[PATCH v5 2/2] Adding Trace Docuemntation
    Gedare Bloom
    gedare at rtems.org
    Wed Jun 13 13:19:40 UTC 2018
Sorry, I didn't see v6, but my comments still apply. I suspect v7 will
be mergeable.
On Wed, Jun 13, 2018 at 9:18 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I think we're almost there. ;) A bit more below:
> On Wed, Jun 13, 2018 at 5:22 AM, Vidushi Vashishth <reachvidu at gmail.com> wrote:
>> - Completed Trace Linker Section
>> - Added Trace Examples section
>> - Removed CTF section
>> - Removed Use cases section
>> - Incorporated changes asked by Chris
> It would be best to provide the "summary of changes" in reply to the
> patch, and instead continue to have a useful commit message that will
> make sense when someone looks in the git-log. For example, looking in
> the log and seeing "Removed CTF section" one would ask where that was
> to begin with. Also, that you incorporated asked for changes can be
> omitted, since this is usually the case for all commits. So make sure
> your commit message only accurately reflects what is in the commit.
> There should be a ticket associated with your project that it would
> make sense to add a line in the commit message: "Updates #2xxx"?
>>  user/index.rst                 |   2 +
>>  user/tracing/captureengine.rst | 182 +++++++++++++++
>>  user/tracing/examples.rst      | 185 +++++++++++++++
>>  user/tracing/index.rst         |  30 +++
>>  user/tracing/introduction.rst  | 105 +++++++++
>>  user/tracing/tracelinker.rst   | 501 +++++++++++++++++++++++++++++++++++++++++
>>  6 files changed, 1005 insertions(+)
>>  create mode 100644 user/tracing/captureengine.rst
>>  create mode 100644 user/tracing/examples.rst
>>  create mode 100644 user/tracing/index.rst
>>  create mode 100644 user/tracing/introduction.rst
>>  create mode 100644 user/tracing/tracelinker.rst
>> diff --git a/user/index.rst b/user/index.rst
>> index 8cbcd1b..a764fe8 100644
>> --- a/user/index.rst
>> +++ b/user/index.rst
>> @@ -52,6 +52,8 @@ to the Community Project hosted at http://www.rtems.org/.
>>         tools/index
>> +        tracing/index
>>         support/index
>>         glossary/index
>> diff --git a/user/tracing/captureengine.rst b/user/tracing/captureengine.rst
>> new file mode 100644
>> index 0000000..b4c1123
>> --- /dev/null
>> +++ b/user/tracing/captureengine.rst
>> @@ -0,0 +1,182 @@
>> +.. comment SPDX-License-Identifier: CC-BY-SA-4.0
>> +.. comment: Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
> Is all of this Chris' writing? Or did you write some of this? You
> should put your copyright and current year on the files with words
> that you create, if any
>> +.. comment: All rights reserved.
>> +.. _capturengine:
>> +Capture Engine
>> +Capture Engine is a trace tool built inside the RTEMS operating system. Capture
>> +Engine is designed to cause the lowest load on the system when operating. Hence
>> +it does not effect RTEMS when operating or when disabled. It binds to RTEMS at
>> +runtime and does not require RTEMS or your application to be rebuilt in order
>> +to use it.
>> +The Capture Engine's sample testcase for the `sparc/erc32` is available in
>> +build directory created when building RTEMS in the path
>> +file: `sparc-rtems5/c/erc32/testsuites/samples` directory.
>> +In order to access the capture testcase perform the following set of
>> +operations inside the RTEMS build directory.
>> +.. code-block:: shell
>> +  $ cd /sparc-rtems5/c/erc32/testsuites/samples
>> +  $ sparc-rtems5-run ./capture.exe
>> +  *** BEGIN OF TEST CAPTURE ENGINE ***
>> +  *** TEST VERSION: 5.0.0.de9b7d712bf5da6593386fd4fbca0d5f8b8431d8
>> +  *** TEST STATE: USER_INPUT
>> +  *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
>> +  *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
>> +  a3a6c34c150a357e57769a26a460c475e188438f, Newlib 3.0.0)
>> +  Press any key to start capture engine (20s remaining)
>> +  Press any key to start capture engine (19s remaining)
>> +  Press any key to start capture engine (18s remaining)
>> +  Monitor ready, press enter to login.
>> +  1-rtems $
>> +Capture Engine comes with a set of commands to perform various actions.
>> +Capture Engine Commands
>> +1) ``copen <buffer-size>``: Used to initialize the Capture Engine with the
>> +   trace buffer size in bytes. By default the Capture Engine is not initialized
>> +   and not running.
>> +2) ``cwceil <priority-value>``: Capture Engine filter used to put an upper
>> +   limit on the event priority to be captured.
>> +3) ``cwfloor <priority-value>``: Capture Engine filter used to put a lower
>> +4) ``cwglob <on/off>``: Enable or disable the global watch.
>> +5) ``cenable``: Enables the Capture Engine. Capture Engine is by default
>> +   disabled after being opened.
>> +6) ``cdisable``: Disables the Capture Engine.
>> +7) ``ctlist``: Lists the watch and trigger configurations.
>> +8) ``ctrace``: Dumps the recorded traces. By default this command displays 24
>> +   trace records. Repeated use of this command will display all the recorded
>> +   traces.
>> +9) ``cwadd <task-name>``: Add watch on a particular task.
>> +10) ``cwtctl <task-name> <on/off>``: Enable or disable watch on a particular
>> +    task.
