[PATCH v3] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Jun 6 00:54:34 UTC 2018
On Wed, 6 Jun 2018, 06:22 Joel Sherrill, <joel at rtems.org> wrote:
> On Tue, Jun 5, 2018, 7:22 PM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On 6 June 2018 at 03:57, Joel Sherrill <joel at rtems.org> wrote:
>>> I think everything is pushed. Is there any patch outstanding?
>>> Thank you.
>> No outstanding patch, everything on my side is squashed into it. :)
> So we can (finally) switch to the RTEMS.org repos to as the baseline?
Yes, finally!
> On Mon, Jun 4, 2018 at 3:44 PM, Vijay Kumar Banerjee <
>>>> Add support in tester to run covoar and generate an html report to
>>>> display
>>>> the summary of the coverage reports generated from covoar.
>>>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>  .gitignore                                    |   1 +
>>>>  tester/rt/coverage.py                         | 385
>>>>  tester/rt/test.py                             |  34 ++-
>>>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>  6 files changed, 450 insertions(+), 13 deletions(-)
>>>>  create mode 100644 tester/rt/coverage.py
>>>>  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>>> diff --git a/.gitignore b/.gitignore
>>>> index 6ab3709..93cb5d2 100644
>>>> --- a/.gitignore
>>>> +++ b/.gitignore
>>>> @@ -9,3 +9,4 @@ waf3-*
>>>>  .lock-waf*
>>>>  build
>>>>  VERSION*
>>>> +*symbols.ini
>>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>> new file mode 100644
>>>> index 0000000..54933d5
>>>> --- /dev/null
>>>> +++ b/tester/rt/coverage.py
>>>> @@ -0,0 +1,385 @@
>>>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>>>> +# All rights reserved.
>>>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>> +# Redistribution and use in source and binary forms, with or without
>>>> +# modification, are permitted provided that the following conditions
>>>> are met:
>>>> +# 1. Redistributions of source code must retain the above copyright
>>>> notice,
>>>> +# this list of conditions and the following disclaimer.
>>>> +# 2. Redistributions in binary form must reproduce the above copyright
>>>> notice,
>>>> +# this list of conditions and the following disclaimer in the
>>>> documentation
>>>> +# and/or other materials provided with the distribution.
>>>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>> 'AS IS'
>>>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>> TO, THE
>>>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>> PURPOSE
>>>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>> CONTRIBUTORS BE
>>>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>> BUSINESS
>>>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>>>> IN
>>>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>> OTHERWISE)
>>>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>>> OF THE
>>>> +# POSSIBILITY OF SUCH DAMAGE.
>>>> +from rtemstoolkit import error
>>>> +from rtemstoolkit import path
>>>> +from rtemstoolkit import log
>>>> +from rtemstoolkit import execute
>>>> +from rtemstoolkit import macros
>>>> +from datetime import datetime
>>>> +from . import options
>>>> +import shutil
>>>> +import os
>>>> +try:
>>>> +    import configparser
>>>> +except:
>>>> +    import ConfigParser as configparser
>>>> +class summary:
>>>> +    def __init__(self, p_summary_dir):
>>>> +        self.summary_file_path = path.join(p_summary_dir,
>>>> 'summary.txt')
>>>> +        self.index_file_path = path.join(p_summary_dir, 'index.html')
>>>> +        self.bytes_analyzed = 0
>>>> +        self.bytes_not_executed = 0
>>>> +        self.percentage_executed = 0.0
>>>> +        self.percentage_not_executed = 100.0
>>>> +        self.ranges_uncovered = 0
>>>> +        self.branches_uncovered = 0
>>>> +        self.branches_total = 0
>>>> +        self.branches_always_taken = 0
>>>> +        self.branches_never_taken = 0
>>>> +        self.percentage_branches_covered = 0.0
>>>> +        self.is_failure = False
>>>> +    def parse(self):
>>>> +        if(not path.exists(self.summary_file_path)):
>>>> +            log.notice('summary file %s does not exist!' %
