[PATCH 02/17] bsps/riscv_generic: Rename and add variants
Fri Jun 22 11:58:59 UTC 2018
From: Hesham Almatary <Hesham.Almatary at cl.cam.ac.uk>
Add BSP variants to match supported RISC-V ISA variants (multilibs).
 bsps/riscv/riscv_generic/config/{riscv_generic.cfg => rv32i.cfg}   | 2 +-
 bsps/riscv/riscv_generic/config/rv32iac.cfg                        | 7 +++++++
 bsps/riscv/riscv_generic/config/rv32im.cfg                         | 7 +++++++
 bsps/riscv/riscv_generic/config/rv32imac.cfg                       | 7 +++++++
 bsps/riscv/riscv_generic/config/rv32imafc.cfg                      | 7 +++++++
 .../riscv_generic/config/{riscv64_generic.cfg => rv64imac.cfg}     | 2 +-
 bsps/riscv/riscv_generic/config/rv64imafdc.cfg                     | 7 +++++++
 7 files changed, 37 insertions(+), 2 deletions(-)
 rename bsps/riscv/riscv_generic/config/{riscv_generic.cfg => rv32i.cfg} (70%)
 create mode 100644 bsps/riscv/riscv_generic/config/rv32iac.cfg
 create mode 100644 bsps/riscv/riscv_generic/config/rv32im.cfg
 create mode 100644 bsps/riscv/riscv_generic/config/rv32imac.cfg
 create mode 100644 bsps/riscv/riscv_generic/config/rv32imafc.cfg
 rename bsps/riscv/riscv_generic/config/{riscv64_generic.cfg => rv64imac.cfg} (70%)
 create mode 100644 bsps/riscv/riscv_generic/config/rv64imafdc.cfg
diff --git a/bsps/riscv/riscv_generic/config/riscv_generic.cfg b/bsps/riscv/riscv_generic/config/rv32i.cfg
similarity index 70%
rename from bsps/riscv/riscv_generic/config/riscv_generic.cfg
rename to bsps/riscv/riscv_generic/config/rv32i.cfg
index 785ac42c67..44a74166e7 100644
--- a/bsps/riscv/riscv_generic/config/riscv_generic.cfg
+++ b/bsps/riscv/riscv_generic/config/rv32i.cfg
@@ -2,6 +2,6 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
 RTEMS_CPU = riscv
-CPU_CFLAGS =
+CPU_CFLAGS = -march=rv32i -mabi=ilp32
 CFLAGS_OPTIMIZE_V ?= -Os
diff --git a/bsps/riscv/riscv_generic/config/rv32iac.cfg b/bsps/riscv/riscv_generic/config/rv32iac.cfg
new file mode 100644
index 0000000000..c321aef017
--- /dev/null
+++ b/bsps/riscv/riscv_generic/config/rv32iac.cfg
@@ -0,0 +1,7 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32iac -mabi=ilp32
+CFLAGS_OPTIMIZE_V ?= -Os
diff --git a/bsps/riscv/riscv_generic/config/rv32im.cfg b/bsps/riscv/riscv_generic/config/rv32im.cfg
index 0000000000..c4171ba20d
--- /dev/null
+++ b/bsps/riscv/riscv_generic/config/rv32im.cfg
@@ -0,0 +1,7 @@
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32im -mabi=ilp32
diff --git a/bsps/riscv/riscv_generic/config/rv32imac.cfg b/bsps/riscv/riscv_generic/config/rv32imac.cfg
index 0000000000..644cadb632
--- /dev/null
+++ b/bsps/riscv/riscv_generic/config/rv32imac.cfg
@@ -0,0 +1,7 @@
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32imac -mabi=ilp32
diff --git a/bsps/riscv/riscv_generic/config/rv32imafc.cfg b/bsps/riscv/riscv_generic/config/rv32imafc.cfg
index 0000000000..2e24a2cc69
--- /dev/null
+++ b/bsps/riscv/riscv_generic/config/rv32imafc.cfg
@@ -0,0 +1,7 @@
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32imafc -mabi=ilp32f
diff --git a/bsps/riscv/riscv_generic/config/riscv64_generic.cfg b/bsps/riscv/riscv_generic/config/rv64imac.cfg
rename from bsps/riscv/riscv_generic/config/riscv64_generic.cfg
rename to bsps/riscv/riscv_generic/config/rv64imac.cfg
index 04897e5bba..e79bf2793b 100644
--- a/bsps/riscv/riscv_generic/config/riscv64_generic.cfg
+++ b/bsps/riscv/riscv_generic/config/rv64imac.cfg
 RTEMS_CPU = riscv
-CPU_CFLAGS = -mcmodel=medany
+CPU_CFLAGS = -march=rv64imac -mabi=lp64
 CFLAGS_OPTIMIZE_V ?= -O0 -g
diff --git a/bsps/riscv/riscv_generic/config/rv64imafdc.cfg b/bsps/riscv/riscv_generic/config/rv64imafdc.cfg
index 0000000000..b1676670e7
--- /dev/null
+++ b/bsps/riscv/riscv_generic/config/rv64imafdc.cfg
@@ -0,0 +1,7 @@
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv64imafdc -mabi=lp64d
+CFLAGS_OPTIMIZE_V ?= -O0 -g
2.13.7
