[PATCH v2 3/3] Rework initialization and interrupt stack support
Thu Jun 21 07:19:37 UTC 2018
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>.  Place the
interrupt stack area in a special section ".rtemsstack.interrupt".  Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures.  There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack().  Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
  * interrupts are disabled during the sequential system initialization,
    and
  * the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
  * Mostly replace the linker symbol based configuration of stacks with
    the standard <rtems/confdefs.h> configuration via
    CONFIGURE_INTERRUPT_STACK_SIZE.  The size of the FIQ, ABT and UND
    mode stack is still defined via linker symbols.  These modes are
    rarely used in applications and the default values provided by the
    BSP should be sufficient in most cases.
  * Remove the bsp_processor_count linker symbol hack used for the SMP
    support. This is possible since the interrupt stack area is now
    allocated by the linker and not allocated from the heap.  This makes
    some configure.ac stuff obsolete.  Remove the now superfluous BSP
    variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
  * Remove unused magic linker command file allocation of initialization
    stack.  Maybe a previous linker command file copy and paste problem?
    In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, sh, v850:
  * Remove magic linker command file allocation of initialization stack.
    Reuse interrupt stack for initialization stack.
m68k:
powerpc:
  * Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
    stack on BSPs using the shared linkcmds.base (replacement for
    REGION_RWEXTRA).
sparc:
  * Remove the hard coded initialization stack.  Use the interrupt stack
    for the initialization stack on the boot processor.  This saves
    16KiB of RAM.
Update #3459.
 .../altera-cyclone-v/config/altcycv_devkit_smp.cfg |   1 -
 .../start/linkcmds.altcycv_devkit_smp              |   3 -
 bsps/arm/csb336/start/start.S                      |  90 ++++++--------
 bsps/arm/csb337/start/start.S                      |  89 +++++++-------
 bsps/arm/edb7312/start/start.S                     |  98 +++++++---------
 bsps/arm/gumstix/start/start.S                     |  87 +++++++-------
 bsps/arm/imx/start/linkcmds.imx7                   |   3 -
 bsps/arm/include/bsp/linker-symbols.h              |  23 +---
 bsps/arm/raspberrypi/start/bspsmp.c                |   7 +-
 .../raspberrypi/start/{linkcmds.in => linkcmds}    |   3 -
 .../config/realview_pbx_a9_qemu_smp.cfg            |   1 -
 .../start/linkcmds.realview_pbx_a9_qemu_smp        |   3 -
 bsps/arm/rtl22xx/start/start.S                     |  71 +++++-------
 bsps/arm/shared/start/arm-a9mpcore-smp.c           |   8 +-
 bsps/arm/shared/start/linkcmds.base                |  50 --------
 bsps/arm/shared/start/start.S                      | 129 ++++++++-------------
 bsps/arm/smdk2410/start/start.S                    |  67 +++++------
 bsps/arm/xilinx-zynq/start/linkcmds.in             |   3 -
 bsps/bfin/TLL6527M/start/linkcmds                  |   4 -
 bsps/bfin/bf537Stamp/start/linkcmds                |   4 -
 bsps/bfin/eZKit533/start/linkcmds                  |   4 -
 bsps/lm32/lm32_evr/start/linkcmds                  |   6 -
 bsps/lm32/milkymist/start/linkcmds                 |   6 -
 bsps/lm32/shared/start/start.S                     |   4 +-
 bsps/m32c/m32cbsp/start/linkcmds                   |  14 ---
 bsps/m32c/m32cbsp/start/start.S                    |   2 +-
 bsps/m68k/gen68340/start/linkcmds                  |   5 -
 bsps/m68k/gen68340/start/start.S                   |   2 +-
 bsps/m68k/gen68360/start/linkcmds                  |   5 -
 bsps/m68k/gen68360/start/linkcmds.bootp            |   5 -
 bsps/m68k/gen68360/start/linkcmds.prom             |   5 -
 bsps/m68k/gen68360/start/start.S                   |   2 +-
 bsps/m68k/genmcf548x/start/linkcmds.COBRA5475      |   2 -
 .../m68k/genmcf548x/start/linkcmds.m5484FireEngine |   2 -
 .../start/linkcmds.m5484FireEngine.flash           |   2 -
 bsps/m68k/mcf52235/start/linkcmds                  |  11 --
 bsps/m68k/mcf52235/start/start.S                   |   8 +-
 bsps/m68k/mcf5225x/start/linkcmds                  |  11 --
 bsps/m68k/mcf5225x/start/start.S                   |   8 +-
 bsps/m68k/mcf5329/start/linkcmds                   |  14 +--
 bsps/m68k/mcf5329/start/linkcmdsflash              |  14 +--
 bsps/m68k/mcf5329/start/start.S                    |   6 +-
 bsps/m68k/mrm332/start/linkcmds                    |   5 -
 bsps/m68k/mrm332/start/start.S                     |   8 +-
 bsps/m68k/shared/start/start.S                     |   9 +-
 bsps/mips/csb350/start/linkcmds                    |   5 -
 bsps/mips/csb350/start/start.S                     |   2 +-
 bsps/mips/hurricane/start/linkcmds                 |   5 -
 bsps/mips/jmr3904/start/linkcmds                   |   8 --
 bsps/mips/jmr3904/start/start.S                    |   2 +-
 bsps/mips/malta/start/linkcmds                     |   8 --
 bsps/mips/malta/start/start.S                      |   2 +-
 bsps/mips/rbtx4925/start/linkcmds                  |   5 -
 bsps/mips/rbtx4938/start/linkcmds                  |   5 -
 bsps/mips/shared/irq/exception.S                   |  10 +-
 bsps/nios2/nios2_iss/start/linkcmds                |   6 +-
 bsps/powerpc/beatnik/start/bspstart.c              |   6 +-
 bsps/powerpc/gen83xx/start/start.S                 |   9 +-
 bsps/powerpc/haleakala/start/bspstart.c            |   7 +-
 bsps/powerpc/haleakala/start/linkcmds              |  16 ---
 bsps/powerpc/motorola_powerpc/start/bspstart.c     |   2 +-
 bsps/powerpc/mpc55xxevb/start/start.S              |  10 +-
 bsps/powerpc/mpc8260ads/start/linkcmds             |  11 --
 bsps/powerpc/mvme3100/start/bspstart.c             |   2 +-
 bsps/powerpc/mvme5500/start/bspstart.c             |   2 +-
 bsps/powerpc/psim/start/start.S                    |  10 +-
 bsps/powerpc/qemuppc/start/bspstart.c              |   6 +-
 bsps/powerpc/qemuppc/start/start.S                 |  15 +--
 bsps/powerpc/qoriq/start/start.S                   |  18 +--
 bsps/powerpc/shared/start/linkcmds.base            |   1 -
 bsps/powerpc/t32mppc/start/start.S                 |   8 +-
 bsps/powerpc/tqm8xx/start/start.S                  |  13 +--
 bsps/powerpc/virtex4/start/bspstart.c              |   7 +-
 bsps/powerpc/virtex4/start/linkcmds                |  11 --
 bsps/powerpc/virtex4/start/start.S                 |   4 +-
 bsps/powerpc/virtex5/start/bspstart.c              |   7 +-
 bsps/powerpc/virtex5/start/linkcmds                |  11 --
 bsps/powerpc/virtex5/start/start.S                 |   4 +-
 bsps/sh/gensh1/include/bsp.h                       |   7 --
 bsps/sh/gensh1/start/cpu_asm.c                     |  10 +-
 bsps/sh/gensh1/start/linkcmds                      |   5 -
 bsps/sh/gensh1/start/start.S                       |  10 +-
 bsps/sh/gensh2/include/bsp.h                       |   6 -
 bsps/sh/gensh2/start/cpu_asm.c                     |  10 +-
 bsps/sh/gensh2/start/linkcmds                      |   5 -
 bsps/sh/gensh2/start/linkcmds.ram                  |   5 -
 bsps/sh/gensh2/start/linkcmds.rom                  |   5 -
 bsps/sh/gensh2/start/start.S                       |  10 +-
 bsps/sh/gensh2/start/start.ram                     |  10 +-
 bsps/sh/gensh2/start/start.rom                     |  10 +-
 bsps/sh/gensh4/include/bsp.h                       |   7 --
 bsps/sh/gensh4/start/cpu_asm.c                     |   9 +-
 bsps/sh/gensh4/start/linkcmds                      |   8 --
 bsps/sh/gensh4/start/linkcmds.rom                  |  12 --
 bsps/sh/gensh4/start/linkcmds.rom2ram              |  12 --
 bsps/sh/gensh4/start/start.S                       |  10 +-
 bsps/sh/shared/start/bspstart.c                    |   8 --
 bsps/sh/shsim/include/bsp.h                        |   6 -
 bsps/sh/shsim/start/cpu_asm.c                      |  10 +-
 bsps/sh/shsim/start/linkcmds                       |  14 ---
 bsps/sh/shsim/start/start.S                        |  12 +-
 bsps/sparc/shared/start/bspgetworkarea.c           |   6 +-
 bsps/sparc/shared/start/start.S                    |  12 +-
 bsps/v850/gdbv850sim/start/linkcmds                |  11 --
 bsps/v850/gdbv850sim/start/start.S                 |  11 +-
 c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am  |   1 -
 c/src/lib/libbsp/arm/raspberrypi/configure.ac      |  17 +--
 c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am   |   1 -
 c/src/lib/libbsp/arm/xilinx-zynq/configure.ac      |   5 -
 cpukit/include/rtems/confdefs.h                    |  54 ++++-----
 cpukit/include/rtems/config.h                      |  35 ++++--
 cpukit/include/rtems/score/percpu.h                |  53 +++------
 cpukit/libmisc/stackchk/check.c                    |   2 -
 cpukit/score/cpu/arm/include/rtems/score/cpu.h     |   6 -
 cpukit/score/cpu/bfin/cpu.c                        |  14 ---
 cpukit/score/cpu/bfin/include/rtems/score/cpu.h    |  91 ---------------
 cpukit/score/cpu/epiphany/cpu.c                    |   5 -
 .../score/cpu/epiphany/include/rtems/score/cpu.h   |  73 ------------
 cpukit/score/cpu/i386/include/rtems/score/cpu.h    |   8 --
 cpukit/score/cpu/lm32/cpu.c                        |  12 --
 cpukit/score/cpu/lm32/include/rtems/score/cpu.h    |  90 --------------
 cpukit/score/cpu/lm32/irq.c                        |   8 +-
 cpukit/score/cpu/m32c/cpu.c                        |  12 --
 cpukit/score/cpu/m32c/cpu_asm.c                    |  12 +-
 cpukit/score/cpu/m32c/include/rtems/score/cpu.h    |  93 ---------------
 cpukit/score/cpu/m68k/cpu.c                        |  26 ++---
 cpukit/score/cpu/m68k/cpu_asm.S                    |   8 +-
 cpukit/score/cpu/m68k/include/rtems/score/cpu.h    |  22 ----
 cpukit/score/cpu/mips/cpu.c                        |   5 -
 cpukit/score/cpu/mips/cpu_asm.S                    |  10 +-
 cpukit/score/cpu/mips/include/rtems/score/cpu.h    |  65 -----------
 cpukit/score/cpu/moxie/cpu.c                       |   7 --
 cpukit/score/cpu/moxie/include/rtems/score/cpu.h   |  77 ------------
 cpukit/score/cpu/nios2/include/rtems/score/cpu.h   |   6 -
 cpukit/score/cpu/nios2/nios2-iic-irq.c             |   8 +-
 cpukit/score/cpu/no_cpu/cpu.c                      |  12 --
 cpukit/score/cpu/no_cpu/cpu_asm.c                  |  12 +-
 cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h  |  93 ++-------------
 cpukit/score/cpu/or1k/cpu.c                        |   4 -
 cpukit/score/cpu/or1k/include/rtems/score/cpu.h    |  73 ------------
 cpukit/score/cpu/powerpc/include/rtems/score/cpu.h |  54 ---------
 cpukit/score/cpu/riscv/cpu.c                       |   5 -
 cpukit/score/cpu/riscv/include/rtems/score/cpu.h   |  15 ---
 cpukit/score/cpu/sh/include/rtems/score/cpu.h      |  43 -------
 cpukit/score/cpu/sparc/include/rtems/score/cpu.h   |  34 ------
 cpukit/score/cpu/sparc64/include/rtems/score/cpu.h |  32 -----
 cpukit/score/cpu/v850/cpu_asm.S                    |  73 ------------
 cpukit/score/cpu/v850/include/rtems/score/cpu.h    |  78 -------------
 cpukit/score/src/isr.c                             |  64 +++++-----
 cpukit/score/src/percpuasm.c                       |  23 ++--
 testsuites/sptests/spfatal07/testcase.h            |  37 +-----
 testsuites/sptests/spsize/size.c                   |   2 -
 152 files changed, 493 insertions(+), 2370 deletions(-)
 delete mode 100644 bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg
 delete mode 100644 bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp
 rename bsps/arm/raspberrypi/start/{linkcmds.in => linkcmds} (92%)
 delete mode 100644 bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg
 delete mode 100644 bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp
diff --git a/bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg b/bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg
deleted file mode 100644
index ed54edfedd..0000000000
--- a/bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg
+++ /dev/null
@@ -1 +0,0 @@
-include $(RTEMS_ROOT)/make/custom/altcycv.inc
diff --git a/bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp b/bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp
index 2da086579f..0000000000
--- a/bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp
+++ /dev/null
@@ -1,3 +0,0 @@
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 2;
-INCLUDE linkcmds.altcycv_devkit
diff --git a/bsps/arm/csb336/start/start.S b/bsps/arm/csb336/start/start.S
index ce452f52a2..2ef4cb71fa 100644
--- a/bsps/arm/csb336/start/start.S
+++ b/bsps/arm/csb336/start/start.S
@@ -8,20 +8,8 @@
  * http://www.rtems.org/license/LICENSE.
-#include <bsp/linker-symbols.h>
-/* Some standard definitions...*/
-.equ PSR_MODE_USR,       0x10
-.equ PSR_MODE_FIQ,       0x11
-.equ PSR_MODE_IRQ,       0x12
-.equ PSR_MODE_SVC,       0x13
-.equ PSR_MODE_ABT,       0x17
-.equ PSR_MODE_UNDEF,     0x1B
-.equ PSR_MODE_SYS,       0x1F
-.equ PSR_I,              0x80
-.equ PSR_F,              0x40
-.equ PSR_T,              0x20
+#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
 .section .bsp_start_text,"ax"
          .code 32
@@ -36,60 +24,56 @@ _start:
          * Since I don't plan to return to the bootloader,
          * I don't have to save the registers.
-         * I'll just set the CPSR for SVC mode, interrupts
-         * off, and ARM instructions.
-        mov     r0, #(PSR_MODE_SVC | PSR_I | PSR_F)
-        msr     cpsr, r0
-        /* zero the bss */
-        ldr     r1, =bsp_section_bss_end
-        ldr     r0, =bsp_section_bss_begin
-_bss_init:
-        mov     r2, #0
-        cmp     r0, r1
-        strlot  r2, [r0], #4
-        blo     _bss_init        /* loop while r0 < r1 */
-        /* --- Initialize stack pointer registers */
-        /* Enter IRQ mode and set up the IRQ stack pointer */
-        mov     r0, #(PSR_MODE_IRQ | PSR_I | PSR_F)     /* No interrupts */
-        msr     cpsr, r0
-        ldr     r1, =bsp_stack_irq_size
-        ldr     sp, =bsp_stack_irq_begin
-        add     sp, sp, r1
+        /* Set end of interrupt stack area */
+        ldr     r7, =_Configuration_Interrupt_stack_area_end
         /* Enter FIQ mode and set up the FIQ stack pointer */
-        mov     r0, #(PSR_MODE_FIQ | PSR_I | PSR_F)     /* No interrupts */
+        mov     r0, #(ARM_PSR_M_FIQ | ARM_PSR_I | ARM_PSR_F)
         msr     cpsr, r0
         ldr     r1, =bsp_stack_fiq_size
-        ldr     sp, =bsp_stack_fiq_begin
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
         /* Enter ABT mode and set up the ABT stack pointer */
-        mov     r0, #(PSR_MODE_ABT | PSR_I | PSR_F)     /* No interrupts */
+        mov     r0, #(ARM_PSR_M_ABT | ARM_PSR_I | ARM_PSR_F)
         msr     cpsr, r0
         ldr     r1, =bsp_stack_abt_size
-        ldr     sp, =bsp_stack_abt_begin
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
-        /* Enter UNDEF mode and set up the UNDEF stack pointer */
-        mov     r0, #(PSR_MODE_UNDEF | PSR_I | PSR_F)     /* No interrupts */
+        /* Enter UND mode and set up the UND stack pointer */
+        mov     r0, #(ARM_PSR_M_UND | ARM_PSR_I | ARM_PSR_F)
         msr     cpsr, r0
         ldr     r1, =bsp_stack_und_size
-        ldr     sp, =bsp_stack_und_begin
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
-        /* Set up the SVC stack pointer last and stay in SVC mode */
-        mov     r0, #(PSR_MODE_SVC | PSR_I | PSR_F)     /* No interrupts */
+        /* Enter IRQ mode and set up the IRQ stack pointer */
+        mov     r0, #(ARM_PSR_M_IRQ | ARM_PSR_I | ARM_PSR_F)
+        msr     cpsr, r0
+        mov     sp, r7
+         * Enter SVC mode and set up the SVC stack pointer, reuse IRQ stack
+         * (interrupts are disabled).
+        mov     r0, #(ARM_PSR_M_SVC | ARM_PSR_I | ARM_PSR_F)
         msr     cpsr, r0
-        ldr     r1, =bsp_stack_svc_size
-        ldr     sp, =bsp_stack_svc_begin
-        add     sp, sp, r1
-        sub     sp, sp, #0x64
+        mov     sp, r7
+        /* Stay in SVC mode */
+        /* zero the bss */
+        ldr     r1, =bsp_section_bss_end
+        ldr     r0, =bsp_section_bss_begin
+_bss_init:
+        mov     r2, #0
+        cmp     r0, r1
+        strlot  r2, [r0], #4
+        blo     _bss_init        /* loop while r0 < r1 */
          * Initialize the MMU. After we return, the MMU is enabled,
diff --git a/bsps/arm/csb337/start/start.S b/bsps/arm/csb337/start/start.S
index f88cf41d78..a755864d0d 100644
--- a/bsps/arm/csb337/start/start.S
+++ b/bsps/arm/csb337/start/start.S
@@ -8,20 +8,8 @@
-.equ PSR_I,              0x80
-.equ PSR_F,              0x40
-.equ PSR_T,              0x20
 .text
 .globl  _start
@@ -29,53 +17,56 @@ _start:
-        msr     cpsr, r0
-_bss_init:
-        mov     r2, #0
-        cmp     r0, r1
-        msr     cpsr, r0
-        add     sp, sp, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        ldr     r1, =bsp_stack_und_size
+        mov     sp, r7
+        sub     r7, r7, r1
         msr     cpsr, r0
-        add     sp, sp, r1
-        sub     sp, sp, #0x64
+        mov     sp, r7
+        msr     cpsr, r0
+        mov     sp, r7
+_bss_init:
+        mov     r2, #0
+        cmp     r0, r1
diff --git a/bsps/arm/edb7312/start/start.S b/bsps/arm/edb7312/start/start.S
index e03707bfcf..5806d41ce4 100644
--- a/bsps/arm/edb7312/start/start.S
+++ b/bsps/arm/edb7312/start/start.S
@@ -12,21 +12,8 @@
-.equ Mode_USR,        	     0x10
-.equ Mode_FIQ,        	     0x11
-.equ Mode_IRQ,        	     0x12
-.equ Mode_SVC,        	     0x13
-.equ Mode_ABT,        	     0x17
-.equ Mode_ABORT,             0x17
-.equ Mode_UNDEF,      	     0x1B
-.equ Mode_SYS,        	     0x1F /*only available on ARM Arch. v4*/
-.equ I_Bit,           	     0x80
-.equ F_Bit,           	     0x40
 .section ".bsp_start_text", "ax"
 .arm
@@ -72,8 +59,44 @@ handler_addr_fiq:
 	.globl	_start
 _start:
-	/* store the sp */
-	mov	r12, sp
+        /* Enter FIQ mode and set up the FIQ stack pointer */
+        msr     cpsr, r0
+        ldr     r1, =bsp_stack_fiq_size
+        mov     sp, r7
+        sub     r7, r7, r1
+        /* Enter ABT mode and set up the ABT stack pointer */
+        msr     cpsr, r0
+        ldr     r1, =bsp_stack_abt_size
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
+        msr     cpsr, r0
+        mov     sp, r7
  * Here is the code to initialize the low-level BSP environment
  * (Chip Select, PLL, ....?)
