[GSoC - Tracing] Status
Thu Jun 21 07:30:33 UTC 2018
Hello Vidushi,
On 12/06/18 14:22, Vidushi Vashishth wrote:
> >in case you receive comments for your patches the highest priority should be to fix the problems with the
> patches and send the next revision of the patch to the list, e.g.
> fixing trivial things like the line ?>length should be done in a
> couple of minutes. If you think a comment is invalid or makes no
> sense, then please say this also. The patch review process should be
> as fast as possible.
> I wasn't finished with the documentation and I intended to incorporate
> the line length change in the next patch. I got caught up with the
> babeltrace conversion hence did not work on the documentation patches.
> I am sorry you feel unhappy about the visibility of my work. I will
> follow your instructions more carefully. I will upload example codes
> to my github repository and notify you.
> >I need to know which tools I have to installon top of the standard
> RTEMS tools on a normal Linux machine.
> Babeltrace is the only tool you need to install for now. The
> instructions to install it are mentioned in :
> http://diamon.org/babeltrace/
> I will add these details to the github repository too. I will make the
> necessary changes in the user manual as well.
Chris committed your user manual changes on Monday. There was no status
report this Monday from you. The last blog post is from June 6
(https://vidushivashishth.github.io/). There is no github repository
with your work. I don't know what you are currently doing?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