>>>> +            self.is_failure = True
>>>> +            return
>>>> +        with open(self.summary_file_path,'r') as summary_file:
>>>> self._get_next_with_colon(summary_file)
>>>> self._get_next_without_colon(summary_file)
>>>> +        if len(self.branches_uncovered) > 0 and
>>>> len(self.branches_total) > 0:
>>>> +            self.percentage_branches_covered = \
>>>> +            1 - (float(self.branches_uncovered) /
>>>> float(self.branches_total))
>>>> +        else:
>>>> +        return
>>>> +    def _get_next_with_colon(self, summary_file):
>>>> +        line = summary_file.readline()
>>>> +        if ':' in line:
>>>> +            return line.split(':')[1].strip()
>>>> +        else:
>>>> +            return ''
>>>> +    def _get_next_without_colon(self, summary_file):
>>>> +        return line.strip().split(' ')[0]
>>>> +class report_gen_html:
>>>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
>>>> +        self.symbol_sets_list = ['score']
>>>> +        self.build_dir = build_dir
>>>> +        self.partial_reports_files = list(["index.html",
>>>> "summary.txt"])
>>>> +        self.number_of_columns = 1
>>>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>> +        self.bsp = bsp
>>>> +    def _find_partial_reports(self):
>>>> +        partial_reports = {}
>>>> +        for symbol_set in self.symbol_sets_list:
>>>> +            set_summary = summary(path.join(self.build_dir,
>>>> +                                  self.bsp + "-coverage",
>>>> +                                  symbol_set))
>>>> +            set_summary.parse()
>>>> +            partial_reports[symbol_set] = set_summary
>>>> +        return partial_reports
>>>> +    def _prepare_head_section(self):
>>>> +        head_section = '''
>>>> +        <head>
>>>> +        <title>RTEMS coverage report</title>
>>>> +        <style type="text/css">
>>>> +            progress[value] {
>>>> +              -webkit-appearance: none;
>>>> +               appearance: none;
>>>> +              width: 150px;
>>>> +              height: 15px;
>>>> +        </style>
>>>> +        </head>'''
>>>> +        return head_section
>>>> +    def _prepare_index_content(self, partial_reports):
>>>> +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
>>>> +        table = "<table>"
>>>> +        table += self._header_row()
>>>> +        for symbol_set in partial_reports:
>>>> +            table += self._row(symbol_set, partial_reports[symbol_set])
>>>> +        table += "</table> </br>"
>>>> +        timestamp = "Analysis performed on " + datetime.now().ctime()
>>>> +        return "<body>\n" + header + table + timestamp + "\n</body>"
>>>> +    def _row(self, symbol_set, summary):
>>>> +        row = "<tr>"
>>>> +        row += "<td>" + symbol_set + "</td>"
>>>> +        if summary.is_failure:
>>>> +            row += ' <td colspan="' + str(self.number_of_columns-1) \
>>>> +            + '" style="background-color:red">FAILURE</td>'
>>>> +        else:
>>>> +            row += " <td>" +
>>>> self._link(summary.index_file_path,"Index") \
>>>> +            + "</td>"
>>>> +            row += " <td>" +
>>>> self._link(summary.summary_file_path,"Summary") \
>>>> +            + "</td>"
>>>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>> +            row += " <td>" + summary.bytes_not_executed + "</td>"
>>>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
>>>> +            row += " <td>" + summary.percentage_executed + "%</td>"
>>>> +            row += " <td>" + summary.percentage_not_executed + "%</td>"
>>>> +            row += ' <td><progress value="' +
>>>> summary.percentage_executed \
>>>> +            + '" max="100"></progress></td>'
>>>> +            row += " <td>" + summary.branches_uncovered + "</td>"
>>>> +            row += " <td>" + summary.branches_total + "</td>"
>>>> +            row += " <td> {:.3%}
>>>> </td>".format(summary.percentage_branches_covered)
>>>> +            row += ' <td><progress value="{:.3}"
>>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>> +            row += "</tr>\n"
