[PATCH v3 19/22] tester: Make leon3-run command use run and not sis.
Mon Jun 18 02:29:17 UTC 2018
 tester/rtems/testing/bsps/leon3-run.ini | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rtems/testing/bsps/leon3-run.ini b/tester/rtems/testing/bsps/leon3-run.ini
index 7e37e5f..a8c97a6 100644
--- a/tester/rtems/testing/bsps/leon3-run.ini
+++ b/tester/rtems/testing/bsps/leon3-run.ini
@@ -35,5 +35,5 @@
 bsp          = leon3
 arch         = sparc
 tester       = %{_rtscripts}/run.cfg
-bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
-bsp_run_opts = -leon3
+bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run
+bsp_run_opts = -a -leon3
2.15.1