>> +11) ``ctset``: Used to set a trigger. The general form of the command is:
>> +``ctset [-?] type [to name/id] [from] [from name/id]``
>> +`type` in the above command refers to the type of trigger needed. The types of
>> +triggers that currently exist
>> +are:
>> +- switch  : a context switch from one task to another task
>> +- create  : the executing task creates a task
>> +- start   : the executing task starts a task
>> +- restart : the executing task restarts a task
>> +- delete  : the executing task deletes a task
>> +- begin   : a task is beginning
>> +- exitted : a task is exitting
>> +Example
>> +The following is a sample run of the capture testsuite. The `test1` command on
>> +the Capture Engine Command Line Interface (CLI) makes the `RMON` task invoke a
>> +call to the `capture_test_1()` command. This function (in the `test1.c` source
>> +code) creates and starts three tasks : `CT1a`, `CT1b` and `CT1c`. These tasks
>> +are passed the object id of a semaphore as a task argument. This run through
>> +traces the context switches between these tasks. ``cwceil`` and ``cwfloor`` are
>> +set to a narrow range of task priorities to avoid creating noise from a large
>> +number of context switches between tasks we are not interested in.
>> +.. code:: shell
>> +  Press any key to start capture engine (17s remaining)
>> +  1-rtems $ copen 50000
>> +  capture engine opened.
>> +  1-rtems $ cwceil 100
>> +  watch ceiling is 100.
>> +  1-rtems $ cwfloor 102
>> +  watch floor is 102.
>> +  1-rtems $ cwglob on
>> +  global watch enabled.
>> +  1-rtems $ ctset RMON
>> +  trigger set.
>> +  1-rtems $ cenable
>> +  capture engine enabled.
>> +  1-rtems $ test1
>> +  1-rtems $ cdisable
>> +  capture engine disabled.
>> +  1-rtems $ ctrace
>> +  0 0:18:17.462314124           0a010003 CT1a 102 102 102   4096  TASK_RECORD
>> +  0 0:18:17.462398963         0 0a010003 CT1a 102 102             CREATED
>> +  0 0:18:17.462647987    249024 0a010003 CT1a 102 102             STARTED
>> +  0 0:18:17.462904334    256347 0a010003 CT1a 102 102             SWITCHED_IN
>> +  0 0:18:17.463069129    164795 0a010003 CT1a 102 102             BEGIN
>> +  0 0:18:17.463335853    266724 0a010003 CT1a 102 102             SWITCHED_OUT
>> +  0 0:18:18.461348547           0a010004 CT1b 101 101 101   4096  TASK_RECORD
>> +  0 0:18:18.461433997 998098144 0a010004 CT1b 101 101             CREATED
>> +  0 0:18:18.461683631    249634 0a010004 CT1b 101 101             STARTED
>> +  0 0:18:18.461934485    250854 0a010004 CT1b 101 101             SWITCHED_IN
>> +  0 0:18:18.462099891    165406 0a010004 CT1b 101 101             BEGIN
>> +  0 0:18:19.460935339 998835448 0a010004 CT1b 101 101             SWITCHED_OUT
>> +  0 0:18:19.461431555           0a010005 CT1c 100 100 100   4096  TASK_RECORD
>> +  0 0:18:19.461516394    581055 0a010005 CT1c 100 100             CREATED
>> +  0 0:18:19.461765418    249024 0a010005 CT1c 100 100             STARTED
>> +  0 0:18:19.462019324    253906 0a010005 CT1c 100 100             SWITCHED_IN
>> +  0 0:18:19.462184119    164795 0a010005 CT1c 100 100             BEGIN
>> +  0 0:18:19.462475257    291138 0a010005 CT1c 100 100             SWITCHED_OUT
>> +  0 0:18:19.462551551     76294 0a010004 CT1b 101 101             SWITCHED_IN
>> +  0 0:18:19.960935645 498384094 0a010004 CT1b 101 101             SWITCHED_OUT
>> +  0 0:18:19.961012549     76904 0a010003 CT1a 102 100             SWITCHED_IN
>> +  0 0:18:19.961341528    328979 0a010003 CT1a 102 102             SWITCHED_OUT
>> +  1-rtems $ ctrace
>> +  0 0:18:19.961418433         0 0a010005 CT1c 100 100             SWITCHED_IN
>> +  0 0:18:19.961672339    253906 0a010005 CT1c 100 100             SWITCHED_OUT
>> +  0 0:18:19.961749854     77515 0a010004 CT1b 101 101             SWITCHED_IN
>> +  0 0:18:20.460967077 499217223 0a010004 CT1b 101 101             SWITCHED_OUT
>> +  0 0:18:20.461219763    252686 0a010005 CT1c 100 100             SWITCHED_IN
>> +  0 0:18:20.461424231    204468 0a010005 CT1c 100 100             TERMINATED
>> +  0 0:18:20.461747107    322876 0a010005 CT1c 100 100             SWITCHED_OUT
>> +  0 0:18:20.461824011     76904 0a010004 CT1b 101 101             SWITCHED_IN
>> +  0 0:18:20.462015052    191041 0a010004 CT1b 101 101             TERMINATED
>> +  0 0:18:20.462336707    321655 0a010004 CT1b 101 101             SWITCHED_OUT
>> +  0 0:18:20.462414222     77515 0a010003 CT1a 102 102             SWITCHED_IN
>> +  0 0:18:20.462608924    194702 0a010003 CT1a 102 102             TERMINATED
>> +  0 0:18:20.462933021    324097 0a010003 CT1a 102 102             SWITCHED_OUT
>> +  1-rtems $ ctrace
>> +  1-rtems $
>> diff --git a/user/tracing/examples.rst b/user/tracing/examples.rst
>> index 0000000..533997e
>> --- /dev/null
>> +++ b/user/tracing/examples.rst
>> @@ -0,0 +1,185 @@
>> +.. _examples:
>> +Tracing Examples
>> +The following example executes RTEMS trace using trace buffering for the
>> +`fileio` sample testcase.