>>>> +        return row
>>>> +    def _header_row(self):
>>>> +        row = "<tr>"
>>>> +        row += "<th> Symbols set name </th>"
>>>> +        row += "<th> Index file </th>"
>>>> +        row += "<th> Summary file </th>"
>>>> +        row += "<th> Bytes analyzed </th>"
>>>> +        row += "<th> Bytes not executed </th>"
>>>> +        row += "<th> Uncovered ranges </th>"
>>>> +        row += "<th> Percentage covered </th>"
>>>> +        row += "<th> Percentage uncovered </th>"
>>>> +        row += "<th> Instruction coverage </th>"
>>>> +        row += "<th> Branches uncovered </th>"
>>>> +        row += "<th> Branches total </th>"
>>>> +        row += "<th> Branches covered percentage </th>"
>>>> +        row += "<th> Branches coverage </th>"
>>>> +        row += "</tr>\n"
>>>> +        self.number_of_columns = row.count('<th>')
>>>> +        return row
>>>> +    def _link(self, address, text):
>>>> +        return '<a href="' + address + '">' + text + '</a>'
>>>> +    def _create_index_file(self, head_section, content):
>>>> +        with open(path.join(self.build_dir,
>>>> +                            self.bsp + "-report.html"),'w') as f:
>>>> +            f.write(head_section)
>>>> +            f.write(content)
>>>> +    def generate(self):
>>>> +        partial_reports = self._find_partial_reports()
>>>> +        head_section = self._prepare_head_section()
>>>> +        index_content = self._prepare_index_content(partial_reports)
>>>> +        self._create_index_file(head_section,index_content)
>>>> +    def add_covoar_src_path(self):
>>>> +        table_js_path = path.join(self.covoar_src_path, 'table.js')
>>>> +        covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
>>>> +            symbol_set_dir = path.join(self.build_dir,
>>>> +                                       self.bsp + '-coverage',
>>>> symbol_set)
>>>> +            html_files = os.listdir(symbol_set_dir)
>>>> +            for html_file in html_files:
>>>> +                html_file = path.join(symbol_set_dir, html_file)
>>>> +                if path.exists(html_file) and 'html' in html_file:
>>>> +                    with open(html_file, 'r') as f:
>>>> +                        file_data = f.read()
>>>> +                    file_data = file_data.replace('table.js',
>>>> table_js_path)
>>>> +                    file_data = file_data.replace('covoar.css',
>>>> +                                                  covoar_css_path)
>>>> +                    with open(html_file, 'w') as f:
>>>> +                        f.write(file_data)
>>>> +class build_path_generator(object):
>>>> +    Generates the build path from the path to executables
>>>> +    def __init__(self, executables, target):
>>>> +        self.executables = executables
>>>> +        self.target = target
>>>> +    def run(self):
>>>> +        build_path = '/'
>>>> +        Path = self.executables[0].split('/')
>>>> +        for P in Path:
>>>> +            if P == self.target:
>>>> +                break;
>>>> +            else:
>>>> +                build_path = path.join(build_path, P)
>>>> +        return build_path
>>>> +class symbol_parser(object):
>>>> +    Parse the symbol sets ini and create custom ini file for covoar
>>>> +    def __init__(self, symbol_config_path,
>>>> +                 symbol_select_path, coverage_arg, build_dir):
>>>> +        self.symbol_select_file = symbol_select_path
>>>> +        self.symbol_file = symbol_config_path
>>>> +        self.symbol_sets = {}
>>>> +        self.cov_arg = coverage_arg
>>>> +        self.ssets = []
>>>> +    def parse(self):
>>>> +        config = configparser.ConfigParser()
>>>> +        try:
>>>> +            config.read(self.symbol_file)
>>>> +            if self.cov_arg:
>>>> +                self.ssets = self.cov_arg.split(',')
>>>> +            else:
>>>> +                self.ssets = config.get('symbol-sets',
>>>> 'sets').split(',')
>>>> +                self.ssets = [ sset.encode('utf-8') for sset in
>>>> self.ssets]
>>>> +            for sset in self.ssets:
>>>> +                lib = path.join(self.build_dir,
