[PATCH] cpu-supplement: Add ARM BSPs chapter
Tue Jun 26 09:23:59 UTC 2018
On 06/06/18 08:57, Sebastian Huber wrote:
>>     2. The size of this Chapter 9 BSPs eventually is going to become
>> much
>>     larger compared to the rest of the manual. It might make better
>> sense
>>     to create it as a supplemental document that you refer to from 8.3
>>     Board Support Packages (BSP). As you say, it is different from
>> the BSP
>>     Developer's Guide, but I think it will be sensible to create an
>> "RTEMS
>>     User Manual BSP Supplement".
>> Depends on the length per BSP family or BSP variant. Five pages per
>> variant will end up in the 800-1000 page range. That would be a lovely
>> problem to have.
>> I hesitate to start another document that is tiny but if we start it
>> with
>> a complete outline with TBD sections, it makes sense. It will be fairly
>> hefty even with TBDs.
> My original proposal was a "RTEMS Hardware Manual" which contains the
> architecture documentation (CPU Supplement) and the BSPs.
I checked in the patch. If the section becomes too large, we can split
it on demand. The content is contained in separate files and thus easy
to move.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