>> +Prerequisites
>> +1. Setup RTEMS for the `sparc/erc32` architecture-bsp pair to run the
>> +   following example.
>> +2. Download the fileio `configuration file <https://devel.rtems.org/attachment
>> +   /wiki/Developer/Tracing/Trace_Buffering/fileio-trace.ini>`_ and store it on
>> +   the top of the installed BSP's directory.
>> +3. Change the value of the keys: `rtems-path` and `prefix` according to your
>> +   rtems installation. The `rtems-path` is the path to the bsp installation
>> +   and `prefix` is the path to the tools used to build rtems. Also set the
>> +   value of the `rtems-bsp` key to `sparc/erc32`.
>> +Demonstration
>> +Inside the RTEMS build directory (the directory where the fileio configuration
>> +has been stored) run the following commands to generate traces:
>> +BSP is configured with the following command -
>> +.. code:: shell
>> +  ../rtems/configure --target=sparc-rtems5 --prefix=/development/rtems/5 \
>> +  --enable-networking --enable-tests --enable-rtemsbsp=erc32 --enable-cxx
>> +The next two commands are used to link the fileio executable.The `-B` option
>> +signifies the use of the complete path to the required directory or file. Write
>> +the full path instead of the path file: `sparc-rtems5/erc32/lib/` in the
>> +following commands according to your installation. Also confirm the path of the
>> +fileio’s executable and object files in the last line of the command according
>> +to your installation.
>> +.. code:: shell
>> +  sparc-rtems5-gcc -Bsparc-rtems5/erc32/lib/ \
>> +  -specs bsp_specs -qrtems -mcpu=cypress -O2 -g -ffunction-sections \
>> +  -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration \
>> +  -Wstrict-prototypes -Wnested-externs -Wl,--gc-sections -mcpu=cypress \
>> +  -o sparc-rtems5/c/erc32/testsuites/samples/fileio.exe sparc-rtems5/c/erc32/\
>> +  testsuites/samples/fileio/fileio-init.o
>> +This is the trace linker command to generate and compile the wrapper c file for
>> +the application. The link command follows the escape sequence "--". "-C" option
>> +denotes the name of the user configuration file and "-W" specifies the name of
>> +the wrapper c file.
>> +.. code:: shell
>> +  rtems-tld -C fileio-trace.ini -W fileio-wrapper -- -Bsparc-rtems5/erc32/lib/ \
>> +The following command is used to run the application. Hit enter key quickly and
>> +type "s" and "root" and "pwd" to run the rtems shell. Use the `rtrace status`,
>> +`rtrace trace` and `rtrace save` commands to know the status of the tracing,
>> +display the contents of the trace buffer and save the buffer to disk in the form
>> +of binary files.
>> +.. code:: shell
>> +  sparc-rtems5-run sparc-rtems5/c/erc32/testsuites/samples/fileio.exe
>> +The output from the above commands will be as follows:
>> +.. code:: shell
>> +  *** BEGIN OF TEST FILE I/O ***
>> +  *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB a3a6c34c150a357e57769a26a460c475e
>> +  188438f, Newlib 3.0.0)
>> +  Press any key to start file I/O sample (20s remaining)
>> +  Press any key to start file I/O sample (19s remaining)
>> +  Press any key to start file I/O sample (18s remaining)
>> +  Press any key to start file I/O sample (17s remaining)
>> +  Press any key to start file I/O sample (16s remaining)
>> +  Press any key to start file I/O sample (15s remaining)
>> +  Press any key to start file I/O sample (14s remaining)
>> +   RTEMS FILE I/O Test Menu
>> +     p -> part_table_initialize
>> +     f -> mount all disks in fs_table
>> +     l -> list  file
>> +     r -> read  file
>> +     w -> write file
>> +     s -> start shell
>> +     Enter your selection ==>s
>> +  Creating /etc/passwd and group with four useable accounts:
>> +    root/pwd
>> +    test/pwd
>> +    rtems/NO PASSWORD
>> +    chroot/NO PASSWORD
>> +  Only the root user has access to all available commands.
>> +   starting shell
>> +  Welcome to rtems-5.0.0 (SPARC/w/FPU/erc32)
>> +  COPYRIGHT (c) 1989-2008.
>> +  On-Line Applications Research Corporation (OAR).
>> +  Login into RTEMS
>> +  /dev/foobar login: root
>> +  Password:
>> +  RTEMS Shell on /dev/foobar. Use 'help' to list commands.
