[PATCH 2/2] spmisc01: Add test cases for basedefs.h stuff
Mon Jun 18 12:42:06 UTC 2018
 testsuites/sptests/spmisc01/init.c       | 199 +++++++++++++++++++++++++++++++
 testsuites/sptests/spmisc01/spmisc01.doc |  28 +++++
 2 files changed, 227 insertions(+)
diff --git a/testsuites/sptests/spmisc01/init.c b/testsuites/sptests/spmisc01/init.c
index 4ff6365eeb..d6c6cbeab9 100644
--- a/testsuites/sptests/spmisc01/init.c
+++ b/testsuites/sptests/spmisc01/init.c
@@ -17,19 +17,218 @@
 #endif
+#include <string.h>
 #include <tmacros.h>
 const char rtems_test_name[] = "SPMISC 1";
+RTEMS_INLINE_ROUTINE int inline_func(void)
+  return 123;
+RTEMS_NO_INLINE static int noinline_func(void)
+  return 456;
+RTEMS_NO_RETURN void noreturn_func(void);
+RTEMS_PURE static int pure_func(void)
+  return 789;
+RTEMS_SECTION(".rtemsroset.test") static int section_variable = 101112;
+RTEMS_USED static int used_func(void)
+  return 131415;
+RTEMS_USED static int used_variable;
+static int unused_arg_and_variable_func(RTEMS_UNUSED int arg)
+  RTEMS_UNUSED int variable;
+  return 161718;
+typedef struct {
+  uint8_t c;
+  uint32_t i;
+} RTEMS_PACKED packed_struct;
+static int alias_func(void) RTEMS_ALIAS(noinline_func);
+int weak_alias_func(void) RTEMS_WEAK_ALIAS(noinline_func);
+static char aligned_variable RTEMS_ALIGNED(64);
+typedef struct {
+  uint8_t c;
+  uint8_t aligned_member RTEMS_ALIGNED(64);
+} aligned_member_struct;
+static void unreachable(void)
+  if (0) {
+    RTEMS_UNREACHABLE();
+RTEMS_PRINTFLIKE(1, 2) static int printflike_func(const char *fmt, ...)
+  return 222324;
+static int obfuscate_variable(int i)
+  RTEMS_OBFUSCATE_VARIABLE(i);
+  return i;
 RTEMS_DECLARE_GLOBAL_SYMBOL(a_global_symbol);
 RTEMS_DEFINE_GLOBAL_SYMBOL(a_global_symbol, 0xabc);
+RTEMS_STATIC_ASSERT(0 != 1, zero_neq_one);
+static int array[3];
+typedef struct {
+  uint32_t i;
+  uint32_t j[RTEMS_ZERO_LENGTH_ARRAY];
+} zero_length_array_struct;
+typedef struct {
+  int a;
+  int b;
+} container_of_struct;
+static void container_of(void)
+  container_of_struct s;
+  int *b;
+  b = &s.b;
+  rtems_test_assert(RTEMS_CONTAINER_OF(b, container_of_struct, b) == &s);
+static int deconst(void)
+  const int i = 282930;
+  int *p;
+  p = RTEMS_DECONST(int *, &i);
+  return *p;
+static int devolatile(void)
+  volatile int i = 313233;
+  int *p;
+  p = RTEMS_DEVOLATILE(int *, &i);
+  return *p;
+static int dequalify(void)
+  volatile const int i = 343536;
+  int *p;
+  p = RTEMS_DEQUALIFY(int *, &i);
+  return *p;
+typedef struct {
+  char a;
+  int b;
+} same_member_type_struct;
+typedef struct {
+  char c;
+  int d;
+} same_member_type_struct_2;
+  RTEMS_HAVE_MEMBER_SAME_TYPE(
+    same_member_type_struct,
