[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Cillian O'Donnell cpodonnell8 at gmail.com
Tue Jun 12 07:19:37 UTC 2018
Looks fine to me. Chris will have the final say though.
On Tue, 12 Jun 2018, 08:00 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On Tue, 12 Jun 2018, 12:27 Joel Sherrill, <joel at rtems.org> wrote:
>> Chris needs to speak up since it is Python.
>> I see changes to HTML output which I doubt are related to the core change.
> There are no real changes to HTML,
> I have just added line breaks in the code
> because it was too long.
>> On Tue, Jun 12, 2018, 8:39 AM Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> Please review this patch. :)
>>> On 7 June 2018 at 16:38, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> Close #3440
>>>>  tester/rt/coverage.py |  6 ++++--
>>>>  tester/rt/test.py     | 15 ++++++++++-----
>>>>  2 files changed, 14 insertions(+), 7 deletions(-)
>>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>> index 54933d5..af24124 100644
>>>> --- a/tester/rt/coverage.py
>>>> +++ b/tester/rt/coverage.py
>>>> @@ -163,7 +163,8 @@ class report_gen_html:
>>>>              row += " <td>" + summary.branches_uncovered + "</td>"
>>>>              row += " <td>" + summary.branches_total + "</td>"
>>>>              row += " <td> {:.3%}
>>>> </td>".format(summary.percentage_branches_covered)
>>>> -            row += ' <td><progress value="{:.3}"
>>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>> +            row += ' <td><progress value="{:.3}"
>>>> max="100"></progress></td>'\
>>>> +                    .format(100*summary.percentage_branches_covered)
>>>>              row += "</tr>\n"
>>>>          return row
>>>> @@ -299,7 +300,8 @@ class covoar(object):
>>>>          if (not path.exists(covoar_result_dir)):
>>>>              path.mkdir(covoar_result_dir)
>>>>          if (not path.exists(symbol_file)):
>>>> -            raise error.general('symbol set file: coverage %s was not
>>>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>> +            raise error.general('symbol set file: %s was not '
>>>> +                    'created for covoar, skipping %s'% (symbol_file,
>>>> set_name))
>>>>          command = ('covoar -S ' + symbol_file
>>>>                    + ' -O ' + covoar_result_dir
>>>>                    + ' -E ' + self.explanations_txt
>>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>> index 0e744cd..cdb5157 100644
>>>> --- a/tester/rt/test.py
>>>> +++ b/tester/rt/test.py
>>>> @@ -232,7 +232,7 @@ def run(command_path = None):
>>>>                      '--filter':         'Glob that executables must
>>>> match to run (default: ' +
>>>>                                default_exefilter + ')',
>>>>                      '--stacktrace':     'Dump a stack trace on a user
>>>> termination (^C)',
>>>> -                    '--coverage':       'Perform coverage analysis of
>>>> test executables.'}
>>>> +                    '--coverage-sets':  'Perform coverage for specific
>>>> sets'}
>>>>          mailer.append_options(optargs)
>>>>          opts = options.load(sys.argv,
>>>>                              optargs = optargs,
>>>> @@ -279,15 +279,20 @@ def run(command_path = None):
>>>>          else:
>>>>              rtems_tools = '%{_prefix}'
>>>>          bsp = opts.find_arg('--rtems-bsp')
>>>> +        if 'cov' in bsp[1].split('-'):
>>>> +            coverage_enabled = True
>>>>          if bsp is None or len(bsp) != 2:
>>>>              raise error.general('RTEMS BSP not provided or an invalid
>>>> option')
>>>>          bsp = config.load(bsp[1], opts)
>>>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>> -        coverage_enabled = opts.find_arg('--coverage')
>>>> +        coverage_sets = opts.find_arg('--coverage-sets')
>>>>          if coverage_enabled:
>>>> -            if len(coverage_enabled) == 2:
>>>> -                coverage_runner = coverage.coverage_run(opts.defaults,
>>>> -                                                coverage_enabled[1],
>>>> +            if coverage_sets:
>>>> +                if len(coverage_sets) != 2:
>>>> +                    raise error.general('No sets provided in
>>>> --coverage-sets')
>>>> +                else :
>>>> +                    coverage_runner =
>>>> +                                                coverage_sets[1],
>>>>                                                  executables)
>>>>              else:
>>>> 0,
>>>> 2.14.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180612/4b3f0b86/attachment-0002.html>