>> +  SHLL [/] # rtrace status
>> +  RTEMS Trace Bufferring: status
>> +     Running:  yes
>> +   Triggered:  yes
>> +       Level:   0%
>> +      Traces:   25
>> +  SHLL [/] # rtrace stop
>> +  RTEMS Trace Bufferring: stop
>> +  SHLL [/] # rtrace trace
>> +  RTEMS Trace Bufferring: trace
>> +   Trace buffer: 0x20921d8
>> +   Words traced: 1487
>> +         Traces: 25
>> +    0:00:40.983197010  2081910  0a010002 [  2/  2] > malloc((size_t) 00000130)
>> +    0:00:40.983333119   136109  0a010002 [  2/  2] < malloc => (void*) 0x219bb88
>> +    0:00:40.983471669   138550  0a010002 [  2/  2] > malloc((size_t) 00000006)
>> +    0:00:40.983606557   134888  0a010002 [  2/  2] < malloc => (void*) 0x219bcc0
>> +    0:00:40.983684682    78125  0a010002 [  2/  2] > malloc((size_t) 00000007)
>> +    0:00:40.983819569   134887  0a010002 [  2/  2] < malloc => (void*) 0x219bcd0
>> +    0:00:40.983909901    90332  0a010002 [  2/  2] > malloc((size_t) 000003fc)
>> +    0:00:40.984046620   136719  0a010002 [  2/  2] < malloc => (void*) 0x219bce0
>> +    0:00:40.986624137  2577517  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.986767569   143432  0a010003 [200/200] < malloc => (void*) 0x219bce0
>> +    0:00:40.987531119   763550  0a010003 [200/200] > calloc((size_t) 00000001, (size_t) 0000005d)
>> +    0:00:40.987603751    72632  0a010003 [200/200] > malloc((size_t) 0000005d)
>> +    0:00:40.987744743   140992  0a010003 [200/200] < malloc => (void*) 0x219bce0
>> +    0:00:40.987824699    79956  0a010003 [200/200] < calloc => (void*) 0x219bce0
>> +    0:00:40.988302604   477905  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.988446647   144043  0a010003 [200/200] < malloc => (void*) 0x219bd48
>> +    0:00:40.988667595   220948  0a010003 [200/200] > calloc((size_t) 00000001, (size_t) 00000080)
>> +    0:00:40.988740837    73242  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.988884880   144043  0a010003 [200/200] < malloc => (void*) 0x219bdd0
>> +    0:00:40.988964836    79956  0a010003 [200/200] < calloc => (void*) 0x219bdd0
>> +    0:00:40.989042961    78125  0a010003 [200/200] > calloc((size_t) 00000001, (size_t) 00000080)
>> +    0:00:40.989110100    67139  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.989254143   144043  0a010003 [200/200] < malloc => (void*) 0x219be58
>> +    0:00:40.989334099    79956  0a010003 [200/200] < calloc => (void*) 0x219be58
>> +    0:00:40.990118401   784302  0a010003 [200/200] > calloc((size_t) 00000001, (size_t) 00000061)
>> +    0:00:40.990176995    58594  0a010003 [200/200] > malloc((size_t) 00000061)
>> +    0:00:40.990309441   132446  0a010003 [200/200] < malloc => (void*) 0x219bd48
>> +    0:00:40.990384515    75074  0a010003 [200/200] < calloc => (void*) 0x219bd48
>> +    0:00:40.990870355   485840  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.991011346   140991  0a010003 [200/200] < malloc => (void*) 0x219bee0
>> +    0:00:40.991227411   216065  0a010003 [200/200] > calloc((size_t) 00000001, (size_t) 00000080)
>> +    0:00:40.991296380    68969  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.991438593   142213  0a010003 [200/200] < malloc => (void*) 0x219bf68
>> +    0:00:40.991514276    75683  0a010003 [200/200] < calloc => (void*) 0x219bf68
>> +    0:00:40.991589349    75073  0a010003 [200/200] > calloc((size_t) 00000001, (size_t) 00000080)
>> +    0:00:40.991653437    64088  0a010003 [200/200] > malloc((size_t) 00000080)
>> +    0:00:40.991794428   140991  0a010003 [200/200] < malloc => (void*) 0x219bff0
>> +    0:00:40.991871332    76904  0a010003 [200/200] < calloc => (void*) 0x219bff0
>> +    0:00:40.992283320   411988  0a010003 [200/200] > malloc((size_t) 00000008)
>> +  SHLL [/] # rtrace save fileio-trace.bin
>> +     Trace File: fileio-trace.bin
>> +         Traces: 25
>> +  SHLL [/] #
>> diff --git a/user/tracing/index.rst b/user/tracing/index.rst
>> index 0000000..b75261d
>> --- /dev/null
>> +++ b/user/tracing/index.rst
>> @@ -0,0 +1,30 @@
>> +.. _tracing-framework:
>> +RTEMS Tracing Framework
>> +.. index:: Tracing Framework
>> +RTEMS Tracing Framework is an on-target software based system which helps track
>> +the ongoings inside the operation of applications, 3rd party packages, and the
>> +kernel in real time.
>> +Software based tracing is a complex process which requires components on both
>> +the target and the host to work together. However its portability across all
>> +architectures and board support packages makes it a useful asset. A key
>> +requirement in RTEMS trace process is to take existing code in compiled format
>> +(ELF) and instrument it in order to log various events and records in real time.
>> +However instrumenting of the code for tracing should happen without rebuilding
>> +the code from the source and without annotating the source with trace code.
>> +.. toctree::
>> +   introduction
>> +   examples
>> +   captureengine
>> +   tracelinker
>> diff --git a/user/tracing/introduction.rst b/user/tracing/introduction.rst
>> index 0000000..7b9e1d3
>> --- /dev/null
>> +++ b/user/tracing/introduction.rst
>> @@ -0,0 +1,105 @@
>> +.. _introduction:
>> +Introduction to Tracing
>> +Tracing is an important function which has several applications including
>> +identification of complex threading, detection of deadlocks, tracing
>> +functions along with their argument values, and return values through
>> +progression of several function calls and audit the performance of an
>> +application according to required specifications.
>> +RTEMS tracing framework is under development and welcomes contribution by users.
