[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Tue Jun 19 03:34:14 UTC 2018
On 19/06/2018 13:24, Chris Johns wrote:
> INFO: DesiredSymbols::createCoverageMap - Attempt to create unified coverage
> maps for _Workspace_Allocate_or_fatal_error with different sizes
> (/opt/work/chris/rtems/kernel/bsps/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture.exe/80!=
> /opt/work/chris/rtems/kernel/bsps/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp.exe/60)
>From the DWARF info I see:
capture.exe:
 dwarf::function: _Workspace_Allocate_or_fatal_error \
  pc_low = 0x40015e04 pc_high = 0x40015e40
base_sp.exe:
  pc_low = 0x4000c070 pc_high = 0x4000c0ac
which is 60 bytes for both so the capture.exe size of 80 is wrong. Moving covoar
over to DWARF will improve this issue.
