[PATCH 1/2] gdb: Add a gdb-common configuration and have gdb-7-1 include it.
Tue Jun 19 01:33:53 UTC 2018
Updates #3460
 source-builder/config/gdb-7-1.cfg      | 143 +------------------------------
 source-builder/config/gdb-8-1.cfg      |   7 ++
 source-builder/config/gdb-common-1.cfg | 148 +++++++++++++++++++++++++++++++++
 3 files changed, 156 insertions(+), 142 deletions(-)
 create mode 100644 source-builder/config/gdb-8-1.cfg
 create mode 100644 source-builder/config/gdb-common-1.cfg
diff --git a/source-builder/config/gdb-7-1.cfg b/source-builder/config/gdb-7-1.cfg
index d13d536..a415f51 100644
--- a/source-builder/config/gdb-7-1.cfg
+++ b/source-builder/config/gdb-7-1.cfg
@@ -4,145 +4,4 @@
 # This configuration file configure's, make's and install's gdb.
-# See if the simulator has been disabled for Windows.
-# Build using the system's readline, it is in better shape
-# than GDB's one with MSYS2.
-%if %{_host_os} == win32
- %if %{defined win32-gdb-disable-sim}
-  %define gdb-disable-sim 1
- %endif
- %define with_system_readline 1
-%endif
-# Default to building simulators.
-%ifn %{defined gdb-disable-sim}
- %define gdb-disable-sim 0
-%else
- %undefine gdb-sim-options
-%endif
-%include %{_configdir}/checks.cfg
-# Select Snapshot Macro Maps
-%select gdb-snapshot
-%select expat-snapshot
-# The description.
-Name:      %{_target}-gdb-%{gdb_version}-%{_host}-%{release}
-Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
-Version:   %{gdb_version}
-Release:   %{release}
-URL: 	   http://www.gnu.org/software/gdb/
-BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
-# GDB has changed it default extension.
-%ifn %{defined gdb_src_ext}
-  %define gdb_src_ext gz
-%endif
-# Source
-%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.%{gdb_src_ext}
-# Disable Python on Cxc builds for now.
-%if "%{_build}" != "%{_host}"
-  %define without_python
-%endif
-# The --with-python option is either the default which is auto or the path to
-# the specific python to be used.
-%if %{defined with_python_path}
-  %define with_python_option --with-python=%{with_python_path}
-%else
-%endif
-# Prepare the source code.
-%prep
-  build_top=$(pwd)
-  gdb_source=%{?gdb_external:%{gdb_expand_name}}%{!?gdb_external:"gdb-%{gdb_version}"}
-  source_dir_gdb=${gdb_source}
-  %source setup gdb -q -n ${gdb_source}
-  %patch setup gdb -p1
-  cd ${build_top}
-%build
-  build_top=$(pwd)
-  %{build_directory}
-  mkdir -p ${build_dir}
-  cd ${build_dir}
-  %{host_build_flags}
-  if test "%{_build}" != "%{_host}" ; then
-    GDB_LIBS_STATIC="-lexpat"
-  else
-    GDB_LIBS="%{_forced_static}"
-  fi
-  LIBS_STATIC=${GDB_LIBS_STATIC} \
-  LIBS=${GDB_LIBS} \
-  ../${source_dir_gdb}/configure \
-    --build=%{_build} --host=%{_host} \
-    --target=%{_target} \
-    --verbose --disable-nls \
-    --disable-gas --disable-binutils --disable-ld --disable-gold --disable-gprof \
-    %{?with_system_readline:--with-system-readline} \
-    --without-included-gettext \
-    --disable-win32-registry \
-    --disable-werror \
-    %{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim} \
-    %{?gdb-sim-options:%{gdb-sim-options}} \
-    --without-zlib \
-    --with-expat \
-    --with-guile=no \
-    %{!?without_python:%{with_python_option}} \
-    --prefix=%{_prefix} --bindir=%{_bindir} \
-    --exec-prefix=%{_exec_prefix} \
-    --includedir=%{_includedir} --libdir=%{_libdir} \
-    --mandir=%{_mandir} --infodir=%{_infodir}
-  %{__make} %{?_smp_mflags} all
-  cd ${build_top}
-%install
-  build_top=$(pwd)
-  %{__rmdir} $SB_BUILD_ROOT
-  cd ${build_dir}
-  %{__make} DESTDIR=$SB_BUILD_ROOT install
-  # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
-  %{__rmdir} $SB_BUILD_ROOT%{_infodir}/configure.info*
-  %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
-  touch $SB_BUILD_ROOT%{_infodir}/dir
-  cd ${build_top}
+%include %{_configdir}/gdb-common-1.cfg
diff --git a/source-builder/config/gdb-8-1.cfg b/source-builder/config/gdb-8-1.cfg
new file mode 100644
index 0000000..dfbe439
--- /dev/null
+++ b/source-builder/config/gdb-8-1.cfg
@@ -0,0 +1,7 @@
+# GDB 8.xx Version 1.