>>>> +                                config.get('libraries', sset))
>>>> +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>> +        except:
>>>> +            raise error.general('Symbol set parsing failed')
>>>> +    def _write_ini(self):
>>>> +        try:
>>>> +            sets = ', '.join(self.symbol_sets.keys())
>>>> +            config.add_section('symbol-sets')
>>>> +            config.set('symbol-sets', 'sets', sets)
>>>> +            for key in self.symbol_sets.keys():
>>>> +                config.add_section(key)
>>>> +                config.set(key, 'libraries', self.symbol_sets[key])
>>>> +            with open(self.symbol_select_file, 'w') as conf:
>>>> +                config.write(conf)
>>>> +        except:
>>>> +            raise error.general('write failed')
>>>> +    def run(self):
>>>> +        self.parse()
>>>> +        self._write_ini()
>>>> +class covoar(object):
>>>> +    Covoar runner
>>>> +    def __init__(self, base_result_dir, config_dir, executables,
>>>> explanations_txt):
>>>> +        self.base_result_dir = base_result_dir
>>>> +        self.config_dir = config_dir
>>>> +        self.executables = ' '.join(executables)
>>>> +        self.explanations_txt = explanations_txt
>>>> +        self.project_name = 'RTEMS-5'
>>>> +    def run(self, set_name, symbol_file):
>>>> +        covoar_result_dir = path.join(self.base_result_dir, set_name)
>>>> +        if (not path.exists(covoar_result_dir)):
>>>> +            path.mkdir(covoar_result_dir)
>>>> +        if (not path.exists(symbol_file)):
>>>> +            raise error.general('symbol set file: coverage %s was not
>>>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>> +        command = ('covoar -S ' + symbol_file
>>>> +                  + ' -O ' + covoar_result_dir
>>>> +                  + ' -E ' + self.explanations_txt
>>>> +                  + ' -p ' + self.project_name + ' ' +
>>>> self.executables)
>>>> +        log.notice('Running covoar for %s' % (set_name))
>>>> +        print( 'covoar results directory:\n' + covoar_result_dir )
>>>> +        executor = execute.execute(verbose = True, output =
>>>> self.output_handler)
>>>> +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>> +        if (exit_code[0] != 0):
>>>> +            raise error.general('covoar failure exit code: %d' %
>>>> (exit_code[0]))
>>>> +        log.notice('Coverage run for %s finished successfully.' %
>>>> (set_name))
>>>> +        log.notice('-----------------------------------------------')
>>>> +    def output_handler(self, text):
>>>> +        log.notice('%s' % (text))
>>>> +class coverage_run(object):
>>>> +    Coverage analysis support for rtems-test
>>>> +    def __init__(self, p_macros, coverage_arg, executables):
>>>> +        Constructor
>>>> +        self.macros = p_macros
>>>> +        self.build_dir = self.macros['_cwd']
>>>> self.macros.expand(self.macros['cov_explanations'])
>>>> +        self.test_dir = path.join(self.build_dir, self.macros['bsp'] +
>>>> '-coverage')
>>>> +        if (not path.exists(self.test_dir)):
>>>> +            path.mkdir(self.test_dir)
>>>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>> +        self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
>>>> +        self.coverage_config_path = path.join(self.rtscripts,
>>>> 'coverage')
>>>> +        self.symbol_config_path = path.join(self.coverage_config_path,
>>>> +                                            'symbol-sets.ini')
>>>> +        self.symbol_select_path = path.join(self.coverage_config_path,
>>>> +                                            self.macros['bsp'] +
>>>> '-symbols.ini')
>>>> +        self.symbol_sets = []
>>>> +        self.no_clean = int(self.macros['_no_clean'])
>>>> +        self.report_format = self.macros['cov_report_format']
>>>> +        self.coverage_arg = coverage_arg
>>>> +        self.target = self.macros['target']
>>>> +    def run(self):
>>>> +        try:
>>>> +            if self.executables is None:
>>>> +                raise error.general('no test executables provided.')
