[PATCH v2] tester: Add script to generate html coverage report from covoar output
Joel Sherrill
joel at rtems.org
Wed Jun 6 04:39:03 UTC 2018
On Tue, Jun 5, 2018, 10:21 PM Chris Johns <chrisj at rtems.org> wrote:
> On 1/6/18 9:13 am, Joel Sherrill wrote:
> > Just chatted with Chris. The coverage BSP ini file was a temporary
> > measure as I thought.
> I may have not understood the specific issue being discussed when we
> talked.
> I separated the INI files because this is what we do else where (see the
> leon3
> example below). I consider options as a way to vary the default behavior
> so the
> less we have the better. A default run without extra options is preferred.
> You cannot add --coverage to all supported BSPs and get coverage and for
> this
> option to be useful this is what the option should do. To control coverage
> you
> need to know it can be supported so the question becomes simple, if you
> can do
> coverage why would you decide not too? In other words 'leon3-qemu-cov'
> should
> not need a --coverage option unless you wish to change the sets used and
> that is
> varying the default behavior.
> For example you can run leon3 with:
> leon3
> leon3-qemu-cov
> leon3-qemu
> leon3-run
> leon3-sis
> leon3_tsim
> leon3_tsim-run
> leon3-tsim-cmds
> and we do not have options to manage any of these differences line 'tsim'
> so why
> is coverage being treated as something special? To me it is not.
> The separation was on purpose and for this reason and not temporary. The
> changes
> needed to have this happen may require some refactoring, I am not sure yet.
Good enough. Think on it.
> > Make a list of all the ideas we have had for improvements. We want
> > the code to get onto master.
> > The list should be converted to Trac tickets very soon. Then we can
> > decide which are critical for GSoC, which Chris or I will work on, and
> > which are part of your GSoC.
> Have these tickets been created?
Don't think so
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180605/fad3c90a/attachment-0002.html>