+# This configuration file configure's, make's and install's gdb.
diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
index 0000000..fe4dbaf
--- /dev/null
+++ b/source-builder/config/gdb-common-1.cfg
@@ -0,0 +1,148 @@
+# GDB Common Version 1.
+# See if the simulator has been disabled for Windows.
+# Build using the system's readline, it is in better shape
+# than GDB's one with MSYS2.
+%if %{_host_os} == win32
+ %if %{defined win32-gdb-disable-sim}
+  %define gdb-disable-sim 1
+ %endif
+ %define with_system_readline 1
+%endif
+# Default to building simulators.
+%ifn %{defined gdb-disable-sim}
+ %define gdb-disable-sim 0
+%else
+ %undefine gdb-sim-options
+%endif
+%include %{_configdir}/checks.cfg
+# Select Snapshot Macro Maps
+%select gdb-snapshot
+%select expat-snapshot
+# The description.
+Name:      %{_target}-gdb-%{gdb_version}-%{_host}-%{release}
+Summary:   GDB v%{gdb_version} for target %{_target} on host %{_host}
+Version:   %{gdb_version}
+Release:   %{release}
+URL: 	   http://www.gnu.org/software/gdb/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# GDB has changed it default extension.
+%ifn %{defined gdb_src_ext}
+  %define gdb_src_ext gz
+%endif
+# Source
+%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.%{gdb_src_ext}
+# Disable Python on Cxc builds for now.
+%if "%{_build}" != "%{_host}"
+  %define without_python
+%endif
+# The --with-python option is either the default which is auto or the path to
+# the specific python to be used.
+%if %{defined with_python_path}
+  %define with_python_option --with-python=%{with_python_path}
+%else
+%endif
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  gdb_source=%{?gdb_external:%{gdb_expand_name}}%{!?gdb_external:"gdb-%{gdb_version}"}
+  source_dir_gdb=${gdb_source}
+  %source setup gdb -q -n ${gdb_source}
+  %patch setup gdb -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  if test "%{_build}" != "%{_host}" ; then
+    GDB_LIBS_STATIC="-lexpat"
+  else
+    GDB_LIBS="%{_forced_static}"
+  fi
+  LIBS_STATIC=${GDB_LIBS_STATIC} \
+  LIBS=${GDB_LIBS} \
+  ../${source_dir_gdb}/configure \
+    --build=%{_build} --host=%{_host} \
+    --target=%{_target} \
+    --verbose --disable-nls \
+    --disable-gas --disable-binutils --disable-ld --disable-gold --disable-gprof \
+    %{?with_system_readline:--with-system-readline} \
+    --without-included-gettext \
+    --disable-win32-registry \
+    --disable-werror \
+    %{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim} \
+    %{?gdb-sim-options:%{gdb-sim-options}} \
+    --without-zlib \
+    --with-expat \
+    --with-guile=no \
+    %{!?without_python:%{with_python_option}} \
+    --prefix=%{_prefix} --bindir=%{_bindir} \
+    --exec-prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} --libdir=%{_libdir} \
+    --mandir=%{_mandir} --infodir=%{_infodir}
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  # Dropped in FSF-binutils-2.9.5, but Cygwin still ships it.
+  %{__rmdir} $SB_BUILD_ROOT%{_infodir}/configure.info*
+  %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
+  touch $SB_BUILD_ROOT%{_infodir}/dir
+  cd ${build_top}
2.14.1
