[PATCH v3 22/22] tester: Make the path to covoar absolute to ignore the env PATH.
Mon Jun 18 02:29:20 UTC 2018
Using the environment's path to find covoar allow invalid versions
to be used which may vary in subtle ways. Find and use the covoar
that is build with the version of 'rtems-test'.
This patch means you do not need to install the tools before
running improving the development experience.
Closes #3458
 tester/rt/coverage.py | 50 ++++++++++++++++++++++++++++++++++----------------
 tester/rt/test.py     | 15 +++++++++------
 2 files changed, 43 insertions(+), 22 deletions(-)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index 093d516..31ad4d1 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -33,6 +33,7 @@ from __future__ import print_function
 import datetime
 import shutil
 import os
+import sys
 try:
     import configparser
@@ -245,21 +246,21 @@ class symbol_parser(object):
     def __init__(self,
                  symbol_config_path,
                  symbol_select_path,
-                 coverage_arg,
+                 symbol_set,
                  build_dir):
         self.symbol_select_file = symbol_select_path
         self.symbol_file = symbol_config_path
         self.build_dir = build_dir
         self.symbol_sets = {}
-        self.cov_arg = coverage_arg
+        self.symbol_set = symbol_set
         self.ssets = []
     def parse(self):
         config = configparser.ConfigParser()
         try:
             config.read(self.symbol_file)
-            if self.cov_arg:
-                self.ssets = self.cov_arg.split(',')
+            if self.symbol_set is not None:
+                self.ssets = self.symbol_set.split(',')
             else:
                 self.ssets = config.get('symbol-sets', 'sets').split(',')
                 self.ssets = [sset.encode('utf-8') for sset in self.ssets]
@@ -291,27 +292,41 @@ class covoar(object):
     Covoar runner
-    def __init__(self, base_result_dir, config_dir, executables, explanations_txt):
+    def __init__(self, base_result_dir, config_dir, executables, explanations_txt, trace):
         self.base_result_dir = base_result_dir
         self.config_dir = config_dir
         self.executables = ' '.join(executables)
         self.explanations_txt = explanations_txt
         self.project_name = 'RTEMS-5'
+        self.trace = trace
+    def _find_covoar(self):
+        covoar_exe = 'covoar'
+        tester_dir = path.dirname(path.abspath(sys.argv[0]))
+        base = path.dirname(tester_dir)
+        exe = path.join(base, 'bin', covoar_exe)
+        if path.isfile(exe):
+            return exe
+        exe = path.join(base, 'build', 'tester', 'covoar', covoar_exe)
+            return exe
+        raise error.general('coverage: %s not found'% (covoar_exe))
     def run(self, set_name, symbol_file):
         covoar_result_dir = path.join(self.base_result_dir, set_name)
-        if (not path.exists(covoar_result_dir)):
+        if not path.exists(covoar_result_dir):
             path.mkdir(covoar_result_dir)
-        if (not path.exists(symbol_file)):
-            raise error.general('symbol set file: coverage %s not created, skipping %s'% (symbol_file, set_name))
-        command = 'covoar -S ' + symbol_file + \
+        if not path.exists(symbol_file):
+            raise error.general('coverage: no symbol set file: %s'% (symbol_file))
+        exe = self._find_covoar()
+        command = exe + ' -S ' + symbol_file + \
                   ' -O ' + covoar_result_dir + \
                   ' -E ' + self.explanations_txt + \
                   ' -p ' + self.project_name + ' ' + self.executables
         log.notice()
         log.notice('Running coverage analysis: %s (%s)' % (set_name, covoar_result_dir))
         start_time = datetime.datetime.now()
-        executor = execute.execute(verbose = True, output = self.output_handler)
+        executor = execute.execute(verbose = self.trace, output = self.output_handler)
         exit_code = executor.shell(command, cwd=os.getcwd())
         if exit_code[0] != 0:
             raise error.general('coverage: covoar failure:: %d' % (exit_code[0]))
@@ -325,11 +340,12 @@ class coverage_run(object):
     Coverage analysis support for rtems-test
-    def __init__(self, p_macros, coverage_arg, executables):
+    def __init__(self, macros_, executables, symbol_set = None, trace = False):
         Constructor
-        self.macros = p_macros
+        self.macros = macros_
         self.build_dir = self.macros['_cwd']
         self.explanations_txt = self.macros.expand(self.macros['cov_explanations'])
         self.test_dir = path.join(self.build_dir, self.macros['bsp'] + '-coverage')
@@ -346,7 +362,7 @@ class coverage_run(object):
         self.symbol_sets = []
         self.no_clean = int(self.macros['_no_clean'])
         self.report_format = self.macros['cov_report_format']
-        self.coverage_arg = coverage_arg
         self.target = self.macros['target']
     def run(self):
@@ -356,11 +372,12 @@ class coverage_run(object):
             build_dir = build_path_generator(self.executables, self.target).run()
             parser = symbol_parser(self.symbol_config_path,
                                    self.symbol_select_path,
-                                   self.coverage_arg,
+                                   self.symbol_set,
                                    build_dir)
             parser.run()
             covoar_runner = covoar(self.test_dir, self.symbol_select_path,
-                                   self.executables, self.explanations_txt)
+                                   self.executables, self.explanations_txt,
+                                   self.trace)
             covoar_runner.run('score', self.symbol_select_path)
             self._generate_reports();
             self._summarize();
@@ -379,7 +396,8 @@ class coverage_run(object):
     def _cleanup(self):
         if not self.no_clean:
-            log.output('Coverage cleaning tempfiles')
+            if self.trace:
+                log.output('Coverage cleaning tempfiles')
             for exe in self.executables:
                 trace_file = exe + '.cov'
                 if path.exists(trace_file):
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 0e744cd..9214ad6 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -228,7 +228,7 @@ def run(command_path = None):
                     '--user-config':    'Path to your local user configuration INI file',
                     '--report-mode':    'Reporting modes, failures (default),all,none',
                     '--list-bsps':      'List the supported BSPs',
-                    '--debug-trace':    'Debug trace based on specific flags',
+                    '--debug-trace':    'Debug trace based on specific flags (console,gdb,output,cov)',
                     '--filter':         'Glob that executables must match to run (default: ' +
                               default_exefilter + ')',
                     '--stacktrace':     'Dump a stack trace on a user termination (^C)',
@@ -266,7 +266,7 @@ def run(command_path = None):
             if len(debug_trace) != 1:
                 debug_trace = debug_trace[1]
             else:
-                raise error.general('no debug flags, can be: console,gdb,output')
+                raise error.general('no debug flags, can be: console,gdb,output,cov')
         else:
             debug_trace = ''
         opts.defaults['exe_trace'] = debug_trace
@@ -285,13 +285,16 @@ def run(command_path = None):
         bsp_config = opts.defaults.expand(opts.defaults['tester'])
         coverage_enabled = opts.find_arg('--coverage')
         if coverage_enabled:
+            cov_trace = 'cov' in debug_trace.split(',')
             if len(coverage_enabled) == 2:
                 coverage_runner = coverage.coverage_run(opts.defaults,
-                                                coverage_enabled[1],
-                                                executables)
+                                                        executables,
+                                                        symbol_set = coverage_enabled[1],
+                                                        trace = cov_trace)
             else:
-                coverage_runner = coverage.coverage_run(opts.defaults, 0,
-                                                        executables)
+                coverage_runner = coverage.coverage_run(opts.defaults,
+                                                        executables,
         report_mode = opts.find_arg('--report-mode')
         if report_mode:
             if report_mode[1] != 'failures' and \
2.15.1
