal_signal);
+#endif
+  if (signal (SIGTERM, SIG_IGN) != SIG_IGN)
+    signal (SIGTERM, fatal_signal);
+#ifdef SIGPIPE
+  if (signal (SIGPIPE, SIG_IGN) != SIG_IGN)
+    signal (SIGPIPE, fatal_signal);
+#endif
+#ifdef SIGCHLD
+  signal (SIGCHLD, SIG_DFL);
+#endif
+void
+unhandled_exception (void)
+  std::cerr << "error: exception handling error, please report" << std::endl;
+  exit (13);
+int
+main (int argc, char* argv[])
+  int ec = 0;
+  setup_signals ();
+  std::set_terminate(unhandled_exception);
+  try
+    std::string exe_name = "a.out";
+    bool        show_addresses = false;
+    bool        pretty_print = false;
+    bool        show_basenames = false;
+    rld::set_cmdline (argc, argv);
+    while (true)
+      int opt = ::getopt_long (argc, argv, "hvVe:aps", rld_opts, NULL);
+      if (opt < 0)
+        break;
+      switch (opt)
+        case 'V':
+          std::cout << "rtems-addr2line (RTEMS Address To Line) " << rld::version ()
+                    << ", RTEMS revision " << rld::rtems::version ()
+                    << std::endl;
+          ::exit (0);
+          break;
+        case 'v':
+          rld::verbose_inc ();
+          break;
+        case 'e':
+          exe_name = optarg;
+          break;
+        case 'a':
+          show_addresses = true;
+          break;
+        case 'p':
+          pretty_print = true;
+          break;
+        case 's':
+          show_basenames = true;
+          break;
+        case '?':
+          usage (3);
+          break;
+        case 'h':
+          usage (0);
+          break;
+     * Set the program name.
+    rld::set_progname (argv[0]);
+    argc -= optind;
+    argv += optind;
+    if (rld::verbose ())
+      std::cout << "RTEMS Address To Line " << rld::version () << std::endl;
+     * If there are no object files there is nothing to link.
+    if (argc == 0)
+      throw rld::error ("no addresses provided", "options");
+      std::cout << "exe: " << exe_name << std::endl;
+     * Load the executable's debug info.
+    rld::files::object exe (exe_name);
+    rld::dwarf::file   debug;
+    try
+       * Load the executable's ELF file debug info.
+      exe.open ();
+      exe.begin ();
+      debug.begin (exe.elf ());
+      debug.load_debug ();
+      for (int arg = 0; arg < argc; ++arg)
+        rld::dwarf::dwarf_address location;
+          std::cout << "address: " << argv[arg] << std::endl;
+         * Use the C routine as C++ does not have a way to automatically handle
+         * different bases on the input.
+        location = ::strtoul (argv[arg], 0, 0);
+        std::string path;
+        int         line;
+        debug.get_source (location, path, line);
+        if (show_addresses)
+          std::cout << std::hex << std::setfill ('0')
+                    << "0x" << location
+                    << std::dec << std::setfill (' ');
+          if (pretty_print)
+            std::cout << ": ";
+          else
+            std::cout << std::endl;
+        if (show_basenames)
+          std::cout << rld::path::basename (path);
+        else
+          std::cout << path;
+        std::cout << ':' << line << std::endl;
+      debug.end ();
+      exe.end ();
+      exe.close ();
+    catch (...)
+      debug.end ();
+      exe.end ();
+      exe.close ();
+      throw;
+  catch (rld::error re)
+    std::cerr << "error: "
+              << re.where << ": " << re.what
+              << std::endl;
+    ec = 10;
+  catch (std::exception e)
+    rld::output_std_exception (e, std::cerr);
+    ec = 11;
+  catch (...)
+     * Helps to know if this happens.
+    std::cout << "error: unhandled exception" << std::endl;
+    ec = 12;
+  return ec;
diff --git a/linkers/wscript b/linkers/wscript
index 10fe2a0..23d3f9c 100644
--- a/linkers/wscript
+++ b/linkers/wscript
@@ -58,6 +58,7 @@ def build(bld):
                         rtemstoolkit + '/elftoolchain/libelf',
                         rtemstoolkit + '/elftoolchain/libdwarf',
                         rtemstoolkit + '/elftoolchain/common',
+                        rtemstoolkit + '/elftoolchain/libelftc',
                         rtemstoolkit + '/libiberty']
     if bld.env.DEST_OS == 'win32':
         conf['includes'] += [rtemstoolkit + '/win32']
@@ -70,7 +71,7 @@ def build(bld):
     # The list of modules.
-    modules = ['rld', 'dwarf', 'elf', 'iberty']
+    modules = ['rld', 'elftc', 'dwarf', 'elf', 'iberty']
     # The list of defines
@@ -165,5 +166,17 @@ def build(bld):
                 linkflags = conf['linkflags'],
                 use = modules)
+    # Build the address to line tool.
+    bld.program(target = 'rtems-addr2line',
+                source = ['rtems-addr2line.cpp'],
+                defines = defines,
+                includes = ['.'] + conf['includes'],
+                cflags = conf['cflags'] + conf['warningflags'],
+                cxxflags = conf['cxxflags'] + conf['warningflags'],
+                linkflags = conf['linkflags'],
+                use = modules)
 def tags(ctx):
     ctx.exec_command('etags $(find . -name \*.[sSch])', shell = True)
2.15.1
