[PATCH v2] tester: Add script to generate html coverage report from covoar output
Mon Jun 4 19:46:15 UTC 2018
On Mon, Jun 4, 2018 at 2:29 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On 5 June 2018 at 00:51, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Jun 4, 2018 at 2:12 PM, Vijay Kumar Banerjee <
>>> On 5 June 2018 at 00:31, Joel Sherrill <joel at rtems.org> wrote:
>>>> I will add that covoar was originally designed to generate a report on
>>>> one
>>>> set at a time. The iteration over symbol sets was done at the scripting
>>>> level above that.
>>>> This had the advantage of being simple at the time. It may still be
>>>> simple
>>>> but moving the iteration over sets to covoar will probably be faster.
>>>> I think DesiredSymbols is instanced a single time. As a starting point,
>>>> there
>>>> would have to be multiple instances of this -- one for each symbol set.
>>>> Beyond that, there is a correlation between the report generated and
>>>> the desired symbols set.
>>>> So I am thinking that we need to define a "context" structure for each
>>>> set. One simple thought is that there is one "master/unified"
>>>> DesiredSymbol
>>>> set under the hood and the symbols in each set are used as a filter
>>>> when generating reports. So process the executables for every symbol
>>>> but generate the report subdirectories based on one of the sets of
>>>> DesiredSymbols.
>>>> I think that should work.
>>>> Cillian.. you have been through the flow. Am I thinking right that it
>>>> is
>>>> And I think we need to merge before doing this type of work. If we can
>>>> process
>>>> a single set correctly, that's a baseline. Adding iteration will be
>>>> easier to review
>>>> as another patch.
>>> we can process a single set correctly.
>>> Shall we proceed with merging the above patch with the suggested small
>>> edits
>>> and then file a ticket for the iteration and then start working on it ?
>> Please.
>>> I am confused with running of coverage for multiple bsp. If a single
>>> report.html has to show the reports of multiple bsps (as hinted by
>>> Cillian)
>>> Then a lot of rewroking would be needed. If we're headed in that way
>>> then I think making separate report.html like leon3-report.html would be
>>> simpler
>>> to achieve, and then create a master index.html for listing all the
>>> report htmls.
>> A single run of the tester will test a single BSP. If you open two shell
>> windows
>> and run the tester in both, will those collide?
>> In it's current state. Yes, it will collide as all the names of files
> (including report.html)
> are constant. :(
But are these all under a directory which includes the BSP? The contents of
each BSP/build specific directory can be identical if the top directory
name is
different.
> covoar does not need support internally to process multiple BSPs
>> concurrently.
>> It is common practice to build and test multiple BSPs in parallel to take
>> advantage
>> of machines with many cores.
>> But if you aren't careful, you can't even have two build/test trees at
>> the same time
>> if they collide on file names in shared directories.
>> Does that make sense?
>>>> On Mon, Jun 4, 2018 at 1:43 PM, Cillian O'Donnell <
>>>> cpodonnell8 at gmail.com> wrote:
>>>>> On 4 June 2018 at 19:03, Vijay Kumar Banerjee <
>>>>>> On 2 June 2018 at 01:00, Vijay Kumar Banerjee <
>>>>>>> On 2 June 2018 at 00:48, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>> On Fri, Jun 1, 2018, 11:21 AM Vijay Kumar Banerjee <
>>>>>>>>> On 1 June 2018 at 20:30, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>>>> On Fri, Jun 1, 2018 at 10:28 AM, Vijay Kumar Banerjee
>>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>>> > On 1 June 2018 at 19:24, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>>>> >> On Fri, Jun 1, 2018 at 2:46 AM, Vijay Kumar Banerjee
>>>>>>>>>> >>> Here's the list of Ideas for improvements:
>>>>>>>>>> >>> 1. Include the section coverage in the bsp config file.
>>>>>>>>>> >>>     If the section is not found then the script will show
>>>>>>>>>> >>>     proper error showing coverage is not supported for the
>>>>>>>>>> >>>     provided bsp config file.
>>>>>>>>>> >>> 2. Update covoar to add support for separate coverage report
>>>>>>>>>> >>> 3. Add a method somewhere in covoar to get the size of an
>>>>>>>>>> instruction
>>>>>>>>>> >>>     and fix the hard coded size 4 in ObjdumpProcessor.cc
>>>>>>>>>> >> What about a single XXX_run command? What about that
>>>>>>>>>> suggestion?
>>>>>>>>>> > The suggestion was to turn test_run and coverage_run into a
>>>>>>>>>> single command.
>>>>>>>>>> > I have kept them separate so that there's a possibility to just
>>>>>>>>>> run the
>>>>>>>>>> > test.