@@ -89,48 +112,7 @@ zi_init:
         STRLOT   r2, [r0], #4
         BLO     zi_init
-/* --- Initialise stack pointer registers */
-/* Enter IRQ mode and set up the IRQ stack pointer */
-    MOV     r0, #Mode_IRQ | I_Bit | F_Bit     /* No interrupts */
-    MSR     cpsr, r0
-    LDR     sp, =bsp_stack_irq_begin
-    add	    sp, sp, r1
-    sub     sp, sp, #0x64
-/* Enter FIQ mode and set up the FIQ stack pointer */
-    MOV     r0, #Mode_FIQ | I_Bit | F_Bit     /* No interrupts */
-    MSR     cpsr, r0
-    ldr	    r1, =bsp_stack_fiq_size
-    LDR     sp, =bsp_stack_fiq_begin
-    add	    sp, sp, r1
-    sub     sp, sp, #0x64
-/* Enter ABT mode and set up the ABT stack pointer */
-    MOV     r0, #Mode_ABT | I_Bit | F_Bit     /* No interrupts */
-    MSR     cpsr, r0
-    ldr	    r1, =bsp_stack_abt_size
-    LDR     sp, =bsp_stack_abt_begin
-    add	    sp, sp, r1
-    sub     sp, sp, #0x64
-/* Set up the SVC stack pointer last and stay in SVC mode */
-    MOV     r0, #Mode_SVC | I_Bit | F_Bit     /* No interrupts */
-    MSR     cpsr, r0
-    LDR     sp, =bsp_stack_svc_begin
-    add	    sp, sp, r1
-    sub     sp, sp, #0x64
-	/* save the original registers */
-	stmdb	sp!, {r4-r12, lr}
 /* --- Now we enter the C code */
 	mov     r0, #0
 	bl	boot_card
-	ldmia	sp!, {r4-r12, lr}
-	mov	sp, r12
-	mov	pc, lr
diff --git a/bsps/arm/gumstix/start/start.S b/bsps/arm/gumstix/start/start.S
index dccc99993e..7c71bdacf1 100644
--- a/bsps/arm/gumstix/start/start.S
+++ b/bsps/arm/gumstix/start/start.S
@@ -7,20 +7,8 @@
-.equ PSR_I,              0x80
-.equ PSR_F,              0x40
-.equ PSR_T,              0x20
 .text
 .globl  _start
@@ -28,53 +16,56 @@ _start:
-        msr     cpsr, r0
-_bss_init:
-        mov     r2, #0
-        cmp     r0, r1
-        msr     cpsr, r0
-        add     sp, sp, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
         msr     cpsr, r0
-        add     sp, sp, r1
-        sub     sp, sp, #0x64
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
+        msr     cpsr, r0
+        mov     sp, r7
+_bss_init:
+        mov     r2, #0
+        cmp     r0, r1
diff --git a/bsps/arm/imx/start/linkcmds.imx7 b/bsps/arm/imx/start/linkcmds.imx7
index 750e1def1d..0d9fe48bf9 100644
--- a/bsps/arm/imx/start/linkcmds.imx7
+++ b/bsps/arm/imx/start/linkcmds.imx7
@@ -22,9 +22,6 @@ REGION_ALIAS ("REGION_STACK", RAM);
 REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
 REGION_ALIAS ("REGION_NOCACHE_LOAD", NOCACHE);
-bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 4096;
 bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
 bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
diff --git a/bsps/arm/include/bsp/linker-symbols.h b/bsps/arm/include/bsp/linker-symbols.h
index 1a996f51f2..135c85f215 100644
--- a/bsps/arm/include/bsp/linker-symbols.h
+++ b/bsps/arm/include/bsp/linker-symbols.h
@@ -43,30 +43,11 @@ extern "C" {
   #define LINKER_SYMBOL(sym) .extern sym
 #endif
-LINKER_SYMBOL(bsp_stack_irq_begin)
-LINKER_SYMBOL(bsp_stack_irq_end)
-LINKER_SYMBOL(bsp_stack_irq_size)
-LINKER_SYMBOL(bsp_stack_fiq_begin)
-LINKER_SYMBOL(bsp_stack_fiq_end)
-LINKER_SYMBOL(bsp_stack_abt_begin)
-LINKER_SYMBOL(bsp_stack_abt_end)
+LINKER_SYMBOL(bsp_stack_fiq_size)
 LINKER_SYMBOL(bsp_stack_abt_size)
-LINKER_SYMBOL(bsp_stack_und_begin)
-LINKER_SYMBOL(bsp_stack_und_end)
 LINKER_SYMBOL(bsp_stack_und_size)
-LINKER_SYMBOL(bsp_stack_hyp_begin)
-LINKER_SYMBOL(bsp_stack_hyp_end)
 LINKER_SYMBOL(bsp_stack_hyp_size)
-LINKER_SYMBOL(bsp_stack_svc_begin)
-LINKER_SYMBOL(bsp_stack_svc_end)
-LINKER_SYMBOL(bsp_stack_svc_size)
 LINKER_SYMBOL(bsp_section_start_begin)
 LINKER_SYMBOL(bsp_section_start_end)
 LINKER_SYMBOL(bsp_section_start_size)
@@ -156,8 +137,6 @@ LINKER_SYMBOL(bsp_translation_table_end)
 #define BSP_NOCACHENOLOAD_SUBSECTION(subsection) \
   __attribute__((section(".bsp_noload_nocache." # subsection)))
-LINKER_SYMBOL(bsp_processor_count)
 #ifdef __cplusplus
diff --git a/bsps/arm/raspberrypi/start/bspsmp.c b/bsps/arm/raspberrypi/start/bspsmp.c
index c3e5451442..44f7a1d376 100644
--- a/bsps/arm/raspberrypi/start/bspsmp.c
+++ b/bsps/arm/raspberrypi/start/bspsmp.c
@@ -57,12 +57,7 @@ bool _CPU_SMP_Start_processor( uint32_t cpu_index )
 uint32_t _CPU_SMP_Initialize(void)
-  uint32_t cpu_count = (uint32_t)bsp_processor_count;
-  if ( cpu_count > 4 )
-    cpu_count = 4;
-  return cpu_count;
+  return 4;
 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
diff --git a/bsps/arm/raspberrypi/start/linkcmds.in b/bsps/arm/raspberrypi/start/linkcmds
similarity index 92%
rename from bsps/arm/raspberrypi/start/linkcmds.in
rename to bsps/arm/raspberrypi/start/linkcmds
index 829716c11c..58423abecb 100644
--- a/bsps/arm/raspberrypi/start/linkcmds.in
+++ b/bsps/arm/raspberrypi/start/linkcmds
@@ -41,8 +41,6 @@ MEMORY {
         RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 32k
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : @RASPBERRYPI_CPUS@;
 REGION_ALIAS ("REGION_START", RAM);
 REGION_ALIAS ("REGION_VECTOR", VECTOR_RAM);
 REGION_ALIAS ("REGION_TEXT", RAM);
@@ -61,7 +59,6 @@ REGION_ALIAS ("REGION_STACK", RAM);
 REGION_ALIAS ("REGION_NOCACHE", RAM);
 REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
-bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 3008;
 bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1M;
diff --git a/bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg b/bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg
index fd51a18004..0000000000
--- a/bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg
+++ /dev/null
@@ -1 +0,0 @@
-include $(RTEMS_ROOT)/make/custom/realview_pbx_a9_qemu.cfg
diff --git a/bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp b/bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp
index d31c4f08ae..0000000000
--- a/bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp
+++ /dev/null
@@ -1,3 +0,0 @@
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 8;
-INCLUDE linkcmds.realview_pbx_a9_qemu
diff --git a/bsps/arm/rtl22xx/start/start.S b/bsps/arm/rtl22xx/start/start.S
index c038198aff..0fc265493d 100644
--- a/bsps/arm/rtl22xx/start/start.S
+++ b/bsps/arm/rtl22xx/start/start.S
@@ -8,20 +8,8 @@
-.equ PSR_I,              0x80
-.equ PSR_F,              0x40
-.equ PSR_T,              0x20
 .text
 .code	32
@@ -30,45 +18,46 @@ _start:
-        bic	r0, r0, #PSR_T
-        msr     cpsr, r0
-        add     sp, sp, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
         msr     cpsr, r0
-        add     sp, sp, r1
-        sub     sp, sp, #0x64
+        mov     sp, r7
          * Initialize the exception vectors. This includes the
diff --git a/bsps/arm/shared/start/arm-a9mpcore-smp.c b/bsps/arm/shared/start/arm-a9mpcore-smp.c
index a3a95f4ea2..a8d3a541d4 100644
--- a/bsps/arm/shared/start/arm-a9mpcore-smp.c
+++ b/bsps/arm/shared/start/arm-a9mpcore-smp.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2013-2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -19,7 +19,6 @@
 #include <libcpu/arm-cp15.h>
 #include <bsp/irq.h>
 static void bsp_inter_processor_interrupt(void *arg)
@@ -28,10 +27,7 @@ static void bsp_inter_processor_interrupt(void *arg)
-  uint32_t hardware_count = arm_gic_irq_processor_count();
-  uint32_t linker_count = (uint32_t) bsp_processor_count;
-  return hardware_count <= linker_count ? hardware_count : linker_count;
+  return arm_gic_irq_processor_count();
 void _CPU_SMP_Finalize_initialization(uint32_t cpu_count)
diff --git a/bsps/arm/shared/start/linkcmds.base b/bsps/arm/shared/start/linkcmds.base
index 5a669d87a8..cab8e85674 100644
--- a/bsps/arm/shared/start/linkcmds.base
+++ b/bsps/arm/shared/start/linkcmds.base
@@ -45,25 +45,12 @@ bsp_stack_abt_size = ALIGN (bsp_stack_abt_size, bsp_stack_align);
 bsp_stack_fiq_size = DEFINED (bsp_stack_fiq_size) ? bsp_stack_fiq_size : 0;
 bsp_stack_fiq_size = ALIGN (bsp_stack_fiq_size, bsp_stack_align);
-bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 0;
-bsp_stack_irq_size = ALIGN (bsp_stack_irq_size, bsp_stack_align);
-bsp_stack_svc_size = DEFINED (bsp_stack_svc_size) ? bsp_stack_svc_size : 0;
-bsp_stack_svc_size = ALIGN (bsp_stack_svc_size, bsp_stack_align);
 bsp_stack_und_size = DEFINED (bsp_stack_und_size) ? bsp_stack_und_size : 0;
 bsp_stack_und_size = ALIGN (bsp_stack_und_size, bsp_stack_align);
 bsp_stack_hyp_size = DEFINED (bsp_stack_hyp_size) ? bsp_stack_hyp_size : 0;
 bsp_stack_hyp_size = ALIGN (bsp_stack_hyp_size, bsp_stack_align);
-bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 0;
-bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
-bsp_stack_all_size = bsp_stack_abt_size + bsp_stack_fiq_size + bsp_stack_irq_size + bsp_stack_svc_size + bsp_stack_und_size + bsp_stack_hyp_size + bsp_stack_main_size;
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 1;
 MEMORY {
 	UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
@@ -297,44 +284,7 @@ SECTIONS {
 	.vector : ALIGN_WITH_INPUT {
 		bsp_section_vector_begin = .;
 		. = . + DEFINED (bsp_vector_table_in_start_section) ? 0 : bsp_vector_table_size;
-		. = ALIGN (bsp_stack_align);
-		bsp_stack_irq_begin = .;
-		. = . + bsp_stack_irq_size;
-		bsp_stack_irq_end = .;
-		bsp_stack_svc_begin = .;
-		. = . + bsp_stack_svc_size;
-		bsp_stack_svc_end = .;
-		bsp_stack_fiq_begin = .;
-		. = . + bsp_stack_fiq_size;
-		bsp_stack_fiq_end = .;
-		bsp_stack_und_begin = .;
-		. = . + bsp_stack_und_size;
-		bsp_stack_und_end = .;
-		bsp_stack_hyp_begin = .;
-		. = . + bsp_stack_hyp_size;
-		bsp_stack_hyp_end = .;
-		bsp_stack_abt_begin = .;
-		. = . + bsp_stack_abt_size;
-		bsp_stack_abt_end = .;
-		bsp_stack_main_begin = .;
-		. = . + bsp_stack_main_size;
-		bsp_stack_main_end = .;
-		bsp_stack_secondary_processors_begin = .;
-		. = . + (bsp_processor_count - 1) * bsp_stack_all_size;
-		bsp_stack_secondary_processors_end = .;
-		*(.bsp_vector)
 	} > REGION_VECTOR AT > REGION_VECTOR
 	.rtemsstack (NOLOAD) : {
 		*(SORT(.rtemsstack.*))
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index aa0f3782c9..148625ff97 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -5,7 +5,7 @@
- * Copyright (c) 2008, 2016 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2008, 2018 embedded brains GmbH.  All rights reserved.
  *  Dornierstr. 4
@@ -19,45 +19,10 @@
-#include <rtems/system.h>
 #include <bspopts.h>
-	/* External symbols */
-	.extern	bsp_reset
-	.extern	boot_card
-	.extern	bsp_start_hook_0
-	.extern	bsp_start_hook_1
-	.extern bsp_stack_irq_end
-	.extern bsp_stack_fiq_end
-	.extern bsp_stack_abt_end
-	.extern bsp_stack_und_end
-	.extern bsp_stack_svc_end
-#ifdef RTEMS_SMP
-	.extern bsp_stack_all_size
-#endif
-	.extern	_ARMV4_Exception_undef_default
-	.extern	_ARMV4_Exception_swi_default
-	.extern	_ARMV4_Exception_data_abort_default
-	.extern	_ARMV4_Exception_pref_abort_default
-	.extern	_ARMV4_Exception_reserved_default
-	.extern	_ARMV4_Exception_interrupt
-	.extern	_ARMV4_Exception_fiq_default
-	.extern	_ARMV7M_Exception_default
-#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
-	.extern bsp_start_init_registers_core
-	.extern bsp_start_init_registers_banked_fiq
-	.extern bsp_start_init_registers_vfp
-#endif
-#ifdef BSP_START_IN_HYP_SUPPORT
-	.extern	bsp_start_arm_drop_hyp_mode
-	.globl	bsp_start_hyp_vector_table_begin
-#endif
 	/* Global symbols */
 	.globl	_start
@@ -65,12 +30,17 @@
 	.globl	bsp_start_vector_table_end
 	.globl	bsp_start_vector_table_size
 	.globl	bsp_vector_table_size
-	.globl	bsp_start_hook_0_done
 #if defined(ARM_MULTILIB_ARCH_V4)
+	.globl	bsp_start_hook_0_done
+#ifdef BSP_START_IN_HYP_SUPPORT
+	.globl	bsp_start_hyp_vector_table_begin
+#endif
 	.arm
@@ -208,12 +178,20 @@ _start:
 	add	r1, r1, r7, asl #PER_CPU_CONTROL_SIZE_LOG2
 	mcr	p15, 0, r1, c13, c0, 4
-	/* Calculate stack offset */
-	ldr	r1, =bsp_stack_all_size
-	mul	r1, r7
 #endif
-	mrs	r4, cpsr	/* save original procesor status value  */
+	/* Calculate interrupt stack area end for current processor */
+	ldr	r1, =_Configuration_Interrupt_stack_size
+#ifdef RTEMS_SMP
+	add	r7, #1
+	mul	r1, r1, r7
+#endif
+	ldr	r2, =_Configuration_Interrupt_stack_area_begin
+	add	r7, r1, r2
+	/* Save original CPSR value */
+	mrs	r4, cpsr
 	orr	r0, r4, #(ARM_PSR_I | ARM_PSR_F)
 	msr	cpsr, r4
@@ -222,38 +200,22 @@ _start:
 	cmp	r0, #ARM_PSR_M_HYP
 	bne	bsp_start_skip_hyp_svc_switch
-	/* Boot loader stats kernel in HYP mode, switch to SVC necessary */
-	ldr	sp, =bsp_stack_hyp_end
-#ifdef RTEMS_SMP
-	add	sp, r1
-#endif
+	/* Boot loader starts kernel in HYP mode, switch to SVC necessary */
+	ldr	r1, =bsp_stack_hyp_size
+	mov	sp, r7
+	sub	r7, r7, r1
 	bl	bsp_start_arm_drop_hyp_mode
 bsp_start_skip_hyp_svc_switch:
 #endif
-	 * Set SVC mode, disable interrupts and enable ARM instructions.
