[GSOC - Tracing] Status Update
Fri Jun 29 05:05:16 UTC 2018
On 28/06/18 19:41, Vidushi Vashishth wrote:
> >Could you please create a self-contained repository which contains
> >* a README
> >* a simple RTEMS application which runs on a simulator BSP
> >* the stuff that makes it possible to view the trace output (it is
> not a problem if it doesn't work, but all pieces should be included)
> >The repository should not be a clone of some larger project. It may
> contain external references as submodules.
> Okay. Got it. I will update you when its done.
Ok, do you have a time estimate for this? Which parts are missing?
> >Did you modify babeltrace?
> No I did not.
Ok, this is good.
> >Why do you need a very recent babeltrace for your work?
> I haven't tested the code with other versions of babeltrace. I cant
> say why it does not work with others. I ll try to test the code with
> other versions and identify what's wrong.
If it doesn't work with the babeltrace shipped with standard
distributions, then this a slight burden to get started for users. It is
not a high priority issue at the moment.
> > Is visualization with Trace Compass a goal of this project?
> No it isn't. Trace generation in CTF is a goal.
What are the consumers of this CTF? Why do we need it? What is the
benefit for the RTEMS users?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
