[PATCH] Generate coverage analysis Report
Joel Sherrill
joel at rtems.org
Wed Jun 6 04:37:26 UTC 2018
On Tue, Jun 5, 2018, 11:07 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Wed, 6 Jun 2018, 08:31 Joel Sherrill, <joel at rtems.org> wrote:
>> On Tue, Jun 5, 2018, 9:54 PM Chris Johns <chrisj at rtems.org> wrote:
>>> On 31/5/18 6:44 am, Vijay Kumar Banerjee wrote:
>>> > On 31 May 2018 at 02:02, Joel Sherrill <joel at rtems.org <mailto:
>>> joel at rtems.org>>
>>> > wrote:
>>> > On Wed, May 30, 2018 at 3:29 PM, Vijay Kumar Banerjee
>>> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
>>> wrote:
>>> > On 31 May 2018 at 00:28, Joel Sherrill <joel at rtems.org
>>> > <mailto:joel at rtems.org>> wrote:
>>> > I may not understand correctly but there is test_run and
>>> > coverage_run. Someone
>>> > suggested making coverage_running an option to test_run.
>>> If that's
>>> > what's being
>>> > asked for, then I think doing it in a follow up patch is
>>> OK.
>>> > If that's the intended request, perhaps a ticket should be
>>> filed.
>>> > Sorry for all the confusion.
>>> > This patch doesn't change the way test works. It only adds an
>>> option to run
>>> > the coverage script. coverage_run just runs the
>>> coverage.coverage_run
>>> > :) And I am saying if we want to have one test_run with an
>>> argument, do it as
>>> > a future work iteration. File a ticket.
>>> > We need to get the code working on the master.
>>> > Okay, we can keep that as a future work (I haven't thought about it
>>> though). :)
>>> > Getting it to work on master is our primary objective.
>>> Was a ticket raised to removing 'coverage_run' and to use 'test_run'?
>> I haven't seen tickets for any of the issues we identified.
> was there supposed to be tickets for each issue?
Yes. If they still apply.
>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180605/2bd580b4/attachment-0002.html>