-	mov	r0, #(ARM_PSR_M_SVC | ARM_PSR_I | ARM_PSR_F)
-	msr	cpsr, r0
 	/* Initialize stack pointer registers for the various modes */
-	mov	r0, #(ARM_PSR_M_IRQ | ARM_PSR_I | ARM_PSR_F)
-	msr	cpsr, r0
-	ldr	sp, =bsp_stack_irq_end
-#ifdef RTEMS_SMP
-	add	sp, r1
-#endif
 	msr	cpsr, r0
-	ldr	sp, =bsp_stack_fiq_end
-#ifdef RTEMS_SMP
-	add	sp, r1
-#endif
+	mov	sp, r7
+	sub	r7, r7, r1
 	bl bsp_start_init_registers_banked_fiq
@@ -262,26 +224,29 @@ bsp_start_skip_hyp_svc_switch:
 	msr	cpsr, r0
-	ldr	sp, =bsp_stack_abt_end
-#ifdef RTEMS_SMP
-	add	sp, r1
-#endif
+	mov	sp, r7
+	sub	r7, r7, r1
 	msr	cpsr, r0
-	ldr	sp, =bsp_stack_und_end
-#ifdef RTEMS_SMP
-	add	sp, r1
-#endif
+	mov	sp, r7
+	sub	r7, r7, r1
+	msr	cpsr, r0
+	mov	sp, r7
-	/* Enter SVC mode and set up the SVC stack pointer */
 	msr	cpsr, r0
-	ldr	sp, =bsp_stack_svc_end
-#ifdef RTEMS_SMP
-	add	sp, r1
-#endif
+	mov	sp, r7
@@ -333,7 +298,7 @@ bsp_start_skip_hyp_svc_switch:
 	SWITCH_FROM_ARM_TO_THUMB	r0
-	mov	r0, r4		/* original cpsr value */
+	mov	r0, r4		/* original CPSR value */
 	mov	r1, r5		/* machine type number or ~0 for DT boot */
 	mov	r2, r6		/* physical address of ATAGs or DTB */
@@ -385,13 +350,11 @@ twiddle:
 	.syntax	unified
-	.extern	bsp_stack_main_end
 	.thumb
 bsp_start_vector_table_begin:
-	.word	bsp_stack_main_end
+	.word	_Configuration_Interrupt_stack_area_end
 	.word	_start /* Reset */
 	.word	_ARMV7M_Exception_default /* NMI */
 	.word	_ARMV7M_Exception_default /* Hard Fault */
@@ -441,7 +404,7 @@ _start:
 #endif /* ARM_MULTILIB_VFP */
-	ldr	sp, =bsp_stack_main_end
+	ldr	sp, =_Configuration_Interrupt_stack_area_end
 	ldr	lr, =bsp_start_hook_0_done + 1
 	b	bsp_start_hook_0
diff --git a/bsps/arm/smdk2410/start/start.S b/bsps/arm/smdk2410/start/start.S
index 95d781cb89..b8d1ddefa0 100644
--- a/bsps/arm/smdk2410/start/start.S
+++ b/bsps/arm/smdk2410/start/start.S
@@ -8,20 +8,8 @@
-.equ PSR_I,              0x80
-.equ PSR_F,              0x40
-.equ PSR_T,              0x20
 .text
 .globl  _start
@@ -65,43 +53,46 @@ _start2:
-        msr     cpsr, r0
-        msr     cpsr, r0
-        add     sp, sp, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
         msr     cpsr, r0
-        add     sp, sp, r1
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
+        sub     r7, r7, r1
+        msr     cpsr, r0
+        mov     sp, r7
         msr     cpsr, r0
-        add     sp, sp, r1
-        sub     sp, sp, #0x64
+        mov     sp, r7
 	/* disable mmu, I and D caches*/
 	nop
diff --git a/bsps/arm/xilinx-zynq/start/linkcmds.in b/bsps/arm/xilinx-zynq/start/linkcmds.in
index 7fd6e2772d..b56309bf37 100644
--- a/bsps/arm/xilinx-zynq/start/linkcmds.in
+++ b/bsps/arm/xilinx-zynq/start/linkcmds.in
@@ -6,8 +6,6 @@ MEMORY {
    NOCACHE   : ORIGIN = @ZYNQ_RAM_ORIGIN_AVAILABLE@ + @ZYNQ_RAM_LENGTH_AVAILABLE@ - @ZYNQ_RAM_NOCACHE_LENGTH@, LENGTH = @ZYNQ_RAM_NOCACHE_LENGTH@
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : @ZYNQ_CPUS@;
 REGION_ALIAS ("REGION_VECTOR",         RAM);
@@ -26,7 +24,6 @@ REGION_ALIAS ("REGION_STACK",          RAM);
diff --git a/bsps/bfin/TLL6527M/start/linkcmds b/bsps/bfin/TLL6527M/start/linkcmds
index 8c7b373864..17b9e244ca 100644
--- a/bsps/bfin/TLL6527M/start/linkcmds
+++ b/bsps/bfin/TLL6527M/start/linkcmds
@@ -11,7 +11,6 @@ STARTUP(start.o)
 _RamBase    = DEFINED(_RamBase)   ? _RamBase : 0x0;
 _RamSize    = DEFINED(_RamSize)   ? _RamSize : 0x04000000;
 _HeapSize   = DEFINED(_HeapSize)  ? _HeapSize : 0x10000;
-_StackSize  = DEFINED(_StackSize) ? _StackSize : 0x10000;
 MEMORY
@@ -123,8 +122,6 @@ SECTIONS
         *(.gnu.linkonce.b.*)
         *(COMMON)
         . = ALIGN (64);
-        _stack_init = .;
-        . += _StackSize;
         _clear_end = .;
          _end = .;
          __end = .;
@@ -170,7 +167,6 @@ SECTIONS
   .debug_funcnames 0 : { *(.debug_funcnames) }
   .debug_typenames 0 : { *(.debug_typenames) }
   .debug_varnames  0 : { *(.debug_varnames) }
-  /*.stack 0x80000 : { _stack = .; *(.stack) }*/
   /* These must appear regardless of  .  */
diff --git a/bsps/bfin/bf537Stamp/start/linkcmds b/bsps/bfin/bf537Stamp/start/linkcmds
index c9925525c9..1492da027a 100644
--- a/bsps/bfin/bf537Stamp/start/linkcmds
+++ b/bsps/bfin/bf537Stamp/start/linkcmds
@@ -15,7 +15,6 @@ _RamBase = DEFINED(_RamBase) ? _RamBase : 0x0;
    to free up mmu entries. */
 _RamSize = DEFINED(_RamSize) ? _RamSize : 0x03400000;
 _HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
 MEMORY
@@ -131,8 +130,6 @@ SECTIONS
         *(COMMON)
         . = ALIGN (64);
-        _stack_init = .;
-        . += _StackSize;
         _clear_end = .;
          _end = .;
          __end = .;
@@ -178,7 +175,6 @@ SECTIONS
diff --git a/bsps/bfin/eZKit533/start/linkcmds b/bsps/bfin/eZKit533/start/linkcmds
index 0fc2da123d..90451bd46a 100644
--- a/bsps/bfin/eZKit533/start/linkcmds
+++ b/bsps/bfin/eZKit533/start/linkcmds
 _RamSize = DEFINED(_RamSize) ? _RamSize : 0x01000000;
 MEMORY
@@ -120,8 +119,6 @@ SECTIONS
         *(COMMON)
         . = ALIGN (64);
-        _stack_init = .;
-        . += _StackSize;
         _clear_end = .;
          _end = .;
          __end = .;
@@ -167,7 +164,6 @@ SECTIONS
diff --git a/bsps/lm32/lm32_evr/start/linkcmds b/bsps/lm32/lm32_evr/start/linkcmds
index d4b3147c63..c89940dd1c 100644
--- a/bsps/lm32/lm32_evr/start/linkcmds
+++ b/bsps/lm32/lm32_evr/start/linkcmds
@@ -12,9 +12,7 @@ STARTUP(start.o)
 RamBase = DEFINED(RamBase) ? RamBase : 0x08000000;
 RamSize = DEFINED(RamSize) ? RamSize : 32M;
 HeapSize = DEFINED(HeapSize) ? HeapSize : 2M;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x2000;
-PROVIDE (__stack = 0);
 MEMORY {
 	ebr	: ORIGIN = 0x04000000 , LENGTH = 32k
 	sdram   : ORIGIN = 0x08000000 , LENGTH = 32M
@@ -249,11 +247,7 @@ SECTIONS
   __rtems_end = . ;
   PROVIDE (end = .);
-  . += _StackSize;
-  _fstack = .;
     . = ALIGN (16);
-    _stack_init = .;
     _clear_end = .;
   } > sdram
diff --git a/bsps/lm32/milkymist/start/linkcmds b/bsps/lm32/milkymist/start/linkcmds
index 6a2721005a..28779a80a8 100644
--- a/bsps/lm32/milkymist/start/linkcmds
+++ b/bsps/lm32/milkymist/start/linkcmds
 RamBase = DEFINED(RamBase) ? RamBase : 0x40000000;
 RamSize = DEFINED(RamSize) ? RamSize : 128M;
 HeapSize = DEFINED(HeapSize) ? HeapSize : 92M;
 MEMORY {
 	sdram   : ORIGIN = 0x40000000 , LENGTH = 128M
@@ -248,11 +246,7 @@ SECTIONS
   __rtems_end = . ;
   PROVIDE (end = .);
-  . += _StackSize;
-  _fstack = .;
     . = ALIGN (16);
-    _stack_init = .;
     _clear_end = .;
   } > sdram
diff --git a/bsps/lm32/shared/start/start.S b/bsps/lm32/shared/start/start.S
index 71cbb54119..3f4a6c672b 100644
--- a/bsps/lm32/shared/start/start.S
+++ b/bsps/lm32/shared/start/start.S
@@ -126,8 +126,8 @@ crt0:
 	nop
 	nop
 	/* Initialize stack pointer */
-	mvhi	sp, hi(_fstack-4)
-	ori	sp, sp, lo(_fstack-4)
+	mvhi	sp, hi(_Configuration_Interrupt_stack_area_end-4)
+	ori	sp, sp, lo(_Configuration_Interrupt_stack_area_end-4)
 	/* Initialize global pointer */
 	mvhi	gp, hi(_edata)
 	ori	gp, gp, lo(_edata)
diff --git a/bsps/m32c/m32cbsp/start/linkcmds b/bsps/m32c/m32cbsp/start/linkcmds
index 201b26fb2c..9863f360b0 100644
--- a/bsps/m32c/m32cbsp/start/linkcmds
+++ b/bsps/m32c/m32cbsp/start/linkcmds
@@ -4,8 +4,6 @@
 _RamBase = DEFINED(_RamBase) ? _RamBase : 0x200000;
 _RamSize = DEFINED(_RamSize) ? _RamSize : 0x800000;
 /* Default linker script, for normal executables */
 OUTPUT_FORMAT("elf32-m32c", "elf32-m32c",
@@ -153,10 +151,6 @@ SECTIONS
     PROVIDE (end = .);
   } > RAM
   PROVIDE (__bsssize = 0);
-  . = ALIGN(16);
-  . += _StackSize;
-  PROVIDE (__stack = .);
@@ -167,14 +161,6 @@ SECTIONS
   PROVIDE (_WorkAreaEnd = .);
   PROVIDE (_WorkAreaSize = _WorkAreaEnd - _WorkAreaBase);
-  .stack (0x200000 + 0x800000 - 2) :
-    *(.stack)
   .vec : {
     *(.vec)
   } > VEC
diff --git a/bsps/m32c/m32cbsp/start/start.S b/bsps/m32c/m32cbsp/start/start.S
index e8268a7bec..029cc09a58 100644
--- a/bsps/m32c/m32cbsp/start/start.S
+++ b/bsps/m32c/m32cbsp/start/start.S
@@ -48,7 +48,7 @@ SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 _start:
 .LFB2:
 	fset	U	/* User stack */
-	ldc	#__stack,sp
+	ldc	#__Configuration_Interrupt_stack_area_end,sp
 #ifdef A16
 	mov.b	#%hi8(__romdatastart),r1h
diff --git a/bsps/m68k/gen68340/start/linkcmds b/bsps/m68k/gen68340/start/linkcmds
index 99eeb3bf70..3621474fe8 100644
--- a/bsps/m68k/gen68340/start/linkcmds
+++ b/bsps/m68k/gen68340/start/linkcmds
@@ -21,7 +21,6 @@
 RamBase = DEFINED(RamBase) ? RamBase : 0x10000000;
 RamSize = DEFINED(RamSize) ? RamSize : 4M;
 HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
  * Declare on-board memory.
@@ -186,10 +185,6 @@ SECTIONS {
                 *(COMMON)
                 . = ALIGN (16);
                 PROVIDE (end = .);
-                . += _StackSize;
-                . = ALIGN (16);
-                _stack_init = .;
                 _clear_end = .;
         } >ram
diff --git a/bsps/m68k/gen68340/start/start.S b/bsps/m68k/gen68340/start/start.S
index 794c6d75b6..85b9aa86fa 100644
--- a/bsps/m68k/gen68340/start/start.S
+++ b/bsps/m68k/gen68340/start/start.S
@@ -850,7 +850,7 @@ ZEROLOOPTEST:
 	cmpl	a1,a0						| Done?
 	bcs.s	ZEROLOOP					| No, skip
-	movel	#_stack_init,a7					| set master stack pointer
+	movel	#_Configuration_Interrupt_stack_area_end,a7		| set master stack pointer
 	movel	d0,a7 at -						| command line
 	jsr	SYM(boot_card)					| Call C main
diff --git a/bsps/m68k/gen68360/start/linkcmds b/bsps/m68k/gen68360/start/linkcmds
index f3d6712988..f2858137d7 100644
--- a/bsps/m68k/gen68360/start/linkcmds
+++ b/bsps/m68k/gen68360/start/linkcmds
@@ -16,7 +16,6 @@
 RamBase = DEFINED(RamBase) ? RamBase : 0x0;
 RamSize = DEFINED(RamSize) ? RamSize : 64M;
@@ -150,10 +149,6 @@ SECTIONS {
                 *(COMMON)
                 . = ALIGN (16);
                 PROVIDE (end = .);
-                . += _StackSize;
-                . = ALIGN (16);
-                _stack_init = .;
                 _clear_end = .;
         } >ram
diff --git a/bsps/m68k/gen68360/start/linkcmds.bootp b/bsps/m68k/gen68360/start/linkcmds.bootp
index b97c66f3a1..a05573cb2c 100644
--- a/bsps/m68k/gen68360/start/linkcmds.bootp
+++ b/bsps/m68k/gen68360/start/linkcmds.bootp
@@ -20,7 +20,6 @@
@@ -152,10 +151,6 @@ SECTIONS {
                 *(COMMON)
                 . = ALIGN (16);
                 PROVIDE (end = .);
-                . += _StackSize;
-                . = ALIGN (16);
-                _stack_init = .;
                 _clear_end = .;
         } >myram
diff --git a/bsps/m68k/gen68360/start/linkcmds.prom b/bsps/m68k/gen68360/start/linkcmds.prom
index 6513ccd544..0e68300de7 100644
--- a/bsps/m68k/gen68360/start/linkcmds.prom
+++ b/bsps/m68k/gen68360/start/linkcmds.prom
@@ -20,7 +20,6 @@
                 *(COMMON)
                 . = ALIGN (16);
                 PROVIDE (end = .);
-                . += _StackSize;
-                . = ALIGN (16);
-                _stack_init = .;
                 _clear_end = .;
         } >ram
diff --git a/bsps/m68k/gen68360/start/start.S b/bsps/m68k/gen68360/start/start.S
index 8511960e16..7549f08af8 100644
--- a/bsps/m68k/gen68360/start/start.S
+++ b/bsps/m68k/gen68360/start/start.S
@@ -390,7 +390,7 @@ ZEROLOOPTEST:
 	cmpl	a1,a0			| Done?
 	jsr	boot_card		| Call C main
diff --git a/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 b/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475
index 52bca8d018..1e817d01ee 100644
--- a/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475
+++ b/bsps/m68k/genmcf548x/start/linkcmds.COBRA5475
@@ -62,8 +62,6 @@ _CoreSramSize1  = DEFINED(_CoreSramSize1)  ? _CoreSramSize1 : (4 * 1024);
 _BootFlashBase  = DEFINED(_BootFlashBase)  ? _BootFlashBase : 0xFC000000;
 _BootFlashSize  = DEFINED(_BootFlashSize)  ? _BootFlashSize : (32 * 1024*1024);
-bsp_initstack_size = DEFINED(StackSize)    ? StackSize  : 0x800;  /* 2 kB   */
 _VBR            = DEFINED(_VBR)            ? _VBR       : _SdramBase;
 __MBAR          = DEFINED(__MBAR)          ? __MBAR     : 0xFE000000;
diff --git a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine
index be746af7ff..ee873c4681 100644
--- a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine
+++ b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine
@@ -63,8 +63,6 @@ _BootFlashSize  = DEFINED(_BootFlashSize)  ? _BootFlashSize : (2 * 1024*1024);
 _CodeFlashBase  = DEFINED(_CodeFlashBase)  ? _CodeFlashBase : 0xE0000000;
 _CodeFlashSize  = DEFINED(_CodeFlashSize)  ? _CodeFlashSize : (16 * 1024*1024);
 __MBAR          = DEFINED(__MBAR)          ? __MBAR     : 0x10000000;
diff --git a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash
index 4db960f111..30df1e4bd7 100644
--- a/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash
+++ b/bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash
@@ -63,8 +63,6 @@ _BootFlashSize = DEFINED(_BootFlashSize)  ? _BootFlashSize : (2 * 1024 * 1024);
 _CodeFlashSize = DEFINED(_CodeFlashSize)  ? _CodeFlashSize : (16 * 1024 * 1024);
diff --git a/bsps/m68k/mcf52235/start/linkcmds b/bsps/m68k/mcf52235/start/linkcmds
index 3e912a210f..0c4d15fe08 100644
--- a/bsps/m68k/mcf52235/start/linkcmds
+++ b/bsps/m68k/mcf52235/start/linkcmds
@@ -16,7 +16,6 @@
 RamBase = DEFINED(RamBase) ? RamBase : 0x20000000;
 RamSize = DEFINED(RamSize) ? RamSize : 32K;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x400;
 _FlashBase = DEFINED(_FlashBase) ? _FlashBase : 0x00000000;
 _VBR = 0x20000000;
@@ -171,16 +170,6 @@ SECTIONS
         PROVIDE (_clear_end = .);
     } >sram
-    .stack :
-         * Starting Stack
-        . += _StackSize;
-        . = ALIGN (16);
-        PROVIDE(_StackInit = .);
-    } >sram
         PROVIDE(WorkAreaBase = .);
diff --git a/bsps/m68k/mcf52235/start/start.S b/bsps/m68k/mcf52235/start/start.S
index e1d837cab5..ecb2c5c980 100644
--- a/bsps/m68k/mcf52235/start/start.S
+++ b/bsps/m68k/mcf52235/start/start.S
@@ -16,14 +16,12 @@
-.extern _StackInit
 BEGIN_CODE
     PUBLIC (_INTERRUPT_VECTOR)
 SYM(_INTERRUPT_VECTOR):
-    .long   _StackInit /* 00 Initial 'SSP' */
+    .long   _Configuration_Interrupt_stack_area_end /* 00 Initial 'SSP' */
     .long   SYM(start) /* 01 Initial PC */
     .long   SYM(_uhoh) /* 02 Access Error */
     .long   SYM(_uhoh) /* 03 Address Error */
@@ -357,7 +355,7 @@ SYM(start):
     movec   d0, %rambar
     /* Locate Stack Pointer */
-    move.l  #_StackInit, sp
+    move.l  #_Configuration_Interrupt_stack_area_end, sp
     /* Initialize FLASHBAR */
     move.l  #_FlashBase, d0
@@ -369,7 +367,7 @@ SYM(start):
 _continue_startup:
     /* Save off intial D0 and D1 to RAM */
     move.l  d6, SYM(_d0_reset)
diff --git a/bsps/m68k/mcf5225x/start/linkcmds b/bsps/m68k/mcf5225x/start/linkcmds
index a2ad1ec047..563aede8eb 100644
--- a/bsps/m68k/mcf5225x/start/linkcmds
+++ b/bsps/m68k/mcf5225x/start/linkcmds
@@ -16,7 +16,6 @@
 RamSize = DEFINED(RamSize) ? RamSize : 64K;
 _VBR = 0x20000000;
     } >sram
-    .stack :
-         * Starting Stack
-        . += _StackSize;
-        . = ALIGN (16);
-    } >sram
diff --git a/bsps/m68k/mcf5225x/start/start.S b/bsps/m68k/mcf5225x/start/start.S
index abc7bb99cc..19d9038431 100644
--- a/bsps/m68k/mcf5225x/start/start.S
+++ b/bsps/m68k/mcf5225x/start/start.S
@@ -16,14 +16,12 @@
-.extern _StackInit
 BEGIN_CODE
@@ -361,7 +359,7 @@ SYM(start):
     movec   d7, %rambar
     move.l  #_FlashBase, d7
@@ -373,7 +371,7 @@ SYM(start):
 _continue_startup:
-//    move.l  #_StackInit, sp		//is done automatically by the CPU
+//    move.l  #_Configuration_Interrupt_stack_area_end, sp		//is done automatically by the CPU
      * Remainder of the startup code is handled by C code
diff --git a/bsps/m68k/mcf5329/start/linkcmds b/bsps/m68k/mcf5329/start/linkcmds
index bed8dfe0fe..78fc50c22a 100644
--- a/bsps/m68k/mcf5329/start/linkcmds
+++ b/bsps/m68k/mcf5329/start/linkcmds
@@ -23,7 +23,6 @@ _BootFlashBase = DEFINED(_FlashBase) ? _FlashBase : 0x00000000;
 _BootFlashSize = DEFINED(_FlashBase) ? _FlashBase : 2M;
 HeapSize = DEFINED(HeapSize) ? HeapSize : 0;
 _VBR = 0x40000000;
@@ -178,23 +177,12 @@ SECTIONS
         *(COMMON)
         . = ALIGN (16);
         PROVIDE (_end = .);
         _clear_end = .;
+        WorkAreaBase = .;
     } > dram
-        WorkAreaBase = .;
-    } > dram
-    .start_stack :
-         * Starting Stack
-        . += _StackSize;
-        . = ALIGN (16);
     } > core_sram
     /* Stabs debugging sections.  */
diff --git a/bsps/m68k/mcf5329/start/linkcmdsflash b/bsps/m68k/mcf5329/start/linkcmdsflash
index 88a6f96ff0..adfb3bacfb 100644
--- a/bsps/m68k/mcf5329/start/linkcmdsflash
+++ b/bsps/m68k/mcf5329/start/linkcmdsflash
 _VBR = 0x40000000;
@@ -174,23 +173,12 @@ SECTIONS
         *(COMMON)
         . = ALIGN (16);
         PROVIDE (_end = .);
         _clear_end = .;
+        WorkAreaBase = .;
     } > dram
-        WorkAreaBase = .;
-    } > dram
-    .start_stack :
-         * Starting Stack
-        . += _StackSize;
-        . = ALIGN (16);
     } > core_sram
diff --git a/bsps/m68k/mcf5329/start/start.S b/bsps/m68k/mcf5329/start/start.S
index 6063fdac74..659c617272 100644
--- a/bsps/m68k/mcf5329/start/start.S
+++ b/bsps/m68k/mcf5329/start/start.S
@@ -16,14 +16,12 @@
-.extern _StackInit
 BEGIN_CODE
@@ -346,7 +344,7 @@ SYM(start):
     move.l  d7, SYM(_d1_reset)
-    move.l  #_StackInit,sp
+    move.l  #_Configuration_Interrupt_stack_area_end,sp
diff --git a/bsps/m68k/mrm332/start/linkcmds b/bsps/m68k/mrm332/start/linkcmds
index f86e80dd02..125538c50c 100644
--- a/bsps/m68k/mrm332/start/linkcmds
+++ b/bsps/m68k/mrm332/start/linkcmds
@@ -32,7 +32,6 @@ __DYNAMIC  =  0;
  * |    heap space      |
  * |        _ENDHEAP    |
  * |    stack space     |
- * |        __stack     | top of stack
  * +--------------------+ <- high memory
@@ -52,7 +51,6 @@ MEMORY
 _copy_data_from_rom = 1;
@@ -194,9 +192,6 @@ SECTIONS
     *(COMMON)
     . = ALIGN (16);
     PROVIDE (end = .);
-    . += _StackSize;
-    . = ALIGN (16);
-    _stack_init = .;
     _clear_end = .;
   } > ram
diff --git a/bsps/m68k/mrm332/start/start.S b/bsps/m68k/mrm332/start/start.S
index 5e2bbebc8e..300b74fc78 100644
--- a/bsps/m68k/mrm332/start/start.S
+++ b/bsps/m68k/mrm332/start/start.S
@@ -37,10 +37,10 @@ BEGIN_CODE
 	movel	#0x0,d0				/* Use the initial vectors until we get going */
 	movecl	d0,vbr
-	movel  #end, d0				/* Next 3 instructions set stack pointer    */
-	addl   #_StackSize,d0       /* sp = end + _StackSize from linker script */
-	movel  d0,sp
-	movel  d0,a6
+	/* Set stack pointer */
+	movel	#_Configuration_Interrupt_stack_area_end,d0
+	movel	d0,sp
+	movel	d0,a6
   /* include in ram_init.S */
diff --git a/bsps/m68k/shared/start/start.S b/bsps/m68k/shared/start/start.S
index b3a3c8b664..9c40cbc3da 100644
--- a/bsps/m68k/shared/start/start.S
+++ b/bsps/m68k/shared/start/start.S
@@ -74,7 +74,7 @@ loop:   movel   #0,a1 at +                 | to zero out uninitialized
         cmpal   a0,a1
         jlt     loop                    | loop until _end reached
-        movel   # SYM (_stack_init),d0  | d0 = stop of stack
+        movel   # SYM (_Configuration_Interrupt_stack_area_end),d0 | d0 = stop of stack
         movw    #0x3700,sr              | SUPV MODE,INTERRUPTS OFF!!!
