[GSoC] Status update: Adding IO Benchmark to RTEMS
Udit agarwal
dev.madaari at gmail.com
Tue Jun 19 22:07:39 UTC 2018
Hi all,
We've managed to run fio on RTEMS. Currently, the following IOengines are
working: psync, vsync ,sync, null, filecreate, ftruncate. Following are the
rough sd card(with FAT fs) benchmarking results i got:
During a read operation:
> IOPS=201, BW=804KiB/s
And during a write operation:
> IOPS=56, BW=224KiB/s
Here <https://gist.github.com/madaari/54a6c43c69a95e7b7d7a61632c8dfda6> are
the complete results. I''ve documented the procedure on my blog
<http://uditagarwal.in/> and updated the ticket #3429
<https://devel.rtems.org/ticket/3429> with the leftovers.
Immediate goal after this is to get the generated code merged upstream to
fio's main repository, i'm working on that, but that can move in parallel
with phase 2 objectives.
Regards,
Udit AGarwal
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180620/c7a1b2aa/attachment.html>