>>>>>>>>>> > If we want to run coverage everytime we run the test. we can do
>>>>>>>>>> it.
>>>>>>>>>> > Then I think the --coverage option can be changed to
>>>>>>>>>> --coverage-sets
>>>>>>>>>> > to mention the sets.
>>>>>>>>>> > If that's what we're looking for then I don't think a separate
>>>>>>>>>> ticket is
>>>>>>>>>> > needed,
>>>>>>>>>> > I can try to do it within tomorrow and submit an updated patch.
>>>>>>>>>> >> Will there be an update to this patch?
>>>>>>>>>> > This patch is working an showing results. I don't have any work
>>>>>>>>>> > going related to this patch currently.
>>>>>>>>>> > If there are any suggestions, I'll try to include all the
>>>>>>>>>> suggested updates
>>>>>>>>>> > as soon as possible and submit. So that we can get it merged.
>>>>>>>>>> I get confused by the similarity between test_run() and
>>>>>>>>>> coverage_run()
>>>>>>>>>> names, and now I'm also seeing some confusion because there is a
>>>>>>>>>> function coverage_run() and a class coverage_run. I suggest you
>>>>>>>>>> remove
>>>>>>>>>> this function coverage_run(), and make either
>>>>>>>>>> coverage_run.__init__()
>>>>>>>>>> or coverage_run.run() take the executables as a parameter
>>>>>>>>>> directly.
>>>>>>>>>> Thank you for the suggestion. :)
>>>>>>>>> I have removed the function and taken executables as a parameter in
>>>>>>>>> I have a question.
>>>>>>>>> The ini file that is fed to covoar is written by the script
>>>>>>>>> according to the
>>>>>>>>> symbols mentioned by the user. I haven't include the ini file in
>>>>>>>>> the patch.
>>>>>>>>> I'm planning to delete the file after the run, unless --no-clean
>>>>>>>>> option is given,
>>>>>>>>> which currently deletes the .cov trace files after the run.
>>>>>>>> That makes sense.
>>>>>>>>> Can I proceed with this ?
>>>>>>>> Yes.
>>>>>>> Added. Thanks. :)
>>>>>>>> also, shall I include that in the .gitignore ?
>>>>>>>> Is the name of the file constant? The same across multiple BSPs? If
>>>>>>>> so, then this will be a problem doing automated testing of multiple BSPs in
>>>>>>>> parallel.
>>>>>>>> The ini file I'm talking about is the symbol sets config file not
>>>>>>> the bsp
>>>>>>> config file. yes the name is constant. Should it be unique to the
>>>>>>> bsp ?
>>>>>>> something like, leon3-symbols.ini ?
>>>>>>> How does the automated testing work?
>>>>>>>> I think the name needs to be unique enough.to support running
>>>>>>>> testing with coverage on multiple BSPs in parallel. That means you can't
>>>>>>>> add it to gitignore. And can add another issue and FIXME to the code.
>>>>>>>>> If it is needed then I have a fix in mind. I can take the bsp name
>>>>>>> and add
>>>>>>> '-symbols.ini' to it. and add *-symbols.ini to .gitignore .
>>>>>> Shall I add this or put a fixme in the code and post a patch ?
>>>>>> Are there any other suggestions for the patch ?
>>>>>> I was looking into covoar for generating separate reports for each
>>>>>> symbolset.
>>>>>> Seems like  all the coverage reports are generated together and are
>>>>>> written
>>>>>> in the _outputDirectory_ .
>>>>> The output directory should be aligned with the bsp and the
>>>>> report.html changed to keep record of this instead of searching for the
>>>>> generic coverage dir. Look for leon3-coverage and so on. As well as the
>>>>> symbol-sets.ini change you mentioned above. That would probably be enough
>>>>> to not cause any conflicts with parallel testing (I may be missing a case
>>>>> there, I let you know if anything else comes to mind). The main thing to
>>>>> think about is if multiple bsps are being tested at the same time, they
>>>>> have to know which config file is there's and which output directory and
>>>>> whatever else they may be looking for, the names have to be unique. These
>>>>> things are all fed to covoar so the changes can be added to coverage.py.
>>>>> I couldn't figure out how to cleanly address this.
>>>>>> If covoar is intended to generate reports from multiple
>>>>>> subsystems/symbolsets,
>>>>>> then I think this would be a needed update. Otherwise we can do it
>>>>>> from the
>>>>>> script, by feeding covoar with a single set ini and putting the
>>>>>> result in a separate
>>>>>> directory .
>>>>>>> Can we do this ?
>>>>>>>>>> -Gedare
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180604/2d660eb8/attachment-0002.html>