         movel   d0,a7                   | set master stack pointer
         movel   d0,a6                   | set base pointer
@@ -135,13 +135,6 @@ SYM (initial_usp):
 SYM (initial_sr):
         .space  2
-	.align 16
-         PUBLIC (starting_stack)
-SYM (starting_stack):
-        .space  0x1000
-         PUBLIC (_stack_init)
-SYM (_stack_init):
 END_DATA
 #endif
 END
diff --git a/bsps/mips/csb350/start/linkcmds b/bsps/mips/csb350/start/linkcmds
index d9d2d1c815..961ada650e 100644
--- a/bsps/mips/csb350/start/linkcmds
+++ b/bsps/mips/csb350/start/linkcmds
@@ -15,7 +15,6 @@ _sdram_size = DEFINED(_sdram_size) ? _sdram_size : 12M;
 RamBase = _sdram_base;
 RamSize = _sdram_size;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x4000;
 ENTRY(_start)
 STARTUP(start.o)
@@ -187,10 +186,6 @@ SECTIONS
     *(.bss .bss.* .gnu.linkonce.b.*)
     *(COMMON)
     . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
     _clear_end = .;
     end = .;
     _end = .;
diff --git a/bsps/mips/csb350/start/start.S b/bsps/mips/csb350/start/start.S
index 9aea3f4cae..dc92f1a430 100644
--- a/bsps/mips/csb350/start/start.S
+++ b/bsps/mips/csb350/start/start.S
@@ -67,7 +67,7 @@ zerobss:
 	bltu	v0,v1,3b
 	addiu	v0,v0,4			/* executed in delay slot */
-	la	t0, _stack_init		/* initialize stack so we */
+	la	t0, _Configuration_Interrupt_stack_area_end /* initialize stack so we */
 	/* We must subtract 24 bytes for the 3 8 byte arguments to main, in
 	   case main wants to write them back to the stack.  The caller is
 	   supposed to allocate stack space for parameters in registers in
diff --git a/bsps/mips/hurricane/start/linkcmds b/bsps/mips/hurricane/start/linkcmds
index 3ffaf52710..51e47158d3 100644
--- a/bsps/mips/hurricane/start/linkcmds
+++ b/bsps/mips/hurricane/start/linkcmds
@@ -8,7 +8,6 @@
 RamBase = DEFINED(RamBase) ? RamBase : 0x80000000;
 ENTRY(start)
 STARTUP(start.o)
@@ -166,10 +165,6 @@ SECTIONS
     *(.bss)
     *(COMMON)
     . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
      end = .;
     _end = .;
diff --git a/bsps/mips/jmr3904/start/linkcmds b/bsps/mips/jmr3904/start/linkcmds
index a3d64a4284..0becab1e6f 100644
--- a/bsps/mips/jmr3904/start/linkcmds
+++ b/bsps/mips/jmr3904/start/linkcmds
@@ -8,7 +8,6 @@
 RamBase = DEFINED(RamBase) ? RamBase : 0x88000000;
 ENTRY(_start)
 STARTUP(start.o)
@@ -164,10 +163,6 @@ SECTIONS
     *(.bss*)
     *(COMMON)
     . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
     _clear_end = .;
@@ -181,9 +176,6 @@ SECTIONS
  _end = .;
-/* Put starting stack in SRAM (8 Kb); this size is the same as the stack from
-      the original script (when everything was in SRAM). */
-   /* __stack = 0x8000A000; */
   /* DWARF debug sections.
      Symbols in the DWARF debugging sections are relative to
      the beginning of the section so we begin them at 0.  */
diff --git a/bsps/mips/jmr3904/start/start.S b/bsps/mips/jmr3904/start/start.S
index 92c0ddd956..9e1fa4182b 100644
--- a/bsps/mips/jmr3904/start/start.S
+++ b/bsps/mips/jmr3904/start/start.S
@@ -139,7 +139,7 @@ zerobss:
 	bltu	v0,v1,3b
 	addiu	v0,v0,4				# executed in delay slot
-	la	t0, _stack_init			# initialize stack so we
+	la	t0, _Configuration_Interrupt_stack_area_end # initialize stack so we
diff --git a/bsps/mips/malta/start/linkcmds b/bsps/mips/malta/start/linkcmds
index 4e44bce110..1d6745cfe1 100644
--- a/bsps/mips/malta/start/linkcmds
+++ b/bsps/mips/malta/start/linkcmds
@@ -8,7 +8,6 @@
 ENTRY(_start)
 STARTUP(start.o)
@@ -165,10 +164,6 @@ SECTIONS
     *(.bss*)
     *(COMMON)
     . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
     _clear_end = .;
@@ -182,9 +177,6 @@ SECTIONS
  _end = .;
diff --git a/bsps/mips/malta/start/start.S b/bsps/mips/malta/start/start.S
index 8f5f96489f..d437575cca 100644
--- a/bsps/mips/malta/start/start.S
+++ b/bsps/mips/malta/start/start.S
@@ -166,7 +166,7 @@ zerobss:
 	bltu	v0,v1,3b
diff --git a/bsps/mips/rbtx4925/start/linkcmds b/bsps/mips/rbtx4925/start/linkcmds
index 7c75cb5d59..3042176adf 100644
--- a/bsps/mips/rbtx4925/start/linkcmds
+++ b/bsps/mips/rbtx4925/start/linkcmds
@@ -8,7 +8,6 @@
 ENTRY(start)
 STARTUP(start.o)
     *(.bss)
     *(COMMON)
     . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
      end = .;
     _end = .;
diff --git a/bsps/mips/rbtx4938/start/linkcmds b/bsps/mips/rbtx4938/start/linkcmds
index a9deef8cd9..e11d1dcee2 100644
--- a/bsps/mips/rbtx4938/start/linkcmds
+++ b/bsps/mips/rbtx4938/start/linkcmds
@@ -8,7 +8,6 @@
 ENTRY(start)
 STARTUP(start.o)
     *(.bss)
     *(COMMON)
     . = ALIGN (64);
-    _stack_limit = .;
-    . += _StackSize;
-    __stack = .;
-    _stack_init = .;
      end = .;
     _end = .;
diff --git a/bsps/mips/shared/irq/exception.S b/bsps/mips/shared/irq/exception.S
index e916ae55fe..30c733b05e 100644
--- a/bsps/mips/shared/irq/exception.S
+++ b/bsps/mips/shared/irq/exception.S
@@ -214,10 +214,8 @@ _chk_int:
-   *  #if ( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE )
-   *    if ( _ISR_Nest_level == 0 )
-   *      switch to software interrupt stack
-   *  #endif
+   *  if ( _ISR_Nest_level == 0 )
+   *    switch to software interrupt stack
@@ -307,9 +305,7 @@ _ISR_Handler_cleanup:
-   *    restore stack
-   *  #endif
+   *  restore stack
    *  if ( !_Thread_Dispatch_necessary )
    *    goto the label "exit interrupt (simple case)"
diff --git a/bsps/nios2/nios2_iss/start/linkcmds b/bsps/nios2/nios2_iss/start/linkcmds
index b900718b6d..bcbfeafe1f 100644
--- a/bsps/nios2/nios2_iss/start/linkcmds
+++ b/bsps/nios2/nios2_iss/start/linkcmds
@@ -24,7 +24,6 @@ DO NOT MODIFY THIS FILE
 RamBase = DEFINED(RamBase) ? RamBase : 0x00000000;
 RamSize = DEFINED(RamSize) ? RamSize : 0x00800000;
-StackSize = DEFINED(StackSize) ? HeapSize : 1024;
 MEMORY
@@ -265,13 +264,12 @@ SECTIONS
         . = ALIGN(32 / 8);
         __bss_end = ABSOLUTE(.);
-        _stack_low = ABSOLUTE(.);
-        . += StackSize;
-        _stack_high = ABSOLUTE(.);
     } > onchip_memory_0
+        _stack_low = ABSOLUTE(.);
+        _stack_high = ABSOLUTE(.);
         WorkAreaBase = .;
     } > onchip_memory_0
diff --git a/bsps/powerpc/beatnik/start/bspstart.c b/bsps/powerpc/beatnik/start/bspstart.c
index 83c6d2efa6..91913cd0ed 100644
--- a/bsps/powerpc/beatnik/start/bspstart.c
+++ b/bsps/powerpc/beatnik/start/bspstart.c
@@ -177,8 +177,8 @@ void bsp_start( void )
   unsigned char  *stack;
   char           *chpt;
-  uint32_t       intrStackStart;
-  uint32_t       intrStackSize;
+  uintptr_t       intrStackStart;
+  uintptr_t       intrStackSize;
   Triv121PgTbl	pt=0;
@@ -239,7 +239,7 @@ void bsp_start( void )
    * This could be done latter (e.g in IRQ_INIT) but it helps to understand
    * some settings below...
-  intrStackStart = (uint32_t)__rtems_end;
+  intrStackStart = (uintptr_t)_Configuration_Interrupt_stack_area_begin;
   intrStackSize  = rtems_configuration_get_interrupt_stack_size();
diff --git a/bsps/powerpc/gen83xx/start/start.S b/bsps/powerpc/gen83xx/start/start.S
index b48a26b7c3..9272702d6b 100644
--- a/bsps/powerpc/gen83xx/start/start.S
+++ b/bsps/powerpc/gen83xx/start/start.S
@@ -417,7 +417,7 @@ start_code_in_ram:
 	li	r3, 0
 	/* Set start stack pointer */
-	LA	r1, start_stack_end
+	LA	r1, _Configuration_Interrupt_stack_area_end
 	stwu	r3, -4(r1)
 	stwu	r3, -4(r1)
@@ -520,10 +520,3 @@ mpc83xx_zero_4_tail:
 	/* Return */
 	blr
-.section ".bsp_rwextra", "aw", @nobits
-	/* Start stack area */
-.align 4
-.space 4096
-start_stack_end:
diff --git a/bsps/powerpc/haleakala/start/bspstart.c b/bsps/powerpc/haleakala/start/bspstart.c
index 5f7f5efb95..986582955a 100644
--- a/bsps/powerpc/haleakala/start/bspstart.c
+++ b/bsps/powerpc/haleakala/start/bspstart.c
@@ -66,9 +66,6 @@
 #include <ppc4xx/ppc405ex.h>
-LINKER_SYMBOL(intrStack_start);
-LINKER_SYMBOL(intrStack_size);
  *  Driver configuration parameters
@@ -188,8 +185,8 @@ void bsp_start( void )
    * Initialize default raw exception handlers.
   ppc_exc_initialize(
-    (uintptr_t) intrStack_start,
-    (uintptr_t) intrStack_size
+    (uintptr_t) _Configuration_Interrupt_stack_area_begin,
+    rtems_configuration_get_interrupt_stack_size()
diff --git a/bsps/powerpc/haleakala/start/linkcmds b/bsps/powerpc/haleakala/start/linkcmds
index 98fea7f990..3bccc97c38 100644
--- a/bsps/powerpc/haleakala/start/linkcmds
+++ b/bsps/powerpc/haleakala/start/linkcmds
@@ -14,9 +14,6 @@ OUTPUT_ARCH(powerpc)
 ENTRY(download_entry)
 EXTERN(__vectors)
-kIntrStackSize = 16K;
-kMainStackSize = 64K;
 RamBase = DEFINED(RamBase) ? RamBase : 0;
 RamSize = DEFINED(RamSize) ? RamSize : 256M;
@@ -246,19 +243,6 @@ SECTIONS
     bss.size = bss.end - bss.start;
     sbss.size = sbss.end - sbss.start;
-    /* Interrupt stack: align to a cache-line boundary */
-    IntrStack_start = ALIGN(0x20);
-    . += kIntrStackSize;
-    intrStack = .;
-    PROVIDE(intrStackPtr = intrStack);
-    PROVIDE(intrStack_start = IntrStack_start);
-    PROVIDE(intrStack_size = kIntrStackSize);
- 	/* Main stack: align to a cache-line boundary */
-	stack.start = ALIGN(0x20);
-	. += kMainStackSize;
-	stack.end   = .;
diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c b/bsps/powerpc/motorola_powerpc/start/bspstart.c
index 7fb684c759..c420f6c19b 100644
--- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
+++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
@@ -220,7 +220,7 @@ void bsp_start( void )
    * Initialize the interrupt related settings.
-  intrStackStart = (uintptr_t) __rtems_end;
diff --git a/bsps/powerpc/mpc55xxevb/start/start.S b/bsps/powerpc/mpc55xxevb/start/start.S
index 0a757e7ada..81893b6276 100644
--- a/bsps/powerpc/mpc55xxevb/start/start.S
+++ b/bsps/powerpc/mpc55xxevb/start/start.S
@@ -228,7 +228,7 @@ zero_intermediate_stack_loop:
 	bl	mpc55xx_start_early
 	/* Initialize start stack */
 	subi	r1, r1, 16
 	li	r0, 0
 	stw	r0, 0(r1)
@@ -289,11 +289,3 @@ mpc55xx_start_load_section:
 	cmpw	cr7, r3, r4
 	beqlr	cr7
 	b	memcpy
-	.section	".bsp_rwextra", "aw", @nobits
-	.align	4
-	.space	4096
-start_stack_end:
diff --git a/bsps/powerpc/mpc8260ads/start/linkcmds b/bsps/powerpc/mpc8260ads/start/linkcmds
index 34fb69149b..84933b48e9 100644
--- a/bsps/powerpc/mpc8260ads/start/linkcmds
+++ b/bsps/powerpc/mpc8260ads/start/linkcmds
@@ -17,7 +17,6 @@ EXTERN(__vectors)
  *      number used there is not constant.  If this happens to you, edit
  *      the lines marked XXX below to use a constant value.
