[PATCH 14/17] build: Enable RISC-V SMP build
Fri Jun 22 11:59:11 UTC 2018
Update #3433.
 aclocal/enable-smp.m4        | 2 +-
 c/src/aclocal/enable-smp.m4  | 2 +-
 cpukit/aclocal/enable-smp.m4 | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/aclocal/enable-smp.m4 b/aclocal/enable-smp.m4
index e6461de685..b8767923c7 100644
--- a/aclocal/enable-smp.m4
+++ b/aclocal/enable-smp.m4
@@ -8,7 +8,7 @@ AC_ARG_ENABLE(smp,
 [case "${enableval}" in
   yes) test -z $enable_rtemsbsp && AC_MSG_ERROR([SMP requires BSPs to be provided, none have, see --enable-rtemsbsp])
        case "${RTEMS_CPU}" in
-         arm|powerpc|sparc|i386) RTEMS_HAS_SMP=yes ;;
+         arm|powerpc|riscv*|sparc|i386) RTEMS_HAS_SMP=yes ;;
          *)          RTEMS_HAS_SMP=no ;;
        esac
diff --git a/c/src/aclocal/enable-smp.m4 b/c/src/aclocal/enable-smp.m4
index 590a7b15ff..1448a2e5eb 100644
--- a/c/src/aclocal/enable-smp.m4
+++ b/c/src/aclocal/enable-smp.m4
@@ -7,7 +7,7 @@ AC_ARG_ENABLE(smp,
 (SMP)])],
   yes) case "${RTEMS_CPU}" in
        esac
diff --git a/cpukit/aclocal/enable-smp.m4 b/cpukit/aclocal/enable-smp.m4
--- a/cpukit/aclocal/enable-smp.m4
+++ b/cpukit/aclocal/enable-smp.m4
 (SMP)])],
        esac
2.13.7