>>>> +            build_dir = build_path_generator(self.executables,
>>>> self.target).run()
>>>> +            parser = symbol_parser(self.symbol_config_path,
>>>> +                                   self.symbol_select_path,
>>>> +                                   self.coverage_arg,
>>>> +                                   build_dir)
>>>> +            parser.run()
>>>> +            covoar_runner = covoar(self.test_dir,
>>>> +                                   self.executables,
>>>> self.explanations_txt)
>>>> +            covoar_runner.run('score', self.symbol_select_path)
>>>> +            self._generate_reports();
>>>> +            self._summarize();
>>>> +        finally:
>>>> +            self._cleanup();
>>>> +    def _generate_reports(self):
>>>> +        log.notice('Generating reports')
>>>> +        if self.report_format == 'html':
>>>> +            report = report_gen_html(self.symbol_sets,
>>>> +                                     self.build_dir,
>>>> +                                     self.rtdir,
>>>> +                                     self.macros['bsp'])
>>>> +            report.generate()
>>>> +            report.add_covoar_src_path()
>>>> +    def _cleanup(self):
>>>> +        if not self.no_clean:
>>>> +            log.notice('***Cleaning tempfiles***')
>>>> +            for exe in self.executables:
>>>> +                trace_file = exe + '.cov'
>>>> +                if path.exists(trace_file):
>>>> +                    os.remove(trace_file)
>>>> +            os.remove(self.symbol_select_path)
>>>> +    def _summarize(self):
>>>> +        log.notice('Coverage analysis finished. You can find results
>>>> in %s' % (self.build_dir))
>>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>> index f4d9b5c..0e744cd 100644
>>>> --- a/tester/rt/test.py
>>>> +++ b/tester/rt/test.py
>>>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>  from rtemstoolkit import reraise
>>>>  from rtemstoolkit import stacktraces
>>>>  from rtemstoolkit import version
>>>> +from rtemstoolkit import check
>>>>  from . import bsps
>>>>  from . import config
>>>>  from . import console
>>>>  from . import report
>>>> +from . import coverage
>>>>  class log_capture(object):
>>>>      def __init__(self):
>>>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>      def run(self):
>>>>          self.thread = threading.Thread(target = self.runner,
>>>> -                                       name = 'test[%s]' %
>>>> path.basename(self.executable))
>>>> +                            name = 'test[%s]' %
>>>>          self.thread.start()
>>>>      def is_alive(self):
>>>> @@ -221,15 +223,16 @@ def run(command_path = None):
>>>>      opts = None
>>>>      default_exefilter = '*.exe'
>>>>      try:
>>>> -        optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>>> -                    '--rtems-bsp':   'The RTEMS BSP to run the test
>>>> on',
>>>> -                    '--user-config': 'Path to your local user
>>>> configuration INI file',
>>>> -                    '--report-mode': 'Reporting modes, failures
>>>> (default),all,none',
>>>> -                    '--list-bsps':   'List the supported BSPs',
>>>> -                    '--debug-trace': 'Debug trace based on specific
>>>> flags',
>>>> -                    '--filter':      'Glob that executables must match
>>>> to run (default: ' +
>>>> +        optargs = { '--rtems-tools':    'The path to the RTEMS tools',
>>>> +                    '--rtems-bsp':      'The RTEMS BSP to run the test
>>>> on',
>>>> +                    '--user-config':    'Path to your local user
>>>> +                    '--report-mode':    'Reporting modes, failures
>>>> +                    '--list-bsps':      'List the supported BSPs',
>>>> +                    '--debug-trace':    'Debug trace based on specific
>>>> flags',
>>>> +                    '--filter':         'Glob that executables must
>>>> match to run (default: ' +
>>>>                                default_exefilter + ')',