-StackSize   = DEFINED(StackSize) ? StackSize : 0x8000;
 RamSize     = DEFINED(RamSize) ? RamDiskSize : 0x0800000; /* 8M program ram */
@@ -289,16 +288,6 @@ SECTIONS
         _startmalloc = .;
      } >ram
-     * Interrupt stack setup
-    IntrStack_start = ALIGN(0x10);
-    . += 0x4000;
-    intrStack = .;
     clear_end = .;
diff --git a/bsps/powerpc/mvme3100/start/bspstart.c b/bsps/powerpc/mvme3100/start/bspstart.c
index a073baa784..6f15b2d7a3 100644
--- a/bsps/powerpc/mvme3100/start/bspstart.c
+++ b/bsps/powerpc/mvme3100/start/bspstart.c
@@ -255,7 +255,7 @@ VpdBufRec          vpdData [] = {
+  intrStackStart = (uintptr_t) _Configuration_Interrupt_stack_area_begin;
diff --git a/bsps/powerpc/mvme5500/start/bspstart.c b/bsps/powerpc/mvme5500/start/bspstart.c
index fc7057613a..47d413bc91 100644
--- a/bsps/powerpc/mvme5500/start/bspstart.c
+++ b/bsps/powerpc/mvme5500/start/bspstart.c
@@ -225,7 +225,7 @@ void bsp_start( void )
diff --git a/bsps/powerpc/psim/start/start.S b/bsps/powerpc/psim/start/start.S
index 918321af5f..03cbdedc5b 100644
--- a/bsps/powerpc/psim/start/start.S
+++ b/bsps/powerpc/psim/start/start.S
@@ -47,7 +47,7 @@ FUNC_NAME(__atexit):			/* tell C's eabi-ctor's we have an atexit function */
 	.long	bsp_section_bss_end
 .Lstack = .-.LCTOC1			/* stack address if set by user */
-	.long	__stack
 	.text
 .Lptr:
@@ -89,7 +89,7 @@ _start:
 .Ldone:
-	lwz	r0,.Lstack(r5)		/* stack address or 0 */
+	lwz	r0,.Lstack(r5)	/* stack area or 0 */
 	cmplwi	1,r0,0			/* equal to 0? */
 	bc	12,6,.Lnostack		/* use default stack if == 0 */
 	mr	sp,r0			/* use user defined stack */
@@ -133,9 +133,3 @@ FUNC_NAME(bsp_reset):
 .Lstart:
 	.size	_start,.Lstart-_start
-.align 4
-.space 4096
-__stack:
diff --git a/bsps/powerpc/qemuppc/start/bspstart.c b/bsps/powerpc/qemuppc/start/bspstart.c
index 15cf9d4207..de3bba0797 100644
--- a/bsps/powerpc/qemuppc/start/bspstart.c
+++ b/bsps/powerpc/qemuppc/start/bspstart.c
@@ -42,8 +42,6 @@ uint32_t bsp_clicks_per_usec;
  * Memory on this board.
 extern char RamSize[];
-extern char bsp_interrupt_stack_start[];
-extern char bsp_interrupt_stack_end[];
 uint32_t BSP_mem_size = (uint32_t)RamSize;
 /* Default decrementer exception handler */
@@ -89,8 +87,8 @@ void bsp_start( void )
-  intrStackStart = (uintptr_t) bsp_interrupt_stack_start;
-  intrStackSize =  (uintptr_t) bsp_interrupt_stack_end - intrStackStart;
+  intrStackSize = rtems_configuration_get_interrupt_stack_size();
   BSP_mem_size = (uint32_t )RamSize;
diff --git a/bsps/powerpc/qemuppc/start/start.S b/bsps/powerpc/qemuppc/start/start.S
index 1ef7a3a02a..d55010e84f 100644
--- a/bsps/powerpc/qemuppc/start/start.S
+++ b/bsps/powerpc/qemuppc/start/start.S
@@ -1,17 +1,14 @@
-#include <rtems/powerpc/powerpc.h>
+#include <libcpu/powerpc-utility.h>
-	.global bsp_interrupt_stack_start
-	.global bsp_interrupt_stack_end
 	.global _start
 	.section .bsp_start_text,"awx", at progbits
 _start:
-	lis   %r1,bsp_interrupt_stack_start at h
-	ori   %r1,%r1,bsp_interrupt_stack_start at l
 	/* Make sure stack is properly aligned */
 	li    %r3, CPU_STACK_ALIGNMENT - 1
 	andc  %r1, %r1, %r3
@@ -42,11 +39,3 @@ __eabi:
 _reset:
 	b _start
 	.size _reset, . - _reset
-	.align 4
-	.space 4096
-bsp_interrupt_stack_start:
-	.space 32768
-bsp_interrupt_stack_end:
diff --git a/bsps/powerpc/qoriq/start/start.S b/bsps/powerpc/qoriq/start/start.S
index 02505a6262..96e00bf38b 100644
--- a/bsps/powerpc/qoriq/start/start.S
+++ b/bsps/powerpc/qoriq/start/start.S
@@ -55,7 +55,9 @@ _start:
 	bl	.Linitearly
 	/* Get start stack */
-	LA	START_STACK, start_stack_end
+	LA	START_STACK, _Configuration_Interrupt_stack_area_begin
+	LA	r3, _Configuration_Interrupt_stack_size
+	add	START_STACK, START_STACK, r3
 	bl	.Linitmore
@@ -226,12 +228,10 @@ _start:
 	isync
-	 * Initialize start stack.  Make sure that we do not share a cache line
-	 * with the heap block management, since initial stacks for the
-	 * secondary processors are allocated from the workspace.
+	 * Initialize start stack.  The stacks are statically allocated and
+	 * properly aligned.
-	subi	r1, START_STACK, 2 * PPC_DEFAULT_CACHE_LINE_SIZE
-	clrrwi	r1, r1, PPC_DEFAULT_CACHE_LINE_POWER
+	subi	r1, START_STACK, PPC_DEFAULT_CACHE_LINE_SIZE
 	li	r0, 0
 	PPC_REG_STORE	r0, 0(r1)
@@ -540,9 +540,3 @@ bsp_exc_vector_base:
 /* Symbol provided for debugging and tracing */
 bsp_exc_vector_end:
-	.align 4
-	.space 4096
-start_stack_end:
diff --git a/bsps/powerpc/shared/start/linkcmds.base b/bsps/powerpc/shared/start/linkcmds.base
index fa49edf7dd..4ad302e86b 100644
--- a/bsps/powerpc/shared/start/linkcmds.base
+++ b/bsps/powerpc/shared/start/linkcmds.base
@@ -321,7 +321,6 @@ SECTIONS {
 	.rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
 		bsp_section_rtemsstack_begin = .;
-		*(.bsp_rwextra)
 		bsp_section_rtemsstack_end = .;
 	} > REGION_RTEMSSTACK AT > REGION_RTEMSSTACK
diff --git a/bsps/powerpc/t32mppc/start/start.S b/bsps/powerpc/t32mppc/start/start.S
index 7c32343f3d..e4066adb6f 100644
--- a/bsps/powerpc/t32mppc/start/start.S
+++ b/bsps/powerpc/t32mppc/start/start.S
@@ -34,7 +34,7 @@ _start:
 	mtspr	HID0, r0
-	LWI	r1, start_stack_end
 	subi	r1, r1, 16
 	li	r0, 0
 	stw	r0, 0(r1)
@@ -195,9 +195,3 @@ bsp_exc_vector_base:
 	PPC_REG_STORE	r3, GPR3_OFFSET(r1)
 	li	r3, 35
 	b	ppc_exc_fatal_normal
-	.align 4
-	.space 4096
-start_stack_end:
diff --git a/bsps/powerpc/tqm8xx/start/start.S b/bsps/powerpc/tqm8xx/start/start.S
index 92bda3fd6d..b16b92e1e2 100644
--- a/bsps/powerpc/tqm8xx/start/start.S
+++ b/bsps/powerpc/tqm8xx/start/start.S
@@ -26,8 +26,6 @@
 .extern boot_card
 PUBLIC_VAR (_start)
-PUBLIC_VAR (bsp_interrupt_stack_start)
-PUBLIC_VAR (bsp_interrupt_stack_end)
 _start:
@@ -119,8 +117,8 @@ start_code_in_ram:
 	/* Set stack pointer (common for RAM/ROM startup) */
-	LA	r1, bsp_section_text_begin
-        addi    r1, r1, -0x10 /* Set up stack pointer = beginning of text section - 0x10 */
+        addi    r1, r1, -0x10
 	/* Create NULL */
 	li r0, 0
@@ -285,10 +283,3 @@ mpc8xx_zero_4_tail:
 	blr
 end_reloc_startup:
-	/* Interrupt stack */
-	.align 4
-	.space 32768
diff --git a/bsps/powerpc/virtex4/start/bspstart.c b/bsps/powerpc/virtex4/start/bspstart.c
index 40cd710a58..93890c1623 100644
--- a/bsps/powerpc/virtex4/start/bspstart.c
+++ b/bsps/powerpc/virtex4/start/bspstart.c
@@ -85,9 +85,6 @@ LINKER_SYMBOL(RamSize);
 LINKER_SYMBOL(__bsp_ram_start);
 LINKER_SYMBOL(__bsp_ram_end);
 LINKER_SYMBOL(__rtems_end);
-LINKER_SYMBOL(_stack);
-LINKER_SYMBOL(StackSize);
-LINKER_SYMBOL(__stack_base);
 LINKER_SYMBOL(WorkAreaBase);
 LINKER_SYMBOL(MsgAreaBase);
 LINKER_SYMBOL(MsgAreaSize);
@@ -174,7 +171,7 @@ void bsp_start(void)
-  intrStackStart = CPU_UP_ALIGN((uint32_t)__bsp_ram_start);
   ppc_exc_initialize(intrStackStart, intrStackSize);
@@ -184,14 +181,12 @@ void bsp_start(void)
          "RAM:              %p                    %p\n"
          "RTEMS:                           %p\n"
          "Interrupt Stack:  0x%08x              0x%x\n"
-         "Stack:            %p             %p          %p\n"
          "Workspace:        %p             %p\n"
          "MsgArea:          %p             %p\n"
          "Physical RAM                     %p\n",
          RamBase,        RamSize,
          __rtems_end,
          intrStackStart,                intrStackSize,
-         __stack_base,   _stack,        StackSize,
          WorkAreaBase,   __bsp_ram_end,
          MsgAreaBase,    MsgAreaSize,
          __phy_ram_end);
diff --git a/bsps/powerpc/virtex4/start/linkcmds b/bsps/powerpc/virtex4/start/linkcmds
index 63864ac0ca..ef9edc626f 100644
--- a/bsps/powerpc/virtex4/start/linkcmds
+++ b/bsps/powerpc/virtex4/start/linkcmds
@@ -15,8 +15,6 @@ EXTERN(__vectors)
 MsgAreaSize       = DEFINED(MsgAreaSize)   ? MsgAreaSize   : 1M;
 RamSize           = DEFINED(RamSize)       ? RamSize       : 128M - MsgAreaSize;
-IntrStackSize     = DEFINED(IntrStackSize) ? IntrStackSize : 16K;
-StackSize         = DEFINED(StackSize)     ? StackSize     : 64K;
 HeapSize          = DEFINED(HeapSize)      ? HeapSize      : 0; /* 0=Use def */
@@ -251,15 +249,6 @@ SECTIONS
   .               = ALIGN(0x10);        /* Align to a cache-line boundary */
   PROVIDE(__bsp_ram_start = .);
-  /* Interrupt stack: aligned on a cache-line boundary */
-  .              += IntrStackSize;
-  __intrStack     = .;
-  /* Main stack lives here */
-  _stack          = ALIGN(0x10); 	/* Align to a cache-line boundary */
-  .              += StackSize;
-  __stack_base    = .;                  /* Initial stack builds downwards */
   } >RAM
diff --git a/bsps/powerpc/virtex4/start/start.S b/bsps/powerpc/virtex4/start/start.S
index 21948409bf..d4b8419551 100644
--- a/bsps/powerpc/virtex4/start/start.S
+++ b/bsps/powerpc/virtex4/start/start.S
@@ -82,7 +82,7 @@
  *    .bss
  *  see linker command file for section placement
- *  The initial stack is set to __stack_base.
+ *  The initial stack is set to _Configuration_Interrupt_stack_area_end.
@@ -109,7 +109,7 @@ bss_length:
 bss_addr:
         .long   __bss_start
 stack_top:
-        .long   __stack_base
 dccr_contents:
         .long   __dccr
 iccr_contents:
diff --git a/bsps/powerpc/virtex5/start/bspstart.c b/bsps/powerpc/virtex5/start/bspstart.c
index 6457143d20..8297b164b6 100644
--- a/bsps/powerpc/virtex5/start/bspstart.c
+++ b/bsps/powerpc/virtex5/start/bspstart.c
@@ -86,9 +86,6 @@ LINKER_SYMBOL(RamSize);
@@ -193,7 +190,7 @@ void bsp_start(void)
@@ -203,14 +200,12 @@ void bsp_start(void)
          "RAM:              %p                    %p\n"
          "RTEMS:                           %p\n"
          "MsgArea:          %p             %p\n"
          RamBase,        RamSize,
          __rtems_end,
          __phy_ram_end);
diff --git a/bsps/powerpc/virtex5/start/linkcmds b/bsps/powerpc/virtex5/start/linkcmds
index 4fd5243f3f..0cb4b4e752 100644
--- a/bsps/powerpc/virtex5/start/linkcmds
+++ b/bsps/powerpc/virtex5/start/linkcmds
 RamSize           = DEFINED(RamSize)       ? RamSize       : 2048M - MsgAreaSize;
   .               = ALIGN(0x20);        /* Align to a cache-line boundary */
-  __intrStack     = .;
-  _stack          = ALIGN(0x20); 	/* Align to a cache-line boundary */
-  .              += StackSize;
   } >RAM
diff --git a/bsps/powerpc/virtex5/start/start.S b/bsps/powerpc/virtex5/start/start.S
index 2b12c18c89..b63c103b14 100644
--- a/bsps/powerpc/virtex5/start/start.S
+++ b/bsps/powerpc/virtex5/start/start.S
@@ -86,7 +86,7 @@
  *    .bss
  *  All the entry veneer has to do is to clear the BSS.
@@ -114,7 +114,7 @@ bss_length:
 bss_addr:
         .long   __bss_start
 stack_top:
         .eject
diff --git a/bsps/sh/gensh1/include/bsp.h b/bsps/sh/gensh1/include/bsp.h
index b757a010d6..b70e8382a5 100644
--- a/bsps/sh/gensh1/include/bsp.h
+++ b/bsps/sh/gensh1/include/bsp.h
@@ -49,13 +49,6 @@ extern "C" {
 /* Constants */
- * Defined in the linker script 'linkcmds'
-extern void *CPU_Interrupt_stack_low;
-extern void *CPU_Interrupt_stack_high;
  * BSP methods that cross file boundaries.
