[PATCH 1/3] score: Add CPU_INTERRUPT_STACK_ALIGNMENT
Tue Jun 19 13:30:39 UTC 2018
Add CPU port define for the interrupt stack alignment.  The alignment
should take the stack ABI and the cache line size into account.
Update #3459.
 cpukit/score/cpu/arm/include/rtems/score/cpu.h      | 2 ++
 cpukit/score/cpu/bfin/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/epiphany/include/rtems/score/cpu.h | 2 ++
 cpukit/score/cpu/i386/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/lm32/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/m32c/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/m68k/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/mips/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/moxie/include/rtems/score/cpu.h    | 2 ++
 cpukit/score/cpu/nios2/include/rtems/score/cpu.h    | 2 ++
 cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h   | 8 ++++++++
 cpukit/score/cpu/or1k/include/rtems/score/cpu.h     | 2 ++
 cpukit/score/cpu/powerpc/include/rtems/score/cpu.h  | 2 ++
 cpukit/score/cpu/riscv/include/rtems/score/cpu.h    | 5 +++++
 cpukit/score/cpu/sh/include/rtems/score/cpu.h       | 2 ++
 cpukit/score/cpu/sparc/include/rtems/score/cpu.h    | 2 ++
 cpukit/score/cpu/sparc64/include/rtems/score/cpu.h  | 2 ++
 cpukit/score/cpu/v850/include/rtems/score/cpu.h     | 2 ++
 18 files changed, 45 insertions(+)
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index f5827b4fc6..3f06c036f0 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -165,6 +165,8 @@
 /* AAPCS, section 5.2.1.2, Stack constraints at a public interface */
 #define CPU_STACK_ALIGNMENT 8
+#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
  * Bitfield handler macros.
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
index a361e023ed..d3e4e4b057 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
@@ -563,6 +563,8 @@ typedef struct {
 #ifndef ASM
diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
index 84565d15d2..65f28ac435 100644
--- a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
@@ -465,6 +465,8 @@ typedef Context_Control CPU_Interrupt_frame;
 /* ISR handler macros */
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 0986663be1..226d20b85f 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -384,6 +384,8 @@ extern Context_Control_fp _CPU_Null_fp_context;
 #define CPU_STACK_ALIGNMENT             16
 /* macros */
 #ifndef ASM
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
index fe8107c51b..77f3389f39 100644
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
@@ -581,6 +581,8 @@ extern Context_Control_fp _CPU_Null_fp_context;
 #define CPU_STACK_ALIGNMENT        CPU_ALIGNMENT
diff --git a/cpukit/score/cpu/m32c/include/rtems/score/cpu.h b/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
index c5486e80d6..3f23c21d88 100644
--- a/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
@@ -556,6 +556,8 @@ typedef struct {
 #define CPU_STACK_ALIGNMENT        0
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
index 459ef8a9cd..bd1f29abe4 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
@@ -355,6 +355,8 @@ extern void*                     _VBR;
 #ifndef ASM
 /* macros */
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index 46d1eb28e8..c20e5f4f01 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -631,6 +631,8 @@ extern Context_Control_fp _CPU_Null_fp_context;
 void mips_vector_exceptions( CPU_Interrupt_frame *frame );
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index 403b05f9fb..9b6dbecc9c 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -465,6 +465,8 @@ typedef struct {
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index 1d088ed058..3cc56e591b 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -87,6 +87,8 @@ extern "C" {
 #define CPU_STACK_ALIGNMENT 4
  * A Nios II configuration with an external interrupt controller (EIC) supports
  * up to 64 interrupt levels.  A Nios II configuration with an internal
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index acb6356efa..ba6e7fe02a 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -695,6 +695,14 @@ extern Context_Control_fp _CPU_Null_fp_context;
+ * The alignment of the interrupt stack in bytes.
+ * The alignment should take the stack ABI and the cache line size into
+ * account.
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index b13057712a..b9296df6e1 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -462,6 +462,8 @@ typedef Context_Control CPU_Interrupt_frame;
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
index db2479b210..ac6ecccc1d 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
@@ -762,6 +762,8 @@ void ppc_set_interrupt_level( uint32_t level );
 #define CPU_STACK_ALIGNMENT        (PPC_STACK_ALIGNMENT)
 #ifndef ASM
 /*  The following routine swaps the endian format of an unsigned int.
  *  It must be static because it is referenced indirectly.
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index c073006cb1..ad2d3dbe46 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -137,6 +137,8 @@ typedef Context_Control CPU_Interrupt_frame;
 #define CPU_CONTEXT_FP_SIZE  0
+#define CPU_CACHE_LINE_BYTES 64
 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
 #if __riscv_xlen == 32
 #define CPU_STACK_MINIMUM_SIZE  4096
@@ -148,6 +150,9 @@ Context_Control_fp  _CPU_Null_fp_context;
 #define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
 #define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
 #define _CPU_Initialize_vectors()
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpu.h b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
index 79453bc1ac..d3c9bc6d39 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
@@ -438,6 +438,8 @@ void CPU_delay( uint32_t   microseconds );
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index 55c1387aaa..8aa701dde2 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -823,6 +823,8 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
 #ifndef ASM
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
index f1412e0bbb..feb7752915 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
@@ -709,6 +709,8 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
 #ifndef ASM
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index 5c65f8532f..dbae3c4234 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
@@ -524,6 +524,8 @@ typedef struct {
2.13.7
