[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Jun 4 19:12:50 UTC 2018
On 5 June 2018 at 00:31, Joel Sherrill <joel at rtems.org> wrote:
> I will add that covoar was originally designed to generate a report on one
> set at a time. The iteration over symbol sets was done at the scripting
> level above that.
> This had the advantage of being simple at the time. It may still be simple
> but moving the iteration over sets to covoar will probably be faster.
> I think DesiredSymbols is instanced a single time. As a starting point,
> there
> would have to be multiple instances of this -- one for each symbol set.
> Beyond that, there is a correlation between the report generated and
> the desired symbols set.
> So I am thinking that we need to define a "context" structure for each
> set. One simple thought is that there is one "master/unified" DesiredSymbol
> set under the hood and the symbols in each set are used as a filter
> when generating reports. So process the executables for every symbol
> but generate the report subdirectories based on one of the sets of
> DesiredSymbols.
> I think that should work.
> Cillian.. you have been through the flow. Am I thinking right that it is
> And I think we need to merge before doing this type of work. If we can
> process
> a single set correctly, that's a baseline. Adding iteration will be easier
> to review
> as another patch.
we can process a single set correctly.
Shall we proceed with merging the above patch with the suggested small edits
and then file a ticket for the iteration and then start working on it ?
I am confused with running of coverage for multiple bsp. If a single
report.html has to show the reports of multiple bsps (as hinted by Cillian)
Then a lot of rewroking would be needed. If we're headed in that way
then I think making separate report.html like leon3-report.html would be
simpler
to achieve, and then create a master index.html for listing all the report
htmls.
> On Mon, Jun 4, 2018 at 1:43 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 4 June 2018 at 19:03, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> On 2 June 2018 at 01:00, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> On 2 June 2018 at 00:48, Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Fri, Jun 1, 2018, 11:21 AM Vijay Kumar Banerjee <
>>>>> vijaykumar9597 at gmail.com> wrote:
>>>>>> On 1 June 2018 at 20:30, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>> On Fri, Jun 1, 2018 at 10:28 AM, Vijay Kumar Banerjee
>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>> > On 1 June 2018 at 19:24, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> >> On Fri, Jun 1, 2018 at 2:46 AM, Vijay Kumar Banerjee
>>>>>>> >>> Here's the list of Ideas for improvements:
>>>>>>> >>> 1. Include the section coverage in the bsp config file.
>>>>>>> >>>     If the section is not found then the script will show
>>>>>>> >>>     proper error showing coverage is not supported for the
>>>>>>> >>>     provided bsp config file.
>>>>>>> >>> 2. Update covoar to add support for separate coverage report
>>>>>>> >>> 3. Add a method somewhere in covoar to get the size of an
>>>>>>> instruction
>>>>>>> >>>     and fix the hard coded size 4 in ObjdumpProcessor.cc
>>>>>>> >> What about a single XXX_run command? What about that suggestion?
>>>>>>> > The suggestion was to turn test_run and coverage_run into a single
>>>>>>> command.
>>>>>>> > I have kept them separate so that there's a possibility to just
>>>>>>> run the
>>>>>>> > test.
>>>>>>> > If we want to run coverage everytime we run the test. we can do it.
>>>>>>> > Then I think the --coverage option can be changed to
>>>>>>> --coverage-sets
>>>>>>> > to mention the sets.
>>>>>>> > If that's what we're looking for then I don't think a separate
>>>>>>> ticket is
>>>>>>> > needed,
>>>>>>> > I can try to do it within tomorrow and submit an updated patch.
>>>>>>> >> Will there be an update to this patch?
>>>>>>> > This patch is working an showing results. I don't have any work
>>>>>>> > going related to this patch currently.
>>>>>>> > If there are any suggestions, I'll try to include all the
>>>>>>> suggested updates
>>>>>>> > as soon as possible and submit. So that we can get it merged.
>>>>>>> I get confused by the similarity between test_run() and
>>>>>>> coverage_run()
>>>>>>> names, and now I'm also seeing some confusion because there is a
>>>>>>> function coverage_run() and a class coverage_run. I suggest you
>>>>>>> remove
>>>>>>> this function coverage_run(), and make either coverage_run.__init__()
>>>>>>> or coverage_run.run() take the executables as a parameter directly.
>>>>>>> Thank you for the suggestion. :)
>>>>>> I have removed the function and taken executables as a parameter in
>>>>>> I have a question.
>>>>>> The ini file that is fed to covoar is written by the script according
>>>>>> to the
>>>>>> symbols mentioned by the user. I haven't include the ini file in the
>>>>>> patch.
>>>>>> I'm planning to delete the file after the run, unless --no-clean
>>>>>> option is given,
>>>>>> which currently deletes the .cov trace files after the run.
>>>>> That makes sense.
>>>>>> Can I proceed with this ?
>>>>> Yes.
>>>> Added. Thanks. :)
>>>>> also, shall I include that in the .gitignore ?
>>>>> Is the name of the file constant? The same across multiple BSPs? If
>>>>> so, then this will be a problem doing automated testing of multiple BSPs in
>>>>> parallel.
>>>>> The ini file I'm talking about is the symbol sets config file not the
>>>> bsp
>>>> config file. yes the name is constant. Should it be unique to the bsp ?
>>>> something like, leon3-symbols.ini ?
>>>> How does the automated testing work?
>>>>> I think the name needs to be unique enough.to support running testing
>>>>> with coverage on multiple BSPs in parallel. That means you can't add it to
>>>>> gitignore. And can add another issue and FIXME to the code.
>>>>>> If it is needed then I have a fix in mind. I can take the bsp name
>>>> and add
>>>> '-symbols.ini' to it. and add *-symbols.ini to .gitignore .
>>> Shall I add this or put a fixme in the code and post a patch ?
>>> Are there any other suggestions for the patch ?
>>> I was looking into covoar for generating separate reports for each
>>> symbolset.
>>> Seems like  all the coverage reports are generated together and are
>>> written
>>> in the _outputDirectory_ .
>> The output directory should be aligned with the bsp and the report.html
>> changed to keep record of this instead of searching for the generic
>> coverage dir. Look for leon3-coverage and so on. As well as the
>> symbol-sets.ini change you mentioned above. That would probably be enough
>> to not cause any conflicts with parallel testing (I may be missing a case
>> there, I let you know if anything else comes to mind). The main thing to
>> think about is if multiple bsps are being tested at the same time, they
>> have to know which config file is there's and which output directory and
>> whatever else they may be looking for, the names have to be unique. These
>> things are all fed to covoar so the changes can be added to coverage.py.
>> I couldn't figure out how to cleanly address this.
>>> If covoar is intended to generate reports from multiple
>>> subsystems/symbolsets,
>>> then I think this would be a needed update. Otherwise we can do it from
>>> the
>>> script, by feeding covoar with a single set ini and putting the result
>>> in a separate
>>> directory .
>>>> Can we do this ?
>>>>>>> -Gedare
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180605/b27abb59/attachment-0002.html>