 void bsp_hw_init(void);
diff --git a/bsps/sh/gensh1/start/cpu_asm.c b/bsps/sh/gensh1/start/cpu_asm.c
index 99d9cc9a6a..57c5c11796 100644
--- a/bsps/sh/gensh1/start/cpu_asm.c
+++ b/bsps/sh/gensh1/start/cpu_asm.c
@@ -44,9 +44,7 @@
 /* from cpu_isps.c */
 extern proc_ptr         _Hardware_isr_Table[];
-#if (CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
-  unsigned long    *_old_stack_ptr;
-#endif
+unsigned long *_old_stack_ptr;
 register unsigned long  *stack_ptr __asm__ ("r15");
@@ -135,7 +133,6 @@ void __ISR_Handler( uint32_t   vector)
   _Thread_Dispatch_disable();
       /* Install irq stack */
@@ -143,8 +140,6 @@ void __ISR_Handler( uint32_t   vector)
       stack_ptr = _CPU_Interrupt_stack_high;
-#endif
   _ISR_Nest_level++;
   _ISR_Local_enable( level );
@@ -159,12 +154,9 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Nest_level--;
-#if(CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
     /* restore old stack pointer */
     stack_ptr = _old_stack_ptr;
-#endif
diff --git a/bsps/sh/gensh1/start/linkcmds b/bsps/sh/gensh1/start/linkcmds
index bb190f8c5a..1ede3a2fb9 100644
--- a/bsps/sh/gensh1/start/linkcmds
+++ b/bsps/sh/gensh1/start/linkcmds
@@ -192,9 +192,6 @@ SECTIONS
   } > onchip_ram
-  _CPU_Interrupt_stack_low  = 0x0f000000 ;
-  _CPU_Interrupt_stack_high = _CPU_Interrupt_stack_low + 4096 ;
   .stab 0 : { *(.stab) }
   .stabstr 0 : { *(.stabstr) }
@@ -228,7 +225,5 @@ SECTIONS
-  stack : { _stack = .; *(.stack) } > onchip_ram
diff --git a/bsps/sh/gensh1/start/start.S b/bsps/sh/gensh1/start/start.S
index 66b1c4e091..6a2941c7e2 100644
--- a/bsps/sh/gensh1/start/start.S
+++ b/bsps/sh/gensh1/start/start.S
@@ -66,7 +66,7 @@ SYM (start):
 	.align 2
 stack_k:
-	.long	SYM(stack)
+	.long	SYM(_Configuration_Interrupt_stack_area_end)
 edata_k:
 	.long	SYM(edata)
 end_k:
@@ -80,11 +80,3 @@ vects_k:
 	.long	SYM(vectab)
 vects_size:
 	.word	255
-#ifdef __ELF__
-	.section .stack,"aw"
-#else
-	.section .stack
-#endif
-SYM(stack):
-	.long	0xdeaddead
diff --git a/bsps/sh/gensh2/include/bsp.h b/bsps/sh/gensh2/include/bsp.h
index 1a08df9a43..38e2c49208 100644
--- a/bsps/sh/gensh2/include/bsp.h
+++ b/bsps/sh/gensh2/include/bsp.h
@@ -63,12 +63,6 @@ extern "C" {
 /* Constants */
diff --git a/bsps/sh/gensh2/start/cpu_asm.c b/bsps/sh/gensh2/start/cpu_asm.c
index 47bc859dbd..7d6e09c4c4 100644
--- a/bsps/sh/gensh2/start/cpu_asm.c
+++ b/bsps/sh/gensh2/start/cpu_asm.c
@@ -42,9 +42,7 @@
-#endif
@@ -136,7 +134,6 @@ void __ISR_Handler( uint32_t   vector)
@@ -144,8 +141,6 @@ void __ISR_Handler( uint32_t   vector)
-#endif
   _ISR_Nest_level++;
@@ -160,12 +155,9 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Nest_level--;
-#endif
diff --git a/bsps/sh/gensh2/start/linkcmds b/bsps/sh/gensh2/start/linkcmds
index e6db97e0c3..d083d33330 100644
--- a/bsps/sh/gensh2/start/linkcmds
+++ b/bsps/sh/gensh2/start/linkcmds
@@ -203,9 +203,6 @@ SECTIONS
   } > onchip_ram
-  _CPU_Interrupt_stack_low  = 0xFFFFF000;
-  _CPU_Interrupt_stack_high = 0xFFFFFFFF;
@@ -239,7 +236,5 @@ SECTIONS
-  .stack 0xFFFFFEC0 : { _stack = .; *(.stack) } > onchip_ram
diff --git a/bsps/sh/gensh2/start/linkcmds.ram b/bsps/sh/gensh2/start/linkcmds.ram
index 8b53cd4f39..01765f683d 100644
--- a/bsps/sh/gensh2/start/linkcmds.ram
+++ b/bsps/sh/gensh2/start/linkcmds.ram
@@ -205,9 +205,6 @@ SECTIONS
   } > onchip_ram
@@ -241,7 +238,5 @@ SECTIONS
diff --git a/bsps/sh/gensh2/start/linkcmds.rom b/bsps/sh/gensh2/start/linkcmds.rom
index 9f50cd7e64..d6a1bee744 100644
--- a/bsps/sh/gensh2/start/linkcmds.rom
+++ b/bsps/sh/gensh2/start/linkcmds.rom
@@ -210,9 +210,6 @@ SECTIONS
   } > onchip_ram
@@ -246,7 +243,5 @@ SECTIONS
diff --git a/bsps/sh/gensh2/start/start.S b/bsps/sh/gensh2/start/start.S
index cba17af740..b8b3f50156 100644
--- a/bsps/sh/gensh2/start/start.S
+++ b/bsps/sh/gensh2/start/start.S
@@ -155,7 +155,7 @@ SYM (start):
 	.align 2
 stack_k:
-	.long	SYM(stack)
 edata_k:
 	.long	SYM(edata)
 end_k:
@@ -176,14 +176,6 @@ vects_size:
 	.word	255
 #ifdef __ELF__
-#else
-	.section .stack
-#endif
-SYM(stack):
-	.long	0xdeaddead
-#ifdef __ELF__
 	.section .bss,"aw"
 #else
 	.section .bss
diff --git a/bsps/sh/gensh2/start/start.ram b/bsps/sh/gensh2/start/start.ram
index 04e68238a6..7f6b5faf65 100644
--- a/bsps/sh/gensh2/start/start.ram
+++ b/bsps/sh/gensh2/start/start.ram
@@ -158,7 +158,7 @@ SYM (start):
 	.align 2
 stack_k:
-	.long	SYM(stack)
 edata_k:
 	.long	SYM(edata)
 end_k:
@@ -179,14 +179,6 @@ vects_size:
 	.word	255
 #ifdef __ELF__
-#else
-	.section .stack
-#endif
-SYM(stack):
-	.long	0xdeaddead
-#ifdef __ELF__
 	.section .bss,"aw"
 #else
 	.section .bss
diff --git a/bsps/sh/gensh2/start/start.rom b/bsps/sh/gensh2/start/start.rom
index 87fadd50f3..79068daa82 100644
--- a/bsps/sh/gensh2/start/start.rom
+++ b/bsps/sh/gensh2/start/start.rom
@@ -67,7 +67,7 @@ SYM (start):
 	.align 2
 stack_k:
-	.long	SYM(stack)
 edata_k:
 	.long	SYM(edata)
 end_k:
@@ -81,11 +81,3 @@ vects_k:
 	.long	SYM(vectab)
 vects_size:
 	.word	255
-#ifdef __ELF__
-#else
-	.section .stack
-#endif
-SYM(stack):
-	.long	0xdeaddead
diff --git a/bsps/sh/gensh4/include/bsp.h b/bsps/sh/gensh4/include/bsp.h
index b70c2ffdac..f29957cfa5 100644
--- a/bsps/sh/gensh4/include/bsp.h
+++ b/bsps/sh/gensh4/include/bsp.h
@@ -53,13 +53,6 @@ extern "C" {
 /* Constants */
  * Defined in start.S
 extern uint32_t   boot_mode;
diff --git a/bsps/sh/gensh4/start/cpu_asm.c b/bsps/sh/gensh4/start/cpu_asm.c
index 52a033bb75..7618db3e27 100644
--- a/bsps/sh/gensh4/start/cpu_asm.c
+++ b/bsps/sh/gensh4/start/cpu_asm.c
@@ -42,9 +42,7 @@
-#endif
@@ -60,7 +58,6 @@ void __ISR_Handler( uint32_t   vector)
@@ -68,8 +65,6 @@ void __ISR_Handler( uint32_t   vector)
-#endif
   _ISR_Nest_level++;
@@ -84,11 +79,9 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Nest_level--;
-#endif
diff --git a/bsps/sh/gensh4/start/linkcmds b/bsps/sh/gensh4/start/linkcmds
index 21e0fdc5c9..df1c157865 100644
--- a/bsps/sh/gensh4/start/linkcmds
+++ b/bsps/sh/gensh4/start/linkcmds
@@ -144,20 +144,12 @@ SECTIONS
    __bss_end = .;
   } > ram
-  .stack : {
-    . = . + 4096;
-  } > ram
   } > ram
   _WorkAreaBase = . ;
-  . = ALIGN(16);
-  _CPU_Interrupt_stack_low  = . ;
diff --git a/bsps/sh/gensh4/start/linkcmds.rom b/bsps/sh/gensh4/start/linkcmds.rom
index 5e37f06941..49b5b08884 100644
--- a/bsps/sh/gensh4/start/linkcmds.rom
+++ b/bsps/sh/gensh4/start/linkcmds.rom
@@ -193,17 +193,6 @@ SECTIONS
   _WorkAreaBase = . ;
-  . = ALIGN(16);
-  .stack . : {
-     stack_start = .;
-     . = . + 4096;
-     stack_end = .;
-  . = ALIGN(16);
@@ -237,6 +226,5 @@ SECTIONS
-  .stack : { _stack = .; *(.stack) }
diff --git a/bsps/sh/gensh4/start/linkcmds.rom2ram b/bsps/sh/gensh4/start/linkcmds.rom2ram
index 2fff0d1f98..99a4a89147 100644
--- a/bsps/sh/gensh4/start/linkcmds.rom2ram
+++ b/bsps/sh/gensh4/start/linkcmds.rom2ram
@@ -197,17 +197,6 @@ SECTIONS
   _WorkAreaBase = . ;
-  . = ALIGN(16);
-  .stack . : {
-     stack_start = .;
-     . = . + 4096;
-     stack_end = .;
-  . = ALIGN(16);
@@ -241,6 +230,5 @@ SECTIONS
diff --git a/bsps/sh/gensh4/start/start.S b/bsps/sh/gensh4/start/start.S
index a695daaf8a..711583ed6d 100644
--- a/bsps/sh/gensh4/start/start.S
+++ b/bsps/sh/gensh4/start/start.S
@@ -215,7 +215,7 @@ _vbr_base_k:
 __VBR_Saved_k:
         .long   SYM(_VBR_Saved)
 stack_k:
-        .long	SYM(stack)
 __bss_start_k:
         .long   __bss_start
 __bss_end_k:
@@ -255,14 +255,6 @@ boot_mode_k:
         .long   _boot_mode
 #ifdef __ELF__
-#else
-        .section .stack
-#endif
-SYM(stack):
-        .long	0xdeaddead
-#ifdef __ELF__
         .section .bss,"aw"
 #else
         .section .bss
diff --git a/bsps/sh/shared/start/bspstart.c b/bsps/sh/shared/start/bspstart.c
index 57b2c9e1ef..a2b0110874 100644
--- a/bsps/sh/shared/start/bspstart.c
+++ b/bsps/sh/shared/start/bspstart.c
@@ -49,14 +49,6 @@ void bsp_start( void )
   #endif
-   *  initialize the interrupt stack for this BSP
-  #if ( CPU_ALLOCATE_INTERRUPT_STACK == FALSE )
-    _CPU_Interrupt_stack_low = &CPU_Interrupt_stack_low;
-    _CPU_Interrupt_stack_high = &CPU_Interrupt_stack_high;
-  #endif
    *  initialize the device driver parameters
   bsp_clicks_per_second = CPU_CLOCK_RATE_HZ;
diff --git a/bsps/sh/shsim/include/bsp.h b/bsps/sh/shsim/include/bsp.h
index 7b8236b09a..ff63b3849b 100644
--- a/bsps/sh/shsim/include/bsp.h
+++ b/bsps/sh/shsim/include/bsp.h
@@ -46,12 +46,6 @@ void *clock_driver_sim_idle_body(uintptr_t);
 #define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
 int _sys_exit (int n);
diff --git a/bsps/sh/shsim/start/cpu_asm.c b/bsps/sh/shsim/start/cpu_asm.c
index 2ca8926a24..1b8135ee0a 100644
--- a/bsps/sh/shsim/start/cpu_asm.c
+++ b/bsps/sh/shsim/start/cpu_asm.c
@@ -18,9 +18,7 @@
 #include <rtems/score/sh.h>
-#endif
@@ -37,7 +35,6 @@ void __ISR_Handler( uint32_t   vector)
@@ -45,8 +42,6 @@ void __ISR_Handler( uint32_t   vector)
-#endif
   _ISR_Nest_level++;
@@ -61,12 +56,9 @@ void __ISR_Handler( uint32_t   vector)
   _ISR_Nest_level--;
-#endif
diff --git a/bsps/sh/shsim/start/linkcmds b/bsps/sh/shsim/start/linkcmds
index 932d94161f..c0381c0b14 100644
--- a/bsps/sh/shsim/start/linkcmds
+++ b/bsps/sh/shsim/start/linkcmds
@@ -202,22 +202,12 @@ SECTIONS
   _end = . ;
   PROVIDE (end = .);
-  .stack : {
-    . += 0x1000;
-    *(.stack)
-    _stack = .;
-  } > ram
-  _stack = .;
   } > ram
   _WorkAreaBase = . ;
-  _CPU_Interrupt_stack_low  = 0x00080000 ;
@@ -251,9 +241,5 @@ SECTIONS
-  .stack 0x00081ff0 : { _stack = .; *(.stack) } > onchip_ram
diff --git a/bsps/sh/shsim/start/start.S b/bsps/sh/shsim/start/start.S
index cc4727b9ff..e116704370 100644
--- a/bsps/sh/shsim/start/start.S
+++ b/bsps/sh/shsim/start/start.S
@@ -68,7 +68,7 @@ SYM (start):
 	.align 2
 stack_k:
-	.long	SYM(stack)
 edata_k:
 	.long	SYM(edata)
 end_k:
@@ -82,13 +82,3 @@ vects_k:
 	.long	SYM(vectab)
 vects_size:
 	.word	255
-#ifdef __ELF__
-#else
-	.section .stack
-#endif
-SYM(stack):
-	.long	0xdeaddead
-monvects_k:
-	.long	SYM(monvects)
diff --git a/bsps/sparc/shared/start/bspgetworkarea.c b/bsps/sparc/shared/start/bspgetworkarea.c
index b05113d9eb..512d223211 100644
--- a/bsps/sparc/shared/start/bspgetworkarea.c
+++ b/bsps/sparc/shared/start/bspgetworkarea.c
@@ -27,13 +27,9 @@ extern uint32_t rdb_start;
 void bsp_work_area_initialize(void)
-  /* must be identical to STACK_SIZE in start.S */
-  #define STACK_SIZE (16 * 1024)
   /* Early dynamic memory allocator is placed just above _end  */
   void *work_area_start = (void *)&end;
-  uintptr_t work_area_size  =
-    (uintptr_t)rdb_start - (uintptr_t)&end - STACK_SIZE;
+  uintptr_t work_area_size = (uintptr_t)rdb_start - (uintptr_t)work_area_start;
    *  The following may be helpful in debugging what goes wrong when
diff --git a/bsps/sparc/shared/start/start.S b/bsps/sparc/shared/start/start.S
index 64498c6110..5bd2937a13 100644
--- a/bsps/sparc/shared/start/start.S
+++ b/bsps/sparc/shared/start/start.S
@@ -265,7 +265,6 @@ SYM(CLOCK_SPEED):
 #define PSR_INIT   0x10c0       /* Disable traps, set s and ps */
 #define WIM_INIT   2
-#define STACK_SIZE 16 * 1024
         PUBLIC(hard_reset)
 SYM(hard_reset):
@@ -317,9 +316,16 @@ SYM(hard_reset):
 	st	%o0, [%o1]
 #endif
-	set	(SYM(rdb_start)), %g5	! End of RAM
+	set	SYM(rdb_start), %g5	! End of RAM
 	st	%sp, [%g5]
-	sub	%sp, 4, %sp		! stack starts at end of RAM - 4
+	set	SYM(_Configuration_Interrupt_stack_size), %g5
+#if defined(START_LEON3_ENABLE_SMP)
+	add	%o0, 1, %o0
+	smul	%o0, %g5, %g5
+#endif
+	set	SYM(_Configuration_Interrupt_stack_area_begin), %sp
+	add	%sp, %g5, %sp
+	sub	%sp, 4, %sp		! stack starts at end of area - 4
 	andn	%sp, 0x0f, %sp		! align stack on 16-byte boundary
         mov     %sp, %fp                ! Set frame pointer
         nop
diff --git a/bsps/v850/gdbv850sim/start/linkcmds b/bsps/v850/gdbv850sim/start/linkcmds
index 86613dd73d..c128a08de1 100644
--- a/bsps/v850/gdbv850sim/start/linkcmds
+++ b/bsps/v850/gdbv850sim/start/linkcmds
@@ -4,7 +4,6 @@
 _RamBase = DEFINED(_RamBase) ? _RamBase : 0x100000; /* RAM starts at 1MB */
 _RamSize = DEFINED(_RamSize) ? _RamSize : 0x100000; /* default is 1MB */
 OUTPUT_FORMAT("elf32-v850-rh850", "elf32-v850-rh850",
@@ -192,8 +191,6 @@ SECTIONS
 	*(.bss)
 	*(COMMON)
-  . += _StackSize;
-  _stack = .;
@@ -233,13 +230,5 @@ SECTIONS
-  /* libgloss - User stack.  */
-  .stack 0x200000	:
-	__stack = .;
-	*(.stack)
diff --git a/bsps/v850/gdbv850sim/start/start.S b/bsps/v850/gdbv850sim/start/start.S
index 419e635393..82ae4ebcb7 100644
--- a/bsps/v850/gdbv850sim/start/start.S
+++ b/bsps/v850/gdbv850sim/start/start.S
@@ -9,7 +9,7 @@ _start:
 	movea   255,		r0,	r20
 	mov     65535,		r21
-	mov     hilo(_stack),	sp
+	mov     hilo(__Configuration_Interrupt_stack_area_end),	sp
 	mov     hilo(__ep),	ep
 	mov     hilo(__gp),	gp
 	mov     hilo(__ctbp),	r6
@@ -36,8 +36,8 @@ _start:
 	movea   255,		r0,	r20
 	mov     r0,		r21
 	ori     65535,		r0,	r21
-	movhi   hi(_stack),	r0,	sp
-	movea   lo(_stack),	sp,	sp
+	movhi   hi(__Configuration_Interrupt_stack_area_end),	r0,	sp
+	movea   lo(__Configuration_Interrupt_stack_area_end),	sp,	sp
 	movhi   hi(__ep),	r0,	ep
 	movea   lo(__ep),	ep,	ep
 	movhi   hi(__gp),	r0,	gp
@@ -66,11 +66,6 @@ _start:
 	/* jarl    _exit,		r31 */
 # endif
-#if 0
-	.section .stack
-_stack:	.long 	1
-#endif
 	.section .data
 	.global ___dso_handle
 	.weak   ___dso_handle
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index 3c5bea2029..5f34001877 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -19,7 +19,6 @@ project_lib_DATA = start.$(OBJEXT)
 project_lib_DATA += linkcmds
 dist_project_lib_DATA += ../../../../../../bsps/arm/altera-cyclone-v/start/linkcmds.altcycv
 dist_project_lib_DATA += ../../../../../../bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit
-dist_project_lib_DATA += ../../../../../../bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp
 project_lib_LIBRARIES = librtemsbsp.a
diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
index c88ce82f43..0f3a399877 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
+++ b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
@@ -10,6 +10,7 @@ AC_INIT([rtems-c-src-lib-libbsp-arm-raspberrypi],[_RTEMS_VERSION],[https://devel
 RTEMS_TOP(../../../../../..)
 RTEMS_SOURCE_TOP
 RTEMS_BUILD_TOP
+RTEMS_BSP_LINKCMDS
 RTEMS_CANONICAL_TARGET_CPU
 AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
@@ -36,21 +37,7 @@ RTEMS_BSPOPTS_SET([BSP_IS_RPI2],[*],[0])
 RTEMS_BSPOPTS_HELP([BSP_IS_RPI2],[Set if the BSP variant is Raspberry Pi 2.])
 AM_CONDITIONAL(RTEMS_RPI2,[test "$BSP_IS_RPI2" = "1"])
-# Hom many CPUs are used?
-RASPBERRYPI_CPUS="1"
-AS_IF([test "$rtems_cv_HAS_SMP" = "yes"],
-      [RASPBERRYPI_CPUS="4"])
-AC_DEFUN([RASPBERRYPI_LINKCMD],[
-AC_ARG_VAR([$1],[$2; default $3])dnl
-[$1]=[$]{[$1]:-[$3]}
-RASPBERRYPI_LINKCMD([RASPBERRYPI_CPUS],[Number of active cores],[${RASPBERRYPI_CPUS}])
 RTEMS_BSP_CLEANUP_OPTIONS
-AC_CONFIG_FILES([
-Makefile
-linkcmds:../../../../../../bsps/arm/raspberrypi/start/linkcmds.in])
+AC_CONFIG_FILES([Makefile])
 AC_OUTPUT
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index e41e065ba1..01e1f3eae4 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -26,7 +26,6 @@ project_lib_DATA = start.$(OBJEXT)
 dist_project_lib_DATA += ../../../../../../bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu
-dist_project_lib_DATA += ../../../../../../bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp
 #                  LibBSP                                                     #
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
index e282b3546b..f58b737b1b 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
@@ -58,10 +58,6 @@ RTEMS_BSPOPTS_HELP([BSP_CONSOLE_MINOR],[minor number of console device])
 RTEMS_BSPOPTS_SET([ZYNQ_CONSOLE_USE_INTERRUPTS],[*],[1])
 RTEMS_BSPOPTS_HELP([ZYNQ_CONSOLE_USE_INTERRUPTS],[use interrupt driven mode for console devices (used by default)])
-ZYNQ_CPUS="1"
-      [ZYNQ_CPUS="2"])
 # Zynq Memory map can be controlled from the configure command line. Use ...
@@ -126,7 +122,6 @@ AC_ARG_VAR([$1],[$2; default $3])dnl
-ZYNQ_LINKCMD([ZYNQ_CPUS],[Number of active cores],[${ZYNQ_CPUS}])
 ZYNQ_LINKCMD([ZYNQ_RAM_ORIGIN],[normal RAM region origin],[${ZYNQ_RAM_ORIGIN}])
 ZYNQ_LINKCMD([ZYNQ_RAM_LENGTH],[normal RAM region length],[${BSP_ZYNQ_RAM_LENGTH}])
 ZYNQ_LINKCMD([ZYNQ_RAM_MMU],[MMU region origin],[${ZYNQ_RAM_MMU}])
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 69bc88aa9d..7a7ec371c9 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1215,12 +1215,13 @@ RTEMS_SYSINIT_ITEM(
   #error "CONFIGURE_IDLE_TASK_STACK_SIZE less than CONFIGURE_MINIMUM_TASK_STACK_SIZE"
 #endif
- * @brief Interrupt stack size configuration.
+ * Interrupt stack configuration.
  * By default, the interrupt stack will be of minimum size.
  * The BSP or application may override this value.
 #ifndef CONFIGURE_INTERRUPT_STACK_SIZE
   #ifdef BSP_INTERRUPT_STACK_SIZE
     #define CONFIGURE_INTERRUPT_STACK_SIZE BSP_INTERRUPT_STACK_SIZE
@@ -1229,18 +1230,23 @@ RTEMS_SYSINIT_ITEM(
   #endif
 #endif
- * This reserves memory for the interrupt stack if it is to be allocated
- * by RTEMS rather than the BSP.
- * @todo Try to get to the point where all BSPs support allocating the
- *       memory from the Workspace.
-#if (CPU_ALLOCATE_INTERRUPT_STACK == 0)
-  #define _CONFIGURE_INTERRUPT_STACK_MEMORY 0
-#else
-  #define _CONFIGURE_INTERRUPT_STACK_MEMORY \
-     _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE )
+#if CONFIGURE_INTERRUPT_STACK_SIZE % CPU_INTERRUPT_STACK_ALIGNMENT != 0
+  #error "CONFIGURE_INTERRUPT_STACK_SIZE fails to meet the CPU port interrupt stack alignment"
+#endif
+#ifdef CONFIGURE_INIT
+  RTEMS_DEFINE_GLOBAL_SYMBOL(
+    _Configuration_Interrupt_stack_size,
+    CONFIGURE_INTERRUPT_STACK_SIZE
+  char _Configuration_Interrupt_stack_area_begin[
+    CONFIGURE_MAXIMUM_PROCESSORS * CONFIGURE_INTERRUPT_STACK_SIZE
+  ] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
+  RTEMS_SECTION( ".rtemsstack.interrupt.begin" );
+  const char _Configuration_Interrupt_stack_area_end[ 0 ]
+    RTEMS_SECTION( ".rtemsstack.interrupt.end" ) = { };
 #endif
@@ -2756,9 +2762,7 @@ RTEMS_SYSINIT_ITEM(
  * This macro accounts for general RTEMS system overhead.
