[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Jun 13 16:23:17 UTC 2018
On Wed, 13 Jun 2018, 21:39 Gedare Bloom, <gedare at rtems.org> wrote:
> On Wed, Jun 13, 2018 at 11:58 AM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > On 13 June 2018 at 10:29, Gedare Bloom <gedare at rtems.org> wrote:
> >> On Thu, Jun 7, 2018 at 7:08 AM, Vijay Kumar Banerjee
> >> > Close #3440
> >> >  tester/rt/coverage.py |  6 ++++--
> >> >  tester/rt/test.py     | 15 ++++++++++-----
> >> >  2 files changed, 14 insertions(+), 7 deletions(-)
> >> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> >> > index 54933d5..af24124 100644
> >> > --- a/tester/rt/coverage.py
> >> > +++ b/tester/rt/coverage.py
> >> > @@ -163,7 +163,8 @@ class report_gen_html:
> >> >              row += " <td>" + summary.branches_uncovered + "</td>"
> >> >              row += " <td>" + summary.branches_total + "</td>"
> >> >              row += " <td> {:.3%}
> >> > </td>".format(summary.percentage_branches_covered)
> >> > -            row += ' <td><progress value="{:.3}"
> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
> >> > +            row += ' <td><progress value="{:.3}"
> >> > max="100"></progress></td>'\
> >> > +                    .format(100*summary.percentage_branches_covered)
> >> Is there a style guide for how to split long lines in Python? I find
> >> splitting before the .format seems strange to me. I might have
> >> preferred to see it split at .format(\ which probably can be done
> >> without using a backslash in this case, since python knows to keep
> >> scanning inside a parenthetical block.
> > Will update it according to your suggestion. :)
> >> >              row += "</tr>\n"
> >> >          return row
> >> > @@ -299,7 +300,8 @@ class covoar(object):
> >> >          if (not path.exists(covoar_result_dir)):
> >> >              path.mkdir(covoar_result_dir)
> >> >          if (not path.exists(symbol_file)):
> >> > -            raise error.general('symbol set file: coverage %s was not
> >> > created for covoar, skipping %s'% (symbol_file, set_name))
> >> > +            raise error.general('symbol set file: %s was not '
> >> > +                    'created for covoar, skipping %s'% (symbol_file,
> >> > set_name))
> >> ditto.
> >> >          command = ('covoar -S ' + symbol_file
> >> >                    + ' -O ' + covoar_result_dir
> >> >                    + ' -E ' + self.explanations_txt
> >> > diff --git a/tester/rt/test.py b/tester/rt/test.py
> >> > index 0e744cd..cdb5157 100644
> >> > --- a/tester/rt/test.py
> >> > +++ b/tester/rt/test.py
> >> > @@ -232,7 +232,7 @@ def run(command_path = None):
> >> >                      '--filter':         'Glob that executables must
> >> > match to run (default: ' +
> >> >                                default_exefilter + ')',
> >> >                      '--stacktrace':     'Dump a stack trace on a user
> >> > termination (^C)',
> >> > -                    '--coverage':       'Perform coverage analysis of
> >> > test executables.'}
> >> > +                    '--coverage-sets':  'Perform coverage for
> specific
> >> > sets'}
> >> >          mailer.append_options(optargs)
> >> >          opts = options.load(sys.argv,
> >> >                              optargs = optargs,
> >> > @@ -279,15 +279,20 @@ def run(command_path = None):
> >> >          else:
> >> >              rtems_tools = '%{_prefix}'
> >> >          bsp = opts.find_arg('--rtems-bsp')
> >> > +        if 'cov' in bsp[1].split('-'):
> >> I'm not sure if this use of the 'cov' field in the bsp config filename
> >> itself is the proper way to go about accomplishing the activation of
> >> coverage. What are other possible ways to get this done? Is the use of
> >> a portion of the bsp config filename done elsewhere in tester?
> > This patch was made following Chris' comments in another thread
> > https://lists.rtems.org/pipermail/devel/2018-June/021931.html
> I can't be sure, but I don't think his intent was to infer the
> coverage from the ini file name. For example, does the tester parse
> the ini file name to check for 'qemu' to decide if that target is
> being used? Instead, it should look in to the config file to read the
> option somehow.
In leon3-qemu.ini the bsp option inside the
config file is set to leon3-qemu.
There's no such special thing added to bsp for coverage.
Only difference we have is that,
the option 'bsp_qemu_cov_opts' is added in the coverage supported file. we
can
read the config file to see if this option is present.
Shall I do it this way?
> >> > +            coverage_enabled = True
> >> >          if bsp is None or len(bsp) != 2:
> >> >              raise error.general('RTEMS BSP not provided or an invalid
> >> > option')
> >> >          bsp = config.load(bsp[1], opts)
> >> >          bsp_config = opts.defaults.expand(opts.defaults['tester'])
> >> > -        coverage_enabled = opts.find_arg('--coverage')
> >> > +        coverage_sets = opts.find_arg('--coverage-sets')
> >> >          if coverage_enabled:
> >> > -            if len(coverage_enabled) == 2:
> >> > -                coverage_runner =
> coverage.coverage_run(opts.defaults,
> >> > -                                                coverage_enabled[1],
> >> > +            if coverage_sets:
> >> > +                if len(coverage_sets) != 2:
> >> > +                    raise error.general('No sets provided in
> >> > --coverage-sets')
> >> > +                else :
> >> I don't think there should be a space character before the colon?
> > that's a mistake, I'll correct it. Thanks.
> >> > +                    coverage_runner =
> >> > +                                                coverage_sets[1],
> >> >                                                  executables)
> >> >              else:
> >> >                  coverage_runner =
> >> > 0,
> >> > 2.14.3
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180613/25389e71/attachment-0002.html>
