[PATCH 3/6] shgen: Import from RTEMS
Joel Sherrill
joel at rtems.org
Fri Jun 8 23:48:05 UTC 2018
On Fri, Jun 8, 2018 at 6:28 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 8/6/18 10:32 pm, Gedare Bloom wrote:
> > On Thu, Jun 7, 2018 at 10:19 PM, Chris Johns <chrisj at rtems.org> wrote:
> >> On 07/06/2018 16:11, Sebastian Huber wrote:
> >>> On 07/06/18 07:53, Chris Johns wrote:
> >>>> On 07/06/2018 15:39, Sebastian Huber wrote:
> >>>>> Corresponding RTEMS commit is 75933d5d25cd50f80162b7a0d2f66a
> 5534e1763f.
> >>>>> Update #3443.
> >>>>> misc/shgen/AUTHORS | 3 +
> >>>>> misc/shgen/COPYING | 340 ++++++++++++++++++++++++++++++
> >>>>> misc/shgen/TODO | 13 ++
> >>>>> misc/shgen/sci.c | 177 ++++++++++++++++++++++++++++
> >>>>> misc/shgen/sci.h | 11 ++
> >>>>> misc/shgen/shgen.c | 114 ++++++++++++++++++
> >>>>> misc/wscript | 9 ++
> >>>>> 7 files changed, 667 insertions(+)
> >>>>> create mode 100644 misc/shgen/AUTHORS
> >>>>> create mode 100644 misc/shgen/COPYING
> >>>>> create mode 100644 misc/shgen/TODO
> >>>>> create mode 100644 misc/shgen/sci.c
> >>>>> create mode 100644 misc/shgen/sci.h
> >>>>> create mode 100644 misc/shgen/shgen.c
> >>>>> diff --git a/misc/shgen/AUTHORS b/misc/shgen/AUTHORS
> >>>>> new file mode 100644
> >>>>> index 0000000..225c2fa
> >>>>> --- /dev/null
> >>>>> +++ b/misc/shgen/AUTHORS
> >>>>> @@ -0,0 +1,3 @@
> >>>>> +Ralf Corsepius (corsepiu at faw.uni-ulm.de)
> >>>>> + * Initial implementation
> >>>>> + * generator for sci bitrate table
> >>>>> diff --git a/misc/shgen/COPYING b/misc/shgen/COPYING
> >>>>> index 0000000..8cc2ef7
> >>>>> --- /dev/null
> >>>>> +++ b/misc/shgen/COPYING
> >>>>> @@ -0,0 +1,340 @@
> >>>>> + GNU GENERAL PUBLIC LICENSE
> >>>> The RTEMS tools is almost clean of GPL code. There is a small piece
> in the
> >>>> rtemstoolkit I would to replace but I have not done that yet.
> >>> The nios2gen is also GPL (the RTEMS GPL with linking exception). Is
> this a
> >>> problem?
> >> We are moving to a BSD-2 license so I assumed this is part of that
> change?
> >>> The GCC, GDB and Binutils are also GPL.
> >> They are not in this repo. It is about our repos and the compliance
> obligations
> >> users have with our code base.
> > No, I think Sebastian's goal is to remove all host tools from the
> rtems.git.
> Sorry, I was meaning the license and not the patch. Moving the tools is a
> good
> idea but the RTEMS Tools is licensed BSD-2 or similar so moving GPL code
> into
> that repo changes this.
Is this tool actually used as part of building any SH BSP? I don't recall
ever seeing a rule using it. I suspect it was used to generate headers
initially manually and that was never part of the RTEMS build process.
The tools was added just in case but never actually used.
IMO if that's the case, then we don't need it. Do we even know what
headers were generated by it?
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180608/192bf5a4/attachment-0002.html>
