[GSOC - Tracing] Status Update
Vidushi Vashishth
reachvidu at gmail.com
Thu Jun 28 03:48:09 UTC 2018
Hi!
Sorry for the delay. I had been trying to make the code run.
https://github.com/VidushiVashishth/babeltrace/tree/master/Demo
This is a demonstration of the how to use babeltrace to convert rtems
traces. I have integrated the program.c code in the rtems main_rtrace.c
file. This is throwing some errors that I am working on. I will push the
changes to the main_rtrace.c file in a couple of hours.
Thanks
On Wed, Jun 27, 2018 at 10:31 AM, Sebastian Huber <
> Hello Vidushi,
> On 22/06/18 03:16, Vidushi Vashishth wrote:
>> Progress so far:
>> - Still working on adding rtrace shell capability to convert RTEMS traces
>> into CTF. There has been progress which I will push to (
>> https://github.com/VidushiVashishth/rtems) by end of today.
> I don't see an update in this repository from you. Could you please
> publish your work today so that I can try it out.
> Address : Dornierstr. 4, D-82178 Puchheim,
> <https://maps.google.com/?q=dress+:+Dornierstr.+4,+D-82178+Puchheim,&entry=gmail&source=g>
> Germany
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180628/278ea0d6/attachment.html>