>> +RTEMS has the following trace components:
>> +- RTEMS :ref:`tracelinker`
>> +- RTEMS :ref:`capturengine`
>> +- Common Trace Format Integration
>> +RTEMS trace framework can currently function using the following methods. Both
>> +of the methods make use of the :ref:`tracelinker` :
>> +.. _tracebuffering:
>> +RTEMS Trace Using Trace Buffering
>> +This scheme of tracing goes through the flow of events described in a
>> +subsequent flowchart:
>> +Step 1: The user creates an application and user configuration file. The
>> +configuration file specifies the use of the trace buffer generator and other
>> +standard initializations. The user then configures their BSP and invokes the
>> +trace linker using a command to link the application executable. The trace
>> +linker uses the application files in compiled format (ELF) and the libraries
>> +used to build the application for performing this link.
>> +Step 2: The RTEMS Trace Linker reads the user’s configuration file and that
>> +results in it reading the standard Trace Buffering Configuration files
>> +installed with the RTEMS Trace Linker. The trace linker uses the target
>> +compiler and linker to create the trace enabled application executable. It
>> +wraps the functions defined in the user’s configuration with code that captures
>> +trace records into the statically allocated buffer. The trace wrapper code is
>> +compiled with the target compiler and the resulting ELF object file is added to
>> +the standard link command line used to link the application and the application
>> +is re-linked using the wrapping option of the GNU linker.
>> +Step 3: The trace linker creates an executable which is capable of running on
>> +the target hardware or simulator.
>> +Step 4: RTEMS shell provides the “rtrace” command to display and save trace
>> +buffers.
>> +.. comment: taken from https://devel.rtems.org/wiki/Developer/Tracing
>> +.. figure:: ../../images/user/rtems-trace-buffering.png
>> +  :align: center
>> +  :width: 75%
>> +.. _printk:
>> +RTEMS Trace Using Printk
>> +This scheme of tracing goes through the flow of events described in a subsequent
>> +flowchart:
>> +Step 1: The user creates an RTEMS application in the normal manner as well as a
>> +Trace Linker configuration file. The configuration file specifies using the
>> +Printk trace mode and the functions to trace. The user invokes the Trace Linker
>> +with the configuration and the normal link command line used to the link the
>> +application executable. The application ELF object files and libraries,
>> +including the RTEMS libraries are standard and do not need to be built
>> +specially.
>> +Step 2: The RTEMS Trace Linker reads the user's configuration file and that
>> +results in it reading the standard Printk Trace Configuration files installed
>> +with the RTEMS Trace Linker. The trace linker uses the target compiler and
>> +linker to create the trace enabled application executable. It wraps the
>> +functions defined in the user's configuration with code that prints the entry
>> +with arguments and exit and return value if any. The trace wrapper code is
>> +is relinked using the wrapping option of the GNU linker.
>> +Step 3: The trace linker creates and RTEMS ELF executable that can be run on the
>> +target hardware or simulator.
>> +Step 4: The application is run in the hardware directly or using a debugger. The
>> +printk() output appears on the target console and the user can save that to a
>> +file.
>> +.. figure:: ../../images/user/rtems-trace-printk.png
>> +  :align: center
>> +  :width: 75%
>> +The :ref:`examples` section describes generation of traces using both of the
>> +aforementioned techniques using the `fileio` testsuite available with RTEMS
>> +installation.
>> diff --git a/user/tracing/tracelinker.rst b/user/tracing/tracelinker.rst
>> index 0000000..a95ec41
>> --- /dev/null
>> +++ b/user/tracing/tracelinker.rst
>> @@ -0,0 +1,501 @@
>> +.. _tracelinker:
>> +Trace Linker
>> +RTEMS trace linker is a post link tool central to the RTEMS trace framework. It
>> +is installed as a part of the RTEMS Tool Project. The RTEMS Trace Linker is a
>> +post link tool that performs a re-link of your application to produce a trace
>> +executable. A trace executable has been instrumented by the RTEMS Trace Linker
>> +with additional code that implements software tracing. A key requirement of the
>> +trace process in RTEMS is to take existing code in a compiled format (ELF) and
>> +instrument it without rebuilding that code from source and without annotating
>> +that source with trace code.
>> +Command Line
>> +A typical command to invoke the trace linker consists of two parts separated by
>> +``--``.  The first part controls the trace linker and provides the various
>> +options it needs and the second part is a standard linker command line you would
>> +use to link an RTEMS application. The current command line for trace linker
>> +consists of:
>> +  $ rtems-tld -h
>> +  rtems-trace-ld [options] objects
>> +  Options and arguments:
>> +   -h          : help (also --help)
>> +   -V          : print linker version number and exit (also --version)
>> +   -v          : verbose (trace import parts), can supply multiple times
>> +                 to increase verbosity (also --verbose)
>> +   -w          : generate warnings (also --warn)
>> +   -k          : keep temporary files (also --keep)
>> +   -c compiler : target compiler is not standard (also --compiler)
>> +   -l linker   : target linker is not standard (also --linker)
>> +   -E prefix   : the RTEMS tool prefix (also --exec-prefix)
>> +   -f cflags   : C compiler flags (also --cflags)
>> +   -r path     : RTEMS path (also --rtems)
>> +   -B bsp      : RTEMS arch/bsp (also --rtems-bsp)
>> +   -W wrapper  : wrapper file name without ext (also --wrapper)
>> +   -C ini      : user configuration INI file (also --config)
>> +   -P path     : user configuration INI file search path (also --path)
>> +The trace linker generates code that needs to be compiled and linked to the
>> +application executable so it needs to know the target compiler and `CFLAGS`.