+    b,
+    same_member_type_struct_2,
+    d
+  same_member_type_struct_eq
+  !RTEMS_HAVE_MEMBER_SAME_TYPE(
+    b,
+    c
+  same_member_type_struct_neq
+static int concat(void)
+  return 373839;
+#define CON con
+#define CAT cat
+#define STR ing
 static void Init(rtems_task_argument arg)
   TEST_BEGIN();
+  rtems_test_assert(inline_func() == 123);
+  RTEMS_COMPILER_MEMORY_BARRIER();
+  rtems_test_assert(noinline_func() == 456);
+  rtems_test_assert(pure_func() == 789);
+  rtems_test_assert(section_variable == 101112);
+  rtems_test_assert(unused_arg_and_variable_func(192021) == 161718);
+  rtems_test_assert(sizeof(packed_struct) == 5);
+  rtems_test_assert(alias_func() == 456);
+  rtems_test_assert(weak_alias_func() == 456);
+  rtems_test_assert(((uintptr_t) &aligned_variable) % 64 == 0);
+  rtems_test_assert(offsetof(aligned_member_struct, aligned_member) % 64 == 0);
+  unreachable();
+  rtems_test_assert(printflike_func("%i", 0) == 222324);
+  rtems_test_assert(obfuscate_variable(252627) == 252627);
   rtems_test_assert((uintptr_t)a_global_symbol == 0xabc);
+  rtems_test_assert(RTEMS_ARRAY_SIZE(array) == 3);
+  rtems_test_assert(sizeof(zero_length_array_struct) == 4);
+  container_of();
+  rtems_test_assert(deconst() == 282930);
+  rtems_test_assert(devolatile() == 313233);
+  rtems_test_assert(dequalify() == 343536);
+      b,
+      d
+      b,
+      c
+  rtems_test_assert(RTEMS_CONCAT(con, cat)() == 373839);
+  rtems_test_assert(RTEMS_XCONCAT(CON, CAT)() == 373839);
+  rtems_test_assert(strcmp(RTEMS_STRING(str), "str") == 0);
+  rtems_test_assert(strcmp(RTEMS_XSTRING(STR), "ing") == 0);
   TEST_END();
   rtems_test_exit(0);
diff --git a/testsuites/sptests/spmisc01/spmisc01.doc b/testsuites/sptests/spmisc01/spmisc01.doc
index 2654788f02..cad97b08bf 100644
--- a/testsuites/sptests/spmisc01/spmisc01.doc
+++ b/testsuites/sptests/spmisc01/spmisc01.doc
@@ -4,8 +4,36 @@ test set name: spbasedefs01
 directives:
+  - RTEMS_ALIAS()
+  - RTEMS_ALIGNED()
+  - RTEMS_ARRAY_SIZE()
+  - RTEMS_COMPILER_MEMORY_BARRIER()
+  - RTEMS_CONCAT()
+  - RTEMS_CONTAINER_OF()
   - RTEMS_DECLARE_GLOBAL_SYMBOL()
+  - RTEMS_DECONST()
   - RTEMS_DEFINE_GLOBAL_SYMBOL()
+  - RTEMS_DEPRECATED
+  - RTEMS_DEQUALIFY()
+  - RTEMS_DEQUALIFY_DEPTHX()
+  - RTEMS_DEVOLATILE()
+  - RTEMS_HAVE_MEMBER_SAME_TYPE()
+  - RTEMS_NO_INLINE
+  - RTEMS_NO_RETURN
+  - RTEMS_OBFUSCATE_VARIABLE()
+  - RTEMS_PACKED
+  - RTEMS_PRINTFLIKE()
+  - RTEMS_PURE
+  - RTEMS_SECTION()
+  - RTEMS_STATIC_ASSERT()
+  - RTEMS_STRING()
+  - RTEMS_TYPEOF_REFX()
+  - RTEMS_UNREACHABLE()
+  - RTEMS_UNUSED
+  - RTEMS_USED
+  - RTEMS_WEAK_ALIAS()
+  - RTEMS_XCONCAT()
+  - RTEMS_XSTRING()
 concepts:
2.13.7