 #define _CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD \
-  ( _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS + \
-    _CONFIGURE_INTERRUPT_STACK_MEMORY \
+  _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS
  * This macro reserves the memory required by the statically configured
@@ -2788,18 +2792,6 @@ RTEMS_SYSINIT_ITEM(
    _CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS) \
- * This macro provides a summation of the memory required by SMP as configured.
-#if defined(RTEMS_SMP)
-  #define _CONFIGURE_MEMORY_FOR_SMP \
-     (CONFIGURE_MAXIMUM_PROCESSORS * \
-      _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) \
-#else
-  #define _CONFIGURE_MEMORY_FOR_SMP 0
-#endif
  * This calculates the memory required for the executive workspace.
@@ -2819,7 +2811,6 @@ RTEMS_SYSINIT_ITEM(
    _CONFIGURE_MEMORY_FOR_POSIX + \
    _CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
    _CONFIGURE_MEMORY_FOR_MP + \
-   _CONFIGURE_MEMORY_FOR_SMP + \
    CONFIGURE_MESSAGE_BUFFER_MEMORY + \
    (CONFIGURE_MEMORY_OVERHEAD * 1024) + \
    _CONFIGURE_HEAP_HANDLER_OVERHEAD \
@@ -3118,7 +3109,6 @@ RTEMS_SYSINIT_ITEM(
     CONFIGURE_TICKS_PER_TIMESLICE,            /* ticks per timeslice quantum */
     CONFIGURE_IDLE_TASK_BODY,                 /* user's IDLE task */
     CONFIGURE_IDLE_TASK_STACK_SIZE,           /* IDLE task stack size */
-    CONFIGURE_INTERRUPT_STACK_SIZE,           /* interrupt stack size */
     CONFIGURE_TASK_STACK_ALLOCATOR_INIT,      /* stack allocator init */
     CONFIGURE_TASK_STACK_ALLOCATOR,           /* stack allocator */
     CONFIGURE_TASK_STACK_DEALLOCATOR,         /* stack deallocator */
@@ -3275,7 +3265,6 @@ RTEMS_SYSINIT_ITEM(
     uint32_t POSIX;
     /* System overhead pieces */
-    uint32_t INTERRUPT_STACK_MEMORY;
     uint32_t MEMORY_FOR_IDLE_TASK;
     /* Classic API Pieces */
@@ -3324,7 +3313,6 @@ RTEMS_SYSINIT_ITEM(
     _CONFIGURE_MEMORY_FOR_POSIX,
-    _CONFIGURE_INTERRUPT_STACK_MEMORY,
     _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS,
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 6b97376511..248ace0721 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -184,13 +184,6 @@ typedef struct {
   uint32_t                       idle_task_stack_size;
-   * This field specifies the size of the interrupt stack.  If less than or
-   * equal to the minimum stack size, then the interrupt stack will be of
-   * minimum stack size.
-  uint32_t                       interrupt_stack_size;
    * @brief Optional task stack allocator initialization hook.
@@ -313,8 +306,34 @@ extern const rtems_configuration_table Configuration;
 #define rtems_configuration_get_idle_task_stack_size() \
         (Configuration.idle_task_stack_size)
+ * @brief Global symbol with a value equal to the configure interrupt stack size.
+ * This global symbol is defined by the application configuration option
+ * CONFIGURE_INIT_TASK_STACK_SIZE via <rtems/confdefs.h>.
+RTEMS_DECLARE_GLOBAL_SYMBOL( _Configuration_Interrupt_stack_size );
+ * @brief The interrupt stack area begin.
+ * The interrupt stack area is defined by the application configuration via
+ * <rtems/confdefs.h>.  The size of the area depends on
+ * CONFIGURE_INIT_TASK_STACK_SIZE and CONFIGURE_MAXIMUM_PROCESSORS.
+extern char _Configuration_Interrupt_stack_area_begin[];
+ * @brief The interrupt stack area end.
+extern const char _Configuration_Interrupt_stack_area_end[];
 #define rtems_configuration_get_interrupt_stack_size() \
-        (Configuration.interrupt_stack_size)
+        ((size_t) _Configuration_Interrupt_stack_size)
 #define rtems_configuration_get_stack_allocate_init_hook() \
         (Configuration.stack_allocate_init_hook)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 360d62807c..9c493a9355 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -295,20 +295,15 @@ typedef struct Per_CPU_Control {
     CPU_Per_CPU_control cpu_per_cpu;
   #endif
-  #if (CPU_ALLOCATE_INTERRUPT_STACK == TRUE) || \
-      (CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
-     * This contains a pointer to the lower range of the interrupt stack for
-     * this CPU.  This is the address allocated and freed.
-    void  *interrupt_stack_low;
+   * @brief The interrupt stack low address for this processor.
+  void *interrupt_stack_low;
-     * This contains a pointer to the interrupt stack pointer for this CPU.
-     * It will be loaded at the beginning on an ISR.
-    void  *interrupt_stack_high;
-  #endif
+   * @brief The interrupt stack high address for this processor.
+  void *interrupt_stack_high;
    *  This contains the current interrupt nesting level on this
@@ -804,33 +799,21 @@ RTEMS_INLINE_ROUTINE struct _Thread_Control *_Thread_Get_executing( void )
 #if defined( ASM ) || defined( _RTEMS_PERCPU_DEFINE_OFFSETS )
-#if (CPU_ALLOCATE_INTERRUPT_STACK == TRUE) || \
-   *  If this CPU target lets RTEMS allocates the interrupt stack, then
-   *  we need to have places in the per CPU table to hold them.
-  #define PER_CPU_INTERRUPT_STACK_LOW \
-    CPU_PER_CPU_CONTROL_SIZE
-  #define PER_CPU_INTERRUPT_STACK_HIGH \
-    PER_CPU_INTERRUPT_STACK_LOW + CPU_SIZEOF_POINTER
-  #define PER_CPU_END_STACK             \
-    PER_CPU_INTERRUPT_STACK_HIGH + CPU_SIZEOF_POINTER
-  #define INTERRUPT_STACK_LOW \
-    (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_LOW)
-  #define INTERRUPT_STACK_HIGH \
-    (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_HIGH)
-#else
-#endif
+#define PER_CPU_INTERRUPT_STACK_LOW \
+  CPU_PER_CPU_CONTROL_SIZE
+#define PER_CPU_INTERRUPT_STACK_HIGH \
+  PER_CPU_INTERRUPT_STACK_LOW + CPU_SIZEOF_POINTER
+#define INTERRUPT_STACK_LOW \
+  (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_LOW)
+#define INTERRUPT_STACK_HIGH \
+  (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_HIGH)
  *  These are the offsets of the required elements in the per CPU table.
 #define PER_CPU_ISR_NEST_LEVEL \
-  PER_CPU_END_STACK
+  PER_CPU_INTERRUPT_STACK_HIGH + CPU_SIZEOF_POINTER
 #define PER_CPU_ISR_DISPATCH_DISABLE \
   PER_CPU_ISR_NEST_LEVEL + 4
 #define PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL \
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index abbd0e0845..bc4a7fc478 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -181,7 +181,6 @@ bool rtems_stack_checker_create_extension(
 void rtems_stack_checker_begin_extension( Thread_Control *executing )
   Per_CPU_Control *cpu_self;
   uint32_t         cpu_self_index;
   Stack_Control   *stack;
@@ -214,7 +213,6 @@ void rtems_stack_checker_begin_extension( Thread_Control *executing )
   _Thread_Dispatch_enable( cpu_self );
 #endif
-#endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index 3f06c036f0..4260e98221 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -105,12 +105,6 @@
 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK FALSE
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
-#define CPU_ALLOCATE_INTERRUPT_STACK FALSE
 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
 #define CPU_HARDWARE_FP FALSE
diff --git a/cpukit/score/cpu/bfin/cpu.c b/cpukit/score/cpu/bfin/cpu.c
index 98c83c9586..f5fb0c4cdd 100644
--- a/cpukit/score/cpu/bfin/cpu.c
+++ b/cpukit/score/cpu/bfin/cpu.c
@@ -198,17 +198,3 @@ void _CPU_Context_Initialize(
     the_context->register_rets = (uint32_t) entry_point;
     the_context->imask = new_level ? 0 : 0xffff;
- *  _CPU_Install_interrupt_stack
- *  NO_CPU Specific Information:
- *  XXX document implementation including references if appropriate
-void _CPU_Install_interrupt_stack( void )
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
index d3e4e4b057..c19a077bd3 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpu.h
@@ -30,35 +30,6 @@ extern "C" {
 /* conditional compilation parameters */
- * Does RTEMS manage a dedicated interrupt stack in software?
- * If TRUE, then a stack is allocated in @ref _ISR_Handler_initialization.
- * If FALSE, nothing is done.
- * If the CPU supports a dedicated interrupt stack in hardware,
- * then it is generally the responsibility of the BSP to allocate it
- * and set it up.
- * If the CPU does not support a dedicated interrupt stack, then
- * the porter has two options: (1) execute interrupts on the
- * stack of the interrupted task, and (2) have RTEMS manage a dedicated
- * interrupt stack.
- * If this is TRUE, @ref CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
- * Only one of @ref CPU_HAS_SOFTWARE_INTERRUPT_STACK and
- * @ref CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
- * possible that both are FALSE for a particular CPU.  Although it
- * is unclear what that would imply about the interrupt processing
- * procedure on that CPU.
- * Port Specific Information:
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
  *  Does the CPU follow the simple vectored interrupt model?
@@ -73,40 +44,6 @@ extern "C" {
 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
- * Does this CPU have hardware support for a dedicated interrupt stack?
- * If TRUE, then it must be installed during initialization.
- * If FALSE, then no installation is performed.
- * Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
- * If TRUE, then the memory is allocated during initialization.
- * If FALSE, then the memory is allocated during initialization.
- * This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
-#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
  * Does the RTEMS invoke the user's ISR with the vector number and
  * a pointer to the saved interrupt frame (1) or just the vector
  * number (0)?
@@ -402,21 +339,6 @@ typedef struct {
  * @defgroup CPUInterrupt Processor Dependent Interrupt Management
- * On some CPUs, RTEMS supports a software managed interrupt stack.
- * This stack is allocated by the Interrupt Manager and the switch
- * is performed in @ref _ISR_Handler.  These variables contain pointers
- * to the lowest and highest addresses in the chunk of memory allocated
- * for the interrupt stack.  Since it is unknown whether the stack
- * grows up or down (in general), this give the CPU dependent
- * code the option of picking the version it wants to use.
- * @note These two variables are required if the macro
- *       @ref CPU_HAS_SOFTWARE_INTERRUPT_STACK is defined as TRUE.
@@ -816,19 +738,6 @@ void _CPU_ISR_install_vector(
- * @ingroup CPUInterrupt
- * This routine installs the hardware interrupt stack pointer.
- * @note  It need only be provided if @ref CPU_HAS_HARDWARE_INTERRUPT_STACK
- *        is TRUE.
-void _CPU_Install_interrupt_stack( void );
  * This routine is the CPU dependent IDLE thread body.
  * @note  It need only be provided if @ref CPU_PROVIDES_IDLE_THREAD_BODY
diff --git a/cpukit/score/cpu/epiphany/cpu.c b/cpukit/score/cpu/epiphany/cpu.c
index 0428a86367..489576cfc7 100644
--- a/cpukit/score/cpu/epiphany/cpu.c
+++ b/cpukit/score/cpu/epiphany/cpu.c
@@ -83,11 +83,6 @@ void _CPU_ISR_install_vector(
   /* Do nothing */
-  /* Do nothing */
 CPU_Counter_ticks _CPU_Counter_read( void )
   static CPU_Counter_ticks counter;
diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
index 65f28ac435..9167c09eab 100644
--- a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
@@ -50,67 +50,6 @@ extern "C" {
- *  If TRUE, then a stack is allocated in _ISR_Handler_initialization.
- *  and set it up.
- *  If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
- *  Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
- *  CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
- *  Currently, for epiphany port, _ISR_Handler is responsible for switching to
- *  RTEMS dedicated interrupt task.
- *  or CPU_INSTALL_HARDWARE_INTERRUPT_STACK is TRUE.
  *  number (0)?
@@ -728,18 +667,6 @@ void _CPU_ISR_install_vector(
- *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
- *         is TRUE.
  *  _CPU_Thread_Idle_body
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 226d20b85f..6b4302f706 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -50,14 +50,6 @@ extern "C" {
- *  i386 has an RTEMS allocated and managed interrupt stack.
  *  number (0)?
diff --git a/cpukit/score/cpu/lm32/cpu.c b/cpukit/score/cpu/lm32/cpu.c
index a9a90c245f..577f5cbb45 100644
--- a/cpukit/score/cpu/lm32/cpu.c
+++ b/cpukit/score/cpu/lm32/cpu.c
@@ -101,18 +101,6 @@ void _CPU_ISR_install_vector(
- *  LM32 Specific Information:
  *  NOTES:
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
index 77f3389f39..d5fd9cea85 100644
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpu.h
@@ -29,35 +29,6 @@ extern "C" {
- * and set it up.
  * If TRUE, then RTEMS allocates the vector table it internally manages.
@@ -71,40 +42,6 @@ extern "C" {
  * number (0)?
@@ -426,21 +363,6 @@ extern Context_Control_fp _CPU_Null_fp_context;
- * NOTE: These two variables are required if the macro
@@ -847,18 +769,6 @@ void _CPU_ISR_install_vector(
   proc_ptr   *old_handler
- * NOTE:  It need only be provided if @ref CPU_HAS_HARDWARE_INTERRUPT_STACK
- *        is TRUE.
diff --git a/cpukit/score/cpu/lm32/irq.c b/cpukit/score/cpu/lm32/irq.c
index be84d747b6..5d227cb2e4 100644
--- a/cpukit/score/cpu/lm32/irq.c
+++ b/cpukit/score/cpu/lm32/irq.c
@@ -21,9 +21,7 @@
-#if( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
-#endif
 void *_exception_stack_frame;
@@ -44,13 +42,11 @@ void __ISR_Handler(uint32_t vector, CPU_Interrupt_frame *ifr)
   if ( _ISR_Nest_level == 0 ) {
     _old_stack_ptr = stack_ptr;
     stack_ptr = _CPU_Interrupt_stack_high - 4;
-#endif
   _ISR_Nest_level++;
@@ -64,10 +60,8 @@ void __ISR_Handler(uint32_t vector, CPU_Interrupt_frame *ifr)
   _ISR_Nest_level--;
   if( _ISR_Nest_level == 0)
-#endif
   _Thread_Dispatch_unnest( _Per_CPU_Get() );
diff --git a/cpukit/score/cpu/m32c/cpu.c b/cpukit/score/cpu/m32c/cpu.c
index 4592e8ced3..6b4f88634d 100644
--- a/cpukit/score/cpu/m32c/cpu.c
+++ b/cpukit/score/cpu/m32c/cpu.c
@@ -113,18 +113,6 @@ void _CPU_ISR_install_vector(
  *  NOTES:
diff --git a/cpukit/score/cpu/m32c/cpu_asm.c b/cpukit/score/cpu/m32c/cpu_asm.c
index f992c57b3d..16a80b2963 100644
--- a/cpukit/score/cpu/m32c/cpu_asm.c
+++ b/cpukit/score/cpu/m32c/cpu_asm.c
@@ -73,10 +73,8 @@ void _ISR_Handler(void)
    *  save some or all context on stack
    *  may need to save some special interrupt information for exit
-   *  #endif
    *  _ISR_Nest_level++;
@@ -100,10 +98,8 @@ void _ISR_Handler(void)
    *    return from interrupt  (maybe to _ISR_Dispatch)
    *  LABEL "exit interrupt (simple case):
-   *    if outermost interrupt
-   *      restore stack
-   *  #endif
+   *  if outermost interrupt
+   *    restore stack
    *  prepare to get out of interrupt
diff --git a/cpukit/score/cpu/m32c/include/rtems/score/cpu.h b/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
index 3f23c21d88..74794fe6fe 100644
--- a/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
@@ -45,35 +45,6 @@ extern "C" {
 #define RTEMS_USE_16_BIT_OBJECT
- * and set it up.
@@ -87,40 +58,6 @@ extern "C" {
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK TRUE
  * number (0)?
@@ -409,22 +346,6 @@ typedef struct {
@@ -836,20 +757,6 @@ void _CPU_ISR_install_vector(
- *        is TRUE.
  * NOTE:  It need only be provided if @ref CPU_PROVIDES_IDLE_THREAD_BODY
diff --git a/cpukit/score/cpu/m68k/cpu.c b/cpukit/score/cpu/m68k/cpu.c
index c50a63fda1..77a91535c3 100644
--- a/cpukit/score/cpu/m68k/cpu.c
+++ b/cpukit/score/cpu/m68k/cpu.c
@@ -20,6 +20,7 @@
 #include <rtems/score/isr.h>
 #include <rtems/score/tls.h>
+#include <rtems/config.h>
 #if ( M68K_HAS_VBR == 0 )
@@ -58,6 +59,15 @@ int (*_FPSP_install_raw_handler)(
   uint32_t _CPU_cacr_shadow;
 #endif
+static void m68k_install_interrupt_stack( void )
+#if ( M68K_HAS_SEPARATE_STACKS == 1 )
+  uintptr_t isp = (uintptr_t) _Configuration_Interrupt_stack_area_end;
+  __asm__ volatile ( "movec %0,%%isp" : "=r" (isp) : "0" (isp) );
+#endif
 void _CPU_Initialize(void)
@@ -74,6 +84,8 @@ void _CPU_Initialize(void)
     _CPU_ISR_jump_table[slot].isr_handler = (uint32_t) 0xDEADDEAD;
 #endif /* M68K_HAS_VBR */
+  m68k_install_interrupt_stack();
 uint32_t   _CPU_ISR_Get_level( void )
@@ -151,20 +163,6 @@ void _CPU_ISR_install_vector(
   _ISR_Vector_table[ vector ] = new_handler;
-#if ( M68K_HAS_SEPARATE_STACKS == 1 )
-  void *isp = _CPU_Interrupt_stack_high;
-  __asm__ volatile ( "movec %0,%%isp" : "=r" (isp) : "0" (isp) );
-#endif
 #if ( M68K_HAS_BFFFO != 1 )
  * Returns table for duplication of the BFFFO instruction (16 bits only)
diff --git a/cpukit/score/cpu/m68k/cpu_asm.S b/cpukit/score/cpu/m68k/cpu_asm.S
index a31c1588a4..6ec89d8ee0 100644
--- a/cpukit/score/cpu/m68k/cpu_asm.S
+++ b/cpukit/score/cpu/m68k/cpu_asm.S
@@ -259,7 +259,7 @@ SYM (_ISR_Handler):
         andl    #0x03fc,d0               | d0 = vector offset in vbr
-#if ( CPU_HAS_SOFTWARE_INTERRUPT_STACK == 1 )
+#if ( M68K_HAS_SEPARATE_STACKS == 0 )
         | Make a0 point just above interrupt stack
         movel   INTERRUPT_STACK_HIGH,a0
         cmpl    INTERRUPT_STACK_LOW,a7  | stack below interrupt stack?