>> +There are a couple of ways to do this. The simplest is to provide the path to
>> +RTEMS using the `-r` option and the architecture and BSP name in the standard
>> +RTEMS format of arch/bsp. The trace linker will extract the compiler and flags
>> +used to build RTEMS and will use them. If you require specific options you can
>> +use the `-f`, `-c`, `-l`, and `-E` options to provide them. If the functions you
>> +are tracing use types from your code then add the include path to the `CFLAGS`.
>> +The trace linker requires you to provide a user configuration file using the
>> +`-C` or ``--config`` option. This is an INI format file detailed in the
>> +Configuration section. You can also provide an INI file search path using the
>> +`-P` option.
>> +If you are working with new configuration files and you want to view the files
>> +the trace linker generates, add the `-k` option to keep the temporary files, and
>> +`-W` to specify an explicit wrapper C file name. If you set the
>> +``dump-on-error`` option in the configuration options section you will get a
>> +dump of the configuration on an error.
>> +Configuration (INI) files
>> +The Trace Linker is controlled using configuration files. Configuration files
>> +are categorized into 3 types:
>> +- User Configuration: These are specific to the user application to be traced.
>> +  This file initializes the values of the trace generator, triggers, enables,
>> +  and traces.
>> +- Tracer Configuration: These are like a library of common or base trace
>> +  functions that can be referenced by an application. These files tend to hold
>> +  the details needed to wrap a specific set of functions. Examples provided with
>> +  the RTEMS Linker are the RTEMS API and Libc.
>> +- Generator Configuration: This is used to encapsulate a specific method of
>> +  tracing. Rtems currently provides generators for trace buffering, printk, and
> s/Rtems/RTEMS
> It is ok to  use 'rtems' or 'RTEMS' but 'Rtems' is strange.
>> +  printf.
>> +The configuration files are in the *INI file format* which is composed of
>> +`sections`. Each section has a section name and set of *keys* which consist of
>> +*names* and *values*. A typical key is of the form ``name=value``. Keys can be
>> +used to include other INI files using the include key name. This is shown in the
>> +following example where the values indicate rtems and rtld-base configuration
>> +files:
>> +  include = rtems.ini, rtld-base.ini
>> +The trace linker also uses values in keys to specify other sections. In this
>> +example the functions name lists `test-trace-funcs` and that section contains a
>> +headers key that further references a section called `test-headers`:
>> +  functions = test-trace-funcs, rtems-api
>> +  [test-trace-funcs]
>> +  ; Parsed via the 'function-set', not parse as a 'trace'.
>> +  headers = test-headers
>> +  [test-headers]
>> +  header = '#include "test-trace-1.h"'
>> +The format of a configuration file is explained next. Snippets of the file:
>> +`test-trace.ini` have been used for explicit understanding. This file can
>> +be found in the rtems-tools directory of the rtems installation.
>> +Tracer Section
>> +The topmost level section is the ``tracer`` section. It can contains the
>> +following keys:
>> +- ``name``: The name of trace being linked.
>> +- ``options``: A list of option sections.
>> +- ``defines``: A list of sections containing defines or define record.
>> +- ``define``: A list of define string that are single or double quoted.
>> +- ``enables``: The list of sections containing enabled functions to trace.
>> +- ``triggers``: The list of sections containing enabled functions to trigger
>> +  trace on.
>> +- ``traces``: The list of sections containing function lists to trace.
>> +- ``functions``: The list of sections containing function details.
>> +- ``include``: The list of files to include
>> +The tracer section of the file:`test-trace.ini` is shown below with explanatory
>> +comments.
>> +  ; RTEMS Trace Linker Test Configuration.
>> +  ; We must provide a top level trace section.
>> +  [tracer]
>> +  ; Name of the trace.
>> +  name = RTEMS Trace Linker Test
>> +  ; The BSP.
>> +  bsp = sparc/sis
>> +  ; Functions to trace.
>> +  traces = test-trace, test-trace-funcs, rtems-api-task
>> +  ; Specify the options.
>> +  options = test-options
>> +  ; Define the function sets. These are the function's that can be
>> +  ; added to the trace lists.
>> +  ; Include RTEMS Trace support.
>> +Options section
>> +The options section in the fileio-trace.ini is called the `fileio-options`. A
>> +general options section can contain following sets of keys:
>> +- ``dump-on-error``: Dump the parsed configuration data on error. The value can
>> +  be true or false.
>> +- ``verbose``: Set the verbose level. The value can be true or a number value.
>> +- ``prefix``: The prefix for the tools and an install RTEMS if rtems-path is not
>> +  set.
>> +- ``cc``: The compiler used to compile the generated wrapper code. Overrides the
>> +  BSP configuration value if a BSP
>> +  is specified.
>> +- ``ld``: The linker used to link the application. The default is the cc value
>> +  as read from the BSP configuration if specified. If your application contains
>> +  C++ code use this setting to the change the linker to g++.
>> +- ``cflags``: Set the CFLAGS used to compiler the wrapper. These flags are
>> +  pre-pended to the BSP read flags if a BSP is specified. This option is used
>> +  to provide extra include paths to header files in your application that
>> +  contain types referenced by functions being traced.
>> +- ``rtems-path``: The path to an install RTEMS if not installed under the prefix.
>> +- ``rtems-bsp``: The BSP we are building the trace executable for. The is an
>> +  arch and bsp pair. For example sparc/erc32.
>> +The options section of the file: `test-trace.ini` uses two of the aforementioned
>> +keys as shown below:
>> +  ; Options can be defined here or on the command line.
