[PATCH v5 1/2] Adding Trace Docuemntation Images
Vidushi Vashishth reachvidu at gmail.com
Wed Jun 13 11:15:10 UTC 2018
>Do we have PDF versions of the PNG images? PNG images are not really good
for PDF generation.
I downloaded the images from the RTEMS website :
https://devel.rtems.org/wiki/Developer/Tracing
Should I convert them to pdf and send?
On Wed, Jun 13, 2018 at 3:06 PM, Sebastian Huber <
> Hello Vidushi,
> the patch set looks good. Would you mind fixing also the white space
> errors:
> git am \[PATCH\ v5\ *
> Applying: Adding Trace Docuemntation Images
> .git/rebase-apply/patch:44: trailing whitespace.
> Capture Engine is a trace tool built inside the RTEMS operating system.
> Capture
> .git/rebase-apply/patch:48: trailing whitespace.
> to use it.
> .git/rebase-apply/patch:49: trailing whitespace.
> .git/rebase-apply/patch:50: trailing whitespace.
> The Capture Engine's sample testcase for the `sparc/erc32` is available in
> .git/rebase-apply/patch:57: trailing whitespace.
> warning: squelched 147 whitespace errors
> warning: 152 lines add whitespace errors.
> for PDF generation.
> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180613/127268b5/attachment-0002.html>