>>>> -                    '--stacktrace':  'Dump a stack trace on a user
>>>> termination (^C)' }
>>>> +                    '--stacktrace':     'Dump a stack trace on a user
>>>> termination (^C)',
>>>> +                    '--coverage':       'Perform coverage analysis of
>>>> test executables.'}
>>>>          mailer.append_options(optargs)
>>>>          opts = options.load(sys.argv,
>>>>                              optargs = optargs,
>>>> @@ -257,6 +260,7 @@ def run(command_path = None):
>>>>              exe_filter = default_exefilter
>>>>          opts.log_info()
>>>>          log.output('Host: ' + host.label(mode = 'all'))
>>>> +        executables = find_executables(opts.params(), exe_filter)
>>>>          debug_trace = opts.find_arg('--debug-trace')
>>>>          if debug_trace:
>>>>              if len(debug_trace) != 1:
>>>> @@ -279,6 +283,15 @@ def run(command_path = None):
>>>>              raise error.general('RTEMS BSP not provided or an invalid
>>>> option')
>>>>          bsp = config.load(bsp[1], opts)
>>>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>> +        coverage_enabled = opts.find_arg('--coverage')
>>>> +        if coverage_enabled:
>>>> +            if len(coverage_enabled) == 2:
>>>> +                coverage_runner = coverage.coverage_run(opts.defaults,
>>>> +                                                coverage_enabled[1],
>>>> +                                                executables)
>>>> +            else:
>>>> 0,
>>>> +                                                        executables)
>>>>          report_mode = opts.find_arg('--report-mode')
>>>>          if report_mode:
>>>>              if report_mode[1] != 'failures' and \
>>>> @@ -288,7 +301,6 @@ def run(command_path = None):
>>>>              report_mode = report_mode[1]
>>>>          else:
>>>>              report_mode = 'failures'
>>>> -        executables = find_executables(opts.params(), exe_filter)
>>>>          if len(executables) == 0:
>>>>              raise error.general('no executables supplied')
>>>>          start_time = datetime.datetime.now()
>>>> @@ -365,6 +377,8 @@ def run(command_path = None):
>>>>                      reports.failures(),
>>>>                      'Log', '===', ''] + output.get()
>>>>              mail.send(to_addr, subject, os.linesep.join(body))
>>>> +            coverage_runner.run()
>>>>      except error.general as gerr:
>>>>          print(gerr)
>>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> index 6b5e7e6..2f89117 100644
>>>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>> @@ -31,9 +31,10 @@
>>>>  # The Leon 3 QEMU BSP
>>>> -[leon3-qemu]
>>>> +[leon3-qemu-cov]
>>>>  bsp               = leon3-qemu
>>>>  arch              = sparc
>>>> +target            = sparc-rtems5
>>>>  tester            = %{_rtscripts}/qemu.cfg
>>>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>> index 0000000..a2ec7bc
>>>> --- /dev/null
>>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>> @@ -0,0 +1,36 @@
>>>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>> are met:
>>>> notice,
>>>> notice,
>>>> documentation
>>>> "AS IS"
>>>> TO, THE
>>>> PURPOSE
>>>> CONTRIBUTORS BE
>>>> BUSINESS
>>>> IN
>>>> OTHERWISE)
>>>> OF THE
>>>> +[symbol-sets]
>>>> +sets = score,rtems
>>>> +[libraries]
>>>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>>> qemu.cfg
>>>> index bfcd2f5..52a3752 100644
>>>> --- a/tester/rtems/testing/qemu.cfg
>>>> +++ b/tester/rtems/testing/qemu.cfg
>>>> @@ -51,8 +51,8 @@
>>>>  # Qemu common option patterns.
>>>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>> -nographic
>>>> -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>> -nographic
>>>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>> -nographic
>>>> +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>> -nographic
>>>>  %define qemu_opts_no_net -net none
>>>> 2.14.3
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180606/9bc949ad/attachment-0002.html>