>> +  [test-options]
>> +  prefix = /development/rtems/5
>> +  verbose = true
>> +Trace Section
>> +A trace section defines how trace wrapper functions are built. To build a trace
>> +function that wraps an existing function in an ELF object file or library
>> +archive we need to have the function's signature. A signature is the function's
>> +declaration with any types used. The signature has specific types and we need
>> +access to those types which means the wrapper code needs to include header files
>> +that define those types. There may also be specific defines needed to access
>> +those types. A trace section can contain the following keys:
>> +- ``generator``: The generator defines the type of tracing being used.
>> +- ``headers``: List of sections that contain header file's keys.
>> +- ``header``: A header key. Typically the include code.
>> +- ``defines``: List of sections that contain defines.
>> +- ``define``: A define key. Typically the define code.
>> +- ``signatures``: List of function signature sections.
>> +- ``trace``: Functions that are instrumented with trace code.
>> +The trace section of the file: `test-trace.ini` is shown below. A trace section
>> +can reference other trace sections of a specific type. This allows a trace
>> +sections to build on other trace sections.
>> +.. code:: shell
>> +  ; User application trace example.
>> +  [test-trace]
>> +  generator = printf-generator
>> +  ; Just here for testing.
>> +  trace = test_trace_3
>> +  header = '#include "test-trace-2.h"'
>> +  defines = test-defines
>> +  define = "#define TEST_TRACE_2 2"
>> +  signatures = test-signatures
>> +  ; Parsed via the 'trace', not parsed as a function-set
>> +  trace = test_trace_1, test_trace_2
>> +  [test-headers]
>> +  [test-defines]
>> +  define = "#define TEST_TRACE_1 1"
>> +  [test-signatures]
>> +  test_trace_1 = void, int
>> +  test_trace_2 = test_type_2, test_type_1
>> +  test_trace_3 = float, float*
>> +Function Section
>> +Function sections define functions that can be traced. They provide any required
>> +defines, header files, and the function signatures. Defining a function so it
>> +can be traced does not mean it is traced. The function must be added to a trace
>> +list to be traced. A function section can consist of the following keys:
>> +- ``headers``: A list of sections containing headers or header records.
>> +- ``header``: A list of include string that are single or double quoted.
>> +- ``defines``: A list of define string that are single or double quoted.
>> +- ``signatures``: A list of section names of function signatures.
>> +- ``includes``: A list of files to include.
>> +Function signatures are specified with the function name being the key's name
>> +and the key's value being the return value and a list of function arguments. You
>> +need to provide void if the function uses void. Variable argument list are
>> +currently not supported. There is no way to determine statically a variable
>> +argument list. The function section in the file: `test-trace.ini` has been
>> +labeled as `test-trace-funcs`. This can be seen in the file snippet of the
>> +previous section.
>> +Generators
>> +Generator section specify how to generate trace wrapping code. The trace
>> +linker and generator section must match to work. The trace linker expects a some
>> +things to be present when wrapping functions. The section's name specifies the
>> +generator and can be listed in a generator key in a tracer or trace section. If
>> +the generator is not interested in a specific phase it does not need to define
>> +it. Nothing will be generated in regard to this phase. For example code to
>> +profile specific functions may only provide the entry-trace and exit-trace code
>> +where a nano-second time stamp is taken.
>> +The generate code will create an entry and exit call and the generator code
>> +block can be used to allocate buffer space for each with the lock held. The
>> +entry call and argument copy is performed with the lock released. The buffer
>> +space having been allocated will cause the trace events to be in order. The same
>> +goes for the exit call. Space is allocated in separate buffer allocate calls so
>> +the blocking calls will have the exit event appear in the correct location in
>> +the buffer.
>> +The following keys can be a part of the generator configuration:
>> +- ``entry-trace``: The wrapper call made on a function's entry. Returns bool
>> +  where true is the function is being traced. This call is made without the lock
>> +  being held if a lock is defined.
>> +- ``arg-trace``: The wrapper call made for each argument to the trace function
>> +  if the function is being traced. This call is made without the lock being held
>> +  if a lock is defined.
>> +- ``exit-trace``: The wrapper call made after a function's exit. Returns bool
>> +- ``ret-trace``: The wrapper call made to log the return value if the function
>> +  is being traced. This call is made without the lock being held if a lock is
>> +  defined.
>> +- ``lock-local``: The wrapper code to declare a local lock variable.
>> +- ``lock-acquire``: The wrapper code to acquire the lock.
>> +- ``lock-release``: The wrapper code to release the lock.
>> +- ``buffer-local``: The wrapper code to declare a buffer index local variable.
>> +- ``buffer-alloc``: The wrapper call made with a lock held if defined to
>> +  allocate buffer space to hold the trace data. A suitable 32bit buffer index is
>> +  returned. If there is no space an invalid index is returned. The generator
>> +  must handle any overhead space needed. The generator needs to make sure the
>> +  space is available before making the alloc all.
>> +- ``code-blocks``: A list of code block section names.
>> +- ``code``: A code block in <<CODE --- CODE (without the single quote).
>> +The following macros can be used in wrapper calls:
>> +- ``@FUNC_NAME@``: The trace function name as a quote C string.
>> +- ``@FUNC_INDEX@``: The trace function index as a held in the sorted list of
>> +  trace functions by the trace linker. It can be used to index the names,
>> +  enables, and triggers data.
>> +- ``@FUNC_LABEL@``: The trace function name as a C label that can be referenced.
>> +  You can take the address of the label.
>> +- ``@FUNC_DATA_SIZE@``: The size of the data in bytes.
>> +- ``@FUNC_DATA_ENTRY_SIZE@``: The size of the entry data in bytes.
>> +- ``@FUNC_DATA_RET_SIZE@``: The size of the return data in bytes.