@@ -272,7 +272,7 @@ SYM (_ISR_Handler):
         movel   a1,a7 at -                 | store task stack pointer
                                         |     on interrupt stack
 2:
-#endif /* CPU_HAS_SOFTWARE_INTERRUPT_STACK == 1 */
+#endif /* M68K_HAS_SEPARATE_STACKS == 0 */
         addql   #1,ISR_NEST_LEVEL        | one nest level deeper
@@ -285,14 +285,14 @@ SYM (_ISR_Handler):
         addql   #4,a7                    | remove vector number
         subql   #1,ISR_NEST_LEVEL        | Reduce interrupt-nesting count
         subql   #4,a0
         cmpl    a0,a7                   | At top of interrupt stack?
         bne.b   1f                      | No, do not restore task stack pointer
         movel   (a7),a7                 | Restore task stack pointer
 1:
         subql   #1,THREAD_DISPATCH_DISABLE_LEVEL
                                          | unnest multitasking
         bne.b    exit                    | If dispatch disabled, exit
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
index bd1f29abe4..d4c4fec5b0 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
@@ -42,20 +42,6 @@ extern "C" {
- *  Use the m68k's hardware interrupt stack support and have the
- *  interrupt manager allocate the memory for it.
-#if ( M68K_HAS_SEPARATE_STACKS == 1)
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK 0
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK 1
-#else
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK 1
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK 0
-#endif
-#define CPU_ALLOCATE_INTERRUPT_STACK     1
  *  number (0)?
@@ -616,14 +602,6 @@ void _CPU_ISR_install_vector(
  *  _CPU_Context_switch
  *  This routine switches from the run context to the heir context.
diff --git a/cpukit/score/cpu/mips/cpu.c b/cpukit/score/cpu/mips/cpu.c
index fe89a10ec7..7f48d090f9 100644
--- a/cpukit/score/cpu/mips/cpu.c
+++ b/cpukit/score/cpu/mips/cpu.c
@@ -166,11 +166,6 @@ void _CPU_ISR_Set_level( uint32_t   new_level )
   mips_set_sr( sr );
-/* we don't support this yet */
   Context_Control  *the_context,
   uintptr_t        *stack_base,
diff --git a/cpukit/score/cpu/mips/cpu_asm.S b/cpukit/score/cpu/mips/cpu_asm.S
index c58aee1e50..8a58831b92 100644
--- a/cpukit/score/cpu/mips/cpu_asm.S
+++ b/cpukit/score/cpu/mips/cpu_asm.S
@@ -872,10 +872,8 @@ _ISR_Handler_1:
-   *  #endif
@@ -939,9 +937,7 @@ _ISR_Handler_1:
-   *    restore stack
-   *  #endif
+   *  restore stack
    *  if !_Thread_Dispatch_necessary
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index c20e5f4f01..df9f2b71b0 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -62,32 +62,6 @@ extern "C" {
- *  If TRUE, then a stack is allocated in _Interrupt_Manager_initialization.
- *  and set it up.
@@ -102,34 +76,6 @@ extern "C" {
  *  number (0)?
@@ -871,17 +817,6 @@ void _CPU_ISR_install_vector(
- *         is TRUE.
  *  _CPU_Internal_threads_Idle_thread_body
diff --git a/cpukit/score/cpu/moxie/cpu.c b/cpukit/score/cpu/moxie/cpu.c
index 2a0dc1e9fd..7fd21cd04c 100644
--- a/cpukit/score/cpu/moxie/cpu.c
+++ b/cpukit/score/cpu/moxie/cpu.c
@@ -105,13 +105,6 @@ void _CPU_ISR_install_vector(
  *  NOTES:
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index 9b6dbecc9c..4b6891f495 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -38,35 +38,6 @@ extern "C" {
 #define RTEMS_USE_32_BIT_OBJECT
- *  and set it up.
- *  MOXIE Specific Information:
- *  XXX
@@ -80,40 +51,6 @@ extern "C" {
- *  XXX
- *  XXX
  *  Does the CPU have hardware floating point?
  *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
@@ -679,20 +616,6 @@ void _CPU_ISR_install_vector(
- *         is TRUE.
- *  XXX
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index 3cc56e591b..ae1c027def 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -27,8 +27,6 @@ extern "C" {
 #include <rtems/score/nios2.h>
 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
@@ -37,10 +35,6 @@ extern "C" {
 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS TRUE
diff --git a/cpukit/score/cpu/nios2/nios2-iic-irq.c b/cpukit/score/cpu/nios2/nios2-iic-irq.c
index 99f1618f02..cec24fd5dc 100644
--- a/cpukit/score/cpu/nios2/nios2-iic-irq.c
+++ b/cpukit/score/cpu/nios2/nios2-iic-irq.c
@@ -32,9 +32,7 @@
  *  Upon entry, interrupts are disabled
-#endif
  * Prototypes
@@ -98,13 +96,11 @@ void __ISR_Handler(void)
   /* Interrupts are disabled upon entry to this Handler */
-#endif
   _ISR_Nest_level++;
@@ -120,9 +116,7 @@ void __ISR_Handler(void)
   _ISR_Nest_level--;
   if( _ISR_Nest_level == 0) {
-#endif
     if( _Thread_Dispatch_is_enabled() )
diff --git a/cpukit/score/cpu/no_cpu/cpu.c b/cpukit/score/cpu/no_cpu/cpu.c
index 88bd413f21..fe1e303320 100644
--- a/cpukit/score/cpu/no_cpu/cpu.c
+++ b/cpukit/score/cpu/no_cpu/cpu.c
@@ -87,18 +87,6 @@ void _CPU_ISR_install_vector(
  *  NOTES:
diff --git a/cpukit/score/cpu/no_cpu/cpu_asm.c b/cpukit/score/cpu/no_cpu/cpu_asm.c
index 4e56960168..359bee3367 100644
--- a/cpukit/score/cpu/no_cpu/cpu_asm.c
+++ b/cpukit/score/cpu/no_cpu/cpu_asm.c
@@ -151,10 +151,8 @@ void _ISR_Handler(void)
-   *  #endif
@@ -178,10 +176,8 @@ void _ISR_Handler(void)
-   *      restore stack
-   *  #endif
+   *    restore stack
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index ba6e7fe02a..c11d37a239 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -46,35 +46,6 @@ extern "C" {
- * and set it up.
@@ -88,40 +59,6 @@ extern "C" {
  * number (0)?
@@ -521,16 +458,13 @@ extern Context_Control_fp _CPU_Null_fp_context;
+ * RTEMS supports a software managed interrupt stack.  The interrupt stacks
+ * are statically allocated by <rtems/confdefs.h> and the switch is performed
+ * by hardware or the interrupt processing code.  These variables contain
+ * pointers to the lowest and highest addresses in the chunk of memory
+ * allocated for the interrupt stack.  Since it is unknown whether the stack
+ * grows up or down (in general), this give the CPU dependent code the option
+ * of picking the version it wants to use.
@@ -1126,19 +1060,6 @@ void _CPU_ISR_install_vector(
- *        is TRUE.
diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
index fe933f0cbb..b4cbe00f9b 100644
--- a/cpukit/score/cpu/or1k/cpu.c
+++ b/cpukit/score/cpu/or1k/cpu.c
@@ -105,10 +105,6 @@ void _CPU_ISR_install_vector(
 void *_CPU_Thread_Idle_body( uintptr_t ignored )
   do {
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index b9296df6e1..b05e5895f2 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -40,67 +40,6 @@ extern "C" {
- *  and set it up.
- *  Currently, for or1k port, _ISR_Handler is responsible for switching to
  *  number (0)?
@@ -736,18 +675,6 @@ void _CPU_ISR_install_vector(
- *         is TRUE.
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
index ac6ecccc1d..ca28cb9a39 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h
@@ -473,60 +473,6 @@ typedef struct {
- *  and set it up.
  *  number (0)?
diff --git a/cpukit/score/cpu/riscv/cpu.c b/cpukit/score/cpu/riscv/cpu.c
index 8d2926e715..fbdb4c5238 100644
--- a/cpukit/score/cpu/riscv/cpu.c
+++ b/cpukit/score/cpu/riscv/cpu.c
@@ -110,11 +110,6 @@ void _CPU_ISR_install_vector(
-  /* Do nothing */
   do {
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
index ad2d3dbe46..b2efff8a65 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpu.h
@@ -50,9 +50,6 @@ extern "C" {
 #define CPU_INLINE_ENABLE_DISPATCH       FALSE
 #define CPU_UNROLL_ENQUEUE_PRIORITY      TRUE
 #define CPU_ISR_PASSES_FRAME_POINTER 1
 #define CPU_SOFTWARE_FP                  FALSE
@@ -351,18 +348,6 @@ void _CPU_ISR_install_vector(
- *         is TRUE.
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpu.h b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
index d3c9bc6d39..3952abeae5 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
@@ -50,38 +50,6 @@ extern "C" {
- *  and set it up.
- * We define the interrupt stack in the linker script
  *  number (0)?
@@ -641,17 +609,6 @@ void _CPU_ISR_install_vector(
- *  NOTE:  It needs only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
- *         is TRUE.
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index 8aa701dde2..59b60e377c 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -69,17 +69,6 @@ extern "C" {
 #endif
- * Does the executive manage a dedicated interrupt stack in software?
- * The SPARC does not have a dedicated HW interrupt stack and one has
- * been implemented in SW.
  * - If TRUE, then RTEMS allocates the vector table it internally manages.
@@ -92,29 +81,6 @@ extern "C" {
- * - If TRUE, then it must be installed during initialization.
- * - If FALSE, then no installation is performed.
- * The SPARC does not have a dedicated HW interrupt stack.
- * Do we allocate a dedicated interrupt stack in the Interrupt Manager?
- * - If TRUE, then the memory is allocated during initialization.
- * - If FALSE, then the memory is allocated during initialization.
- * The SPARC does not have hardware support for switching to a
- * dedicated interrupt stack.  The port includes support for doing this
- * in software.
  * number (0)?
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
index feb7752915..3172802046 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
@@ -34,18 +34,6 @@ extern "C" {
@@ -59,26 +47,6 @@ extern "C" {
  *  number (0)?
diff --git a/cpukit/score/cpu/v850/cpu_asm.S b/cpukit/score/cpu/v850/cpu_asm.S
index 328c71cea2..e9aa738d13 100644
--- a/cpukit/score/cpu/v850/cpu_asm.S
+++ b/cpukit/score/cpu/v850/cpu_asm.S
@@ -138,76 +138,3 @@ restore:
 __CPU_Context_restore:
         mov      r6, r7         /* move to second parameter register */
         br       restore
-#if 0
- *  This routine provides the RTEMS interrupt management.
- *  v850 Specific Information:
-void _ISR_Handler(void); /* C warning avoidance */
-    *  This discussion ignores a lot of the ugly details in a real
-    *  implementation such as saving enough registers/state to be
-    *  able to do something real.  Keep in mind that the goal is
-    *  to invoke a user's ISR handler which is written in C and
-    *  uses a certain set of registers.
-    *  Also note that the exact order is to a large extent flexible.
-    *  Hardware will dictate a sequence for a certain subset of
-    *  _ISR_Handler while requirements for setting
-   *  At entry to "common" _ISR_Handler, the vector number must be
-   *  available.  On some CPUs the hardware puts either the vector
-   *  number or the offset into the vector table for this ISR in a
-   *  known place.  If the hardware does not give us this information,
-   *  then the assembly portion of RTEMS for this port will contain
-   *  a set of distinct interrupt entry points which somehow place
-   *  the vector number in a known place (which is safe if another
-   *  interrupt nests this one) and branches to _ISR_Handler.
-   *  save some or all context on stack
-   *  may need to save some special interrupt information for exit
-   *  #if ( CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE )
-   *    if ( _ISR_Nest_level == 0 )
-   *      switch to software interrupt stack
-   *  #endif
-   *  _ISR_Nest_level++;
-   *  _Thread_Dispatch_disable_level++;
-   *  (*_ISR_Vector_table[ vector ])( vector );
-   *  _Thread_Dispatch_disable_level--;
-   *  --_ISR_Nest_level;
-   *  if ( _ISR_Nest_level )
-   *    goto the label "exit interrupt (simple case)"
-   *  if ( _Thread_Dispatch_disable_level )
-   *  if ( _Thread_Dispatch_necessary ) {
-   *    call _Thread_Dispatch() or prepare to return to _ISR_Dispatch
-   *    prepare to get out of interrupt
-   *    return from interrupt  (maybe to _ISR_Dispatch)
-   *  LABEL "exit interrupt (simple case):
-   *      restore stack
-   *  #endif
-#endif
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index dbae3c4234..f19efa9bec 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
- * and set it up.
- * The v850 does not have support for a hardware interrupt stack.
  * @def CPU_HARDWARE_FP
@@ -389,21 +326,6 @@ typedef struct {
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index 1078ef6f63..3bda275b07 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -23,7 +23,6 @@
 #include <rtems/score/interr.h>
 #include <rtems/score/stackimpl.h>
-#include <rtems/score/wkspace.h>
 #if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
@@ -36,51 +35,48 @@
 void _ISR_Handler_initialization( void )
+  uint32_t  cpu_max;
+  uint32_t  cpu_index;
+  size_t    stack_size;
+  char     *stack_low;
   _ISR_Nest_level = 0;
   _CPU_Initialize_vectors();
 #endif
-#if ( CPU_ALLOCATE_INTERRUPT_STACK == TRUE )
-    size_t stack_size = rtems_configuration_get_interrupt_stack_size();
-    uint32_t cpu_max = rtems_configuration_get_maximum_processors();
-    uint32_t cpu_index;
+  stack_size = rtems_configuration_get_interrupt_stack_size();
-    if ( !_Stack_Is_enough( stack_size ) )
-      _Internal_error( INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL );
+  if ( !_Stack_Is_enough( stack_size ) )
+    _Internal_error( INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL );
-    for ( cpu_index = 0 ; cpu_index < cpu_max; ++cpu_index ) {
-      Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
-      void *low = _Workspace_Allocate_or_fatal_error( stack_size );
-      void *high = _Addresses_Add_offset( low, stack_size );
+  cpu_max = rtems_configuration_get_maximum_processors();
+  stack_low = _Configuration_Interrupt_stack_area_begin;
-#if (CPU_STACK_ALIGNMENT != 0)
-      high = _Addresses_Align_down( high, CPU_STACK_ALIGNMENT );
-#endif
+  for ( cpu_index = 0 ; cpu_index < cpu_max; ++cpu_index ) {
+    Per_CPU_Control *cpu;
+    char            *stack_high;
-      cpu->interrupt_stack_low = low;
-      cpu->interrupt_stack_high = high;
+    cpu = _Per_CPU_Get_by_index( cpu_index );
+    stack_high = _Addresses_Add_offset( stack_low, stack_size );
-       * Interrupt stack might have to be aligned and/or setup in a specific
-       * way.  Do not use the local low or high variables here since
-       * _CPU_Interrupt_stack_setup() is a nasty macro that might want to play
-       * with the real memory locations.
-#if defined(_CPU_Interrupt_stack_setup)
-      _CPU_Interrupt_stack_setup(
-        cpu->interrupt_stack_low,
-#endif
+    cpu->interrupt_stack_low = stack_low;
+    cpu->interrupt_stack_high = stack_high;
+     * Interrupt stack might have to be aligned and/or setup in a specific
+     * way.  Do not use the local low or high variables here since
+     * _CPU_Interrupt_stack_setup() is a nasty macro that might want to play
+     * with the real memory locations.
+#if defined(_CPU_Interrupt_stack_setup)
+    _CPU_Interrupt_stack_setup(
+      cpu->interrupt_stack_low,
 #endif
-#if ( CPU_HAS_HARDWARE_INTERRUPT_STACK == TRUE )
-  _CPU_Install_interrupt_stack();
-#endif
+    stack_low = stack_high;
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
index 2908643f6c..ccd101a929 100644
--- a/cpukit/score/src/percpuasm.c
+++ b/cpukit/score/src/percpuasm.c
@@ -122,17 +122,14 @@ RTEMS_STATIC_ASSERT(
 #endif
-#if CPU_ALLOCATE_INTERRUPT_STACK == TRUE \
-  || CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE
-  RTEMS_STATIC_ASSERT(
-    offsetof(Per_CPU_Control, interrupt_stack_low)
-      == PER_CPU_INTERRUPT_STACK_LOW,
+RTEMS_STATIC_ASSERT(
+  offsetof(Per_CPU_Control, interrupt_stack_low)
+    == PER_CPU_INTERRUPT_STACK_LOW,
-    offsetof(Per_CPU_Control, interrupt_stack_high)
-      == PER_CPU_INTERRUPT_STACK_HIGH,
-#endif
+  offsetof(Per_CPU_Control, interrupt_stack_high)
+    == PER_CPU_INTERRUPT_STACK_HIGH,
diff --git a/testsuites/sptests/spfatal07/testcase.h b/testsuites/sptests/spfatal07/testcase.h
index e84796324e..156f9b55e2 100644
--- a/testsuites/sptests/spfatal07/testcase.h
+++ b/testsuites/sptests/spfatal07/testcase.h
@@ -9,28 +9,6 @@
  *  http://www.rtems.org/license/LICENSE.
-#include <rtems/bspIo.h>
- *  Way too much stack space.  Should generate a fatal error
- *  on the init task create.
-#define CONFIGURE_HAS_OWN_INIT_TASK_TABLE
-#define CONFIGURE_INIT_TASK_STACK_SIZE   RTEMS_MINIMUM_STACK_SIZE
-rtems_initialization_tasks_table Initialization_tasks[] = {
-  { rtems_build_name('I', 'N', 'I', ' '),
-    RTEMS_MINIMUM_STACK_SIZE,
-    1,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    Init,
-    RTEMS_DEFAULT_MODES,
-    0
-#define CONFIGURE_INIT_TASK_TABLE Initialization_tasks
-#define CONFIGURE_INIT_TASK_TABLE_SIZE \
-  sizeof(CONFIGURE_INIT_TASK_TABLE) / sizeof(rtems_initialization_tasks_table)
 #define FATAL_ERROR_TEST_NAME            "7"
 #define FATAL_ERROR_DESCRIPTION \
         "Core Configuration Invalid ISR stack size"
@@ -38,20 +16,9 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
 #define FATAL_ERROR_EXPECTED_ERROR       \
-  #define CONFIGURE_INTERRUPT_STACK_SIZE (STACK_MINIMUM_SIZE - 1)
-#endif
+#define CONFIGURE_INTERRUPT_STACK_SIZE CPU_INTERRUPT_STACK_ALIGNMENT
 void force_error()
-    /* we will not run this far */
-  #else
-    printk(
-      "WARNING - Test not applicable on this target architecture.\n"
-      "WARNING - Only applicable when CPU_ALLOCATE_INTERRUPT_STACK == TRUE.\n"
-    TEST_END();
-    rtems_test_exit(0);
-  #endif
+  /* we will not run this far */
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index 7b7b3a5dbb..951cdd7414 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -391,10 +391,8 @@ uninitialized =
 /* cpu.h */
 uninitialized += (sizeof _CPU_Null_fp_context);
 uninitialized += (sizeof _CPU_Interrupt_stack_low) +
                  (sizeof _CPU_Interrupt_stack_high);
-#endif
 #endif
2.13.7