>> +- ``@ARG_NUM@``: The argument number to the trace function.
>> +- ``@ARG_TYPE@``: The type of the argument as a C string.
>> +- ``@ARG_SIZE@``: The size of the type of the argument in bytes.
>> +- ``@ARG_LABEL@``: The argument as a C label that can be referenced.
>> +- ``@RET_TYPE@``: The type of the return value as a C string.
>> +- ``@RET_SIZE@``: The size of the type of the return value in bytes.
>> +- ``@RET_LABEL@``: The return value as a C label that can be referenced.
>> +The `buffer-alloc`, `entry-trace`, and `exit-trace` can be transformed using the
>> +following macros:
>> +- ``@FUNC_NAME@``
>> +- ``@FUNC_INDEX@``
>> +- ``@FUNC_LABEL@``
>> +- ``@FUNC_DATA_SZIE@``
>> +- ``@FUNC_DATA_ENTRY_SZIE@``
>> +- ``@FUNC_DATA_EXIT_SZIE@``
>> +The `arg-trace` can be transformed using the following macros:
>> +- ``@ARG_NUM@``
>> +- ``@ARG_TYPE@``
>> +- ``@ARG_SIZE@``
>> +- ``@ARG_LABEL@``
>> +The `ret-trace` can be transformed using the following macros:
>> +- ``@RET_TYPE@``
>> +- ``@RET_SIZE@``
>> +- ``@RET_LABEL@``
>> +The file: `test-trace.ini` specifies ``printf-generator`` as its generator. This
>> +section can be found in the file: `rtld-print.ini` in the rtems-tools directory
>> +and is shown below:
>> +.. code:: shell
>> +  ; A printf generator prints to stdout the trace functions.
>> +  [printf-generator]
>> +  headers = printf-generator-headers
>> +  entry-trace = "rtld_pg_printf_entry(@FUNC_NAME@, (void*) &@FUNC_LABEL@);"
>> +  arg-trace = "rtld_pg_printf_arg(@ARG_NUM@, @ARG_TYPE@, @ARG_SIZE@, (void*) &@ARG_LABEL@);"
>> +  exit-trace = "rtld_pg_printf_exit(@FUNC_NAME@, (void*) &@FUNC_LABEL@);"
>> +  ret-trace = "rtld_pg_printf_ret(@RET_TYPE@, @RET_SIZE@, (void*) &@RET_LABEL@);"
>> +  code = <<<CODE
>> +  static inline void rtld_pg_printf_entry(const char* func_name,
>> +                                          void*       func_addr)
>> +    printf (">>> %s (0x%08x)\n", func_name, func_addr);
>> +  static inline void rtld_pg_printf_arg(int         arg_num,
>> +                                        const char* arg_type,
>> +                                        int         arg_size,
>> +                                        void*       arg)
>> +    const unsigned char* p = arg;
>> +    int   i;
>> +    printf (" %2d] %s(%d) = ", arg_num, arg_type, arg_size);
>> +    for (i = 0; i < arg_size; ++i, ++p) printf ("%02x", (unsigned int) *p);
>> +    printf ("\n");
>> +  static inline void rtld_pg_printf_exit(const char* func_name,
>> +                                         void*       func_addr)
>> +    printf ("<<< %s (0x%08x)\n", func_name, func_addr);
>> +  static inline void rtld_pg_printf_ret(const char* ret_type,
>> +                                        int         ret_size,
>> +                                        void*       ret)
>> +    const unsigned char* p = ret;
>> +    int   i;
>> +    printf (" rt] %s(%d) = ", ret_type, ret_size);
>> +    for (i = 0; i < ret_size; ++i, ++p) printf ("%02x", (unsigned int) *p);
>> +    printf ("\n");
>> +  CODE
>> +  [printf-generator-headers]
>> +  header = "#include <stdio.h>"
>> +Function Wrapping
>> +The trace linker's major role is to wrap functions in the existing executable
>> +with trace code. The directions on how to wrap application functions is provided
>> +by the generator configuration. The wrapping function uses a GNU linker option
>> +called --wrap=symbol. The GNU Ld manual states:
>> +"Use a wrapper function for symbol. Any undefined reference to symbol will be
>> +resolved to __wrap_symbol. Any undefined reference to __real_symbol will be
>> +resolved to symbol."
>> +The trace linker generates C code with a wrapper for each function to be
>> +instrumented. The trace code generated is driven by the configuration INI files.
>> +Function Signatures
>> +A function signature is the function's declaration. It is the name of the
>> +function, the return value, and the arguments. Tracing using function wrappers
>> +requires that we have accurate function signatures and ideally we would like to
>> +determine the function signature from the data held in ELF files. ELF files can
>> +contain DWARF data, the ELF debugging data format. In time the trace project
>> +would like to support libdwarf so the DWARF data can be accessed and used to
>> +determine a function's signature. This work is planned but not scheduled to be
>> +done and so in the meantime we explicitly define the function signatures in the
>> +configuration files.
> These two sections "Function Wrapping" and "Function Signatures" seem
> misplaced. I suspect they belong before Generators, maybe merged with
> the "Function Sections" part?
>> +Development
>> +The Trace Linker is part of the RTEMS tools git repository available at :
>> +https://git.rtems.org/rtems-tools
>> +The RTEMS tools project utilizes the waf build system. Use the following
>> +commands in the topmost build directory to build the tools project:
>> +First we configure using:
>> +  $./waf configure --prefix=$HOME/development/rtems/5
>> +Then we build and install using:
>> +  $./waf build install
>> 2.7.4
>> devel mailing list
>> devel at rtems.org
